[mapserver-commits] r10627 - trunk/docs/en/ogc
Tue Oct 19 13:46:01 EDT 2010
Author: jmckenna
Date: 2010-10-19 10:46:01 -0700 (Tue, 19 Oct 2010)
New Revision: 10627
   trunk/docs/en/ogc/wcs_server.txt
use demo.mapserver.org services.  fix wcs_formats (ticket#3527)
Modified: trunk/docs/en/ogc/wcs_server.txt
--- trunk/docs/en/ogc/wcs_server.txt	2010-10-19 17:44:06 UTC (rev 10626)
+++ trunk/docs/en/ogc/wcs_server.txt	2010-10-19 17:46:01 UTC (rev 10627)
@@ -6,9 +6,7 @@
 :Author:       Jeff McKenna
 :Contact:      jmckenna at gatewaygeomatics.com
-:Revision: $Revision$
-:Date: $Date$
-:Last Updated: 2008/04/18
+:Last Updated: 2010-10-19
 .. contents:: Table of Contents
     :depth: 2
@@ -81,7 +79,7 @@
 	NAME WCS_server
 	STATUS ON
 	SIZE 400 300
-	SYMBOLSET ../etc/symbols.sym
+	SYMBOLSET "../etc/symbols.txt"
 	EXTENT -2200000 -712631 3072800 3840000
 	UNITS METERS
 	SHAPEPATH "../data"
@@ -131,7 +129,6 @@
 	    "wcs_label"           "Elevation/Bathymetry"  ### required
 	    "wcs_rangeset_name"   "Range 1"               ### required to support DescribeCoverage request
 	    "wcs_rangeset_label"  "My Label"              ### required to support DescribeCoverage request
-            "wcs_rangeset_nullvalue" "-65535"
 	  END
 	  TYPE RASTER ### required
 	  STATUS ON
@@ -175,7 +172,7 @@
 Here is a working example of a GetCapabilities request:
-http://maps.dnr.state.mn.us/cgi-bin/mapserv50?MAP=/usr/local/www/docs_maps/mapserver_demos/wcs/demo.map&SERVICE=wcs&VERSION=1.0.0&REQUEST=GetCapabilities
+http://demo.mapserver.org/cgi-bin/wcs?SERVICE=wcs&VERSION=1.0.0&REQUEST=GetCapabilities
 Test With a DescribeCoverage Request
@@ -193,7 +190,7 @@
 Here is a working example of a DescribeCoverage request:
-http://maps.dnr.state.mn.us/cgi-bin/mapserv50?MAP=/usr/local/www/docs_maps/mapserver_demos/wcs/demo.map&SERVICE=wcs&VERSION=1.0.0&REQUEST=DescribeCoverage&COVERAGE=modis
+http://demo.mapserver.org/cgi-bin/wcs?SERVICE=wcs&VERSION=1.0.0&REQUEST=DescribeCoverage&COVERAGE=modis
 Test With a GetCoverage Request
@@ -224,7 +221,7 @@
    **RESY=y:** When requesting a georectified grid coverage, this requests a subset with a specific spatial resolution.  One of WIDTH/HEIGHT or RESX/Y is required.
-   **FORMAT=output_format:** Output format of map, as stated in the GetCapabilities.
+   **FORMAT=output_format:** Output format of map, as stated in the DescribeCoverage response.
 The following are optional GetCoverage parameters according to the WCS spec:
@@ -238,9 +235,9 @@
     &coverage=bathymetry&CRS=EPSG:42304&BBOX=-2200000,-712631,3072800,3840000
     &WIDTH=3199&HEIGHT=2833&FORMAT=GTiff
-Here is a working example of a GetCoverage request (note that a 3MB tif is being requested, so this may take a few seconds):
+Here is a working example of a GetCoverage request (note that a 350KB tif is being requested, so this may take a second):
-http://gws2.pcigeomatics.com/wcs1.0.0/wcs?SERVICE=wcs&VERSION=1.0.0&REQUEST=GetCoverage&COVERAGE=demo/wcs_l7_ms.pix&CRS=EPSG:4326&BBOX=-117.88341239280106,33.707704191028995,-117.65485697866967,33.89850474983795&WIDTH=700&HEIGHT=700&FORMAT=GeoTIFF
+http://demo.mapserver.org/cgi-bin/wcs?SERVICE=wcs&VERSION=1.0.0&REQUEST=GetCoverage&COVERAGE=modis-001&CRS=EPSG:26915&BBOX=159707,4597395,1400707,5501395&WIDTH=400&HEIGHT=300&FORMAT=GEOTIFF_RGB
 WCS 1.1.0+ Issues
@@ -433,7 +430,7 @@
 **wcs_formats**
-- *Description:* (Optional) The formats which may be requested for this layer, in a comma-delimited list. (e.g. "GTiff,MrSID")
+- *Description:* (Optional) The formats which may be requested for this layer, separated by a space. (e.g. "GTiff MrSID")
 **wcs_keywords**
@@ -511,10 +508,6 @@
 - *Description:* (Required for DescribeCoverage request)
-**wcs_rangeset_nullvalue**
-- *Description:* Used to establish the null value for the layer in the DescribeCoverage result.  It also sets the NULLVALUE item on the OUTPUTFORMAT object so that unitialized areas of the result will be set to this value, and where possible the returned file will have this value marked as nodata in metadata.
 **wcs_srs**
 - *Description:* (Optional) Spatial reference system of the layer, in the form of: EPSG:code (e.g. EPSG:42304)
