[mapserver-commits] r12110 - branches/branch-6-0/docs/en/optimization trunk/docs/en/optimization
Wed Aug 24 09:36:39 EDT 2011
Author: havatv
Date: 2011-08-24 06:36:39 -0700 (Wed, 24 Aug 2011)
New Revision: 12110
   branches/branch-6-0/docs/en/optimization/fastcgi.txt
   trunk/docs/en/optimization/fastcgi.txt
Added examples on how to use fastCGI (#3123).
Modified: branches/branch-6-0/docs/en/optimization/fastcgi.txt
--- branches/branch-6-0/docs/en/optimization/fastcgi.txt	2011-08-24 09:18:12 UTC (rev 12109)
+++ branches/branch-6-0/docs/en/optimization/fastcgi.txt	2011-08-24 13:36:39 UTC (rev 12110)
@@ -87,10 +87,38 @@
       -appConnTimeout 60 -idle-timeout 60 -init-start-delay 1
       -minProcesses 2 -maxClassProcesses 20 -startDelay 5
-4.  Install a copy of the mapserv executable into the cgi-bin directory
-    with the extension .fcgi (ie. mapserv.fcgi).  Use this executable when
-    you want to utilize fastcgi support.
+4.  Install a copy of the mapserv executable (originally **mapserv**
+    or **mapserv.exe**) into the cgi-bin directory with the extension
+    **.fcgi** (ie. **mapserv.fcgi**).  Use this executable when you
+    want to utilize fastcgi support.
+    For some platforms, the Mapserver link would then have to changed
+    from:
+      http://your.domain.name/cgi-bin/mapserv?MAP=/path/to/mapfile.map
+    To:
+      http://your.domain.name/cgi-bin/mapserv.fcgi?MAP=/path/to/mapfile.map
+    For other platforms, the Mapserver link would then have to changed
+    from:
+      http://your.domain.name/cgi-bin/mapserv.exe?MAP=/path/to/mapfile.map
+    To:
 5.  In your mapfile, set a PROCESSING directive to tell FastCGI to cache
     the connections and layer information on all layers for which connection
     caching is desired - ie. all slow layers.
Modified: trunk/docs/en/optimization/fastcgi.txt
--- trunk/docs/en/optimization/fastcgi.txt	2011-08-24 09:18:12 UTC (rev 12109)
+++ trunk/docs/en/optimization/fastcgi.txt	2011-08-24 13:36:39 UTC (rev 12110)
@@ -87,10 +87,38 @@
+    from:
+    To:
+    from:
+    To:
