[mapserver-commits] r12247 - in trunk/mapserver/mapcache: . include src
Fri Aug 26 07:10:43 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:10:43 -0700 (Fri, 26 Aug 2011)
New Revision: 12247
   trunk/mapserver/mapcache/geocache.xml
   trunk/mapserver/mapcache/include/geocache.h
   trunk/mapserver/mapcache/src/configuration.c
   trunk/mapserver/mapcache/src/dimension.c
   trunk/mapserver/mapcache/src/service_wms.c
   trunk/mapserver/mapcache/src/service_wmts.c
typo
thomas.bonfort | 2011-01-13 17:21:12 +0100 (Thu, 13 Jan 2011)
Modified: trunk/mapserver/mapcache/geocache.xml
--- trunk/mapserver/mapcache/geocache.xml	2011-08-26 11:10:36 UTC (rev 12246)
+++ trunk/mapserver/mapcache/geocache.xml	2011-08-26 11:10:43 UTC (rev 12247)
@@ -303,8 +303,8 @@
          are currently used to populate the GetCapabilities document.
       <metadata>
-         <title>osm mapserver served map of midi-pyrénées</title>
-         <abstract>see http://mapserver-utils.googlecode.com</abstract>
+         <title>vmap0 map</title>
+         <abstract>blabla</abstract>
       </metadata>
       <!-- watermark
@@ -378,6 +378,10 @@
             <values>foobar,foobarbaz,foo,bar</values>
          </dimension>
+         <dimension name="ELEVATION">
+            <default>0</default>
+            <values>0,1000,2000,3000,4000</values>
+         </dimension>
       </dimensions>
    </tileset>
    <tileset name="test2">
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:10:36 UTC (rev 12246)
+++ trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:10:43 UTC (rev 12247)
@@ -1012,37 +1012,18 @@
-typedef enum {
-   GEOCACHE_DIMENSION_VALUES,
-   GEOCACHE_DIMENSION_INTERVAL,
-   GEOCACHE_DIMENSION_REGEX
-} geocache_dimension_type;
-typedef struct geocache_dimension_entry geocache_dimension_entry;
 struct geocache_dimension {
-   geocache_dimension_type type;
    char *name;
+   char *unit;
    apr_table_t *metadata;
    char *default_value;
-   int (*validate)(geocache_context *context, geocache_dimension *dimension, const char *value);
-typedef struct geocache_dimension_values geocache_dimension_values;
-struct geocache_dimension_values {
-   geocache_dimension dimension;
    int nvalues;
    char **values;
+   int (*validate)(geocache_context *context, geocache_dimension *dimension, const char *value);
-geocache_dimension_values* geocache_dimension_values_create(apr_pool_t *pool);
+geocache_dimension* geocache_dimension_create(apr_pool_t *pool);
-typedef struct geocache_dimension_regexp geocache_dimension_regexp;
-struct geocache_dimension_regexp {
-   regex_t *regex;
 #endif /* GEOCACHE_H_ */
 /* vim: ai ts=3 sts=3 et sw=3
Modified: trunk/mapserver/mapcache/src/configuration.c
--- trunk/mapserver/mapcache/src/configuration.c	2011-08-26 11:10:36 UTC (rev 12246)
+++ trunk/mapserver/mapcache/src/configuration.c	2011-08-26 11:10:43 UTC (rev 12247)
@@ -215,21 +215,28 @@
    apr_array_header_t *dimensions = apr_array_make(ctx->pool,1,sizeof(geocache_dimension*));
    for(dimension_node = ezxml_child(node,"dimension"); dimension_node; dimension_node = dimension_node->next) {
       char *name = (char*)ezxml_attr(dimension_node,"name");
-      char *default_value, *values, *key, *last;
+      char *key, *last, *values;
       int count = 1;
+      geocache_dimension *dimension = geocache_dimension_create(ctx->pool);
       ezxml_t dchild_node;
       if(!name || !strlen(name)) {
          ctx->set_error(ctx, GEOCACHE_PARSE_ERROR, "mandatory attribute \"name\" not found in <dimension>");
          return;
-      name = apr_pstrdup(ctx->pool,name);
+      dimension->name = apr_pstrdup(ctx->pool,name);
+      dchild_node = ezxml_child(dimension_node,"unit");
+      if(dchild_node && dchild_node->txt) {
+         dimension->unit = apr_pstrdup(ctx->pool,dchild_node->txt);
       dchild_node = ezxml_child(dimension_node,"default");
       if(!dchild_node || !dchild_node->txt) {
          ctx->set_error(ctx, GEOCACHE_PARSE_ERROR, "<dimension> \"%s\" has no default value",name);
          return;
-      default_value = apr_pstrdup(ctx->pool,dchild_node->txt);
+      dimension->default_value = apr_pstrdup(ctx->pool,dchild_node->txt);
       dchild_node = ezxml_child(dimension_node,"values");
@@ -237,9 +244,6 @@
          return;
       values = apr_pstrdup(ctx->pool,dchild_node->txt);
-      geocache_dimension_values *dimension = geocache_dimension_values_create(ctx->pool);
-      dimension->dimension.name = name;
-      dimension->dimension.default_value = default_value;
       for(key=values;*key;key++) if(*key == ',') count++;
       dimension->values = (char**)apr_pcalloc(ctx->pool,count*sizeof(char*));
@@ -253,7 +257,7 @@
          ctx->set_error(ctx, GEOCACHE_PARSE_ERROR, "<dimension> \"%s\" has no values",name);
          return;
-      APR_ARRAY_PUSH(dimensions,geocache_dimension*) = (geocache_dimension*)dimension;
+      APR_ARRAY_PUSH(dimensions,geocache_dimension*) = dimension;
    if(apr_is_empty_array(dimensions)) {
       ctx->set_error(ctx, GEOCACHE_PARSE_ERROR, "<dimensions> for tileset \"%s\" has no dimensions defined (expecting <dimension> children)",tileset->name);
Modified: trunk/mapserver/mapcache/src/dimension.c
--- trunk/mapserver/mapcache/src/dimension.c	2011-08-26 11:10:36 UTC (rev 12246)
+++ trunk/mapserver/mapcache/src/dimension.c	2011-08-26 11:10:43 UTC (rev 12247)
@@ -16,27 +16,31 @@
 #include "geocache.h"
-int _geocache_dimension_values_validate(geocache_context *ctx, geocache_dimension *dimension, const char *value) {
+int _geocache_dimension_validate(geocache_context *ctx, geocache_dimension *dim, const char *value) {
    int i;
-   geocache_dimension_values *dim = (geocache_dimension_values*)dimension;
-#ifdef DEBUG
-   if(dimension->type != GEOCACHE_DIMENSION_VALUES) {
-      ctx->set_error(ctx, GEOCACHE_ERROR, "##### BUG ###### dimension values 1");
-      return;
+   if(dim->unit && !strcmp(dim->unit,"ISO8601")) {
+      for(i=0;i<dim->nvalues;i++) {
+         if(!strcmp(value,dim->values[i]))
+            return GEOCACHE_SUCCESS;
+   } else if(dim->unit && !strcmp(dim->unit,"m")) {
+   } else {
-#endif
-   for(i=0;i<dim->nvalues;i++) {
-      if(!strcmp(value,dim->values[i]))
-         return GEOCACHE_SUCCESS;
    return GEOCACHE_FAILURE;
-geocache_dimension_values* geocache_dimension_values_create(apr_pool_t *pool) {
-   geocache_dimension_values *dimension = apr_pcalloc(pool, sizeof(geocache_dimension_values));
-   dimension->dimension.type = GEOCACHE_DIMENSION_VALUES;
+geocache_dimension* geocache_dimension_create(apr_pool_t *pool) {
+   geocache_dimension *dimension = apr_pcalloc(pool, sizeof(geocache_dimension));
    dimension->nvalues = 0;
-   dimension->dimension.validate = _geocache_dimension_values_validate;
+   dimension->validate = _geocache_dimension_validate;
    return dimension;
Modified: trunk/mapserver/mapcache/src/service_wms.c
--- trunk/mapserver/mapcache/src/service_wms.c	2011-08-26 11:10:36 UTC (rev 12246)
+++ trunk/mapserver/mapcache/src/service_wms.c	2011-08-26 11:10:43 UTC (rev 12247)
@@ -21,7 +21,7 @@
-static char *wms_capabilities_preamble = "<?xml version=\"1.0\" encoding=\"ISO-8859-1\" standalone=\"no\" ?>\n"
+static char *wms_capabilities_preamble = "<?xml version=\"1.0\" encoding=\"UTF-8\" standalone=\"no\" ?>\n"
         "<!DOCTYPE WMT_MS_Capabilities SYSTEM\n"
             "\"http://schemas.opengeospatial.net/wms/1.1.1/WMS_MS_Capabilities.dtd\" [\n"
               "<!ELEMENT VendorSpecificCapabilities (TileSet*) >\n"
@@ -79,6 +79,7 @@
               "<Title>%s</Title>\n"
               "<Abstract>%s</Abstract>\n"
               "<SRS>%s</SRS>\n"
+              "%s"
               "<BoundingBox srs=\"%s\" minx=\"%f\" miny=\"%f\" maxx=\"%f\" maxy=\"%f\" />\n"
             "</Layer>\n";
@@ -108,6 +109,7 @@
       const void *key; apr_ssize_t keylen;
       apr_hash_this(tileindex_index,&key,&keylen,(void**)&tileset);
       char *resolutions="";
       int i;
       for(i=0;i<tileset->grid->levels;i++) {
          resolutions = apr_psprintf(ctx->pool,"%s%.20f ",resolutions,tileset->grid->resolutions[i]);
@@ -145,11 +147,34 @@
          if(!abstract) {
             abstract = "no abstract set, add some in metadata";
+      char *dimensions = "";
+      if(tileset->dimensions) {
+         int i;
+         for(i=0;i<tileset->dimensions->nelts;i++) {
+            geocache_dimension *dimension = APR_ARRAY_IDX(tileset->dimensions,i,geocache_dimension*);
+            dimensions = apr_psprintf(ctx->pool,"%s"
+                  "<Dimension name=\"%s\" default=\"%s\"",
+                  dimensions,
+                  dimension->name,
+                  dimension->default_value);
+            if(dimension->unit) {
+               dimensions = apr_pstrcat(ctx->pool,dimensions,
+                  " units=\"%s\"",dimension->unit,NULL);
+            dimensions = apr_pstrcat(ctx->pool,dimensions,">",dimension->values[0],NULL);
+            int j;
+            for(j=1;j<dimension->nvalues;j++) {
+               dimensions = apr_pstrcat(ctx->pool,dimensions,",",dimension->values[j],NULL);
+            dimensions = apr_pstrcat(ctx->pool,dimensions,"</Dimension>\n",NULL);
          char *layercaps = apr_psprintf(ctx->pool,wms_layer,
                tileset->name,
                title,
                abstract,
                tileset->grid->srs,
+               dimensions,
                tileset->grid->srs,
                tileset->grid->extents[0][0],
                tileset->grid->extents[0][1],
Modified: trunk/mapserver/mapcache/src/service_wmts.c
--- trunk/mapserver/mapcache/src/service_wmts.c	2011-08-26 11:10:36 UTC (rev 12246)
+++ trunk/mapserver/mapcache/src/service_wmts.c	2011-08-26 11:10:43 UTC (rev 12247)
@@ -180,6 +180,30 @@
       if(!abstract) {
+      char *dimensions="";
+         int i;
+                  "    <Dimension>\n"
+                  "      <ows:Identifier>%s</ows:Identifier>\n"
+                  "      <Default>%s</Default>\n",
+                  dimensions,
+                  dimension->name,
+               dimension = apr_pstrcat(ctx->pool,dimension,
+                  "      <UOM>",dimension->unit,"</UOM>\n",NULL);
+            int i = dimension->nvalues;
+            while(i--) {
+               dimensions = apr_pstrcat(ctx->pool,dimensions,"      <Value>",dimension->values[i],"</Value>\n",NULL);
+            dimensions = apr_pstrcat(ctx->pool,dimensions,"    </Dimension>\n",NULL);
       caps = apr_psprintf(ctx->pool,"%s"
             "  <Layer>\n"
@@ -193,12 +217,13 @@
             "    <Style isDefault=\"true\">\n"
             "      <ows:Identifier>_null</ows:Identifier>\n"
             "    </Style>\n"
+            "%s" /*dimensions*/
             "    <Format>%s</Format>\n"
             "    <TileMatrixSetLink>\n"
             "      <TileMatrixSet>%s</TileMatrixSet>\n"
             "    </TileMatrixSetLink>\n"
-            "  </Layer>",caps,title,abstract,
-            tileset->name,tileset->format->mime_type,tileset->grid->name);
+            "  </Layer>\n",caps,title,abstract,
+            tileset->name,dimensions,tileset->format->mime_type,tileset->grid->name);
       layer_index = apr_hash_next(layer_index);
    caps = apr_pstrcat(ctx->pool,caps,"</Contents>\n</Capabilities>\n",NULL);
@@ -357,6 +382,28 @@
       row = matrixheight-row-1;
+      /*look for dimensions*/
+         int i;
+         req->tiles[0]->dimensions = apr_table_make(ctx->pool,tileset->dimensions->nelts);
+            const char *value;
+            if((value = apr_table_get(params,dimension->name)) != NULL) {
+               int ok = dimension->validate(ctx,dimension,value);
+               GC_CHECK_ERROR(ctx);
+               if(ok == GEOCACHE_SUCCESS)
+                  apr_table_setn(req->tiles[0]->dimensions,dimension->name,value);
+               else {
+                  ctx->set_error(ctx,GEOCACHE_REQUEST_ERROR,"dimension \"%s\" value \"%s\" fails to validate",
+                        dimension->name, value);
+                  return;
+            } else {
+               apr_table_setn(req->tiles[0]->dimensions,dimension->name,dimension->default_value);
       req->tiles[0]->x = col;
