[mapserver-commits] r12431 - in trunk/mapserver/mapcache: include src
Fri Aug 26 07:25:14 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:25:14 -0700 (Fri, 26 Aug 2011)
New Revision: 12431
   trunk/mapserver/mapcache/include/geocache.h
   trunk/mapserver/mapcache/src/core.c
   trunk/mapserver/mapcache/src/mod_geocache.c
   trunk/mapserver/mapcache/src/tileset.c
allow full wms operation by default
thomas.bonfort | 2011-08-15 18:25:17 +0200 (Mon, 15 Aug 2011)
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:25:09 UTC (rev 12430)
+++ trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:25:14 UTC (rev 12431)
@@ -428,6 +428,8 @@
    geocache_buffer *data;
    int width, height;
    double extent[4];
+   apr_time_t mtime; /**< last modification time */
+   int expires; /**< time in seconds after which the tile should be rechecked for validity */
 struct geocache_feature_info {
Modified: trunk/mapserver/mapcache/src/core.c
--- trunk/mapserver/mapcache/src/core.c	2011-08-26 11:25:09 UTC (rev 12430)
+++ trunk/mapserver/mapcache/src/core.c	2011-08-26 11:25:14 UTC (rev 12431)
@@ -51,6 +51,15 @@
       geocache_tileset_tile_get(ctx, tile);
       if(GC_HAS_ERROR(ctx))
          return NULL;
+      /* update the map modification time if it is older than the tile mtime */
+      if(tile->mtime>map->mtime) map->mtime = tile->mtime;
+      /* set the map expiration delay to the tile expiration delay,
+       * either if the map hasn't got an expiration delay yet
+       * or if the tile expiration is shorter than the map expiration
+      if(!map->expires || tile->expires<map->expires) map->expires = tile->expires;
    geocache_image *getmapim = geocache_tileset_assemble_map_tiles(ctx,map->tileset,map->grid_link,
          map->extent, map->width, map->height,
@@ -82,6 +91,9 @@
          if(GC_HAS_ERROR(ctx)) return NULL;
          geocache_image_merge(ctx,baseim,overlayim);
+         if(overlaymap->mtime > basemap->mtime) basemap->mtime = overlaymap->mtime;
+         if(!basemap->expires || overlaymap->expires<basemap->expires) basemap->expires = overlaymap->expires;
       basemap->data = basemap->tileset->format->write(ctx,baseim,basemap->tileset->format);
Modified: trunk/mapserver/mapcache/src/mod_geocache.c
--- trunk/mapserver/mapcache/src/mod_geocache.c	2011-08-26 11:25:09 UTC (rev 12430)
+++ trunk/mapserver/mapcache/src/mod_geocache.c	2011-08-26 11:25:14 UTC (rev 12431)
@@ -195,6 +195,33 @@
    return OK;
+static int geocache_write_map(geocache_context_apache_request *ctx, geocache_map *map) {
+   int rc;
+   char *timestr;
+   request_rec *r = ctx->request;
+   if(map->expires) {
+      apr_time_t now = apr_time_now();
+      apr_time_t additional = apr_time_from_sec(map->expires);
+      apr_time_t expires = now + additional;
+      apr_table_set(r->headers_out, "Cache-Control",apr_psprintf(r->pool, "max-age=%d", map->expires));
+      timestr = apr_palloc(r->pool, APR_RFC822_DATE_LEN);
+      apr_rfc822_date(timestr, expires);
+      apr_table_setn(r->headers_out, "Expires", timestr);
+   if(map->mtime) {
+      ap_update_mtime(r, map->mtime);
+      if((rc = ap_meets_conditions(r)) != OK) {
+         return rc;
+      apr_rfc822_date(timestr, map->mtime);
+      apr_table_setn(r->headers_out, "Last-Modified", timestr);
+   return geocache_write_image_buffer(ctx, map->data, map->tileset->format);
 static int geocache_write_tile(geocache_context_apache_request *ctx, geocache_tile *tile) {
    int rc;
    char *timestr;
@@ -343,7 +370,7 @@
       if(GC_HAS_ERROR(global_ctx)) {
          return report_error(apache_ctx);
-      ret = geocache_write_image_buffer(apache_ctx,map->data, map->tileset->format);
+      ret = geocache_write_map(apache_ctx,map);
       return ret;
    } else if( request->type == GEOCACHE_REQUEST_GET_FEATUREINFO) {
       geocache_request_get_feature_info *req_fi = (geocache_request_get_feature_info*)request;
Modified: trunk/mapserver/mapcache/src/tileset.c
--- trunk/mapserver/mapcache/src/tileset.c	2011-08-26 11:25:09 UTC (rev 12430)
+++ trunk/mapserver/mapcache/src/tileset.c	2011-08-26 11:25:14 UTC (rev 12431)
@@ -270,7 +270,7 @@
    geocache_tileset* tileset = (geocache_tileset*)apr_pcalloc(ctx->pool, sizeof(geocache_tileset));
    tileset->metasize_x = tileset->metasize_y = 1;
    tileset->metabuffer = 0;
-   tileset->expires = 0;
+   tileset->expires = 300; /*set a reasonable default to 5 mins */
    tileset->auto_expire = 0;
    tileset->metadata = apr_table_make(ctx->pool,3);
    tileset->dimensions = NULL;
@@ -286,7 +286,11 @@
 geocache_tile* geocache_tileset_tile_create(apr_pool_t *pool, geocache_tileset *tileset, geocache_grid_link *grid_link) {
    geocache_tile *tile = (geocache_tile*)apr_pcalloc(pool, sizeof(geocache_tile));
    tile->tileset = tileset;
-   tile->expires = tileset->expires;
+   if(tileset->auto_expire) {
+      tile->expires = tileset->auto_expire;
+   } else {
+      tile->expires = tileset->expires;
    tile->grid_link = grid_link;
    if(tileset->dimensions) {
       int i;
@@ -432,14 +436,13 @@
             ctx->set_error(ctx, 500, "tileset %s: failed to re-get tile %d %d %d from cache after set", tile->tileset->name,tile->x,tile->y,tile->z);
-      /* update the tile expiration time */
-      if(tile->tileset->auto_expire && tile->mtime) {
-         apr_time_t now = apr_time_now();
-         apr_time_t expire_time = tile->mtime + apr_time_from_sec(tile->tileset->auto_expire);
-         tile->expires = apr_time_sec(expire_time-now);
+   /* update the tile expiration time */
+   if(tile->tileset->auto_expire && tile->mtime) {
+      apr_time_t expire_time = tile->mtime + apr_time_from_sec(tile->tileset->auto_expire);
+      tile->expires = apr_time_sec(expire_time-now);
 void geocache_tileset_tile_delete(geocache_context *ctx, geocache_tile *tile) {
