[mapserver-commits] r12079 - sandbox/inspire_soc2011/mapserver
Fri Aug 19 11:09:17 EDT 2011
Author: stefanl
Date: 2011-08-19 08:09:17 -0700 (Fri, 19 Aug 2011)
New Revision: 12079
   sandbox/inspire_soc2011/mapserver/mapwms.c
   sandbox/inspire_soc2011/mapserver/rfc73.rst
msWMSGetMap also requires requested_language for %language% substitution
Modified: sandbox/inspire_soc2011/mapserver/mapwms.c
--- sandbox/inspire_soc2011/mapserver/mapwms.c	2011-08-19 14:59:12 UTC (rev 12078)
+++ sandbox/inspire_soc2011/mapserver/mapwms.c	2011-08-19 15:09:17 UTC (rev 12079)
@@ -2190,7 +2190,7 @@
   char **tokens = NULL;
   int numtokens = 0;
   char *validated_language = NULL;
   updatesequence = msOWSLookupMetadata(&(map->web.metadata), "MO", "updatesequence");
   sldenabled = msOWSLookupMetadata(&(map->web.metadata), "MO", "sld_enabled");
@@ -3161,19 +3161,34 @@
 ** msWMSGetMap()
 int msWMSGetMap(mapObj *map, int nVersion, char **names, char **values, int numentries,
-                char *wms_exception_format, owsRequestObj *ows_request)
+                char *wms_exception_format, owsRequestObj *ows_request, const char *requested_language)
   imageObj *img;
   int i = 0;
   int sldrequested = MS_FALSE,  sldspatialfilter = MS_FALSE;
   const char *http_max_age;
+  char *validated_language = NULL;
+  /* This function owns validated_language, so remember to free it later*/
+  validated_language = msOWSGetInspireLanguage(map, "MO", requested_language);
+  if (validated_language != NULL)
+      for(i=0; i<map->numlayers; i++)
+         layerObj *layer = GET_LAYER(map, i);
+         if(layer->data) layer->data = msCaseReplaceSubstring(layer->data, "%language%", validated_language);
+         if(layer->connection) layer->connection = msCaseReplaceSubstring(layer->connection, "%language%", validated_language);
+  msFree(validated_language);
   /* __TODO__ msDrawMap() will try to adjust the extent of the map */
   /* to match the width/height image ratio. */
   /* The spec states that this should not happen so that we can deliver */
   /* maps to devices with non-square pixels. */
 /* If there was an SLD in the request, we need to treat it */
 /* diffrently : some SLD may contain spatial filters requiring */
 /* to do a query. While parsing the SLD and applying it to the */
@@ -4520,7 +4535,7 @@
   if (strcasecmp(request, "map") == 0 || strcasecmp(request, "GetMap") == 0)
-     return msWMSGetMap(map, nVersion, req->ParamNames, req->ParamValues, req->NumParams, wms_exception_format, ows_request);
+     return msWMSGetMap(map, nVersion, req->ParamNames, req->ParamValues, req->NumParams, wms_exception_format, ows_request, language);
   else if (strcasecmp(request, "feature_info") == 0 || strcasecmp(request, "GetFeatureInfo") == 0)
     return msWMSFeatureInfo(map, nVersion, req->ParamNames, req->ParamValues, req->NumParams, wms_exception_format, ows_request);
   else if (strcasecmp(request, "DescribeLayer") == 0)
Modified: sandbox/inspire_soc2011/mapserver/rfc73.rst
--- sandbox/inspire_soc2011/mapserver/rfc73.rst	2011-08-19 14:59:12 UTC (rev 12078)
+++ sandbox/inspire_soc2011/mapserver/rfc73.rst	2011-08-19 15:09:17 UTC (rev 12079)
@@ -307,6 +307,7 @@
   [S] int msDumpLayer(.., const char *validated_language)
   [S] void msWMSPrintNestedGroups(.., const char *validated_language)
   [S] int msWMSGetCapabilities(.., const char *requested_language)
+  [S] int msWMSGetMap(.., const char *requested_language)
   [C] int msWMSLoadGetMapParams(..)
   [C] int msWMSDescribeLayer(..)
