[mapserver-commits] r12488 - in trunk/mapserver/mapcache: include src
Fri Aug 26 07:31:13 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:31:13 -0700 (Fri, 26 Aug 2011)
New Revision: 12488
   trunk/mapserver/mapcache/include/geocache.h
   trunk/mapserver/mapcache/src/configuration_xml.c
   trunk/mapserver/mapcache/src/geocache_seed.c
   trunk/mapserver/mapcache/src/grid.c
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:31:04 UTC (rev 12487)
+++ trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:31:13 UTC (rev 12488)
@@ -1262,9 +1262,22 @@
 double geocache_grid_get_horizontal_resolution(double *bbox, int width);
 double geocache_grid_get_vertical_resolution(double *bbox, int height);
+ * \brief compute grid level given a resolution
+ * \param grid
+ * \param resolution
+ * \param level
 int geocache_grid_get_level(geocache_context *ctx, geocache_grid *grid, double *resolution, int *level);
-void geocache_grid_compute_limits(const geocache_grid *grid, const double *extent, int **limits);
+ * \brief precompute min/max x/y values for the given extent
+ * \param grid
+ * \param extent
+ * \param tolerance the number of tiles around the given extent that can be requested without returning an error.
+void geocache_grid_compute_limits(const geocache_grid *grid, const double *extent, int **limits, int tolerance);
 /* in util.c */
 int geocache_util_extract_int_list(geocache_context *ctx, const char* args, const char *sep, int **numbers,
         int *numbers_count);
Modified: trunk/mapserver/mapcache/src/configuration_xml.c
--- trunk/mapserver/mapcache/src/configuration_xml.c	2011-08-26 11:31:04 UTC (rev 12487)
+++ trunk/mapserver/mapcache/src/configuration_xml.c	2011-08-26 11:31:13 UTC (rev 12488)
@@ -483,7 +483,7 @@
    for(cur_node = ezxml_child(node,"grid"); cur_node; cur_node = cur_node->next) {
       int i;
-      char *restrictedExtent = NULL;
+      char *restrictedExtent = NULL, *sTolerance = NULL;
       if (tileset->grid_links == NULL) {
          tileset->grid_links = apr_array_make(ctx->pool,1,sizeof(geocache_grid_link*));
@@ -516,7 +516,20 @@
       } else {
          extent = grid->extent;
-      geocache_grid_compute_limits(grid,extent,gridlink->grid_limits);
+      int tolerance = 5;
+      sTolerance = (char*)ezxml_attr(cur_node,"tolerance");
+      if(sTolerance) {
+         char *endptr;
+         tolerance = (int)strtol(sTolerance,&endptr,10);
+         if(*endptr != 0 || tolerance < 0) {
+            ctx->set_error(ctx, 400, "failed to parse grid tolerance %s (expecting a positive integer)",
+                  sTolerance);
+            return;
+      geocache_grid_compute_limits(grid,extent,gridlink->grid_limits,tolerance);
       /* compute wgs84 bbox if it wasn't supplied already */
       if(!havewgs84bbox && !strcasecmp(grid->srs,"EPSG:4326")) {
Modified: trunk/mapserver/mapcache/src/geocache_seed.c
--- trunk/mapserver/mapcache/src/geocache_seed.c	2011-08-26 11:31:04 UTC (rev 12487)
+++ trunk/mapserver/mapcache/src/geocache_seed.c	2011-08-26 11:31:13 UTC (rev 12488)
@@ -647,7 +647,7 @@
     if(extent) {
        // update the grid limits
-       geocache_grid_compute_limits(grid_link->grid,extent,grid_link->grid_limits);
+       geocache_grid_compute_limits(grid_link->grid,extent,grid_link->grid_limits,0);
     /* adjust our grid limits so they align on the metatile limits
Modified: trunk/mapserver/mapcache/src/grid.c
--- trunk/mapserver/mapcache/src/grid.c	2011-08-26 11:31:04 UTC (rev 12487)
+++ trunk/mapserver/mapcache/src/grid.c	2011-08-26 11:31:13 UTC (rev 12488)
@@ -59,7 +59,8 @@
 const char* geocache_grid_get_srs(geocache_context *ctx, geocache_grid *grid) {
    return (const char*)grid->srs;
-void geocache_grid_compute_limits(const geocache_grid *grid, const double *extent, int **limits) {
+void geocache_grid_compute_limits(const geocache_grid *grid, const double *extent, int **limits, int tolerance) {
    int i;
    double epsilon = 0.0000001;
    for(i=0;i<grid->nlevels;i++) {
@@ -70,10 +71,10 @@
       level->maxy = ceil((grid->extent[3]-grid->extent[1] - 0.01* unitheight)/unitheight);
       level->maxx = ceil((grid->extent[2]-grid->extent[0] - 0.01* unitwidth)/unitwidth);
-      limits[i][0] = floor((extent[0] - grid->extent[0]) / unitwidth + epsilon);
-      limits[i][2] = ceil((extent[2] - grid->extent[0]) / unitwidth - epsilon);
-      limits[i][1] = floor((extent[1] - grid->extent[1]) / unitheight + epsilon);
-      limits[i][3] = ceil((extent[3] - grid->extent[1]) / unitheight - epsilon);
+      limits[i][0] = floor((extent[0] - grid->extent[0]) / unitwidth + epsilon) - tolerance;
+      limits[i][2] = ceil((extent[2] - grid->extent[0]) / unitwidth - epsilon) + tolerance;
+      limits[i][1] = floor((extent[1] - grid->extent[1]) / unitheight + epsilon) - tolerance;
+      limits[i][3] = ceil((extent[3] - grid->extent[1]) / unitheight - epsilon) + tolerance;
       // to avoid requesting out-of-range tiles
       if (limits[i][0] < 0) limits[i][0] = 0;
       if (limits[i][2] > level->maxx) limits[i][2] = level->maxx;
