[mapserver-commits] r12230 - in trunk/mapserver/mapcache: . include src
Fri Aug 26 07:09:08 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:09:08 -0700 (Fri, 26 Aug 2011)
New Revision: 12230
   trunk/mapserver/mapcache/configure
   trunk/mapserver/mapcache/configure.in
   trunk/mapserver/mapcache/geocache.xml
   trunk/mapserver/mapcache/include/geocache.h
   trunk/mapserver/mapcache/src/configuration.c
   trunk/mapserver/mapcache/src/lock.c
add apache-restart task
thomas.bonfort | 2011-01-10 14:58:04 +0100 (Mon, 10 Jan 2011)
Modified: trunk/mapserver/mapcache/configure
--- trunk/mapserver/mapcache/configure	2011-08-26 11:09:01 UTC (rev 12229)
+++ trunk/mapserver/mapcache/configure	2011-08-26 11:09:08 UTC (rev 12230)
@@ -1531,52 +1531,6 @@
 } # ac_fn_c_try_run
-# ac_fn_c_try_link LINENO
-# Try to link conftest.$ac_ext, and return whether this succeeded.
-ac_fn_c_try_link ()
-  as_lineno=${as_lineno-"$1"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
-  rm -f conftest.$ac_objext conftest$ac_exeext
-  if { { ac_try="$ac_link"
-case "(($ac_try" in
-  *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
-  *) ac_try_echo=$ac_try;;
-esac
-eval ac_try_echo="\"\$as_me:${as_lineno-$LINENO}: $ac_try_echo\""
-$as_echo "$ac_try_echo"; } >&5
-  (eval "$ac_link") 2>conftest.err
-  ac_status=$?
-  if test -s conftest.err; then
-    grep -v '^ *+' conftest.err >conftest.er1
-    cat conftest.er1 >&5
-    mv -f conftest.er1 conftest.err
-  fi
-  $as_echo "$as_me:${as_lineno-$LINENO}: \$? = $ac_status" >&5
-  test $ac_status = 0; } && {
-	 test -z "$ac_c_werror_flag" ||
-	 test ! -s conftest.err
-       } && test -s conftest$ac_exeext && {
-	 test "$cross_compiling" = yes ||
-	 $as_test_x conftest$ac_exeext
-       }; then :
-  ac_retval=0
-else
-  $as_echo "$as_me: failed program was:" >&5
-sed 's/^/| /' conftest.$ac_ext >&5
-	ac_retval=1
-fi
-  # Delete the IPA/IPO (Inter Procedural Analysis/Optimization) information
-  # created by the PGI compiler (conftest_ipa8_conftest.oo), as it would
-  # interfere with the next link command; also delete a directory that is
-  # left behind by Apple's compiler.  We do this before executing the actions.
-  rm -rf conftest.dSYM conftest_ipa8_conftest.oo
-  eval $as_lineno_stack; ${as_lineno_stack:+:} unset as_lineno
-  as_fn_set_status $ac_retval
-} # ac_fn_c_try_link
 # ac_fn_c_check_header_mongrel LINENO HEADER VAR INCLUDES
 # Tests whether HEADER exists, giving a warning if it cannot be compiled using
@@ -1694,6 +1648,52 @@
 } # ac_fn_c_check_header_compile
+# ac_fn_c_try_link LINENO
+# Try to link conftest.$ac_ext, and return whether this succeeded.
+ac_fn_c_try_link ()
+  as_lineno=${as_lineno-"$1"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
+  rm -f conftest.$ac_objext conftest$ac_exeext
+  if { { ac_try="$ac_link"
+case "(($ac_try" in
+  *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
+  *) ac_try_echo=$ac_try;;
+esac
+eval ac_try_echo="\"\$as_me:${as_lineno-$LINENO}: $ac_try_echo\""
+$as_echo "$ac_try_echo"; } >&5
+  (eval "$ac_link") 2>conftest.err
+  ac_status=$?
+  if test -s conftest.err; then
+    grep -v '^ *+' conftest.err >conftest.er1
+    cat conftest.er1 >&5
+    mv -f conftest.er1 conftest.err
+  fi
+  $as_echo "$as_me:${as_lineno-$LINENO}: \$? = $ac_status" >&5
+  test $ac_status = 0; } && {
+	 test -z "$ac_c_werror_flag" ||
+	 test ! -s conftest.err
+       } && test -s conftest$ac_exeext && {
+	 test "$cross_compiling" = yes ||
+	 $as_test_x conftest$ac_exeext
+       }; then :
+  ac_retval=0
+else
+  $as_echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+	ac_retval=1
+fi
+  # Delete the IPA/IPO (Inter Procedural Analysis/Optimization) information
+  # created by the PGI compiler (conftest_ipa8_conftest.oo), as it would
+  # interfere with the next link command; also delete a directory that is
+  # left behind by Apple's compiler.  We do this before executing the actions.
+  rm -rf conftest.dSYM conftest_ipa8_conftest.oo
+  eval $as_lineno_stack; ${as_lineno_stack:+:} unset as_lineno
+  as_fn_set_status $ac_retval
+} # ac_fn_c_try_link
 cat >config.log <<_ACEOF
 This file contains any messages produced by compilers while
 running configure, to aid debugging if configure makes a mistake.
@@ -3268,6 +3268,42 @@
+# On IRIX 5.3, sys/types and inttypes.h are conflicting.
+for ac_header in sys/types.h sys/stat.h stdlib.h string.h memory.h strings.h \
+		  inttypes.h stdint.h unistd.h
+do :
+  as_ac_Header=`$as_echo "ac_cv_header_$ac_header" | $as_tr_sh`
+ac_fn_c_check_header_compile "$LINENO" "$ac_header" "$as_ac_Header" "$ac_includes_default
+if eval test \"x\$"$as_ac_Header"\" = x"yes"; then :
+  cat >>confdefs.h <<_ACEOF
+#define `$as_echo "HAVE_$ac_header" | $as_tr_cpp` 1
+_ACEOF
+fi
+done
+ac_fn_c_check_header_mongrel "$LINENO" "semaphore.h" "ac_cv_header_semaphore_h" "$ac_includes_default"
+if test "x$ac_cv_header_semaphore_h" = xyes; then :
+else
+  as_fn_error $? "cannot find semaphore.h" "$LINENO" 5
+fi
+ac_fn_c_check_header_mongrel "$LINENO" "fcntl.h" "ac_cv_header_fcntl_h" "$ac_includes_default"
+if test "x$ac_cv_header_fcntl_h" = xyes; then :
+else
+  as_fn_error $? "cannot find fcntl.h" "$LINENO" 5
+fi
 # Check whether --enable-module was given.
 if test "${enable_module+set}" = set; then :
   enableval=$enable_module;
@@ -3511,25 +3547,8 @@
     fi
 fi
-# On IRIX 5.3, sys/types and inttypes.h are conflicting.
-for ac_header in sys/types.h sys/stat.h stdlib.h string.h memory.h strings.h \
-		  inttypes.h stdint.h unistd.h
-do :
-  as_ac_Header=`$as_echo "ac_cv_header_$ac_header" | $as_tr_sh`
-ac_fn_c_check_header_compile "$LINENO" "$ac_header" "$as_ac_Header" "$ac_includes_default
-if eval test \"x\$"$as_ac_Header"\" = x"yes"; then :
-  cat >>confdefs.h <<_ACEOF
-#define `$as_echo "HAVE_$ac_header" | $as_tr_cpp` 1
-_ACEOF
-fi
-done
 # Check whether --with-fastcgi was given.
 if test "${with_fastcgi+set}" = set; then :
   withval=$with_fastcgi;
@@ -3781,7 +3800,7 @@
     APR_INC=`$APRCONFIG --includes`
-    APR_LIBS=`$APRCONFIG --link-ld`
+    APR_LIBS=`$APRCONFIG --link-libtool`
     LIBTOOL=`$APRCONFIG --apr-libtool`
Modified: trunk/mapserver/mapcache/configure.in
--- trunk/mapserver/mapcache/configure.in	2011-08-26 11:09:01 UTC (rev 12229)
+++ trunk/mapserver/mapcache/configure.in	2011-08-26 11:09:08 UTC (rev 12230)
@@ -184,7 +184,7 @@
     fi
     AC_SUBST(APRCONFIG)
     AC_SUBST(APR_INC,`$APRCONFIG --includes`)
-    AC_SUBST(APR_LIBS,`$APRCONFIG --link-ld`)
+    AC_SUBST(APR_LIBS,`$APRCONFIG --link-libtool`)
     AC_SUBST(LIBTOOL, `$APRCONFIG --apr-libtool`)
@@ -399,6 +399,11 @@
 DEBUG_CHECK
+AC_CHECK_HEADER([semaphore.h],,[AC_MSG_ERROR([cannot find semaphore.h])])
+AC_CHECK_HEADER([fcntl.h],,[AC_MSG_ERROR([cannot find fcntl.h])])
 AC_ARG_ENABLE(module,
     AC_HELP_STRING([--enable-module],[Enable apache module building]),
Modified: trunk/mapserver/mapcache/geocache.xml
--- trunk/mapserver/mapcache/geocache.xml	2011-08-26 11:09:01 UTC (rev 12229)
+++ trunk/mapserver/mapcache/geocache.xml	2011-08-26 11:09:08 UTC (rev 12230)
@@ -386,13 +386,6 @@
    <merge_format>PNGQ_FAST</merge_format>
-   <!-- this is the location where locks will be stored when a tile
-        is not in the cache.
-        this directory MUST exist, and be accessible for reading and
-        writing by the user running apache (usually www-data or nobody)
-   <lock_dir>/tmp</lock_dir>
    <!-- services
       services that will be responded to by mod-geocache
       each service is accessible at the url http://host/path/to/geocache/{service},
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:09:01 UTC (rev 12229)
+++ trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:09:08 UTC (rev 12230)
@@ -599,11 +599,6 @@
     geocache_image_format *merge_format;
-     * directory where we store file locks
-    char *lockdir;
       * how should error messages be reported to the user
      geocache_error_reporting reporting;
Modified: trunk/mapserver/mapcache/src/configuration.c
--- trunk/mapserver/mapcache/src/configuration.c	2011-08-26 11:09:01 UTC (rev 12229)
+++ trunk/mapserver/mapcache/src/configuration.c	2011-08-26 11:09:08 UTC (rev 12230)
@@ -94,7 +94,6 @@
          geocache_imageio_create_jpeg_format(pool,"JPEG",95),
          "JPEG");
    cfg->merge_format = geocache_configuration_get_image_format(cfg,"PNG");
-   cfg->lockdir = NULL;
    cfg->reporting = GEOCACHE_REPORT_MSG;
    grid = geocache_grid_create(pool);
@@ -828,9 +827,7 @@
             config->merge_format = format;
          } else if(!xmlStrcmp(cur_node->name, BAD_CAST "lock_dir")) {
-            xmlChar *value = xmlNodeGetContent(cur_node);
-            config->lockdir = apr_pstrdup(ctx->pool, (char*)value);
-            xmlFree(value);
+            //do nothing, not used anymore
          } else {
             ctx->set_error(ctx, GEOCACHE_PARSE_ERROR, "failed to parse geocache config file %s: unknown tag <%s>",
                   filename, cur_node->name);
@@ -855,32 +852,6 @@
       return;
-   /* check our lock directory exists */
-   if(!config->lockdir) {
-      ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "no lock directory configured."
-            " You should add one with the <lock_dir> configuration tag");
-      return;
-   } else {
-      apr_dir_t *dir;
-      int ret = apr_dir_open(&dir,config->lockdir, ctx->pool);
-      if(APR_SUCCESS != ret) {
-          ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "failed to open directory %s, does it exist?",config->lockdir);
-          return;
-      apr_dir_close(dir);
-#ifdef notused
-      testlockfilename = apr_psprintf(ctx->pool,"%s/test.lock",config->lockdir);
-      if(apr_file_open(&testlockfile, testlockfilename, APR_FOPEN_CREATE|APR_FOPEN_WRITE,
-                  APR_OS_DEFAULT, ctx->pool) != APR_SUCCESS) {
-          ctx->set_error(ctx, GEOCACHE_DISK_ERROR,  "failed to create test lockfile %s",testlockfilename);
-          return; /* we could not create the file */
-      apr_file_close(testlockfile);
-      apr_file_remove(testlockfilename,ctx->pool);
-#endif
    if(!config->services[GEOCACHE_SERVICE_WMS] &&
          !config->services[GEOCACHE_SERVICE_TMS]) {
       ctx->set_error(ctx, GEOCACHE_PARSE_ERROR, "no services configured."
Modified: trunk/mapserver/mapcache/src/lock.c
--- trunk/mapserver/mapcache/src/lock.c	2011-08-26 11:09:01 UTC (rev 12229)
+++ trunk/mapserver/mapcache/src/lock.c	2011-08-26 11:09:08 UTC (rev 12230)
@@ -17,11 +17,13 @@
 #include "geocache.h"
 #include <apr_file_io.h>
 #include <apr_strings.h>
+#include <semaphore.h>
+#include <errno.h>
+#include <fcntl.h>
 char *geocache_tileset_tile_lock_key(geocache_context *ctx, geocache_tile *tile) {
   return apr_psprintf(ctx->pool,
-          "%s/%s-%d-%d-%d.lck",
-          tile->tileset->config->lockdir,
+          "%s-%d-%d-%d",
           tile->tileset->name,
           tile->z, tile->y, tile->x);
@@ -34,37 +36,14 @@
  * \private \memberof geocache_cache_disk
 void geocache_tileset_tile_lock(geocache_context *ctx, geocache_tile *tile) {
-  char *lockname;
-  apr_file_t *f;
-  apr_status_t rv;
-  lockname = geocache_tileset_tile_lock_key(ctx,tile);
-  /*create file, and fail if it already exists*/
-  if (apr_file_open(&f, lockname,
-          APR_FOPEN_CREATE | APR_FOPEN_EXCL | APR_FOPEN_WRITE | APR_FOPEN_SHARELOCK | APR_FOPEN_BUFFERED | APR_FOPEN_BINARY,
-     * opening failed, is this because we don't have write permissions, or because
-     * the file already exists?
-    if (apr_file_open(&f, lockname, APR_FOPEN_CREATE | APR_FOPEN_WRITE, APR_OS_DEFAULT, ctx->pool) != APR_SUCCESS) {
-      ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "failed to create lockfile %s", lockname);
-    } else {
-      ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "failed to create lockfile %s, because it already exists", lockname);
-      apr_file_close(f);
-      return; /* we have write access, but the file already exists */
-  rv = apr_file_lock(f, APR_FLOCK_EXCLUSIVE | APR_FLOCK_NONBLOCK);
-  if (rv != APR_SUCCESS) {
-    if (rv == EAGAIN) {
-      ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "####### TILE LOCK ######## file %s is already locked", lockname);
-    } else {
-      ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "failed to lock file %s", lockname);
-    return;
-  tile->lock = f;
+   char *lockname = geocache_tileset_tile_lock_key(ctx,tile);
+   sem_t *lock;
+   if ((lock = sem_open(lockname, O_CREAT|O_EXCL, 0644, 1)) == SEM_FAILED) {
+      ctx->set_error(ctx,GEOCACHE_MUTEX_ERROR, "failed to create pthread semaphore %s",lockname);
+      return;
+   sem_wait(lock);
+   tile->lock = lock;
@@ -74,35 +53,20 @@
  * \sa geocache_cache::tile_lock_exists()
 void geocache_tileset_tile_unlock(geocache_context *ctx, geocache_tile *tile) {
-  apr_file_t *f = (apr_file_t*) tile->lock;
-  const char *lockname;
+  sem_t *lock = (sem_t*) tile->lock;
+  int semvalue;
+  const char *lockname = geocache_tileset_tile_lock_key(ctx,tile);
   if (!tile->lock) {
-    lockname = geocache_tileset_tile_lock_key(ctx, tile);
-    ctx->log(ctx, GEOCACHE_ERROR, "###### TILE UNLOCK ######### attempting to unlock tile %s not created by this thread", lockname);
-    /*fail if the lock does not exists*/
-    if (apr_file_open(&f, lockname, APR_FOPEN_READ, APR_OS_DEFAULT, ctx->pool) != APR_SUCCESS) {
-      ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "###### TILE UNLOCK ######### tile %s is not locked", lockname);
-      return;
+     ctx->set_error(ctx,GEOCACHE_MUTEX_ERROR,"###### TILE UNLOCK ######### attempting to unlock tile %s not created by this thread", lockname);
+     return;
+  sem_post(lock);
+  sem_getvalue(lock,&semvalue);
+  if(semvalue>0) {
+     sem_unlink(lockname);
   } else {
-    f = (apr_file_t*) tile->lock;
-    apr_file_name_get(&lockname, f);
+     sem_close(lock);
-  apr_file_remove(lockname, ctx->pool);
-  int rv = apr_file_unlock(f);
-    ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "failed to unlock file %s", lockname);
-    return;
-  rv = apr_file_close(f);
-    ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "failed to close file %s", lockname);
-    return;
   tile->lock = NULL;
@@ -113,16 +77,21 @@
 int geocache_tileset_tile_lock_exists(geocache_context *ctx, geocache_tile *tile) {
   char *lockname;
-  apr_file_t *f;
   if (tile->lock)
     return GEOCACHE_TRUE;
-    return GEOCACHE_FALSE;
-  } else {
-    return GEOCACHE_TRUE;
+   sem_t *lock = sem_open(lockname, 0, 0644, 1) ;
+   if (lock == SEM_FAILED) {
+      if(errno == ENOENT) {
+         return GEOCACHE_FALSE;
+      } else {
+         ctx->set_error(ctx,GEOCACHE_MUTEX_ERROR,"lock_exists: failed to open mutex %s",lockname);
+   } else {
+      sem_close(lock);
+      return GEOCACHE_TRUE;
@@ -133,7 +102,7 @@
 void geocache_tileset_tile_lock_wait(geocache_context *ctx, geocache_tile *tile) {
   char *lockname;
-  apr_file_t *f;
+  sem_t *lock;
 #ifdef DEBUG
   if (tile->lock) {
     ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "### BUG ### waiting for a lock we have created ourself");
@@ -141,11 +110,25 @@
 #endif
-    ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "### BUG ### waiting for a lock on an unlocked file");
-    return;
+  lock = sem_open(lockname, 0, 0644, 1) ;
+  if( lock == SEM_FAILED ) {
+        /* the lock doesn't exist (anymore?) */
+        return;
+     } else {
+        ctx->set_error(ctx,GEOCACHE_MUTEX_ERROR, "lock_wait: failed to open semaphore %s",lockname);
+        return;
+  } else {
+     int semvalue;
+     sem_wait(lock);
+     sem_post(lock);
+     if(semvalue>0) {
+     } else {
+        sem_close(lock);
-  apr_file_lock(f, APR_FLOCK_SHARED);
