[mapserver-commits] r12162 - in trunk/mapserver/mapcache: . include src
Fri Aug 26 07:03:23 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:03:23 -0700 (Fri, 26 Aug 2011)
New Revision: 12162
Added:
   trunk/mapserver/mapcache/src/geocache_seed.c
   trunk/mapserver/mapcache/Makefile.inc.in
   trunk/mapserver/mapcache/include/geocache.h
   trunk/mapserver/mapcache/src/Makefile
   trunk/mapserver/mapcache/src/fastcgi_geocache.c
   trunk/mapserver/mapcache/src/mod_geocache.c
   trunk/mapserver/mapcache/src/util.c
add benchmarking script
thomas.bonfort | 2010-11-11 10:40:32 +0100 (Thu, 11 Nov 2010)
Modified: trunk/mapserver/mapcache/Makefile.inc.in
--- trunk/mapserver/mapcache/Makefile.inc.in	2011-08-26 11:03:16 UTC (rev 12161)
+++ trunk/mapserver/mapcache/Makefile.inc.in	2011-08-26 11:03:23 UTC (rev 12162)
@@ -1,4 +1,4 @@
-TARGETS=@TARGETS@
+TARGETS=@TARGETS@ geocache_seed
 APXS=@APXS@
 CC=@CC@
 APACHECTL=@APACHECTL@
@@ -33,6 +33,6 @@
-OBJS=$(shell find . -regex '^.*\.c$$' -print | grep -v mod_geocache.c | grep -v fastcgi_geocache.c |sed "s/^\(.*\)\.c$$/\1.o/")
-LOBJS=$(shell find . -regex '^.*\.c$$' -print | grep -v mod_geocache.c | grep -v fastcgi_geocache.c | sed "s/^\(.*\)\.c$$/\1.lo/")
+OBJS=$(shell find . -regex '^.*\.c$$' -print | grep -v geocache_seed.c | grep -v mod_geocache.c | grep -v fastcgi_geocache.c |sed "s/^\(.*\)\.c$$/\1.o/")
+LOBJS=$(shell find . -regex '^.*\.c$$' -print | grep -v geocache_seed.c | grep -v mod_geocache.c | grep -v fastcgi_geocache.c | sed "s/^\(.*\)\.c$$/\1.lo/")
 APXS_WCFLAGS=$(shell for flag in $(GC_CFLAGS); do echo "-Wc,$$flag "; done)
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:03:16 UTC (rev 12161)
+++ trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:03:23 UTC (rev 12162)
@@ -89,7 +89,7 @@
     * \brief query context to know if an error has occured
     * \memberof geocache_context
-   int (*get_error)(geocache_context *ctx);
+   geocache_error_code (*get_error)(geocache_context *ctx);
     * \brief get human readable message for the error
@@ -131,9 +131,11 @@
    apr_pool_t *pool;
    char *_errmsg;
-   int _errcode;
+   geocache_error_code _errcode;
+void geocache_context_init(geocache_context *ctx);
 #define GC_CHECK_ERROR_RETURN(ctx) (if(((geocache_context*)ctx)->_errcode) return GEOCACHE_FAILURE;)
 #define GC_CHECK_ERROR(ctx) if(((geocache_context*)ctx)->_errcode) return;
 #define GC_HAS_ERROR(ctx) (((geocache_context*)ctx)->_errcode > 0)
Modified: trunk/mapserver/mapcache/src/Makefile
--- trunk/mapserver/mapcache/src/Makefile	2011-08-26 11:03:16 UTC (rev 12161)
+++ trunk/mapserver/mapcache/src/Makefile	2011-08-26 11:03:23 UTC (rev 12162)
@@ -22,8 +22,11 @@
 geocache.fcgi: fastcgi_geocache.c $(OBJS)
 	$(LIBTOOL) --mode=link $(CC) -o geocache.fcgi $(GC_CFLAGS) $(APR_CFLAGS) $(FCGI_INC) fastcgi_geocache.c $(LOBJS) $(GC_LIBS) $(APR_LIBS) $(FCGI_LIB)
+geocache_seed: geocache_seed.c $(OBJS)
+	$(LIBTOOL) --mode=link $(CC) -o geocache_seed $(GC_CFLAGS) $(APR_CFLAGS) geocache_seed.c $(LOBJS) $(GC_LIBS) $(APR_LIBS)
 clean:
 	rm -f *.o
 	rm -f *.so
Modified: trunk/mapserver/mapcache/src/fastcgi_geocache.c
--- trunk/mapserver/mapcache/src/fastcgi_geocache.c	2011-08-26 11:03:16 UTC (rev 12161)
+++ trunk/mapserver/mapcache/src/fastcgi_geocache.c	2011-08-26 11:03:23 UTC (rev 12162)
@@ -66,9 +66,7 @@
 void init_fcgi_context(geocache_context_fcgi *ctx) {
-   ctx->ctx.set_error = fcgi_context_set_error;
-   ctx->ctx.get_error = fcgi_context_get_error;
-   ctx->ctx.get_error_message = fcgi_context_get_error_message;
+   geocache_context_init((geocache_context*)ctx);
    ctx->ctx.log = fcgi_context_log;
Added: trunk/mapserver/mapcache/src/geocache_seed.c
--- trunk/mapserver/mapcache/src/geocache_seed.c	                        (rev 0)
+++ trunk/mapserver/mapcache/src/geocache_seed.c	2011-08-26 11:03:23 UTC (rev 12162)
@@ -0,0 +1,125 @@
+#include "geocache.h"
+#include <apr_thread_proc.h>
+#include <apr_getopt.h>
+static const apr_getopt_option_t seed_options[] = {
+    /* long-option, short-option, has-arg flag, description */
+    { "config", 'c', TRUE, "configuration file"},
+    { "tileset", 't', TRUE, "tileset to seed" },
+    { "zoom", 'z', TRUE, "min and max zoomlevels to seed" },
+    { "extent", 'e', TRUE, "extent" },
+    { "nthreads", 'n', TRUE, "number of parallel threads to use" },
+    { "help", 'h', FALSE, "show help" },
+    { NULL, 0, 0, NULL },
+static void* APR_THREAD_FUNC doseed(apr_thread_t *thd, void *data) {
+    int thread_id = (int)data;
+    int i;
+    for(i=0;i<10;i++) {
+        printf("thread %d: %d\n",thread_id,i);
+    apr_thread_exit(thd,APR_SUCCESS);
+    return NULL;
+int usage(const char *progname, char *msg) {
+    printf("%s\nusage: %s options\n"
+            "-c|--config conffile : configuration file to load\n"
+            "-t|--tileset tileset : name of the tileset to seed\n"
+            "[-z|--zoom minzoom,maxzoom] : zoomlevels to seed\n"
+            "[-e|--extent minx,miny,maxx,maxy] : extent to seed\n"
+            "[-n|--nthreads n] : number of parallel threads\n",
+            msg,progname);
+    return 1;
+int main(int argc, const char **argv) {
+    /* initialize apr_getopt_t */
+    apr_getopt_t *opt;
+    const char *configfile=NULL;
+    geocache_cfg *cfg = NULL;
+    geocache_tileset *tileset;
+    geocache_context ctx;
+    apr_thread_t **threads;
+    apr_threadattr_t *thread_attrs;
+    const char *tileset_name=NULL;
+    int *zooms = NULL;//[2];
+    double *extent = NULL;//[4];
+    int nthreads=1;
+    int optch;
+    int rv,n;
+    const char *optarg;
+    apr_initialize();
+    apr_pool_create_core(&ctx.pool);
+    geocache_context_init(&ctx);
+    cfg = geocache_configuration_create(ctx.pool);
+    apr_getopt_init(&opt, ctx.pool, argc, argv);
+    /* parse the all options based on opt_option[] */
+    while ((rv = apr_getopt_long(opt, seed_options, &optch, &optarg)) == APR_SUCCESS) {
+        switch (optch) {
+            case 'h':
+                return usage(argv[0],NULL);
+                break;
+            case 'c':
+                configfile = optarg;
+                break;
+            case 't':
+                tileset_name = optarg;
+                break;
+            case 'n':
+                nthreads = (int)strtol(optarg, NULL, 10);
+                break;
+            case 'e':
+                if ( GEOCACHE_SUCCESS != geocache_util_extract_double_list(&ctx, (char*)optarg, ',', &extent, &n) ||
+                        n != 4 || extent[0] >= extent[2] || extent[1] >= extent[3] ) {
+                    return usage(argv[0], "failed to parse extent, expecting comma separated 4 doubles");
+                break;
+            case 'z':
+                if ( GEOCACHE_SUCCESS != geocache_util_extract_int_list(&ctx, (char*)optarg, ',', &zooms, &n) ||
+                        n != 2 || zooms[0] >= zooms[1]) {
+                    return usage(argv[0], "failed to parse zooms, expecting comma separated 2 ints");
+                break;
+    if (rv != APR_EOF) {
+        return usage(argv[0],"bad options");
+    if( ! configfile ) {
+        return usage(argv[0],"config not specified");
+    } else {
+        geocache_configuration_parse(&ctx,configfile,cfg);
+        if(ctx.get_error(&ctx))
+            return usage(argv[0],ctx.get_error_message(&ctx));
+    if( ! tileset_name ) {
+        return usage(argv[0],"tileset not specified");
+    } else {
+        tileset = geocache_configuration_get_tileset(cfg,tileset_name);
+        if(!tileset) {
+            return usage(argv[0], "tileset not found in configuration");
+    if( ! nthreads ) {
+        return usage(argv[0],"failed to parse nthreads, must be int");
+    } else {
+        apr_threadattr_create(&thread_attrs, ctx.pool);
+        threads = (apr_thread_t**)apr_pcalloc(ctx.pool, nthreads*sizeof(apr_thread_t*));
+        for(n=0;n<nthreads;n++) {
+            apr_thread_create(&threads[n], thread_attrs, doseed, (void*)n, ctx.pool);
+            apr_thread_join(&rv, threads[n]);
+    return 0;
Modified: trunk/mapserver/mapcache/src/mod_geocache.c
--- trunk/mapserver/mapcache/src/mod_geocache.c	2011-08-26 11:03:16 UTC (rev 12161)
+++ trunk/mapserver/mapcache/src/mod_geocache.c	2011-08-26 11:03:23 UTC (rev 12162)
@@ -54,24 +54,6 @@
    request_rec *request;
-void apache_context_set_error(geocache_context *c, geocache_error_code code, char *message, ...) {
-   va_list args;
-   va_start(args,message);
-   c->_errmsg = apr_pvsprintf(c->pool,message,args);
-   c->_errcode = code;
-   va_end(args);
-int apache_context_get_error(geocache_context *c) {
-   return c->_errcode;
-char* apache_context_get_error_message(geocache_context *c) {
-   return c->_errmsg;
 void apache_context_server_log(geocache_context *c, geocache_log_level level, char *message, ...) {
    geocache_context_apache_server *ctx = (geocache_context_apache_server*)c;
    va_list args;
@@ -88,12 +70,6 @@
    va_end(args);
-void init_apache_context(geocache_context_apache *ctx) {
-   ctx->ctx.set_error = apache_context_set_error;
-   ctx->ctx.get_error = apache_context_get_error;
-   ctx->ctx.get_error_message = apache_context_get_error_message;
 int geocache_util_mutex_aquire(geocache_context *r, int nonblocking) {
    int ret;
    geocache_context_apache_request *ctx = (geocache_context_apache_request*)r;
@@ -121,14 +97,14 @@
 void init_apache_request_context(geocache_context_apache_request *ctx) {
-   init_apache_context((geocache_context_apache*)ctx);
    ctx->ctx.ctx.log = apache_context_request_log;
    ctx->ctx.ctx.global_lock_aquire = geocache_util_mutex_aquire;
    ctx->ctx.ctx.global_lock_release = geocache_util_mutex_release;
 void init_apache_server_context(geocache_context_apache_server *ctx) {
    ctx->ctx.ctx.log = apache_context_server_log;
Modified: trunk/mapserver/mapcache/src/util.c
--- trunk/mapserver/mapcache/src/util.c	2011-08-26 11:03:16 UTC (rev 12161)
+++ trunk/mapserver/mapcache/src/util.c	2011-08-26 11:03:23 UTC (rev 12162)
@@ -65,5 +65,37 @@
    return GEOCACHE_SUCCESS;
+geocache_error_code _geocache_context_get_error_default(geocache_context *ctx) {
+    return ctx->_errcode;
+char* _geocache_context_get_error_msg_default(geocache_context *ctx) {
+    return ctx->_errmsg;
+void _geocache_context_set_error_default(geocache_context *ctx, geocache_error_code code, char *msg, ...) {
+    char *fmt;
+    va_list args;
+    va_start(args,msg);
+    if(ctx->_errmsg) {
+        fmt=apr_psprintf(ctx->pool,"%s\n%s",ctx->_errmsg,msg);
+    } else {
+        fmt=msg;
+        ctx->_errcode = code;
+    ctx->_errmsg = apr_pvsprintf(ctx->pool,fmt,args);
+    va_end(args);
+void geocache_context_init(geocache_context *ctx) {
+    ctx->_errcode = GEOCACHE_NO_ERROR;
+    ctx->_errmsg = NULL;
+    ctx->get_error = _geocache_context_get_error_default;
+    ctx->get_error_message = _geocache_context_get_error_msg_default;
+    ctx->set_error = _geocache_context_set_error_default;
