[mapserver-commits] r12100 - branches/branch-6-0/docs/en/mapfile trunk/docs/en/mapfile
Tue Aug 23 09:37:01 EDT 2011
Author: havatv
Date: 2011-08-23 06:37:01 -0700 (Tue, 23 Aug 2011)
New Revision: 12100
   branches/branch-6-0/docs/en/mapfile/legend.txt
   trunk/docs/en/mapfile/legend.txt
Added indexes (#4001)
Modified: branches/branch-6-0/docs/en/mapfile/legend.txt
--- branches/branch-6-0/docs/en/mapfile/legend.txt	2011-08-23 13:31:07 UTC (rev 12099)
+++ branches/branch-6-0/docs/en/mapfile/legend.txt	2011-08-23 13:37:01 UTC (rev 12100)
@@ -1,14 +1,17 @@
 .. _legend:
+.. index:: LEGEND
  LEGEND
-.. index:: LEGEND
 The size of the legend image is NOT known prior to creation so be careful
 not to hard-code width and height in the <IMG> tag in the template file.
+.. index::
+   pair: LEGEND; IMAGECOLOR
 IMAGECOLOR [r] [g] [b]
     Color to initialize the legend with (i.e. the background).
@@ -19,30 +22,54 @@
     .. deprecated:: 4.6
+.. index::
+   pair: LEGEND; KEYSIZE
+KEYSIZE [x][y]
+    Size of symbol key boxes in pixels. Default is 20 by 10.
+.. index::
+   pair: LEGEND; KEYSPACING
+KEYSPACING [x][y]
+    Spacing between symbol key boxes ([y]) and labels ([x]) in pixels.
+    Default is 5 by 5.
+.. index::
+   pair: LEGEND; LABEL
 :ref:`LABEL`
     Signals the start of a :ref:`LABEL` object
+.. index::
+   pair: LEGEND; OUTLINECOLOR
 OUTLINECOLOR [r] [g] [b]
     Color to use for outlining symbol key boxes.
+.. index::
+   pair: LEGEND; POSITION
 POSITION [ul|uc|ur|ll|lc|lr]
     Where to place an embedded legend in the map. Default is lr.
-KEYSIZE [x][y]
-    Size of symbol key boxes in pixels. Default is 20 by 10.
-KEYSPACING [x][y]
-    Spacing between symbol key boxes ([y]) and labels ([x]) in pixels.
-    Default is 5 by 5.
+.. index::
+   pair: LEGEND; POSTLABELCACHE
 POSTLABELCACHE [true|false]
     Tells MapServer to render this legend after all labels in the cache have
     been drawn. Useful for adding neatlines and similar elements.
     Default is false.
+.. index::
+   pair: LEGEND; STATUS
 STATUS [on|off|embed]
     Is the legend image to be created.
+.. index::
+   pair: LEGEND; TEMPLATE
 TEMPLATE [filename]
     HTML legend template file.
@@ -50,6 +77,9 @@
         :ref:`html_legend`
+.. index::
+   pair: LEGEND; TRANSPARENT
 TRANSPARENT [on|off]
     Should the background color for the legend be transparent.
     This flag is now deprecated in favor of declaring transparency within
Modified: trunk/docs/en/mapfile/legend.txt
--- trunk/docs/en/mapfile/legend.txt	2011-08-23 13:31:07 UTC (rev 12099)
+++ trunk/docs/en/mapfile/legend.txt	2011-08-23 13:37:01 UTC (rev 12100)
@@ -1,14 +1,17 @@
 .. _legend:
+.. index:: LEGEND
  LEGEND
-.. index:: LEGEND
+.. index::
@@ -19,30 +22,54 @@
     .. deprecated:: 4.6
+.. index::
+KEYSIZE [x][y]
+.. index::
+KEYSPACING [x][y]
+.. index::
 :ref:`LABEL`
+.. index::
+.. index::
-KEYSIZE [x][y]
-KEYSPACING [x][y]
+.. index::
     Default is false.
+.. index::
+.. index::
 TEMPLATE [filename]
@@ -50,6 +77,9 @@
         :ref:`html_legend`
+.. index::
