[mapserver-commits] r12859 - trunk/mapserver
Tue Dec 6 15:29:17 EST 2011
Author: assefa
Date: 2011-12-06 12:29:17 -0800 (Tue, 06 Dec 2011)
New Revision: 12859
   trunk/mapserver/mapdraw.c
fix windows nuild
Modified: trunk/mapserver/mapdraw.c
--- trunk/mapserver/mapdraw.c	2011-12-06 16:58:19 UTC (rev 12858)
+++ trunk/mapserver/mapdraw.c	2011-12-06 20:29:17 UTC (rev 12859)
@@ -692,13 +692,14 @@
   layer->project = MS_TRUE;
   if(layer->masklayer) {
+    int maskLayerIdx;
      /* render the mask layer in its own imageObj */
      if(!MS_IMAGE_RENDERER(image)->supports_pixel_buffer) {
         msSetError(MS_MISCERR, "Layer (%s) references references a mask layer, but the selected renderer does not support them", "msDrawLayer()",
               layer->name);
         return (MS_FAILURE);
-     int maskLayerIdx = msGetLayerIndex(map,layer->masklayer);
+     maskLayerIdx = msGetLayerIndex(map,layer->masklayer);
      if(maskLayerIdx == -1) {
         msSetError(MS_MISCERR, "Layer (%s) references unknown mask layer (%s)", "msDrawLayer()",
               layer->name,layer->masklayer);
@@ -852,10 +853,11 @@
      renderer->getRasterBufferHandle(image_draw,&rb);
      if(maskLayer && maskLayer->maskimage) {
         rasterBufferObj mask;
+	 unsigned int row,col;
         memset(&mask,0,sizeof(rasterBufferObj));
         MS_IMAGE_RENDERER(maskLayer->maskimage)->getRasterBufferHandle(maskLayer->maskimage,&mask);
         /* modify the pixels of the overlay */
-        unsigned int row,col;
         if(rb.type == MS_BUFFER_BYTE_RGBA) {
            for(row=0;row<rb.height;row++) {
               unsigned char *ma,*a,*r,*g,*b;
