[mapserver-commits] r12004 - branches/branch-6-0/docs/en/mapfile trunk/docs/en/mapfile
Fri Aug 5 06:36:15 EDT 2011
Author: havatv
Date: 2011-08-05 03:36:14 -0700 (Fri, 05 Aug 2011)
New Revision: 12004
   branches/branch-6-0/docs/en/mapfile/style.txt
   trunk/docs/en/mapfile/style.txt
Fixed error in size units in the style document (#3944)
Modified: branches/branch-6-0/docs/en/mapfile/style.txt
--- branches/branch-6-0/docs/en/mapfile/style.txt	2011-08-05 10:10:14 UTC (rev 12003)
+++ branches/branch-6-0/docs/en/mapfile/style.txt	2011-08-05 10:36:14 UTC (rev 12004)
@@ -175,24 +175,24 @@
     .. versionadded:: 6.0 moved from :ref:`SYMBOL`
 MAXSIZE [double]
-    Maximum size in layer `SIZEUNITS` to draw a symbol. Default is
-    500.  Starting from version 5.4, the value can also be a decimal
-    value (and not only integer).
+    Maximum size in pixels to draw a symbol. Default is 500.  Starting
+    from version 5.4, the value can also be a decimal value (and not
+    only integer).
 MAXWIDTH [double]
-    Maximum width in layer `SIZEUNITS` to draw the line work. Default is 32.
-    Starting from version 5.4, the value can also be a decimal
+    Maximum width in pixels to draw the line work. Default is 32.
+    Starting from version 5.4, the value can also be a decimal value
+    (and not only integer).
 MINSIZE [double]
-    Minimum size in layer `SIZEUNITS` to draw a symbol. Default is 0.  Starting
-    from version 5.4, the value can also be a decimal value (and
-    not only integer).
+    Minimum size in pixels to draw a symbol. Default is 0.  Starting
+    only integer).
 MINWIDTH [double]
-    Minimum width in layer `SIZEUNITS` to draw the line work. Default
-    is 0.  Starting from version 5.4, the value can also be a decimal
+    Minimum width in pixels to draw the line work. Default is 0.
 OFFSET [x][y]
     Geometry offset values in layer `SIZEUNITS`.
Modified: trunk/docs/en/mapfile/style.txt
--- trunk/docs/en/mapfile/style.txt	2011-08-05 10:10:14 UTC (rev 12003)
+++ trunk/docs/en/mapfile/style.txt	2011-08-05 10:36:14 UTC (rev 12004)
 MAXSIZE [double]
+    only integer).
 MAXWIDTH [double]
 MINSIZE [double]
+    only integer).
 MINWIDTH [double]
 OFFSET [x][y]
