[mapserver-commits] r10674 - in trunk/docs/en/mapscript: . php
Tue Oct 26 10:11:02 EDT 2010
Author: aboudreault
Date: 2010-10-26 07:11:02 -0700 (Tue, 26 Oct 2010)
New Revision: 10674
   trunk/docs/en/mapscript/mapscript.txt
   trunk/docs/en/mapscript/php/index.txt
Modified wrong note about the ZoomRectangle method in swig/php mapscript
Modified: trunk/docs/en/mapscript/mapscript.txt
--- trunk/docs/en/mapscript/mapscript.txt	2010-10-26 13:51:18 UTC (rev 10673)
+++ trunk/docs/en/mapscript/mapscript.txt	2010-10-26 14:11:02 UTC (rev 10674)
@@ -1815,11 +1815,23 @@
     can be constrained to a maximum *maxextent*.  Returns MS_SUCCESS or
     MS_FAILURE.
-zoomRectangle( rectObj_ imgrect, int width, int height, rectObj_ extent, rectObj_ maxextent ) : int
-    Zoom to a pixel coordinate rectangle in the image of *width* and *height*
-    dimensions and georeferencing *extent*.  Zooming can be constrained to a
-    maximum *maxextent*.  Returns MS_SUCCESS or MS_FAILURE.
+zoomRectangle( rectObj_ imgrect, int width, int height, rectObj_ extent,
+    rectObj_ maxextent ) : int Zoom to a pixel coordinate rectangle in the
+    image of *width* and *height* dimensions and georeferencing
+    *extent*. Zooming can be constrained to a maximum *maxextent*. The
+    *imgrect* rectangle contains the coordinates of the LL and UR
+    coordinates in pixel: the maxy in the rect object should be < miny
+    value. Returns MS_SUCCESS or MS_FAILURE.
+              ------- UR (values in the rect object : maxx, maxy)
+              LL (values in the rectobject minx, miny)
 zoomScale( float scale, pointObj_ imgpoint, int width, int height, rectObj_ extent, rectObj_ maxextent) : int
     Like the previous methods, but zooms to the point at a specified scale.
Modified: trunk/docs/en/mapscript/php/index.txt
--- trunk/docs/en/mapscript/php/index.txt	2010-10-26 13:51:18 UTC (rev 10673)
+++ trunk/docs/en/mapscript/php/index.txt	2010-10-26 14:11:02 UTC (rev 10674)
@@ -1315,19 +1315,7 @@
     Set the map extents to a given extents. Returns MS_SUCCESS or MS_FAILURE on error.
     Parameters are :
-        - oPixelExt (rect object) : Pixel Extents, with (0,0) at the top-left
-          The rectangle contains the coordinates of the LL and UR coordinates
-          in pixel. (the maxy in the rect object should be < miny value)
-              ------- UR (values in the rect object : maxx, maxy)
-              LL (values in the rectobject minx, miny)
+        - oPixelExt (rect object) : Pixel Extents
         - Width : width in pixel of the current image.
         - Height : Height in pixel of the current image.
         - Georef extent (rectObj) : current georef extents.
