[mapserver-commits] r12837 - trunk/mapserver/mapcache
Fri Dec 2 16:57:03 EST 2011
Author: assefa
Date: 2011-12-02 13:57:03 -0800 (Fri, 02 Dec 2011)
New Revision: 12837
Added:
   trunk/mapserver/mapcache/Makefile.vc
   trunk/mapserver/mapcache/nmake.opt
windows make files
Added: trunk/mapserver/mapcache/Makefile.vc
--- trunk/mapserver/mapcache/Makefile.vc	                        (rev 0)
+++ trunk/mapserver/mapcache/Makefile.vc	2011-12-02 21:57:03 UTC (rev 12837)
@@ -0,0 +1,79 @@
+# makefile.vc - Main mapcache makefile for MSVC++
+# To use the makefile:
+#  - Open a DOS prompt window
+#  - Run the VCVARS32.BAT script to initialize the VC++ environment variables
+#  - Start the build with:  nmake /f makefile.vc
+# $Id: $
+!INCLUDE nmake.opt
+BASE_CFLAGS = 	$(OPTFLAGS)
+CFLAGS=$(BASE_CFLAGS) $(MAPCACHE_CFLAGS)
+CC=     cl
+LINK=   link
+# Main mapcache library.
+MAPCACHE_OBJS = src\axisorder.obj  src\dimension.obj  src\imageio_mixed.obj  src\service_wms.obj \
+	        src\buffer.obj src\ezxml.obj  src\imageio_png.obj  src\service_wmts.obj \
+                src\cache_disk.obj  src\lock.obj src\services.obj \
+                src\cache_memcache.obj src\grid.obj  src\source.obj \
+		src\cache_sqlite.obj src\http.obj src\source_gdal.obj \
+		src\cache_tiff.obj src\image.obj src\service_demo.obj src\source_mapserver.obj \
+		src\configuration.obj src\image_error.obj src\service_kml.obj src\source_wms.obj \
+		src\configuration_xml.obj src\imageio.obj src\service_tms.obj src\tileset.obj \
+		src\core.obj src\imageio_jpeg.obj src\service_ve.obj src\util.obj \
+		$(REGEX_OBJ)
+MAPCACHE_FCGI = 	mapcache.exe
+MAPCACHE_SEED = 	mapcache_seed.exe
+default: 	all
+all:		$(MAPCACHE_LIB) $(MAPCACHE_FCGI) $(MAPCACHE_SEED)
+$(MAPCACHE_LIB): $(MAPCACHE_OBJS)
+	lib /debug /out:$(MAPCACHE_LIB) $(MAPCACHE_OBJS)
+$(MAPCACHE_FCGI): $(MAPCACHE_LIB)
+          $(CC) $(CFLAGS) src\fastcgi_mapcache.c /Femapcache.exe $(LIBS)
+	         if exist $@.manifest mt -manifest $@.manifest -outputresource:$@;1
+$(MAPCACHE_SEED): $(MAPCACHE_LIB)
+          $(CC) $(CFLAGS) src\mapcache_seed.c /Femapcache_seed.exe $(LIBS)
+.c.obj:
+	$(CC) $(CFLAGS) /c $*.c /Fo$*.obj
+.cpp.obj:
+	$(CC) $(CFLAGS) /c $*.cpp /Fo$*.obj
+clean:
+    del src\*.obj
+    del $(MAPCACHE_FCGI)
+    del *.lib
+    del *.manifest
+install: $(MAPCACHE_EXE)
+	-mkdir $(BINDIR)
+	copy *.exe $(BINDIR)
Added: trunk/mapserver/mapcache/nmake.opt
--- trunk/mapserver/mapcache/nmake.opt	                        (rev 0)
+++ trunk/mapserver/mapcache/nmake.opt	2011-12-02 21:57:03 UTC (rev 12837)
@@ -0,0 +1,197 @@
+# nmake.opt - mapcache
+# Uncomment the following if you are building for 64-bit windows
+# (x64). You'll need to have PATH, INCLUDE and LIB set up for 64-bit
+# compiles.
+#WIN64=YES
+# Check compiler version given in command line
+# nmake -f makefile.vc MSVC_VER=xxxx
+# 1310 = 7.1 (2003)   1400 = 8.0 (2005)
+!IFNDEF MSVC_VER
+#assume msvc 7.1
+MSVC_VER=1310
+!ENDIF
+# File locations and where to install things
+# If you are using the MapServer Build Kit, almost everything should be
+# relative to this directory throughout this option file.
+# Set the following to point to the directory adjacent to the dependent libs.
+!IFNDEF MAPCACHE_BASE
+MAPCACHE_BASE =  c:/projects/mapserver-buildkit-2008/mapserver-trunk/mapcache
+#MAPCACHE_BASE =  .
+!ENDIF
+# Optmization, debug, and related compile flags.
+!IF $(MSVC_VER) == 1400
+# Optimized, with using MSVCRT.
+OPTFLAGS =	/nologo /Ox /MD $(WARNING_LEVEL) $(DEBUG) /EHsc /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE
+# Debug with MSVCRT
+#OPTFLAGS = /nologo /Zi /MD $(WARNING_LEVEL) $(DEBUG) /EHsc /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE
+#LDFLAGS =  /NODEFAULTLIB:msvcrt /NODEFAULTLIB:libcd /DEBUG
+!ELSE
+#OPTFLAGS = /nologo /Zi /MDd $(WARNING_LEVEL) $(DEBUG) /EHsc
+!ENDIF
+# Set the Warning level for the compiler (defaults to W1)
+WARNING_LEVEL=/W3
+# Debugging Options
+#NEED_NONBLOCKING_STDERR=-DNEED_NONBLOCKING_STDERR
+ENABLE_STDERR_DEBUG=-DENABLE_STDERR_DEBUG
+# Set the linker debug option
+LDEBUG=/debug
+# DEBUG Build flags
+# Set the DEBUG flag if you wish to make a debug build
+DEBUG=/DDEBUG
+# APR: Apacge Protable Runtime library
+#APR_DIR = $(MAPCACHE_BASE)\..\..\apr-1.4.5
+APR_DIR = $(MAPCACHE_BASE)\..\..\apr-dist
+# PNG support
+PNG_DIR=$(MAPCACHE_BASE)\..\..\libpng-1.2.35
+ZLIB_DIR=$(MAPCACHE_BASE)\..\..\zlib-1.2.5
+ZLIB_INC=-I$(ZLIB_DIR)
+CURL=-DUSE_CURL
+CURL_DIR=$(MAPCACHE_BASE)\..\..\curl-7.21.3
+WINSOCK_LIB ="C:\Program Files\Microsoft SDKs\Windows\v6.0A\Lib\WS2_32.Lib"
+JPEG_DIR=$(MAPCACHE_BASE)\..\..\jpeg-8c
+JPEG_INC = -I$(JPEG_DIR)
+# FastCGI Support
+# Uncomment, and update accordingly.
+FCGI_DEF=-DUSE_FASTCGI
+FCGI_DIR=$(MAPCACHE_BASE)\..\..\fcgi-2.4.0
+# Section II: Mapserver Rendering Configuration
+# Section VI: Support Libraries.
+# REGEX Libary
+# VC++ does not include the REGEX library... so we must provide our one.
+# The following definitions will try to build GNU regex-0.12 located in the
+# regex-0.12 sub-directory.
+# If it was not included in the source distribution, then you can get it from:
+#    ftp://ftp.gnu.org/pub/gnu/regex/regex-0.12.tar.gz
+# Provide the full path to the REGEX project directory
+# You do not need this library if you are compiling for PHP mapscript.
+# In that case the PHP regex library will be used instead
+REGEX_DIR=$(MAPCACHE_BASE)\..\..\regex-0.12
+# Set the png support libaries
+!IFDEF PNG_DIR
+!IFNDEF PNG_LIB
+PNG_LIB=$(PNG_DIR)\projects\visualc71\Win32_LIB_Release\libpng.lib $(ZLIB_DIR)/old/visualc6/Win32_DLL_Release/zlib1.lib
+!ENDIF
+PNG_INC=-I$(PNG_DIR)
+!ENDIF
+CURL_INC = -I$(CURL_DIR)/include
+CURL_LIB = $(CURL_DIR)/lib/libcurl_imp.lib
+!IFDEF JPEG_DIR
+JPEG_LIB=$(JPEG_DIR)/libjpeg.lib
+!ENDIF
+FCGI_LIB=$(FCGI_DIR)\libfcgi\Release\libfcgi.lib
+FCGI_INC=-I$(FCGI_DIR)\include
+# Section VII: Variable Setup
+# Should not need to be updated.
+MAPCACHE_LIB =    mapcache.lib
+MAPCACHE_INC= -I$(MAPCACHE_BASE)\include
+#APR
+APR_INC=-I$(APR_DIR)\include
+APR_LIB=$(APR_DIR)/lib/apr-1.lib $(APR_DIR)/lib/aprutil-1.lib $(APR_DIR)/lib/libapr-1.lib $(APR_DIR)/lib/libaprutil-1.lib
+# Setup REGEX object and includes
+REGEX_OBJ=$(REGEX_DIR)\regex.obj
+REGEX_INC=-I$(REGEX_DIR)
+# REGEX needs some special flags... here they are for VC++ 6.0
+REGEX_OPT=-DHAVE_STRING_H -DREGEX_MALLOC
+# Section IX: Collect compiler flags
+!IFNDEF EXTERNAL_LIBS
+EXTERNAL_LIBS= $(PNG_LIB) $(CURL_LIB) $(JPEG_LIB) $(APR_LIB) $(FRIBIDI_LIB) $(FCGI_LIB)
+!ENDIF
+LIBS=$(MAPCACHE_LIB) $(EXTERNAL_LIBS)
+!IFNDEF INCLUDES
+INCLUDES=$(MAPCACHE_INC) $(APR_INC) $(REGEX_INC) $(PNG_INC) $(ZLIB_INC) $(CURL_INC) $(JPEG_INC) $(FCGI_INC)
+!ENDIF
+MAPCACHE_DEFS =$(REGEX_OPT) $(FCGI_DEF)
+!IFDEF WIN64
+MAPCACHE_CFLAGS=$(INCLUDES) $(MAPCACHE_DEFS) -DWIN32 -D_WIN32 -DUSE_GENERIC_MS_NINT
+!ELSE
+!ENDIF
