[mapserver-commits] r10504 - in sandbox/mapserver6: . mapscript/php
Mon Sep 13 15:05:06 EDT 2010
Author: aboudreault
Date: 2010-09-13 19:05:06 +0000 (Mon, 13 Sep 2010)
New Revision: 10504
   sandbox/mapserver6/mapagg.cpp
   sandbox/mapserver6/mapscript/php/class.c
   sandbox/mapserver6/mapscript/php/image.c
   sandbox/mapserver6/mapscript/php/mapscript_i.c
   sandbox/mapserver6/maputil.c
Fixed PHP/MapScript to use proper functions of mapserver 6 rendering
Modified: sandbox/mapserver6/mapagg.cpp
--- sandbox/mapserver6/mapagg.cpp	2010-09-11 16:05:20 UTC (rev 10503)
+++ sandbox/mapserver6/mapagg.cpp	2010-09-13 19:05:06 UTC (rev 10504)
@@ -631,7 +631,7 @@
 	rendering_buffer b(overlay->data.rgba.pixels, overlay->width, overlay->height, overlay->data.rgba.row_step);
 	pixel_format pf(b);
 	AGG2Renderer *r = AGG_RENDERER(dest);
-	r->m_renderer_base.blend_from(pf,0, 0, 0,unsigned(opacity * 255));
+	r->m_renderer_base.blend_from(pf,0, dstX, dstY,unsigned(opacity * 255));
 	return MS_FAILURE;
Modified: sandbox/mapserver6/mapscript/php/class.c
--- sandbox/mapserver6/mapscript/php/class.c	2010-09-11 16:05:20 UTC (rev 10503)
+++ sandbox/mapserver6/mapscript/php/class.c	2010-09-13 19:05:06 UTC (rev 10504)
@@ -652,10 +652,10 @@
     php_map = (php_map_object *) zend_object_store_get_object(php_layer->parent.val TSRMLS_CC);
-    if (!(MS_DRIVER_GD(php_image->image->format)|| MS_DRIVER_AGG(php_image->image->format)))
+    if (!MS_RENDERER_PLUGIN(php_image->image->format))
         mapscript_report_mapserver_error(E_WARNING TSRMLS_CC);
-        mapscript_report_php_error(E_WARNING, "DrawLegendicon function is only available for GD and AGG drivers" TSRMLS_CC);
+        mapscript_report_php_error(E_WARNING, "DrawLegendicon function is only available for renderer plugin drivers" TSRMLS_CC);
         RETURN_LONG(MS_FAILURE);
Modified: sandbox/mapserver6/mapscript/php/image.c
--- sandbox/mapserver6/mapscript/php/image.c	2010-09-11 16:05:20 UTC (rev 10503)
+++ sandbox/mapserver6/mapscript/php/image.c	2010-09-13 19:05:06 UTC (rev 10504)
@@ -180,7 +180,9 @@
     zval *zimage;
     zval *zobj = getThis();
     php_image_object *php_image, *php_imageSrc;
-    int oldTransparentColor, newTransparentColor=-1, r, g, b;
+    /*int oldTransparentColor, newTransparentColor=-1, r, g, b;*/
+    rendererVTableObj *renderer = NULL;
+    rasterBufferObj rb;
     PHP_MAPSCRIPT_ERROR_HANDLING(TRUE);
     if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "Ol|lll",
@@ -199,11 +201,11 @@
     php_image = (php_image_object *) zend_object_store_get_object(zobj TSRMLS_CC);
     php_imageSrc = (php_image_object *) zend_object_store_get_object(zimage TSRMLS_CC);
-    if( (!MS_DRIVER_GD(php_imageSrc->image->format) && !MS_DRIVER_AGG(php_imageSrc->image->format)) ||
- 	(!MS_DRIVER_GD(php_image->image->format) && !MS_DRIVER_AGG(php_image->image->format)))
+    if (!MS_RENDERER_PLUGIN(php_imageSrc->image->format) ||
+ 	!MS_RENDERER_PLUGIN(php_image->image->format))
-            mapscript_throw_exception("PasteImage function should only be used with GD or AGG images." TSRMLS_CC);
+            mapscript_throw_exception("PasteImage function should only be used with GD, AGG or CAIRO images." TSRMLS_CC);
             return;
@@ -214,11 +216,18 @@
       msAlphaAGG2GD(php_image->image);
 #endif
+    renderer = MS_IMAGE_RENDERER(php_image->image);
+    memset(&rb,0,sizeof(rasterBufferObj));
+    renderer->getRasterBufferHandle(php_imageSrc->image, &rb);
+    renderer->mergeRasterBuffer(php_image->image, &rb, 1.0, 0, 0, dstx, dsty, rb.width, rb.height);
     /* Look for r,g,b in color table and make it transparent.
      * will return -1 if there is no exact match which will result in
      * no transparent color in the call to gdImageColorTransparent().
-    if (transparent != -1)
+/*    if (transparent != -1)
         r = (transparent / 0x010000) & 0xff;
         g = (transparent / 0x0100) & 0xff;
@@ -237,7 +246,7 @@
                            0, 0, php_imageSrc->image->img.gd->sx, php_imageSrc->image->img.gd->sy,
                            angle);
-    gdImageColorTransparent(php_imageSrc->image->img.gd, oldTransparentColor);
+                           gdImageColorTransparent(php_imageSrc->image->img.gd, oldTransparentColor);*/
     RETURN_LONG(MS_SUCCESS);
@@ -260,12 +269,7 @@
     php_map_object *php_map;
     int status = MS_SUCCESS;
     /* stdout specific vars */
-    char *imagePath = NULL;
-    char *pBuf = NULL;
     int size=0;
-    int   b;
-    FILE *tmp = NULL;
-    char  buf[4096];
     void *iptr=NULL;
@@ -301,7 +305,7 @@
-    if( MS_DRIVER_GD(php_image->image->format) || MS_DRIVER_AGG(php_image->image->format))
+    if (MS_RENDERER_PLUGIN(php_image->image->format))
         iptr = (void *)msSaveImageBuffer(php_image->image, &size, php_image->image->format);
@@ -310,44 +314,7 @@
         iptr = php_image->image->img.imagemap;
         size = strlen(php_image->image->img.imagemap);
-    else if (MS_DRIVER_SVG(php_image->image->format))
-        status = MS_FAILURE;
-        if (imagePath)
-            pBuf = msTmpFile(NULL, imagePath, "svg");
-            tmp = fopen(pBuf, "w");
-        if (tmp == NULL)
-            mapscript_throw_mapserver_exception("Unable to open temporary file for SVG output." TSRMLS_CC);
-            return;
-        if (msSaveImagetoFpSVG(php_image->image, tmp) == MS_SUCCESS)
-            fclose(tmp);
-            tmp = fopen(pBuf, "r");
-            while ((b = fread(buf, 1, sizeof(buf), tmp)) > 0)
-                php_write(buf, b TSRMLS_CC);
-            fclose(tmp);
-            status = MS_SUCCESS;
-        else
-            return;
-        RETURN_LONG(status);
     if (size == 0) {
         mapscript_throw_mapserver_exception("Failed writing image to stdout" TSRMLS_CC);
         return;
Modified: sandbox/mapserver6/mapscript/php/mapscript_i.c
--- sandbox/mapserver6/mapscript/php/mapscript_i.c	2010-09-11 16:05:20 UTC (rev 10503)
+++ sandbox/mapserver6/mapscript/php/mapscript_i.c	2010-09-13 19:05:06 UTC (rev 10504)
@@ -1288,7 +1288,7 @@
     msFreeShape(shape); /* frees all lines and points before re-filling */
     msSHPReadShape(self->hSHP, i, shape);
-    msTransformShapeToPixel(shape, map->extent, map->cellsize);
+    msTransformShapeToPixel(shape, map->extent, map->cellsize, MS_SIMPLIFY_DEFAULT);
     return 0;
Modified: sandbox/mapserver6/maputil.c
--- sandbox/mapserver6/maputil.c	2010-09-11 16:05:20 UTC (rev 10503)
+++ sandbox/mapserver6/maputil.c	2010-09-13 19:05:06 UTC (rev 10504)
@@ -755,6 +755,7 @@
             msBufferInit(&buffer);
             renderer->getRasterBufferHandle(image,&data);
             msSaveRasterBufferToBuffer(&data,&buffer,format);
+            *size_ptr = buffer.size;
             return buffer.data;
             //don't free the bufferObj as we don't own the bytes anymore
         } else {
