[mapserver-commits] r10670 - branches/branch-5-6/docs/en/development/rfc
Mon Oct 25 11:43:28 EDT 2010
Author: aboudreault
Date: 2010-10-25 08:43:28 -0700 (Mon, 25 Oct 2010)
New Revision: 10670
   branches/branch-5-6/docs/en/development/rfc/ms-rfc-55.txt
docs-5.6: Removed invalid limitation in rfc 55.
Modified: branches/branch-5-6/docs/en/development/rfc/ms-rfc-55.txt
--- branches/branch-5-6/docs/en/development/rfc/ms-rfc-55.txt	2010-10-25 15:42:45 UTC (rev 10669)
+++ branches/branch-5-6/docs/en/development/rfc/ms-rfc-55.txt	2010-10-25 15:43:28 UTC (rev 10670)
@@ -145,13 +145,6 @@
 by default) only when the RESOLUTION is set to the default 72 or equal
 to the DEFRESOLUTION setting.
-The implementation of this feature in v5.6 has a limitation: the STYLE's
-MINSIZE, MAXSIZE, MINWIDTH and MAXWIDTH parameters are not automatically
-adjusted to reflect the resolution change. This is because we cannot easily
-access the defresolution/resolution ratio at the level where those parameters
-are handled, and with the new rendering API in 6.0 this will no longer be
-an issue.
 Files Impacted
