[mapserver-commits] r10650 - trunk/mapserver
Sat Oct 23 14:41:12 EDT 2010
Author: assefa
Date: 2010-10-23 11:41:12 -0700 (Sat, 23 Oct 2010)
New Revision: 10650
   trunk/mapserver/mapwfs.c
Return an error if the number of filters is incorrect (#3584)
Modified: trunk/mapserver/mapwfs.c
--- trunk/mapserver/mapwfs.c	2010-10-23 16:52:06 UTC (rev 10649)
+++ trunk/mapserver/mapwfs.c	2010-10-23 18:41:12 UTC (rev 10650)
@@ -2132,27 +2132,32 @@
       /*      20,20</gml:coordinates></gml:Box></Within></Filter>)            */
       nFilters = 0;
-      if (strlen(pszFilter) > 0 && pszFilter[0] == '(') {
-	tokens = msStringSplit(pszFilter+1, '(', &nFilters);
+      if (strlen(pszFilter) > 0 && pszFilter[0] == '(')
+          tokens = msStringSplit(pszFilter+1, '(', &nFilters);
-	if (tokens == NULL || nFilters <=0 || nFilters != numlayers) {
-	  msSetError(MS_WFSERR, "Wrong number of FILTER attributes",
-		     "msWFSGetFeature()");
-	  return msWFSException(map, "filter", "InvalidParameterValue", paramsObj->pszVersion);
-	paszFilter = (char **)malloc(sizeof(char *)*nFilters);
-	for (i=0; i<nFilters; i++)
-	  paszFilter[i] = strdup(tokens[i]);
+          if (tokens &&  nFilters > 0 && numlayers == nFilters)
+              paszFilter = (char **)malloc(sizeof(char *)*nFilters);
+              for (i=0; i<nFilters; i++)
+                paszFilter[i] = strdup(tokens[i]);
-	if (tokens)
-	  msFreeCharArray(tokens, nFilters);
-      } else {
-	nFilters=1;
-	paszFilter[0] = pszFilter;
+              msFreeCharArray(tokens, nFilters);
+      else if (numlayers == 1)
+          nFilters=1;
+          paszFilter[0] = pszFilter;
+      if (numlayers != nFilters)
+          msSetError(MS_WFSERR, "Wrong number of filter elements, one filter must be specified for each feature type listed in the TYPENAME parameter.",
+                     "msWFSGetFeature()");
+          return msWFSException(map, "filter", "InvalidParameterValue", paramsObj->pszVersion);
       /*      run through the filters and build the class expressions.        */
       /*      TODO: items may have namespace prefixes, or reference aliases,  */
