[mapserver-commits] r10624 - in trunk/msautotest/wxs: . expected
Tue Oct 19 11:51:07 EDT 2010
Author: warmerdam
Date: 2010-10-19 08:51:07 -0700 (Tue, 19 Oct 2010)
New Revision: 10624
Added:
   trunk/msautotest/wxs/expected/wfsogr10_ograuto.xml
   trunk/msautotest/wxs/expected/wfsogr11_caps.xml
   trunk/msautotest/wxs/expected/wfsogr11_ogrgml.xml
   trunk/msautotest/wxs/expected/wfsogr10_caps.xml
   trunk/msautotest/wxs/expected/wfsogr10_csvstream.txt
   trunk/msautotest/wxs/expected/wfsogr10_gml2.xml
   trunk/msautotest/wxs/expected/wfsogr10_midmif.txt
   trunk/msautotest/wxs/expected/wfsogr10_ogrgml.xml
   trunk/msautotest/wxs/wfs_ogr.map
more tests, including WFS 1.1 (#3570)
Modified: trunk/msautotest/wxs/expected/wfsogr10_caps.xml
--- trunk/msautotest/wxs/expected/wfsogr10_caps.xml	2010-10-19 15:49:01 UTC (rev 10623)
+++ trunk/msautotest/wxs/expected/wfsogr10_caps.xml	2010-10-19 15:51:07 UTC (rev 10624)
@@ -59,7 +59,6 @@
         <CSV/>
         <CSVSTREAM/>
         <OGRGML/>
-        <OGRGMLSTREAM/>
         <SHAPEZIP/>
         <MIDMIF/>
       </ResultFormat>
Modified: trunk/msautotest/wxs/expected/wfsogr10_csvstream.txt
--- trunk/msautotest/wxs/expected/wfsogr10_csvstream.txt	2010-10-19 15:49:01 UTC (rev 10623)
+++ trunk/msautotest/wxs/expected/wfsogr10_csvstream.txt	2010-10-19 15:51:07 UTC (rev 10624)
@@ -1,4 +1,4 @@
 Content-Type: text/csv; streamed
-WKT,FNODE_,TNODE_,LPOLY_,RPOLY_,LENGTH,ROAD_,ROAD_ID,F_CODE,NAME_E,NAME_F
-"LINESTRING (-60.201189792961586 46.102354406835836 0,-60.22203990695251 46.101246346098861 0,-60.242066599783321 46.097807469452071 0,-60.26248817949871 46.10046243986185 0,-60.302916095741153 46.10953640399341 0,-60.317500401724708 46.115654968046151 0,-60.338340466865311 46.124390858000147 0,-60.351258604383098 46.135729469595994 0,-60.35166078709053 46.151702162290846 0)",613,1511,0,0,      14862.892,1521,1521,67,,
+WKT,FNODE_,TNODE_,LPOLY_,RPOLY_,LENGTH,ROAD_ID,F_CODE,NAME_E,NAME_F
+"LINESTRING (-60.201189792961586 46.102354406835836 0,-60.22203990695251 46.101246346098861 0,-60.242066599783321 46.097807469452071 0,-60.26248817949871 46.10046243986185 0,-60.302916095741153 46.10953640399341 0,-60.317500401724708 46.115654968046151 0,-60.338340466865311 46.124390858000147 0,-60.351258604383098 46.135729469595994 0,-60.35166078709053 46.151702162290846 0)",613,1511,0,0,      14862.892,1521,67,,
Modified: trunk/msautotest/wxs/expected/wfsogr10_gml2.xml
--- trunk/msautotest/wxs/expected/wfsogr10_gml2.xml	2010-10-19 15:49:01 UTC (rev 10623)
+++ trunk/msautotest/wxs/expected/wfsogr10_gml2.xml	2010-10-19 15:51:07 UTC (rev 10624)
@@ -31,7 +31,6 @@
         <ms:LPOLY_>0</ms:LPOLY_>
         <ms:RPOLY_>0</ms:RPOLY_>
         <ms:LENGTH>14862.892</ms:LENGTH>
-        <ms:ROAD_>1521</ms:ROAD_>
         <ms:ROAD_ID>1521</ms:ROAD_ID>
         <ms:F_CODE>67</ms:F_CODE>
         <ms:NAME_E></ms:NAME_E>
Modified: trunk/msautotest/wxs/expected/wfsogr10_midmif.txt
--- trunk/msautotest/wxs/expected/wfsogr10_midmif.txt	2010-10-19 15:49:01 UTC (rev 10623)
+++ trunk/msautotest/wxs/expected/wfsogr10_midmif.txt	2010-10-19 15:51:07 UTC (rev 10624)
@@ -5,7 +5,7 @@
 Content-Type: application/binary
 Content-Transfer-Encoding: binary
-613,1511,0,0,14862.892,1521,1521,67,"",""
+613,1511,0,0,14862.892,1521,67,"",""
 --xxOGRBoundaryxx
 Content-Disposition: attachment; filename=result.mif
@@ -16,13 +16,12 @@
 Charset "Neutral"
 Delimiter ","
 CoordSys Earth Projection 1, 104
-Columns 10
+Columns 9
   FNODE_ Integer
   TNODE_ Integer
   LPOLY_ Integer
   RPOLY_ Integer
   LENGTH Float
-  ROAD_ Integer
   ROAD_ID Integer
   F_CODE Integer
   NAME_E Char(26)
Added: trunk/msautotest/wxs/expected/wfsogr10_ograuto.xml
--- trunk/msautotest/wxs/expected/wfsogr10_ograuto.xml	                        (rev 0)
+++ trunk/msautotest/wxs/expected/wfsogr10_ograuto.xml	2010-10-19 15:51:07 UTC (rev 10624)
@@ -0,0 +1,89 @@
+Content-Type: multipart/mixed; boundary=xxOGRBoundaryxx
+--xxOGRBoundaryxx
+Content-Disposition: attachment; filename=result.gml
+Content-Type: application/binary
+Content-Transfer-Encoding: binary
+<?xml version="1.0" encoding="utf-8" ?>
+<ogr:FeatureCollection
+     xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
+     xsi:schemaLocation="http://ogr.maptools.org/ result.xsd"
+     xmlns:ogr="http://ogr.maptools.org/"
+     xmlns:gml="http://www.opengis.net/gml">
+  <gml:boundedBy>
+    <gml:Box>
+      <gml:coord><gml:X>-64.0523554055784</gml:X><gml:Y>46.98084304633409</gml:Y></gml:coord>
+    </gml:Box>
+  </gml:boundedBy>
+  <gml:featureMember>
+    <ogr:popplace fid="F0">
+      <ogr:geometryProperty><gml:Point><gml:coordinates>-64.052355405578396,46.980843046334087,0</gml:coordinates></gml:Point></ogr:geometryProperty>
+      <ogr:UNIQUE_KEY>BACMK</ogr:UNIQUE_KEY>
+      <ogr:NAME>Tignish</ogr:NAME>
+      <ogr:CAPITAL>0</ogr:CAPITAL>
+      <ogr:POP_CLASS>1</ogr:POP_CLASS>
+    </ogr:popplace>
+  </gml:featureMember>
+</ogr:FeatureCollection>
+--xxOGRBoundaryxx
+Content-Disposition: attachment; filename=result.xsd
+<?xml version="1.0" encoding="UTF-8"?>
+<xs:schema targetNamespace="http://ogr.maptools.org/" xmlns:ogr="http://ogr.maptools.org/" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:gml="http://www.opengis.net/gml" elementFormDefault="qualified" version="1.0">
+<xs:import namespace="http://www.opengis.net/gml" schemaLocation="http://schemas.opengis.net/gml/2.1.2/feature.xsd"/>
+<xs:element name="FeatureCollection" type="ogr:FeatureCollectionType" substitutionGroup="gml:_FeatureCollection"/>
+<xs:complexType name="FeatureCollectionType">
+  <xs:complexContent>
+    <xs:extension base="gml:AbstractFeatureCollectionType">
+      <xs:attribute name="lockId" type="xs:string" use="optional"/>
+      <xs:attribute name="scope" type="xs:string" use="optional"/>
+    </xs:extension>
+  </xs:complexContent>
+</xs:complexType>
+<xs:element name="popplace" type="ogr:popplace_Type" substitutionGroup="gml:_Feature"/>
+<xs:complexType name="popplace_Type">
+    <xs:extension base="gml:AbstractFeatureType">
+      <xs:sequence>
+        <xs:element name="geometryProperty" type="gml:PointPropertyType" nillable="true" minOccurs="0" maxOccurs="1"/>
+        <xs:element name="UNIQUE_KEY" nillable="true" minOccurs="0" maxOccurs="1">
+          <xs:simpleType>
+            <xs:restriction base="xs:string">
+              <xs:maxLength value="5"/>
+            </xs:restriction>
+          </xs:simpleType>
+        </xs:element>
+        <xs:element name="NAME" nillable="true" minOccurs="0" maxOccurs="1">
+          <xs:simpleType>
+              <xs:maxLength value="50"/>
+            </xs:restriction>
+          </xs:simpleType>
+        </xs:element>
+        <xs:element name="CAPITAL" nillable="true" minOccurs="0" maxOccurs="1">
+          <xs:simpleType>
+            <xs:restriction base="xs:integer">
+              <xs:totalDigits value="3"/>
+            </xs:restriction>
+          </xs:simpleType>
+        </xs:element>
+        <xs:element name="POP_CLASS" nillable="true" minOccurs="0" maxOccurs="1">
+          <xs:simpleType>
+            </xs:restriction>
+          </xs:simpleType>
+        </xs:element>
+      </xs:sequence>
+    </xs:extension>
+</xs:complexType>
+</xs:schema>
+--xxOGRBoundaryxx--
Modified: trunk/msautotest/wxs/expected/wfsogr10_ogrgml.xml
--- trunk/msautotest/wxs/expected/wfsogr10_ogrgml.xml	2010-10-19 15:49:01 UTC (rev 10623)
+++ trunk/msautotest/wxs/expected/wfsogr10_ogrgml.xml	2010-10-19 15:51:07 UTC (rev 10624)
@@ -26,7 +26,6 @@
       <ogr:LPOLY_>0</ogr:LPOLY_>
       <ogr:RPOLY_>0</ogr:RPOLY_>
       <ogr:LENGTH>14862.892</ogr:LENGTH>
-      <ogr:ROAD_>1521</ogr:ROAD_>
       <ogr:ROAD_ID>1521</ogr:ROAD_ID>
       <ogr:F_CODE>67</ogr:F_CODE>
       <ogr:NAME_E></ogr:NAME_E>
@@ -94,13 +93,6 @@
             </xs:restriction>
           </xs:simpleType>
         </xs:element>
-        <xs:element name="ROAD_" nillable="true" minOccurs="0" maxOccurs="1">
-          <xs:simpleType>
-            <xs:restriction base="xs:integer">
-              <xs:totalDigits value="11"/>
-            </xs:restriction>
-          </xs:simpleType>
-        </xs:element>
         <xs:element name="ROAD_ID" nillable="true" minOccurs="0" maxOccurs="1">
           <xs:simpleType>
Added: trunk/msautotest/wxs/expected/wfsogr11_caps.xml
--- trunk/msautotest/wxs/expected/wfsogr11_caps.xml	                        (rev 0)
+++ trunk/msautotest/wxs/expected/wfsogr11_caps.xml	2010-10-19 15:51:07 UTC (rev 10624)
@@ -0,0 +1,180 @@
+Content-type: text/xml
+<?xml version="1.0" encoding="ISO-8859-1"?>
+<wfs:WFS_Capabilities xmlns:gml="http://www.opengis.net/gml" xmlns:wfs="http://www.opengis.net/wfs" xmlns:ows="http://www.opengis.net/ows" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ogc="http://www.opengis.net/ogc" xmlns="http://www.opengis.net/wfs" version="1.1.0" updateSequence="123" xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
+  <ows:ServiceIdentification>
+    <ows:Title>Test simple wfs</ows:Title>
+    <ows:Abstract>Test WFS Abstract</ows:Abstract>
+    <ows:Keywords>
+      <ows:Keyword>ogc</ows:Keyword>
+      <ows:Keyword>wfs</ows:Keyword>
+      <ows:Keyword>gml</ows:Keyword>
+      <ows:Keyword>om</ows:Keyword>
+    </ows:Keywords>
+    <ows:ServiceType codeSpace="OGC">OGC WFS</ows:ServiceType>
+    <ows:ServiceTypeVersion>1.1.0</ows:ServiceTypeVersion>
+    <ows:Fees>none</ows:Fees>
+    <ows:AccessConstraints>none</ows:AccessConstraints>
+  </ows:ServiceIdentification>
+  <ows:ServiceProvider>
+    <ows:ProviderName>MapServer</ows:ProviderName>
+    <ows:ProviderSite xlink:type="simple" xlink:href="http://localhost"/>
+    <ows:ServiceContact>
+      <ows:IndividualName>Tom Kralidis</ows:IndividualName>
+      <ows:PositionName>self</ows:PositionName>
+      <ows:ContactInfo>
+        <ows:Phone>
+          <ows:Voice>+xx-xxx-xxx-xxxx</ows:Voice>
+          <ows:Facsimile>+xx-xxx-xxx-xxxx</ows:Facsimile>
+        </ows:Phone>
+        <ows:Address>
+          <ows:DeliveryPoint>123 SomeRoad Road</ows:DeliveryPoint>
+          <ows:City>Toronto</ows:City>
+          <ows:AdministrativeArea>Ontario</ows:AdministrativeArea>
+          <ows:PostalCode>xxx-xxx</ows:PostalCode>
+          <ows:Country>Canada</ows:Country>
+          <ows:ElectronicMailAddress>tomkralidis at xxxxxxx.xxx</ows:ElectronicMailAddress>
+        </ows:Address>
+        <ows:OnlineResource xlink:type="simple" xlink:href="http://localhost"/>
+        <ows:HoursOfService>0800h - 1600h EST</ows:HoursOfService>
+        <ows:ContactInstructions>during hours of service</ows:ContactInstructions>
+      </ows:ContactInfo>
+      <ows:Role>staff</ows:Role>
+    </ows:ServiceContact>
+  </ows:ServiceProvider>
+  <ows:OperationsMetadata>
+    <ows:Operation name="GetCapabilities">
+      <ows:DCP>
+        <ows:HTTP>
+          <ows:Get xlink:type="simple" xlink:href="http://localhost/path/to/wfs_simple?"/>
+          <ows:Post xlink:type="simple" xlink:href="http://localhost/path/to/wfs_simple?"/>
+        </ows:HTTP>
+      </ows:DCP>
+      <ows:Parameter name="service">
+        <ows:Value>WFS</ows:Value>
+      </ows:Parameter>
+      <ows:Parameter name="AcceptVersions">
+        <ows:Value>1.0.0</ows:Value>
+        <ows:Value> 1.1.0</ows:Value>
+      </ows:Parameter>
+      <ows:Parameter name="AcceptFormats">
+        <ows:Value>text/xml</ows:Value>
+      </ows:Parameter>
+    </ows:Operation>
+    <ows:Operation name="DescribeFeatureType">
+      <ows:DCP>
+        <ows:HTTP>
+        </ows:HTTP>
+      </ows:DCP>
+      <ows:Parameter name="outputFormat">
+        <ows:Value>XMLSCHEMA</ows:Value>
+        <ows:Value>text/xml; subtype=gml/2.1.2</ows:Value>
+        <ows:Value>text/xml; subtype=gml/3.1.1</ows:Value>
+      </ows:Parameter>
+    </ows:Operation>
+    <ows:Operation name="GetFeature">
+      <ows:DCP>
+        <ows:HTTP>
+        </ows:HTTP>
+      </ows:DCP>
+      <ows:Parameter name="resultType">
+        <ows:Value>results</ows:Value>
+        <ows:Value>hits</ows:Value>
+      </ows:Parameter>
+        <ows:Value>text/csv</ows:Value>
+        <ows:Value>text/csv; streamed</ows:Value>
+        <ows:Value>text/xml; subtype=gml/2.1.2; driver=ogr</ows:Value>
+        <ows:Value>application/shapefile</ows:Value>
+        <ows:Value>MIDMIF</ows:Value>
+      </ows:Parameter>
+    </ows:Operation>
+  </ows:OperationsMetadata>
+  <FeatureTypeList>
+    <Operations>
+      <Operation>Query</Operation>
+    </Operations>
+    <FeatureType>
+      <Name>road</Name>
+      <Title>road</Title>
+      <DefaultSRS>urn:ogc:def:crs:EPSG::4326</DefaultSRS>
+      <OtherSRS>urn:ogc:def:crs:EPSG::4269</OtherSRS>
+      <OtherSRS>urn:ogc:def:crs:EPSG::3978</OtherSRS>
+      <OutputFormats>
+        <Format>text/xml; subtype=gml/3.1.1</Format>
+        <Format>text/csv</Format>
+        <Format>text/csv; streamed</Format>
+        <Format>text/xml; subtype=gml/2.1.2; driver=ogr</Format>
+        <Format>application/shapefile</Format>
+        <Format>MIDMIF</Format>
+      </OutputFormats>
+      <ows:WGS84BoundingBox dimensions="2">
+        <ows:LowerCorner>-66.633317770969 42.382053788395</ows:LowerCorner>
+        <ows:UpperCorner>-59.292113839180 48.295511938680</ows:UpperCorner>
+      </ows:WGS84BoundingBox>
+    </FeatureType>
+    <FeatureType>
+      <Name>popplace</Name>
+      <Title>popplace</Title>
+      <OutputFormats>
+      </OutputFormats>
+        <ows:LowerCorner>-66.328616887533 42.5631251681</ows:LowerCorner>
+        <ows:UpperCorner>-59.688212172925 47.941250727064</ows:UpperCorner>
+    </FeatureType>
+  </FeatureTypeList>
+  <ogc:Filter_Capabilities>
+    <ogc:Spatial_Capabilities>
+      <ogc:GeometryOperands>
+        <ogc:GeometryOperand>gml:Point</ogc:GeometryOperand>
+        <ogc:GeometryOperand>gml:LineString</ogc:GeometryOperand>
+        <ogc:GeometryOperand>gml:Polygon</ogc:GeometryOperand>
+        <ogc:GeometryOperand>gml:Envelope</ogc:GeometryOperand>
+      </ogc:GeometryOperands>
+      <ogc:SpatialOperators>
+        <ogc:SpatialOperator name="Equals"/>
+        <ogc:SpatialOperator name="Disjoint"/>
+        <ogc:SpatialOperator name="Touches"/>
+        <ogc:SpatialOperator name="Within"/>
+        <ogc:SpatialOperator name="Overlaps"/>
+        <ogc:SpatialOperator name="Crosses"/>
+        <ogc:SpatialOperator name="Intersects"/>
+        <ogc:SpatialOperator name="Contains"/>
+        <ogc:SpatialOperator name="DWithin"/>
+        <ogc:SpatialOperator name="Beyond"/>
+        <ogc:SpatialOperator name="BBOX"/>
+      </ogc:SpatialOperators>
+    </ogc:Spatial_Capabilities>
+    <ogc:Scalar_Capabilities>
+      <ogc:LogicalOperators/>
+      <ogc:ComparisonOperators>
+        <ogc:ComparisonOperator>LessThan</ogc:ComparisonOperator>
+        <ogc:ComparisonOperator>GreaterThan</ogc:ComparisonOperator>
+        <ogc:ComparisonOperator>LessThanEqualTo</ogc:ComparisonOperator>
+        <ogc:ComparisonOperator>GreaterThanEqualTo</ogc:ComparisonOperator>
+        <ogc:ComparisonOperator>EqualTo</ogc:ComparisonOperator>
+        <ogc:ComparisonOperator>NotEqualTo</ogc:ComparisonOperator>
+        <ogc:ComparisonOperator>Like</ogc:ComparisonOperator>
+        <ogc:ComparisonOperator>Between</ogc:ComparisonOperator>
+      </ogc:ComparisonOperators>
+    </ogc:Scalar_Capabilities>
+    <ogc:Id_Capabilities>
+      <ogc:EID/>
+      <ogc:FID/>
+    </ogc:Id_Capabilities>
+  </ogc:Filter_Capabilities>
+</wfs:WFS_Capabilities>
Added: trunk/msautotest/wxs/expected/wfsogr11_ogrgml.xml
--- trunk/msautotest/wxs/expected/wfsogr11_ogrgml.xml	                        (rev 0)
+++ trunk/msautotest/wxs/expected/wfsogr11_ogrgml.xml	2010-10-19 15:51:07 UTC (rev 10624)
@@ -0,0 +1,332 @@
+--xxOGRBoundaryxx
+  <gml:boundedBy>
+    <gml:Box>
+      <gml:coord><gml:X>2279399</gml:X><gml:Y>-55344.50390625</gml:Y></gml:coord>
+      <gml:coord><gml:X>2600377</gml:X><gml:Y>461586.8125</gml:Y></gml:coord>
+    </gml:Box>
+  </gml:boundedBy>
+      <ogr:geometryProperty><gml:Point><gml:coordinates>2281604.25,340848.9375,0</gml:coordinates></gml:Point></ogr:geometryProperty>
+    </ogr:popplace>
+    <ogr:popplace fid="F1">
+      <ogr:geometryProperty><gml:Point><gml:coordinates>2503805.5,427872.65625,0</gml:coordinates></gml:Point></ogr:geometryProperty>
+      <ogr:UNIQUE_KEY>CAGYX</ogr:UNIQUE_KEY>
+      <ogr:NAME>Cheticamp</ogr:NAME>
+      <ogr:POP_CLASS>2</ogr:POP_CLASS>
+    </ogr:popplace>
+    <ogr:popplace fid="F2">
+      <ogr:geometryProperty><gml:Point><gml:coordinates>2499190.0,194088.234375,0</gml:coordinates></gml:Point></ogr:geometryProperty>
+      <ogr:UNIQUE_KEY>CBIKA</ogr:UNIQUE_KEY>
+      <ogr:NAME>Sheet Harbour</ogr:NAME>
+    </ogr:popplace>
+    <ogr:popplace fid="F3">
+      <ogr:geometryProperty><gml:Point><gml:coordinates>2434957.0,347013.59375,0</gml:coordinates></gml:Point></ogr:geometryProperty>
+      <ogr:UNIQUE_KEY>BACII</ogr:UNIQUE_KEY>
+      <ogr:NAME>Souris</ogr:NAME>
+    </ogr:popplace>
+    <ogr:popplace fid="F4">
+      <ogr:geometryProperty><gml:Point><gml:coordinates>2578914.25,292073.09375,0</gml:coordinates></gml:Point></ogr:geometryProperty>
+      <ogr:UNIQUE_KEY>CAGBW</ogr:UNIQUE_KEY>
+      <ogr:NAME>Canso</ogr:NAME>
+    </ogr:popplace>
+    <ogr:popplace fid="F5">
+      <ogr:geometryProperty><gml:Point><gml:coordinates>2536072.75,311524.96875,0</gml:coordinates></gml:Point></ogr:geometryProperty>
+      <ogr:UNIQUE_KEY>CBELL</ogr:UNIQUE_KEY>
+      <ogr:NAME>Port Hawkesbury</ogr:NAME>
+    </ogr:popplace>
+    <ogr:popplace fid="F6">
+      <ogr:geometryProperty><gml:Point><gml:coordinates>2494520.0,285855.40625,0</gml:coordinates></gml:Point></ogr:geometryProperty>
+      <ogr:UNIQUE_KEY>CAATB</ogr:UNIQUE_KEY>
+      <ogr:NAME>Antigonish</ogr:NAME>
+    </ogr:popplace>
+    <ogr:popplace fid="F7">
+      <ogr:geometryProperty><gml:Point><gml:coordinates>2348711.75,204294.0625,0</gml:coordinates></gml:Point></ogr:geometryProperty>
+      <ogr:UNIQUE_KEY>CBKDH</ogr:UNIQUE_KEY>
+      <ogr:NAME>Springhill</ogr:NAME>
+    </ogr:popplace>
+    <ogr:popplace fid="F8">
+      <ogr:geometryProperty><gml:Point><gml:coordinates>2377598.0,135734.703125,0</gml:coordinates></gml:Point></ogr:geometryProperty>
+      <ogr:UNIQUE_KEY>CBPAK</ogr:UNIQUE_KEY>
+      <ogr:NAME>Windsor</ogr:NAME>
+    </ogr:popplace>
+    <ogr:popplace fid="F9">
+      <ogr:geometryProperty><gml:Point><gml:coordinates>2398677.25,70608.140625,0</gml:coordinates></gml:Point></ogr:geometryProperty>
+      <ogr:UNIQUE_KEY>CAWAZ</ogr:UNIQUE_KEY>
+      <ogr:NAME>Lunenburg</ogr:NAME>
+    </ogr:popplace>
+    <ogr:popplace fid="F10">
+      <ogr:geometryProperty><gml:Point><gml:coordinates>2388340.0,19784.322265625,0</gml:coordinates></gml:Point></ogr:geometryProperty>
+      <ogr:UNIQUE_KEY>CAUWZ</ogr:UNIQUE_KEY>
+      <ogr:NAME>Liverpool</ogr:NAME>
+    </ogr:popplace>
+    <ogr:popplace fid="F11">
+      <ogr:geometryProperty><gml:Point><gml:coordinates>2313364.75,98278.921875,0</gml:coordinates></gml:Point></ogr:geometryProperty>
+      <ogr:UNIQUE_KEY>CAZHC</ogr:UNIQUE_KEY>
+      <ogr:NAME>Middleton</ogr:NAME>
+    </ogr:popplace>
+    <ogr:popplace fid="F12">
+      <ogr:geometryProperty><gml:Point><gml:coordinates>2279399,39858,0</gml:coordinates></gml:Point></ogr:geometryProperty>
+      <ogr:UNIQUE_KEY>CAJOA</ogr:UNIQUE_KEY>
+      <ogr:NAME>Digby</ogr:NAME>
+    </ogr:popplace>
+    <ogr:popplace fid="F13">
+      <ogr:geometryProperty><gml:Point><gml:coordinates>2359906.5,-30454.435546875,0</gml:coordinates></gml:Point></ogr:geometryProperty>
+      <ogr:UNIQUE_KEY>CBIKP</ogr:UNIQUE_KEY>
+      <ogr:NAME>Shelburne</ogr:NAME>
+    </ogr:popplace>
+    <ogr:popplace fid="F14">
+      <ogr:geometryProperty><gml:Point><gml:coordinates>2325561.75,294362.25,0</gml:coordinates></gml:Point></ogr:geometryProperty>
+      <ogr:UNIQUE_KEY>BADSZ</ogr:UNIQUE_KEY>
+      <ogr:NAME>Summerside</ogr:NAME>
+      <ogr:POP_CLASS>3</ogr:POP_CLASS>
+    </ogr:popplace>
+    <ogr:popplace fid="F15">
+      <ogr:geometryProperty><gml:Point><gml:coordinates>2600377.0,419421.71875,0</gml:coordinates></gml:Point></ogr:geometryProperty>
+      <ogr:UNIQUE_KEY>CBQFA</ogr:UNIQUE_KEY>
+      <ogr:NAME>Glace Bay</ogr:NAME>
+    </ogr:popplace>
+    <ogr:popplace fid="F16">
+      <ogr:geometryProperty><gml:Point><gml:coordinates>2449341.5,253906.09375,0</gml:coordinates></gml:Point></ogr:geometryProperty>
+      <ogr:UNIQUE_KEY>CBBJR</ogr:UNIQUE_KEY>
+      <ogr:NAME>New Glasgow</ogr:NAME>
+    </ogr:popplace>
+    <ogr:popplace fid="F17">
+      <ogr:geometryProperty><gml:Point><gml:coordinates>2418051.5,205002.203125,0</gml:coordinates></gml:Point></ogr:geometryProperty>
+      <ogr:UNIQUE_KEY>CBMKT</ogr:UNIQUE_KEY>
+      <ogr:NAME>Truro</ogr:NAME>
+    </ogr:popplace>
+    <ogr:popplace fid="F18">
+      <ogr:geometryProperty><gml:Point><gml:coordinates>2329295.75,218397.28125,0</gml:coordinates></gml:Point></ogr:geometryProperty>
+      <ogr:UNIQUE_KEY>CAAOO</ogr:UNIQUE_KEY>
+      <ogr:NAME>Amherst</ogr:NAME>
+    </ogr:popplace>
+    <ogr:popplace fid="F19">
+      <ogr:geometryProperty><gml:Point><gml:coordinates>2345781.25,130999.546875,0</gml:coordinates></gml:Point></ogr:geometryProperty>
+      <ogr:UNIQUE_KEY>CASWE</ogr:UNIQUE_KEY>
+      <ogr:NAME>Kentville</ogr:NAME>
+    </ogr:popplace>
+    <ogr:popplace fid="F20">
+      <ogr:geometryProperty><gml:Point><gml:coordinates>2382666.75,60910.9375,0</gml:coordinates></gml:Point></ogr:geometryProperty>
+      <ogr:UNIQUE_KEY>CAFBR</ogr:UNIQUE_KEY>
+      <ogr:NAME>Bridgewater</ogr:NAME>
+    </ogr:popplace>
+    <ogr:popplace fid="F21">
+      <ogr:geometryProperty><gml:Point><gml:coordinates>2294923.75,-55344.50390625,0</gml:coordinates></gml:Point></ogr:geometryProperty>
+      <ogr:UNIQUE_KEY>CBPIB</ogr:UNIQUE_KEY>
+      <ogr:NAME>Yarmouth</ogr:NAME>
+    </ogr:popplace>
+    <ogr:popplace fid="F22">
+      <ogr:geometryProperty><gml:Point><gml:coordinates>2574240.0,416102.34375,0</gml:coordinates></gml:Point></ogr:geometryProperty>
+      <ogr:UNIQUE_KEY>CBLHE</ogr:UNIQUE_KEY>
+      <ogr:NAME>Sydney Mines</ogr:NAME>
+    </ogr:popplace>
+    <ogr:popplace fid="F23">
+      <ogr:geometryProperty><gml:Point><gml:coordinates>2587598.0,404010.53125,0</gml:coordinates></gml:Point></ogr:geometryProperty>
+      <ogr:UNIQUE_KEY>CBLGX</ogr:UNIQUE_KEY>
+      <ogr:NAME>Sydney</ogr:NAME>
+      <ogr:POP_CLASS>4</ogr:POP_CLASS>
+    </ogr:popplace>
+    <ogr:popplace fid="F24">
+      <ogr:geometryProperty><gml:Point><gml:coordinates>2437026.0,130358.3515625,0</gml:coordinates></gml:Point></ogr:geometryProperty>
+      <ogr:UNIQUE_KEY>CAIYJ</ogr:UNIQUE_KEY>
+      <ogr:NAME>Dartmouth</ogr:NAME>
+      <ogr:POP_CLASS>5</ogr:POP_CLASS>
+    </ogr:popplace>
+    <ogr:popplace fid="F25">
+      <ogr:geometryProperty><gml:Point><gml:coordinates>2402416.5,461586.8125,0</gml:coordinates></gml:Point></ogr:geometryProperty>
+      <ogr:UNIQUE_KEY>EGIIG</ogr:UNIQUE_KEY>
+      <ogr:NAME>Fatima</ogr:NAME>
+    </ogr:popplace>
+    <ogr:popplace fid="F26">
+      <ogr:geometryProperty><gml:Point><gml:coordinates>2378567.25,305099.78125,0</gml:coordinates></gml:Point></ogr:geometryProperty>
+      <ogr:UNIQUE_KEY>BAARG</ogr:UNIQUE_KEY>
+      <ogr:NAME>Charlottetown</ogr:NAME>
+      <ogr:CAPITAL>2</ogr:CAPITAL>
+    </ogr:popplace>
+    <ogr:popplace fid="F27">
+      <ogr:geometryProperty><gml:Point><gml:coordinates>2431943.75,118985.3828125,0</gml:coordinates></gml:Point></ogr:geometryProperty>
+      <ogr:UNIQUE_KEY>CAPHL</ogr:UNIQUE_KEY>
+      <ogr:NAME>Halifax</ogr:NAME>
+      <ogr:POP_CLASS>6</ogr:POP_CLASS>
+    </ogr:popplace>
+--xxOGRBoundaryxx
+    </xs:extension>
+</xs:complexType>
+      <xs:sequence>
+          <xs:simpleType>
+            </xs:restriction>
+          </xs:simpleType>
+        </xs:element>
+          <xs:simpleType>
+            </xs:restriction>
+          </xs:simpleType>
+        </xs:element>
+          <xs:simpleType>
+            </xs:restriction>
+          </xs:simpleType>
+        </xs:element>
+          <xs:simpleType>
+            </xs:restriction>
+          </xs:simpleType>
+        </xs:element>
+      </xs:sequence>
+    </xs:extension>
+</xs:complexType>
+</xs:schema>
Modified: trunk/msautotest/wxs/wfs_ogr.map
--- trunk/msautotest/wxs/wfs_ogr.map	2010-10-19 15:49:01 UTC (rev 10623)
+++ trunk/msautotest/wxs/wfs_ogr.map	2010-10-19 15:51:07 UTC (rev 10624)
@@ -3,6 +3,11 @@
 # REQUIRES: SUPPORTS=WFS INPUT=OGR
+# Some tests in this sequence will be quite sensitive to the GDAL/OGR version.
+# The tests are currently expected to run with GDAL/OGR 1.8 (prerelease)
+# WFS 1.0
 # Do formats show up in the Capabilities
 # RUN_PARMS: wfsogr10_caps.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetCapabilities" > [RESULT_DEVERSION]
@@ -15,10 +20,21 @@
 # Generate dump streamed directly to CSV
 # RUN_PARMS: wfsogr10_csvstream.txt [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&TYPENAME=road&featureid=road.1521&OUTPUTFORMAT=CSVSTREAM" > [RESULT]
-# Generate dump streamed directly to OGR GML
+# Generate dump streamed directly to OGR GML from memory.
 # RUN_PARMS: wfsogr10_ogrgml.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&TYPENAME=road&featureid=road.1521&OUTPUTFORMAT=OGRGML" > [RESULT]
+# OGR GML from OGR layer to test OGR "auto" support.  Also tests aliasing.
+# RUN_PARMS: wfsogr10_ograuto.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&featureid=popplace.BACMK&OUTPUTFORMAT=OGRGML" > [RESULT]
+# WFS 1.1
+# Do formats show up in the Capabilities
+# RUN_PARMS: wfsogr11_caps.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WFS&VERSION=1.1.0&REQUEST=GetCapabilities" > [RESULT_DEVERSION]
+# RUN_PARMS: wfsogr11_ogrgml.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&TYPENAME=popplace&OUTPUTFORMAT=text/xml; subtype=gml/2.1.2; driver=ogr&srsName=urn:ogc:def:crs:EPSG::3978" > [RESULT]
 MAP
@@ -60,23 +76,16 @@
 OUTPUTFORMAT
   NAME "OGRGML"
   DRIVER "OGR/GML"
+  MIMETYPE "text/xml; subtype=gml/2.1.2; driver=ogr"
   FORMATOPTION "STORAGE=memory"
   FORMATOPTION "FORM=multipart"
   FORMATOPTION "FILENAME=result.gml"
 END
 OUTPUTFORMAT
-  NAME "OGRGMLSTREAM"
-  DRIVER "OGR/GML"
-  MIMETYPE "text/xml; subtype=gml/2.1.2"
-  FORMATOPTION "STORAGE=stream"
-  FORMATOPTION "FILENAME=result.gml"
-END
-OUTPUTFORMAT
   NAME "SHAPEZIP"
   DRIVER "OGR/ESRI Shapefile"
-  MIMETYPE "application/zip"
+  MIMETYPE "application/shapefile"
   FORMATOPTION "STORAGE=filesystem"
   FORMATOPTION "FORM=zip"
   FORMATOPTION "FILENAME=result.zip"
@@ -145,6 +154,7 @@
     "wfs_featureid"     "ROAD_ID"
     "wfs_getfeature_formatlist" "csv,csvstream,ogrgml,ogrgmlstream,shapezip,midmif"
     "gml_include_items" "all"
+    "gml_exclude_items" "ROAD_"
     "gml_types"         "auto"
  END
   TYPE LINE
@@ -166,8 +176,10 @@
     "wfs_title"         "popplace"
     "wfs_description"   "populated places"
     "wfs_featureid"     "UNIQUE_KEY"
-    "wfs_getfeature_formatlist" "csv,ogrgml,shapezip"
-    "gml_include_items" "all"
+    "wfs_getfeature_formatlist" "csv,ogrgml,shapezip,midmif"
+    "gml_include_items" "NAME,UNIQUE_KEY,CAPITAL,POP_RANGE"
+    "gml_POP_RANGE_alias" "POP_CLASS"
+    "gml_types"         "auto"
   END
   TYPE POINT
   STATUS ON
