[mapserver-commits] r12245 - trunk/mapserver/mapcache/src
Fri Aug 26 07:10:32 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:10:32 -0700 (Fri, 26 Aug 2011)
New Revision: 12245
Added:
   trunk/mapserver/mapcache/src/dimension.c
add missing math.h
thomas.bonfort | 2011-01-13 14:57:31 +0100 (Thu, 13 Jan 2011)
Added: trunk/mapserver/mapcache/src/dimension.c
--- trunk/mapserver/mapcache/src/dimension.c	                        (rev 0)
+++ trunk/mapserver/mapcache/src/dimension.c	2011-08-26 11:10:32 UTC (rev 12245)
@@ -0,0 +1,44 @@
+ *  Copyright 2010 Thomas Bonfort
+ *  Licensed under the Apache License, Version 2.0 (the "License");
+ *  you may not use this file except in compliance with the License.
+ *  You may obtain a copy of the License at
+ *      http://www.apache.org/licenses/LICENSE-2.0
+ *  Unless required by applicable law or agreed to in writing, software
+ *  distributed under the License is distributed on an "AS IS" BASIS,
+ *  WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+ *  See the License for the specific language governing permissions and
+ *  limitations under the License.
+#include "geocache.h"
+int _geocache_dimension_values_validate(geocache_context *ctx, geocache_dimension *dimension, const char *value) {
+   int i;
+   geocache_dimension_values *dim = (geocache_dimension_values*)dimension;
+#ifdef DEBUG
+   if(dimension->type != GEOCACHE_DIMENSION_VALUES) {
+      ctx->set_error(ctx, GEOCACHE_ERROR, "##### BUG ###### dimension values 1");
+      return;
+#endif
+   for(i=0;i<dim->nvalues;i++) {
+      if(!strcmp(value,dim->values[i]))
+         return GEOCACHE_SUCCESS;
+   return GEOCACHE_FAILURE;
+geocache_dimension_values* geocache_dimension_values_create(apr_pool_t *pool) {
+   geocache_dimension_values *dimension = apr_pcalloc(pool, sizeof(geocache_dimension_values));
+   dimension->dimension.type = GEOCACHE_DIMENSION_VALUES;
+   dimension->nvalues = 0;
+   dimension->dimension.validate = _geocache_dimension_values_validate;
+   return dimension;
+/* vim: ai ts=3 sts=3 et sw=3
