[mapserver-commits] r10665 - in trunk/docs/en: development/rfc mapfile ogc output
Sun Oct 24 22:16:10 EDT 2010
Author: warmerdam
Date: 2010-10-24 19:16:10 -0700 (Sun, 24 Oct 2010)
New Revision: 10665
Added:
   trunk/docs/en/output/ogr.txt
   trunk/docs/en/development/rfc/ms-rfc-62.txt
   trunk/docs/en/mapfile/outputformat.txt
   trunk/docs/en/ogc/wfs_server.txt
   trunk/docs/en/output/index.txt
added details on OGR Output from WFS (#3570)
Modified: trunk/docs/en/development/rfc/ms-rfc-62.txt
--- trunk/docs/en/development/rfc/ms-rfc-62.txt	2010-10-24 19:26:16 UTC (rev 10664)
+++ trunk/docs/en/development/rfc/ms-rfc-62.txt	2010-10-25 02:16:10 UTC (rev 10665)
@@ -48,9 +48,9 @@
 will be extended to show all the legal output formats for all of the
 layers (based on wfs_getfeature_formatlist metadata).
-Note that in WFS 1.0.0 there is no mechanism to discover supported formats
-automatically, and even in WFS 1.1.0 there is no mechanism to discover
-which formats are available for which layers.
+Note that in WFS 1.0.0 there is no mechanism to discover the format list on
+a per-layer basis, only the overall list.  WFS 1.1.0 supports an overall
+list and a per-layer list.
 outputFormatObj
Modified: trunk/docs/en/mapfile/outputformat.txt
--- trunk/docs/en/mapfile/outputformat.txt	2010-10-24 19:26:16 UTC (rev 10664)
+++ trunk/docs/en/mapfile/outputformat.txt	2010-10-25 02:16:10 UTC (rev 10665)
@@ -69,19 +69,23 @@
 NAME [name]
     The name to use use in the IMAGETYPE keyword of the map file to
-    select this output format.(optional)
+    select this output format.  This name is also used in metadata describing
+    wxs formats allowed, and can be used (sometimes along with mimetype) to
+    select the output format via keywords in OGC requests. (optional)
 DRIVER [name]
     The name of the driver to use to generate this output format. Some driver
     names include the definition of the format if the driver supports multiple
     formats. For AGG, the possbile driver names are "AGG/PNG" and "AGG/JPEG".
     For GD the possible driver names are "GD/Gif", "GD/PNG",
-    "GD/WBMP" and "GD/JPEG". For flash the driver is just called "SWF". For
-    output through GDAL the GDAL shortname for the format is appended, such
-    as "GDAL/GTiff". Note that PNG, JPEG and GIF output can be generated with
-    either GDAL or GD (GD is generally more efficient).(mandatory)
+    "GD/WBMP" and "GD/JPEG". For flash the driver is just called "SWF".
+    For output through OGR the OGR driver name is appended, such as
+    "OGR/Mapinfo File".  For output through GDAL the GDAL shortname for the
+    format is appended, such as "GDAL/GTiff". Note that PNG, JPEG and GIF
+    output can be generated with either GDAL or GD (GD is generally more
+    efficient).  TEMPLATE should be used for template based output. (mandatory)
-IMAGEMODE [PC256/RGB/RGBA/INT16/FLOAT32]
+IMAGEMODE [PC256/RGB/RGBA/INT16/FLOAT32/FEATURE]
     Selects the imaging mode in which the output is generated. Does matter
     for non-raster formats like Flash. Not all formats support all
     combinations. For instance GD/GIF supports only PC256. (optional)
@@ -100,6 +104,8 @@
     - FLOAT32: Render raw 32bit floating point pixel values
       (no presentation). Only works for RASTER layers (through GDAL)
       and WMS layers currently.
+    - FEATURE: Output is a non-image result, such as features written
+      via templates or OGR.
 MIMETYPE [type]
     Provide the mime type to be used when returning results over the web.
@@ -140,6 +146,7 @@
       BYTE/INT16/FLOAT) to pre-initialize the raster and an attempt is made
       to record this in the resulting file as the nodata value. This is
       automatically set in WCS mode if rangeset_nullvalue is set.
+    - OGR/\*: See OGR Output document for details of OGR format options.
     - GD/PNG and AGG/PNG both support quantizing from 24/32 bits to 8bits,
       in order to reduce the final image size (and therefore save bandwidth) (see
       also http://trac.osgeo.org/mapserver/ticket/2436#comment:4 for strategies
Modified: trunk/docs/en/ogc/wfs_server.txt
--- trunk/docs/en/ogc/wfs_server.txt	2010-10-24 19:26:16 UTC (rev 10664)
+++ trunk/docs/en/ogc/wfs_server.txt	2010-10-25 02:16:10 UTC (rev 10665)
@@ -66,6 +66,7 @@
 For a detailed discussion on the versions supported, see `bug#884`_.
 Configuring your MapFile to Serve WFS layers
@@ -301,6 +302,12 @@
   provides for the ability to use WFS GetFeature to page through results.
   Note that STARTINDEX=1 means start with the first feature, skipping none.
+**OUTPUTFORMAT**
+  Normally OUTPUTFORMAT should be GML2 for WFS 1.0 and either "text/xml;
+  subtype=gml/2.1.2" or "text/xml; subtype=gml/3.1.1" for WFS 1.1.  However
+  as an extension to the specification, it is also possible to configure
+  MapServer for a variety of other feature output formats.  This is discussed
+  in some detail in the :ref:`OGR Output <ogr_output>` document.
 Reference Section
@@ -476,6 +483,28 @@
 - *Description:* (Optional) Specifies the type of the attribute.  Valid values
   are Integer|Real|Character|Date|Boolean.
+**gml_[item name]_width**
+  (Optional) Specifies the width of the indicated field for formats where
+  this is significant, such as Shapefiles.
+**gml_[item name]_precision**
+  (Optional) Specifies the precision of the indicated field for formats where
+  this is significant, such as Shapefiles.  Precision is the number of decimal
+  places, and is only needed for "Real" fields.  Currently this is only used
+  for OGR based output formats, not the WFS GML2/GML3 output.
+**gml_types**
+  (Optional) If this field is "auto" then some input feature drivers (ie.
+  OGR, POSTGIS, ORACLESPATIAL and native shapefiles) will automatically
+  populate the type, width and precision metadata for the layer based on the
+  source file. Currently this is only used
+    "gml_types"   "auto"
 **gml_xml_items**
 - *Description:* (Optional) A comma delimited list of items that should not be
@@ -553,8 +582,8 @@
 - This is just a basic WFS (read-only): transaction requests are not supported
-  and probably never will given the nature of MapServer.  `GeoServer`_ is
-  recommended for those needing WFS-T support.
+  and probably never will given the nature of MapServer.  `GeoServer`_ or
+  `TinyOWS`_ is recommended for those needing WFS-T support.
 - WFS spec. seems to require that features of a given feature type must all be
   of the same geometry type (point, line, polygon). This works fine for shapefiles,
@@ -576,6 +605,7 @@
 .. _`uDig`: http://udig.refractions.net/
 .. _`WFS 1.0.0 spec`: https://portal.opengeospatial.org/files/?artifact_id=7176
 .. _`GeoServer`: http://geoserver.org
+.. _`TinyOWS`: http://www.tinyows.org
 .. _`GML2 request output`: http://demo.mapserver.org/cgi-bin/wfs?SERVICE=WFS&VERSION=1.0.0&REQUEST=getfeature&TYPENAME=continents&MAXFEATURES=1&OUTPUTFORMAT=gml2
 .. _`GML3 request output`: http://demo.mapserver.org/cgi-bin/wfs?SERVICE=WFS&VERSION=1.0.0&REQUEST=getfeature&TYPENAME=continents&MAXFEATURES=1&OUTPUTFORMAT=gml3
 .. _`bug#884`: http://trac.osgeo.org/mapserver/ticket/884
Modified: trunk/docs/en/output/index.txt
--- trunk/docs/en/output/index.txt	2010-10-24 19:26:16 UTC (rev 10664)
+++ trunk/docs/en/output/index.txt	2010-10-25 02:16:10 UTC (rev 10665)
@@ -17,4 +17,5 @@
    pdf
    svg
    tile_mode
+   ogr_output
Added: trunk/docs/en/output/ogr.txt
--- trunk/docs/en/output/ogr.txt	                        (rev 0)
+++ trunk/docs/en/output/ogr.txt	2010-10-25 02:16:10 UTC (rev 10665)
@@ -0,0 +1,319 @@
+.. _ogr_output:
+ OGR Output
+:Author: Frank Warmerdam
+:Contact: warmerdam at pobox.com
+:Revision: $Revision$
+:Date: $Date$
+:Last Updated: 2010/10/22
+.. contents:: Table of Contents
+    :depth: 2
+    :backlinks: top
+Introduction
+OGR output support was added to MapServer 6.0.  It provides an output driver
+to produce feature style output suitable as a return result from WMS
+GetFeatureInfo or WFS GetFeature requests.  OGR feature output depends on
+MapServer being built against the GDAL/OGR library.  The OGR output driver
+should be enabled in MapServer 6.0 or newer when INPUT=OGR appears in the
+version string.
+OUTPUTFORMAT Declarations
+Details of OGR output formats allowed are controlled by an OUTPUTFORMAT
+declaration.  The declarations define the OGR format driver to be used,
+creation options specific to that driver, and more general instructions to
+MapServer on how to package multi-file results and whether to try and
+build the result on disk or in memory.
+Examples::
+  OUTPUTFORMAT
+    NAME "CSV"
+    DRIVER "OGR/CSV"
+    MIMETYPE "text/csv"
+    FORMATOPTION "LCO:GEOMETRY=AS_WKT"
+    FORMATOPTION "STORAGE=memory"
+    FORMATOPTION "FORM=simple"
+    FORMATOPTION "FILENAME=result.csv"
+  END
+  OUTPUTFORMAT
+    NAME "OGRGML"
+    DRIVER "OGR/GML"
+    FORMATOPTION "STORAGE=filesystem"
+    FORMATOPTION "FORM=multipart"
+    FORMATOPTION "FILENAME=result.gml"
+  END
+  OUTPUTFORMAT
+    NAME "SHAPEZIP"
+    DRIVER "OGR/ESRI Shapefile"
+    FORMATOPTION "FORM=zip"
+    FORMATOPTION "FILENAME=result.zip"
+  END
+The OGR format driver to be used is determined by the name appearing
+after "OGR/" in the DRIVER argument.  This name should match one of
+the formats listed as supported for the "-f" argument to ogr2ogr in the
+ogr2ogr usage message.
+The IMAGEMODE for OGR output is FEATURE, but this is implicit and does
+not need to be explicitly stated for OGR output driver declarations.
+The OGR renderer will support the following FORMATOPTION declarations:
+**DSCO:\***
+  Anything prefixed by DSCO: is used as a dataset creation option with the
+  OGR driver. See the OGR web page for the particular format driver to see
+  layer creation options available.
+**LCO:\***
+  Anything prefixed by LCO: is used as a layer creation option.  See
+  the OGR web page for the particular format driver to see layer creation
+  options available.w
+**FORM=simple/zip/multipart**
+  Indicates whether the result should be a simple single file (single), a
+  mime multipart attachment (multipart) or a zip file (zip).  "zip" is
+  the default.
+**STORAGE=memory/filesystem/stream**
+  Indicates where the datasource should be stored while being written.
+  "file" is the default.
+  If "memory" then it will be created in /vsimem/ - but this is only suitable
+  for drivers supporting VSI*L which we can't easily determine automatically.
+  If "file" then a temporary directory will be created under the IMAGEPATH
+  were the file(s) will be written and then read back to stream to the
+  client.
+  If "stream" then the datasource will be created with a name "/vsistdout"
+  as an attempt to write directly to stdout.  Only a few OGR drivers will
+  work properly in this mode (ie. CSV, perhaps kml, gml).
+**FILENAME=name**
+  Provides a name for the datasource created, default is "result.dat".
+LAYER Metadata
+The OGR output driver utilizes several items from the LAYER level METADATA
+object.  Some of these were originally intended for GML output or are
+primarily intended to support WFS.
+**wfs_getfeature_formatlist**
+  (Optional) A comma delimited list of formats supported for WFS GetFeature
+  responses.  The OUTPUTFORMAT NAME values should be listed.
+    "wfs_getfeature_formatlist" "OGRGML,SHAPEZIP,CSV"
+**gml_include_items**
+  (Optional) A comma delimited list of items to include, or keyword
+  "all".  You can enable full exposure by using the keyword "all".
+    "gml_include_items" "all"
+  You can specify a list of attributes (fields) for partial exposure, such as:
+    "gml_include_items" "Name,ID"
+  The new default behaviour is to expose no attributes at all.
+  "all". As of MapServer 4.6, you can control how many attributes (fields) you expose
+  for your data layer with this metadata. The previous behaviour was simply to expose
+  all attributes all of the time. You can enable full exposure by using the keyword "all",
+  such as:
+**gml_[item name]_alias**
+  (Optional) An alias for an attribute's name.  The resulting file will refer
+  to this attribute by the alias.  Here is an example:
+    "gml_province_alias" "prov"
+**gml_[item name]_type**
+  (Optional) Specifies the type of the attribute.  Valid values
+  are Integer|Real|Character|Date|Boolean.
+**gml_types**
+  OGR, and native shapefiles) will automatically populate the type, width and
+  precision metadata for the layer based on the source file.
+**ows/wfs_geomtype**
+  (Optional) Set the geometry type of OGR layers created from this MapServer
+  LAYER.  One of "Point", "LineString", "Polygon", "MultiPoint",
+  "MultiLineString", "MultiPolygon", "GeometryCollection", "Geometry",
+  or "None".  Most are fairly obvious, but "Geometry" can be used to represent
+  a mix of geometry types, and "None" is sometimes suitable for layers without
+  geometry.  Note that layers which are a mix of polygon and multipolygon
+  would normally have to be described as "Geometry".
+    "ows_geomtype"  "Polygon"
+MAP / WEB Metadata
+**wms_feature_info_mime_type**
+  In order for WMS GetFeatureInfo to allow selection of OGR output formats,
+  the mime type associated with the OUTPUTFORMAT must be listed in this metadata
+  item.
+    "wms_feature_info_mime_type" "text/csv"
+Geometry Types Supported
+In MapServer we have POINT, LINE and POLYGON layers which also allow for
+features with multiple points, lines or polygons.  However, in the OGC Simple
+Feature geometry model used by OGR a point and multipoint layer are quite
+distinct.  Likewise for a LineString and MultiLineString and Polygon an
+MultiPolygon layer type.
+To work around the mismatches between the MapServer and OGR geometry models,
+there is a mechanism to specify the geometry type to be used when exporting
+through OGR.  This is the "wfs/ows_geomtype" metadata item on the layer. It
+may be one of one of "Point", "LineString", "Polygon", "MultiPoint",
+"MultiLineString", "MultiPolygon", "GeometryCollection", "Geometry", or "None".
+If this item is not specified, then "Point", "LineString" or "Polygon" will
+be used depending on the TYPE of the LAYER.   In cases of mixed geometry
+types (ie. polygons and multipolygons) the geometry type should be set to
+"Geometry" which means any geometry type.
+    "ows_geomtype" "Geometry"
+Attribute Field Definitions
+For OGR output it is highly desirable to be able to create the output fields
+with the appropriate datatype, width and precision to reflect the source
+feature definition.
+It is possible to set the gml_[item]_type, gml_[item]_width and
+gml_[item]_precision metadata on the layer to provide detailed field
+definitions::
+    METADATA
+      "gml_ID_type"        "Integer"
+      "gml_ID_width"       "8"
+      "gml_AREA_type"      "Real"
+      "gml_AREA_width"     "15"
+      "gml_AREA_precision" "6"
+      "gml_NAME_type"      "Character"
+      "gml_NAME_width"     "64"
+However, doing this manually is tedious and error prone.  For that reason
+some feature sources (at least OGR, Shapefiles, POSTGIS and ORACLESPATIAL)
+support a mechanism to automatically populate this information from the
+source datastore.  To accomplish this specify::
+If no effort is made to set type, width and precision information for
+attribute fields, they will all be treated as variable length character
+fields when writing through OGR.
+Return Packaging
+One of the challenges returning generalized feature formats is that
+many such formats consists of multiple files which must be returned in
+the result.  There are three approaches taken to this based on the
+FORM FORMATOPTION in the OUTPUTFORMAT declaration.
+**simple**
+  In this case a single result is returned.  This is suitable for format
+  drivers that produce a single file.  The return result will have the
+  mimetype listed in the OUTPUTFORMAT declaration.  Note that if the OGR
+  driver actually returns multiple files, only the primary one (the one
+  with a name matching the filename passed into the OGR CreateDataSource call)
+  will be returned.  The return result will have a suggested filename based
+  on the FILENAME FORMATOPTION.
+**multipart**
+  In this case all the files produced are returned as a multipart mime
+  result.  In this case the MIMETYPE of the OUTPUTFORMAT is ignored.  All
+  component files are returned with a mime type of "application/binary" and
+  the whole package is "multipart/mixed".
+**zip**
+  In this case all the files produced are bundled into one .zip file and
+  this zip file is returned with a mimetype of "application/zip".   The
+  OUTPUTFORMAT MIMETYPE is ignored.
+One caveat with "zip" results is that this option is only available if
+the GDAL/OGR version is 1.8 or newer (or a 1.8 development later than
+approximately Oct 15, 2010).  Earlier versions of GDAL/OGR lacked the
+zipping capability needed.
+Test Suite Example
+The MSAutoTest test suite contains a test case for use of OGR Output from
+WFS.   The mapfile is at:
+  http://svn.osgeo.org/mapserver/trunk/msautotest/wxs/wfs_ogr.map
+The comments at the start of the file have a variety of sample requests
+that can be run against the map, as long as [MAPFILE] is replaced with the
+mapfile name.  They requests should be run against mapserv sitting in the
+msautotest/wxs directory.
Property changes on: trunk/docs/en/output/ogr.txt
___________________________________________________________________
Added: svn:keywords
   + Author Date Id Rev URL
