[mapserver-commits] r12415 - in trunk/mapserver/mapcache: . include src
Fri Aug 26 07:23:49 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:23:49 -0700 (Fri, 26 Aug 2011)
New Revision: 12415
   trunk/mapserver/mapcache/geocache.xml
   trunk/mapserver/mapcache/include/geocache.h
   trunk/mapserver/mapcache/src/configuration.c
   trunk/mapserver/mapcache/src/tileset.c
move sqlite db creation to a post-config step which is run by an unpriviledged user
thomas.bonfort | 2011-08-02 13:27:32 +0200 (Tue, 02 Aug 2011)
Modified: trunk/mapserver/mapcache/geocache.xml
--- trunk/mapserver/mapcache/geocache.xml	2011-08-26 11:23:43 UTC (rev 12414)
+++ trunk/mapserver/mapcache/geocache.xml	2011-08-26 11:23:49 UTC (rev 12415)
@@ -468,7 +468,7 @@
          <params>
             <FORMAT>image/png</FORMAT>
             <LAYERS>default</LAYERS>
-            <MAP>/gro1/mapserver-utils/osm.map</MAP>
+            <MAP>/Users/tbonfort/dev/mapserver-utils/osm.map</MAP>
          </params>
       </getmap>
    </source>
@@ -751,5 +751,13 @@
    <!-- do not enable this yet, dragons ahead !!
    <pathinfo_hack/>
+   <!-- resample mode
+        filter applied when resampling tiles for full wms requests.
+        can be either:
+        - nearest : fastest, poor quality
+        - bilinear: slower, higher qulity
+   <resample_mode>bilinear</resample_mode>
 </geocache>
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:23:43 UTC (rev 12414)
+++ trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:23:49 UTC (rev 12415)
@@ -766,6 +766,11 @@
    GEOCACHE_GETMAP_FORWARD
 } geocache_getmap_strategy;
+typedef enum {
+   GEOCACHE_RESAMPLE_NEAREST,
+   GEOCACHE_RESAMPLE_BILINEAR
+} geocache_resample_mode;
  * a configuration that will be served
@@ -820,6 +825,8 @@
     geocache_getmap_strategy getmap_strategy;
+    geocache_resample_mode resample_mode;
     apr_table_t *metadata;
     const char *lockdir;
Modified: trunk/mapserver/mapcache/src/configuration.c
--- trunk/mapserver/mapcache/src/configuration.c	2011-08-26 11:23:43 UTC (rev 12414)
+++ trunk/mapserver/mapcache/src/configuration.c	2011-08-26 11:23:49 UTC (rev 12415)
@@ -1091,6 +1091,18 @@
          goto cleanup;
+   config->resample_mode = GEOCACHE_RESAMPLE_BILINEAR;
+   if ((node = ezxml_child(doc,"resample_mode")) != NULL) {
+      if(!strcmp(node->txt,"nearest")) {
+         config->resample_mode = GEOCACHE_RESAMPLE_NEAREST;
+      } else if(!strcmp(node->txt,"bilinear")) {
+      } else {
+         ctx->set_error(ctx,400, "unknown value %s for node <resample_mode> (allowed values: nearest, bilinear", node->txt);
+         goto cleanup;
    if((node = ezxml_child(doc,"lock_dir")) != NULL) {
       config->lockdir = apr_pstrdup(ctx->pool, node->txt);
Modified: trunk/mapserver/mapcache/src/tileset.c
--- trunk/mapserver/mapcache/src/tileset.c	2011-08-26 11:23:43 UTC (rev 12414)
+++ trunk/mapserver/mapcache/src/tileset.c	2011-08-26 11:23:49 UTC (rev 12415)
@@ -154,7 +154,14 @@
    cairo_translate (cr, dstminx,dstminy);
    cairo_scale  (cr, hf, vf);
    cairo_set_source_surface (cr, srcsurface, 0, 0);
-   cairo_pattern_set_filter (cairo_get_source (cr), CAIRO_FILTER_NEAREST);
+   switch(ctx->config->resample_mode) {
+      case GEOCACHE_RESAMPLE_BILINEAR:
+         cairo_pattern_set_filter (cairo_get_source (cr), CAIRO_FILTER_BILINEAR);
+         break;
+      default:
+         cairo_pattern_set_filter (cairo_get_source (cr), CAIRO_FILTER_NEAREST);
+         break;
    cairo_paint (cr);
    cairo_surface_destroy(srcsurface);
    cairo_surface_destroy(dstsurface);
