[mapserver-commits] r12424 - in trunk/mapserver/mapcache: include src
Fri Aug 26 07:24:34 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:24:34 -0700 (Fri, 26 Aug 2011)
New Revision: 12424
   trunk/mapserver/mapcache/include/geocache.h
   trunk/mapserver/mapcache/src/configuration.c
   trunk/mapserver/mapcache/src/mod_geocache.c
   trunk/mapserver/mapcache/src/service_demo.c
   trunk/mapserver/mapcache/src/service_tms.c
   trunk/mapserver/mapcache/src/service_wms.c
   trunk/mapserver/mapcache/src/service_wmts.c
compiler warning
thomas.bonfort | 2011-08-11 09:34:50 +0200 (Thu, 11 Aug 2011)
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:24:27 UTC (rev 12423)
+++ trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:24:34 UTC (rev 12424)
@@ -756,8 +756,9 @@
 struct geocache_server_cfg {
-    apr_global_mutex_t *mutex;
-    char *mutex_name;
+   apr_global_mutex_t *mutex;
+   char *mutex_name;
+   apr_hash_t *aliases; /**< list of geocache configurations aliased to a server uri */
 typedef enum {
@@ -830,6 +831,7 @@
     apr_table_t *metadata;
     const char *lockdir;
+    const char *endpoint; /**< the uri where the base of the service is mapped */
Modified: trunk/mapserver/mapcache/src/configuration.c
--- trunk/mapserver/mapcache/src/configuration.c	2011-08-26 11:24:27 UTC (rev 12423)
+++ trunk/mapserver/mapcache/src/configuration.c	2011-08-26 11:24:34 UTC (rev 12424)
@@ -1136,7 +1136,17 @@
    apr_dir_close(lockdir);
+   /* if we were suppplied with an onlineresource, make sure it ends with a / */
+   char *url;
+   if(NULL != (url = (char*)apr_table_get(config->metadata,"url"))) {
+      char *urlend = url + strlen(url)-1;
+      if(*urlend != '/') {
+         url = apr_pstrcat(ctx->pool,url,"/",NULL);
+         apr_table_setn(config->metadata,"url",url);
 cleanup:
    ezxml_free(doc);
    return;
Modified: trunk/mapserver/mapcache/src/mod_geocache.c
--- trunk/mapserver/mapcache/src/mod_geocache.c	2011-08-26 11:24:27 UTC (rev 12423)
+++ trunk/mapserver/mapcache/src/mod_geocache.c	2011-08-26 11:24:34 UTC (rev 12424)
@@ -151,7 +151,10 @@
 static geocache_context_apache_request* apache_request_context_create(request_rec *r) {
    geocache_context_apache_request *ctx = apr_pcalloc(r->pool, sizeof(geocache_context_apache_request));
    ctx->ctx.ctx.pool = r->pool;
-   ctx->ctx.ctx.config = ap_get_module_config(r->per_dir_config, &geocache_module);
+   /* lookup the configuration object given the configuration file name */
+   geocache_server_cfg* cfg = ap_get_module_config(r->server->module_config, &geocache_module);
+   geocache_cfg *config = apr_hash_get(cfg->aliases,(void*)r->filename,APR_HASH_KEY_STRING);
+   ctx->ctx.ctx.config = config;
    ctx->request = r;
    init_apache_request_context(ctx);
    return ctx;
@@ -255,11 +258,8 @@
 static int mod_geocache_request_handler(request_rec *r) {
    apr_table_t *params;
-   geocache_cfg *config = NULL;
    geocache_request *request = NULL;
-   geocache_context_apache_request *apache_ctx = apache_request_context_create(r);
-   geocache_context *global_ctx = (geocache_context*)apache_ctx;
    int ret;
    if (!r->handler || strcmp(r->handler, "geocache")) {
@@ -270,11 +270,12 @@
+   geocache_context_apache_request *apache_ctx = apache_request_context_create(r);
+   geocache_context *global_ctx = (geocache_context*)apache_ctx;
    params = geocache_http_parse_param_string(global_ctx, r->args);
-   config = ap_get_module_config(r->per_dir_config, &geocache_module);
-   geocache_service_dispatch_request(global_ctx,&request,r->path_info,params,config);
+   geocache_service_dispatch_request(global_ctx,&request,r->path_info,params,global_ctx->config);
    if(GC_HAS_ERROR(global_ctx)) {
       return report_error(apache_ctx);
@@ -293,13 +294,19 @@
        * remove the path_info from the end of the url (we want the url of the base of the service)
        * TODO: is there an apache api to access this ?
-      if(*(original->path_info)) {
+      if(*(original->path_info) && strcmp(original->path_info,"/")) {
          char *end = strstr(url,original->path_info);
          if(end) {
+            /* make sure our url ends with a single '/' */
+            if(*end == '/') {
+               char *slash = end;
+               while((*(--slash))=='/') end--;
+               end++;
             *end = '\0';
-      request->service->create_capabilities_response(global_ctx,req_caps,url,original->path_info,config);
+      request->service->create_capabilities_response(global_ctx,req_caps,url,original->path_info,global_ctx->config);
@@ -375,6 +382,11 @@
 #ifndef DISABLE_VERSION_STRING
    ap_add_version_component(p, GEOCACHE_USERAGENT);
 #endif
+   for (s = s->next; s; s = s->next) {
+      geocache_server_cfg* config = ap_get_module_config(s->module_config, &geocache_module);
+      config->mutex = cfg->mutex;
    return OK;
@@ -383,57 +395,151 @@
    apr_global_mutex_child_init(&(cfg->mutex),cfg->mutex_name, pool);
+static int geocache_alias_matches(const char *uri, const char *alias_fakename)
+    /* Code for this function from Apache mod_alias module. */
+    const char *aliasp = alias_fakename, *urip = uri;
+    while (*aliasp) {
+        if (*aliasp == '/') {
+            /* any number of '/' in the alias matches any number in
+             * the supplied URI, but there must be at least one...
+            if (*urip != '/')
+                return 0;
+            do {
+                ++aliasp;
+            } while (*aliasp == '/');
+            do {
+                ++urip;
+            } while (*urip == '/');
+        else {
+            /* Other characters are compared literally */
+            if (*urip++ != *aliasp++)
+                return 0;
+    /* Check last alias path component matched all the way */
+    if (aliasp[-1] != '/' && *urip != '\0' && *urip != '/')
+        return 0;
+    /* Return number of characters from URI which matched (may be
+     * greater than length of alias, since we may have matched
+     * doubled slashes)
+    return urip - uri;
+static int geocache_hook_intercept(request_rec *r)
+   geocache_server_cfg *sconfig = ap_get_module_config(r->server->module_config, &geocache_module);
+   if (!sconfig->aliases)
+      return DECLINED;
+   if (r->uri[0] != '/' && r->uri[0])
+      return DECLINED;
+   apr_hash_index_t *entry = apr_hash_first(r->pool,sconfig->aliases);
+   /* loop through the entries to find one where the alias matches */
+   while (entry) {
+      int l = 0;
+      const char *alias;
+      apr_ssize_t aliaslen;
+      geocache_cfg *c;
+      apr_hash_this(entry,(const void**)&alias,&aliaslen,(void**)&c);
+      if((l=geocache_alias_matches(r->uri, c->endpoint))>0) {
+         r->handler = "geocache";
+         r->filename = c->configFile;
+         r->path_info = &(r->uri[l]);
+         return OK;
+      entry = apr_hash_next(entry);
+   return DECLINED;
 static void mod_geocache_register_hooks(apr_pool_t *p) {
    ap_hook_child_init(mod_geocache_child_init, NULL, NULL, APR_HOOK_MIDDLE);
    ap_hook_post_config(mod_geocache_post_config, NULL, NULL, APR_HOOK_MIDDLE);
-   ap_hook_handler(mod_geocache_request_handler, NULL, NULL, APR_HOOK_LAST);
+   ap_hook_handler(mod_geocache_request_handler, NULL, NULL, APR_HOOK_MIDDLE);
+   static const char * const p1[] = { "mod_alias.c", "mod_rewrite.c", NULL };
+   static const char * const n1[]= { "mod_userdir.c",
+                                      "mod_vhost_alias.c", NULL };
+   ap_hook_translate_name(geocache_hook_intercept, p1, n1, APR_HOOK_MIDDLE);
-static void* mod_geocache_create_dir_conf(apr_pool_t *pool, char *x) {
-   geocache_cfg *cfg = geocache_configuration_create(pool);
-   return cfg;
 static void* mod_geocache_create_server_conf(apr_pool_t *pool, server_rec *s) {
    geocache_server_cfg *cfg = apr_pcalloc(pool, sizeof(geocache_server_cfg));
    char *mutex_unique_name = apr_psprintf(pool,"geocachemutex-%d",getpid());
    cfg->mutex_name = ap_server_root_relative(pool, mutex_unique_name);
+   cfg->aliases = NULL;
    return cfg;
 static void *mod_geocache_merge_server_conf(apr_pool_t *p, void *base_, void *vhost_)
-   return base_;
+   geocache_server_cfg *base = (geocache_server_cfg*)base_;
+   geocache_server_cfg *vhost = (geocache_server_cfg*)vhost_;
+   geocache_server_cfg *cfg = apr_pcalloc(p,sizeof(geocache_server_cfg));
+   cfg->mutex = base->mutex;
+   cfg->mutex_name = base->mutex_name;
+   if (base->aliases && vhost->aliases) {
+      cfg->aliases = apr_hash_overlay(p, vhost->aliases,base->aliases);
+   else if (vhost->aliases) {
+      cfg->aliases = apr_hash_copy(p,vhost->aliases);
+   else if (base->aliases) {
+      cfg->aliases = apr_hash_copy(p,base->aliases);
+   return vhost;
-static const char* geocache_set_config_file(cmd_parms *cmd, void *cfg, const char *val) {
-   geocache_cfg *config = (geocache_cfg*)cfg;
+static const char* geocache_add_alias(cmd_parms *cmd, void *cfg, const char *alias, const char* configfile) {
+   geocache_server_cfg *sconfig = ap_get_module_config(cmd->server->module_config, &geocache_module);
+   geocache_cfg *config = geocache_configuration_create(cmd->pool);
    geocache_context *ctx = (geocache_context*)apache_server_context_create(cmd->server,cmd->pool);
    char *msg = NULL;
-   config->configFile = apr_pstrdup(cmd->pool,val);
-   geocache_configuration_parse(ctx,val,config);
+   config->configFile = apr_pstrdup(cmd->pool,configfile);
+   config->endpoint = alias;
+   geocache_configuration_parse(ctx,configfile,config);
    if(GC_HAS_ERROR(ctx)) {
       return ctx->get_error_message(ctx);
-   ap_log_error(APLOG_MARK, APLOG_INFO, 0, cmd->server, "loaded geocache configuration file from %s", config->configFile);
+   ap_log_error(APLOG_MARK, APLOG_INFO, 0, cmd->server, "loaded geocache configuration file from %s on alias %s", config->configFile, alias);
+   if(!sconfig->aliases) {
+      sconfig->aliases = apr_hash_make(cmd->pool);
+   apr_hash_set(sconfig->aliases,configfile,APR_HASH_KEY_STRING,config);
    return msg;
 static const command_rec mod_geocache_cmds[] = {
-      AP_INIT_TAKE1("GeoCacheConfigFile", geocache_set_config_file,NULL,ACCESS_CONF,"Location of configuration file"),
+      AP_INIT_TAKE2("GeoCacheAlias", geocache_add_alias ,NULL,RSRC_CONF,"Aliased location of configuration file"),
       { NULL }
 module AP_MODULE_DECLARE_DATA geocache_module =
       STANDARD20_MODULE_STUFF,
-      mod_geocache_create_dir_conf,
       NULL,
+      NULL,
       mod_geocache_create_server_conf,
       mod_geocache_merge_server_conf,
       mod_geocache_cmds,
Modified: trunk/mapserver/mapcache/src/service_demo.c
--- trunk/mapserver/mapcache/src/service_demo.c	2011-08-26 11:24:27 UTC (rev 12423)
+++ trunk/mapserver/mapcache/src/service_demo.c	2011-08-26 11:24:34 UTC (rev 12424)
@@ -361,7 +361,8 @@
       drequest->service = NULL;
       return;
    } else {
-      cpathinfo++; /* skip the leading / */
+      while(*cpathinfo == '/')
+         cpathinfo++; /* skip the leading /'s */
       int i;
       for(i=0;i<GEOCACHE_SERVICES_COUNT;i++) {
          /* loop through the services that have been configured */
@@ -388,7 +389,7 @@
       geocache_service *service = ctx->config->services[i];
       if(!service || service->type == GEOCACHE_SERVICE_DEMO) continue; /* skip an unconfigured service, and the demo one */
-      caps = apr_pstrcat(ctx->pool,caps,"<a href=\"",urlprefix,"/demo/",service->name,"\">",
+      caps = apr_pstrcat(ctx->pool,caps,"<a href=\"",urlprefix,"demo/",service->name,"\">",
             service->name,"</a><br/>",NULL);
    caps = apr_pstrcat(ctx->pool,caps,"</body></html>",NULL);
@@ -516,7 +517,7 @@
             ol_layer_name,
             tileset->name,
             grid->name,
-            apr_pstrcat(ctx->pool,url_prefix,"/tms/",NULL),
+            apr_pstrcat(ctx->pool,url_prefix,"tms/",NULL),
             tileset->name,
             grid->name,
             extension,
@@ -583,7 +584,7 @@
             ol_layer_name,
             tileset->name,
             grid->name,
-            apr_pstrcat(ctx->pool,url_prefix,"/wmts/",NULL),
+            apr_pstrcat(ctx->pool,url_prefix,"wmts/",NULL),
             tileset->name,
             grid->name,
             mime_type,
@@ -645,7 +646,7 @@
             ol_layer_name,
             tileset->name,
             grid->name,
-            apr_pstrcat(ctx->pool,url_prefix,"/ve",NULL),
+            apr_pstrcat(ctx->pool,url_prefix,"ve",NULL),
             tileset->name,
             grid->name,
             resolutions,
@@ -683,7 +684,7 @@
             continue; //skip layers not in wgs84
-               "<li><a href=\"",url_prefix,"/kml/",tileset->name,
+               "<li><a href=\"",url_prefix,"kml/",tileset->name,
                "@",grid->name,"/0/0/0.kml\">",tileset->name,"</a></li>",
                NULL);
Modified: trunk/mapserver/mapcache/src/service_tms.c
--- trunk/mapserver/mapcache/src/service_tms.c	2011-08-26 11:24:27 UTC (rev 12423)
+++ trunk/mapserver/mapcache/src/service_tms.c	2011-08-26 11:24:34 UTC (rev 12424)
@@ -35,12 +35,13 @@
    if(!onlineresource) {
       onlineresource = url;
    request->request.mime_type = apr_pstrdup(ctx->pool,"text/xml");
    if(!request->version) {
       caps = ezxml_new("Services");
       ezxml_t TileMapService = ezxml_add_child(caps,"TileMapService",0);
       ezxml_set_attr(TileMapService,"version","1.0");
-      char* serviceurl = apr_pstrcat(ctx->pool,onlineresource,"/tms/1.0.0/",NULL);
+      char* serviceurl = apr_pstrcat(ctx->pool,onlineresource,"tms/1.0.0/",NULL);
       ezxml_set_attr(TileMapService,"href",serviceurl);
    } else {
       if(!request->tileset) {
@@ -66,7 +67,7 @@
                ezxml_set_attr(tilemap,"srs",grid->srs);
                if(profile)
                   ezxml_set_attr(tilemap,"profile",profile);
-               char *href = apr_pstrcat(ctx->pool,onlineresource,"/tms/1.0.0/",tileset->name,"@",grid->name,NULL);
+               char *href = apr_pstrcat(ctx->pool,onlineresource,"tms/1.0.0/",tileset->name,"@",grid->name,NULL);
                ezxml_set_attr(tilemap,"href",href);
             tileindex_index = apr_hash_next(tileindex_index);
@@ -87,7 +88,7 @@
          caps = ezxml_new("TileMap");
          ezxml_set_attr(caps,"version",request->version);
          ezxml_set_attr(caps,"tilemapservice",
-               apr_pstrcat(ctx->pool,onlineresource,"/tms/",request->version,"/",NULL));
+               apr_pstrcat(ctx->pool,onlineresource,"tms/",request->version,"/",NULL));
          ezxml_set_txt(ezxml_add_child(caps,"Title",0),title);
          ezxml_set_txt(ezxml_add_child(caps,"Abstract",0),abstract);
@@ -118,7 +119,7 @@
             ezxml_t xmltileset = ezxml_add_child(tilesets,"TileSet",0);
             char *order = apr_psprintf(ctx->pool,"%d",i);
             ezxml_set_attr(xmltileset,"href",
                      "/",order,NULL));
             ezxml_set_attr(xmltileset,"units-per-pixel",apr_psprintf(ctx->pool,"%.20f",grid->levels[i]->resolution));
Modified: trunk/mapserver/mapcache/src/service_wms.c
--- trunk/mapserver/mapcache/src/service_wms.c	2011-08-26 11:24:27 UTC (rev 12423)
+++ trunk/mapserver/mapcache/src/service_wms.c	2011-08-26 11:24:34 UTC (rev 12424)
@@ -36,7 +36,8 @@
    if(!url) {
       url = guessed_url;
-   url = apr_pstrcat(ctx->pool,url,"/",req->request.service->url_prefix,"?",NULL);
+   url = apr_pstrcat(ctx->pool,url,req->request.service->url_prefix,"?",NULL);
    caps = ezxml_new("WMT_MS_Capabilities");
    ezxml_set_attr(caps,"version","1.1.1");
Modified: trunk/mapserver/mapcache/src/service_wmts.c
--- trunk/mapserver/mapcache/src/service_wmts.c	2011-08-26 11:24:27 UTC (rev 12423)
+++ trunk/mapserver/mapcache/src/service_wmts.c	2011-08-26 11:24:34 UTC (rev 12424)
@@ -50,7 +50,7 @@
    ezxml_t dcp = ezxml_add_child(operation,"ows:DCP",0);
    ezxml_t http = ezxml_add_child(dcp,"ows:HTTP",0);
    ezxml_t get = ezxml_add_child(http,"ows:Get",0);
-   ezxml_set_attr(get,"xlink:href",apr_pstrcat(ctx->pool,onlineresource,"/wmts?",NULL));
+   ezxml_set_attr(get,"xlink:href",apr_pstrcat(ctx->pool,onlineresource,"wmts?",NULL));
    ezxml_t constraint = ezxml_add_child(get,"ows:Constraint",0);
    ezxml_set_attr(constraint,"name","GetEncoding");
    ezxml_t allowedvalues = ezxml_add_child(constraint,"ows:AllowedValues",0);
@@ -161,7 +161,7 @@
             ezxml_set_attr(resourceurl,"format",iformat);
             ezxml_set_attr(resourceurl,"resourcetype","FeatureInfo");
             ezxml_set_attr(resourceurl,"template",
-                  apr_pstrcat(ctx->pool,onlineresource,"/wmts/1.0.0/",tileset->name,"/default/",
+                  apr_pstrcat(ctx->pool,onlineresource,"wmts/1.0.0/",tileset->name,"/default/",
                      dimensionstemplate,"{TileMatrixSet}/{TileMatrix}/{TileRow}/{TileCol}.",apr_psprintf(ctx->pool,"%d",i),NULL));
@@ -170,7 +170,7 @@
       ezxml_set_attr(resourceurl,"format",tileset->format->mime_type);
       ezxml_set_attr(resourceurl,"resourceType","tile");
                dimensionstemplate,"{TileMatrixSet}/{TileMatrix}/{TileRow}/{TileCol}.",tileset->format->extension,NULL));
