[mapserver-commits] r10637 - trunk/mapserver
Wed Oct 20 10:42:59 EDT 2010
Author: assefa
Date: 2010-10-20 07:42:59 -0700 (Wed, 20 Oct 2010)
New Revision: 10637
   trunk/mapserver/mapfile.c
   trunk/mapserver/mapwfs.c
Axis not swapping when srs is not given #3574
Modified: trunk/mapserver/mapfile.c
--- trunk/mapserver/mapfile.c	2010-10-20 01:30:57 UTC (rev 10636)
+++ trunk/mapserver/mapfile.c	2010-10-20 14:42:59 UTC (rev 10637)
@@ -1248,6 +1248,9 @@
 int msLoadProjectionStringEPSG(projectionObj *p, const char *value)
+#ifdef USE_PROJ
+   if(p) msFreeProjection(p);
     p->gt.need_geotransform = MS_FALSE;
     if (strncasecmp(value, "EPSG:", 5) == 0)
@@ -1271,6 +1274,12 @@
     return msLoadProjectionString(p, value);
+#else
+  msSetError(MS_PROJERR, "Projection support is not available.",
+             "msLoadProjectionStringEPSG()");
+  return(-1);
+#endif
Modified: trunk/mapserver/mapwfs.c
--- trunk/mapserver/mapwfs.c	2010-10-20 01:30:57 UTC (rev 10636)
+++ trunk/mapserver/mapwfs.c	2010-10-20 14:42:59 UTC (rev 10637)
@@ -302,6 +302,9 @@
         queries layers
     pszMapSRS = msOWSGetEPSGProj(&(map->projection), &(map->web.metadata), "FO", MS_TRUE);
+    if(pszMapSRS && nVersion >  OWS_1_0_0)
+      msLoadProjectionStringEPSG(&(map->projection), pszMapSRS);
     if (srs == NULL || nVersion == OWS_1_0_0)
         for (i=0; i<map->numlayers; i++)
@@ -2362,19 +2365,23 @@
               layerObj *lp;
               rectObj ext;
+              int status;
               lp = GET_LAYER(map, j);
               if (lp->status == MS_ON)
                    if (msOWSGetLayerExtent(map, lp, "FO", &ext) == MS_SUCCESS)
-                       char szBuf[32];
                        if (pszMapSRS != NULL && strncmp(pszMapSRS, "EPSG:", 5) == 0) {
-                           sprintf(szBuf, "init=epsg:%.10s", pszMapSRS+5);
-                           if (msLoadProjectionString(&(map->projection), szBuf) != 0) {
+                           if( msOWSParseVersionString(paramsObj->pszVersion) >= OWS_1_1_0 )
+                             status = msLoadProjectionStringEPSG(&(map->projection), pszMapSRS);
+                           else
+                             status = msLoadProjectionString(&(map->projection), pszMapSRS);
+                           if (status != 0) {
                                msSetError(MS_WFSERR, "msLoadProjectionString() failed: %s",
-                                          "msWFSGetFeature()", szBuf);
+                                          "msWFSGetFeature()", pszMapSRS);
                                return msWFSException(map, "mapserv", "NoApplicableCode",
                                                      paramsObj->pszVersion);
@@ -2390,8 +2397,10 @@
                                if (strncmp(pszLayerSRS, "EPSG:", 5) == 0)
-                                   sprintf(szBuf, "init=epsg:%.10s", pszLayerSRS+5);
-                                   msLoadProjectionString(&(lp->projection), szBuf);
+                                     msLoadProjectionStringEPSG(&(lp->projection), pszLayerSRS);
+                                   else
+                                     msLoadProjectionString(&(lp->projection), pszLayerSRS);
