[mapserver-commits] r10543 - trunk/docs/en/ogc
Wed Sep 29 23:17:20 EDT 2010
Author: warmerdam
Date: 2010-09-30 03:17:20 +0000 (Thu, 30 Sep 2010)
New Revision: 10543
   trunk/docs/en/ogc/wms_client.txt
Updated to reflect the following changes:
 - GDAL is now required for WMS client support for MapServer 6.
 - Support for wms_extent for request restriction (#3543)
 - Reflect that files not normally written to disk now (#3555)
 - Support for wms_nonsquare_ok item (#3409)
Modified: trunk/docs/en/ogc/wms_client.txt
--- trunk/docs/en/ogc/wms_client.txt	2010-09-30 02:59:44 UTC (rev 10542)
+++ trunk/docs/en/ogc/wms_client.txt	2010-09-30 03:17:20 UTC (rev 10543)
@@ -42,8 +42,8 @@
 The WMS connection type is enabled by the *--with-wmsclient* configure switch.
-It requires PROJ4, libcurl version 7.10.1 or more recent, and optionally GDAL
-(see below).  Windows users who do not want to compile MapServer should use
+It requires PROJ4, GDAL and libcurl version 7.10.1 or more recent.   Windows
+users who do not want to compile MapServer should use
 `MS4W`_ (which comes ready for WMS/WFS client and server use), or check for the
 availability of other :ref:`Windows binaries <windows>` with WMS support.
@@ -53,15 +53,6 @@
   (if your system came with an older version of libcurl preinstalled then you MUST
   uninstall it prior to installing the new version)
-You might want to also include GDAL support if you want your application to be
-able to reproject map slides received from remote servers. This is because raster
-resampling works only together with the GDAL library in MapServer. If GDAL is not
-included in your MapServer build then your application can only serve maps in the
-subset of the projections supported by all the remote servers (this should be
-sufficient for most applications). If you compile with GDAL then make sure that
-your GDAL includes GIF and/or PNG support, depending on which image format you
-request from remote servers.
 Once the required libraries are installed, then configure MapServer using the
 *--with-wmsclient* switch (plus all the other switches you used to use) and recompile.
 This will give you a new set of executables (and possibly php_mapscript.so if you
@@ -142,10 +133,11 @@
 Storing Temporary Files
-You have to set the IMAGEPATH value in the WEB object of your mapfile to point to a valid and
+Before version 6.0, and in version 6.0 when wms_cache_to_disk metadata is turned on,
+you have to set the IMAGEPATH value in the WEB object of your mapfile to point to a valid and
 writable directory. MapServer will use this directory to store temporary files downloaded from
 the remote servers. The temporary files are automatically deleted by MapServer so you won't
-notice them... but a valid IMAGEPATH is still required.
+notice them.
 Example 3. Setting IMAGEPATH Parameter in Mapfile
@@ -247,7 +239,8 @@
   This will allow MapServer to request the layer only at scales where it makes sense
 - **PROJECTION object**
-  - it is optional at this point. MapServer will create one internally if needed.
+  - it is optional at this point. MapServer will create one internally if needed.  Including one may
+    allow MapServer to avoid looking up a definition in the PROJ.4 init files.
 - **"wms_auth_username" metadata**
   - msEncrypt-style authorization string.  Empty strings are also accepted.
@@ -424,6 +417,25 @@
 - **"wms_transparent" metadata**
   - specifies whether the map background is to be made transparent or not. TRANSPARENT can take on two values, "TRUE" or "FALSE".  If not specified, MapServer sets default to "TRUE"
+- **"wms_cache_to_disk" metadata**
+  - set this to "1" to force MapServer to write fetched images to disk.  Writing to disk
+  is necessary to take advantage of MapServer's caching logic to avoid refetching WMS
+  requests made previously.  This feature is new to MapServer 6.0 - previously results were always written
+  to disk.
+- **"wms_nonsquare_ok" metadata**
+  - set this to "0" to indicate that the remote WMS only supports requests for square pixels.  In this
+  case MapServer will be careful to only make square pixel requests even if it means oversampling in one
+  dimension compared to the resolution of image data required.  This feature is new to MapServer 6.0.
+- **"wms_extent" metadata**
+  - If there is exactly one SRS supported by this layer (as listed in the wms_srs metadata), and if
+  the wms_extent metadata item (or an extent specified via the EXTENT keyword) is set then MapServer will
+  take care to only making requests within this area.  This can short circuit requests completely outside
+  the layer, reduce processing for layers that only partially overlap the target map area and avoid poor
+  behaviors with reprojection in some areas.  The contents of this metadata item should be of the form
+  "minx miny maxx maxy".  This feature is new to MapServer 6.0.
 .. note::
     Note that each of the above metadata can also be referred to as 'ows_*' instead of 'wms_*'.
