[mapserver-commits] r12166 - trunk/mapserver/mapcache/src
Fri Aug 26 07:03:43 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:03:43 -0700 (Fri, 26 Aug 2011)
New Revision: 12166
   trunk/mapserver/mapcache/src/configuration.c
   trunk/mapserver/mapcache/src/fastcgi_geocache.c
   trunk/mapserver/mapcache/src/imageio.c
   trunk/mapserver/mapcache/src/imageio_png.c
add two missing functions for older versions of apr
thomas.bonfort | 2010-12-09 10:25:30 +0100 (Thu, 09 Dec 2010)
Modified: trunk/mapserver/mapcache/src/configuration.c
--- trunk/mapserver/mapcache/src/configuration.c	2011-08-26 11:03:37 UTC (rev 12165)
+++ trunk/mapserver/mapcache/src/configuration.c	2011-08-26 11:03:43 UTC (rev 12166)
@@ -177,12 +177,12 @@
             ctx->set_error(ctx, GEOCACHE_PARSE_ERROR, "unknown tag %s for format \"%s\"", cur_node->name, name);
             return;
-         if(colors == -1) {
-            format = geocache_imageio_create_png_format(ctx->pool,name,compression);
-         } else {
-            format = geocache_imageio_create_png_q_format(ctx->pool,name,compression, colors);
+      if(colors == -1) {
+         format = geocache_imageio_create_png_format(ctx->pool,name,compression);
+      } else {
+         format = geocache_imageio_create_png_q_format(ctx->pool,name,compression, colors);
    } else if(!strcmp(type,"JPEG")){
       int quality = 95;
       for(cur_node = node->children; cur_node; cur_node = cur_node->next) {
Modified: trunk/mapserver/mapcache/src/fastcgi_geocache.c
--- trunk/mapserver/mapcache/src/fastcgi_geocache.c	2011-08-26 11:03:37 UTC (rev 12165)
+++ trunk/mapserver/mapcache/src/fastcgi_geocache.c	2011-08-26 11:03:43 UTC (rev 12166)
@@ -105,7 +105,7 @@
    geocache_context_fcgi *ctx = apr_pcalloc(pool, sizeof(geocache_context_fcgi));
    ctx->ctx.pool = pool;
    init_fcgi_context(ctx);
-   ret = apr_proc_mutex_create(&ctx->mutex,"/tmp/geocache.mutex",APR_LOCK_PROC_PTHREAD,pool);
+   ret = apr_proc_mutex_create(&ctx->mutex,"geocache_mutex",APR_LOCK_DEFAULT,pool);
    if(ret != APR_SUCCESS) {
       ctx->ctx.set_error(&ctx->ctx,GEOCACHE_MUTEX_ERROR,"failed to created mutex");
    } else {
@@ -176,7 +176,7 @@
       apr_table_t *params;
       geocache_context *ctx = (geocache_context*) fcgi_context_request_create(globalctx,out,err);
       geocache_tile *tile;
-      geocache_request *request;
+      geocache_request *request = NULL;
       char *pathInfo = FCGX_GetParam("PATH_INFO",envp);
       int i;
Modified: trunk/mapserver/mapcache/src/imageio.c
--- trunk/mapserver/mapcache/src/imageio.c	2011-08-26 11:03:37 UTC (rev 12165)
+++ trunk/mapserver/mapcache/src/imageio.c	2011-08-26 11:03:43 UTC (rev 12166)
@@ -24,14 +24,14 @@
 int geocache_imageio_image_has_alpha(geocache_image *img) {
    int i,j;
    unsigned char *ptr, *rptr = img->data;
-   for(i=0;i<img->h;i++) {
-      rptr += img->stride;
+   for(i=0;i<img->h;i++) {
       ptr = rptr;
-      for(j=0;j<img->w;i++) {
+      for(j=0;j<img->w;j++) {
          if(ptr[3]<255)
             return 1;
          ptr += 4;
+      rptr += img->stride;
    return 0;
Modified: trunk/mapserver/mapcache/src/imageio_png.c
--- trunk/mapserver/mapcache/src/imageio_png.c	2011-08-26 11:03:37 UTC (rev 12165)
+++ trunk/mapserver/mapcache/src/imageio_png.c	2011-08-26 11:03:43 UTC (rev 12166)
@@ -84,7 +84,7 @@
    img->stride = img->w * 4;
    row_pointers = apr_pcalloc(ctx->pool,img->h * sizeof(unsigned char*));
-   png_bytep rowptr = img->data;
+   unsigned char *rowptr = img->data;
       row_pointers[i] = rowptr;
       rowptr += img->stride;
@@ -95,7 +95,7 @@
    png_set_strip_16(png_ptr);
    png_set_gray_to_rgb(png_ptr);
    png_set_add_alpha(png_ptr, 0xff, PNG_FILLER_AFTER);
    png_read_update_info(png_ptr, info_ptr);
 #ifdef DEBUG
    if(img->stride != png_get_rowbytes(png_ptr, info_ptr)) {
@@ -105,6 +105,7 @@
 #endif
    png_read_image(png_ptr, row_pointers);
    png_read_end(png_ptr,NULL);
    png_destroy_read_struct(&png_ptr, &info_ptr, NULL);
@@ -153,7 +154,7 @@
       color_type = PNG_COLOR_TYPE_RGB_ALPHA;
    else
       color_type = PNG_COLOR_TYPE_RGB;
    png_set_IHDR(png_ptr, info_ptr, img->w, img->h,
          8, color_type, PNG_INTERLACE_NONE,
          PNG_COMPRESSION_TYPE_DEFAULT, PNG_FILTER_TYPE_DEFAULT);
@@ -163,6 +164,8 @@
       png_set_compression_level (png_ptr, Z_BEST_SPEED);
    png_write_info(png_ptr, info_ptr);
+   if(color_type == PNG_COLOR_TYPE_RGB)
+       png_set_filler(png_ptr, 255, PNG_FILLER_AFTER);
    for(row=0;row<img->h;row++) {
