[mapserver-commits] r12866 - in trunk/mapserver: . mapscript/php
Wed Dec 7 11:24:26 EST 2011
Author: aboudreault
Date: 2011-12-07 08:24:26 -0800 (Wed, 07 Dec 2011)
New Revision: 12866
   trunk/mapserver/configure
   trunk/mapserver/mapscript/php/mapscript_error.c
   trunk/mapserver/mapscript/php/php_mapscript.c
   trunk/mapserver/mapscript/php/php_mapscript.h
   trunk/mapserver/mapscript/php/php_mapscript_util.c
   trunk/mapserver/mapscript/php/php_regex.c
regenerated configure script with autoconf2.59 and fixed some include path issue in php mapscript
Modified: trunk/mapserver/configure
--- trunk/mapserver/configure	2011-12-07 15:20:11 UTC (rev 12865)
+++ trunk/mapserver/configure	2011-12-07 16:24:26 UTC (rev 12866)
@@ -309,7 +309,7 @@
 # include <unistd.h>
 #endif"
-ac_subst_vars='SHELL PATH_SEPARATOR PACKAGE_NAME PACKAGE_TARNAME PACKAGE_VERSION PACKAGE_STRING PACKAGE_BUGREPORT exec_prefix prefix program_transform_name bindir sbindir libexecdir datadir sysconfdir sharedstatedir localstatedir libdir includedir oldincludedir infodir mandir build_alias host_alias target_alias DEFS ECHO_C ECHO_N ECHO_T LIBS CC CFLAGS LDFLAGS CPPFLAGS ac_ct_CC EXEEXT OBJEXT CXX CXXFLAGS ac_ct_CXX RANLIB ac_ct_RANLIB LEX LEXLIB LEX_OUTPUT_ROOT YACC XTRALIBS CPP EGREP C_PIC STRINGS MS_VERSION PKG_CONFIG FT_BIN FT_ENABLED FT_INC FT_LIB ZLIB_ENABLED ZLIB_INC ZLIB_LIB PNG_ENABLED PNG_INC PNG_LIB GIF_ENABLED GIF_INC GIF_LIB JPEG_ENABLED JPEG_INC JPEG_LIB ICONV_ENABLED ICONV_INC ICONV_LIB GD_DEF GD_INC GD_LIB GD_STATIC MAKE_GD MAKE_GD_CLEAN FTGL_ENABLED FTGL_INC FTGL_LIB OGL_ENABLED OGL_INC OGL_LIB AGG_LIB AGG_INC AGG_OBJ PROJ_ENABLED PROJ_INC PROJ_LIBS THREAD_FLAG THREAD_LIB SDE_ENABLED SDE_INC SDE_LIB GEOS_CONFIG GEOS_ENABLED GEOS_INC GEOS_LIB GDAL_CONFIG GDAL_EN
 ABLED OGR_ENABLED GDAL_INC GDAL_LIB PG_CONFIG POSTGIS_ENABLED POSTGIS_INC POSTGIS_LIB MY_CONFIG MYSQL_ENABLED MYSQL_INC MYSQL_LIB ORACLESPATIAL_ENABLED ORACLESPATIAL_INC ORACLESPATIAL_LIB WMS_SVR_ENABLED WFS_SVR_ENABLED WCS_SVR_ENABLED LIBCURL_CONFIG CURL_INC CURL_LIB EXEMPI_ENABLED EXEMPI_INC EXEMPI_LIB LIBXML2_CONFIG XML2_INC XML2_LIB WMS_LYR_ENABLED WFS_LYR_ENABLED SOS_SVR_ENABLED XSLT_ENABLED XSLT_INC XSLT_LIB EXSLT_ENABLED EXSLT_INC EXSLT_LIB FRIBIDI_CONFIG FRIBIDI_ENABLED FRIBIDI_INC FRIBIDI_LIB CAIRO_ENABLED CAIRO_INC CAIRO_LIB FASTCGI_ENABLED FASTCGI_INC FASTCGI_LIB HTTPD MS_INC MS_LIB IGNORE_MISSING_DATA USE_POINT_Z_M USE_NINT DEBUG_FLAGS LD_SHARED SO_EXT SO_COMMAND_NAME PHP_LD_SHARED PHP_VERSION_FLAG PHP_SRC_DIR PHP_CC PHP_LD PHP_REGEX_INC PHP_REGEX_OBJ USE_PHP_REGEX MAKE_PHPMS MAKE_PHPMS_CLEAN APACHE_INC OS_INCLUDE_DIR ALL_ENABLED ALL_INC ALL_LIB ALL_STATIC_LIB RPATHS LIBOBJS LTLIBOBJS'
+ac_subst_vars='SHELL PATH_SEPARATOR PACKAGE_NAME PACKAGE_TARNAME PACKAGE_VERSION PACKAGE_STRING PACKAGE_BUGREPORT exec_prefix prefix program_transform_name bindir sbindir libexecdir datadir sysconfdir sharedstatedir localstatedir libdir includedir oldincludedir infodir mandir build_alias host_alias target_alias DEFS ECHO_C ECHO_N ECHO_T LIBS CC CFLAGS LDFLAGS CPPFLAGS ac_ct_CC EXEEXT OBJEXT CXX CXXFLAGS ac_ct_CXX RANLIB ac_ct_RANLIB LEX LEXLIB LEX_OUTPUT_ROOT YACC XTRALIBS CPP EGREP C_PIC STRINGS MS_VERSION PKG_CONFIG FT_BIN FT_ENABLED FT_INC FT_LIB ZLIB_ENABLED ZLIB_INC ZLIB_LIB PNG_ENABLED PNG_INC PNG_LIB GIF_ENABLED GIF_INC GIF_LIB JPEG_ENABLED JPEG_INC JPEG_LIB ICONV_ENABLED ICONV_INC ICONV_LIB GD_DEF GD_INC GD_LIB GD_STATIC MAKE_GD MAKE_GD_CLEAN FTGL_ENABLED FTGL_INC FTGL_LIB OGL_ENABLED OGL_INC OGL_LIB AGG_LIB AGG_INC AGG_OBJ PROJ_ENABLED PROJ_INC PROJ_LIBS THREAD_FLAG THREAD_LIB SDE_ENABLED SDE_INC SDE_LIB GEOS_CONFIG GEOS_ENABLED GEOS_INC GEOS_LIB GDAL_CONFIG GDAL_EN
 ABLED OGR_ENABLED GDAL_INC GDAL_LIB PG_CONFIG POSTGIS_ENABLED POSTGIS_INC POSTGIS_LIB MY_CONFIG MYSQL_ENABLED MYSQL_INC MYSQL_LIB ORACLESPATIAL_ENABLED ORACLESPATIAL_INC ORACLESPATIAL_LIB WMS_SVR_ENABLED WFS_SVR_ENABLED WCS_SVR_ENABLED LIBCURL_CONFIG CURL_INC CURL_LIB EXEMPI_ENABLED EXEMPI_INC EXEMPI_LIB LIBXML2_CONFIG XML2_INC XML2_LIB WMS_LYR_ENABLED WFS_LYR_ENABLED SOS_SVR_ENABLED XSLT_ENABLED XSLT_INC XSLT_LIB EXSLT_ENABLED EXSLT_INC EXSLT_LIB FRIBIDI_CONFIG FRIBIDI_ENABLED FRIBIDI_INC FRIBIDI_LIB CAIRO_ENABLED CAIRO_INC CAIRO_LIB LIBSVG_CAIRO_ENABLED LIBSVG_CAIRO_INC LIBSVG_CAIRO_LIB FASTCGI_ENABLED FASTCGI_INC FASTCGI_LIB HTTPD MS_INC MS_LIB IGNORE_MISSING_DATA USE_POINT_Z_M USE_NINT DEBUG_FLAGS LD_SHARED SO_EXT SO_COMMAND_NAME PHP_LD_SHARED PHP_VERSION_FLAG PHP_SRC_DIR PHP_CC PHP_LD PHP_REGEX_INC PHP_REGEX_OBJ USE_PHP_REGEX MAKE_PHPMS MAKE_PHPMS_CLEAN APACHE_INC OS_INCLUDE_DIR ALL_ENABLED ALL_INC ALL_LIB ALL_STATIC_LIB RPATHS LIBOBJS LTLIBOBJS'
 ac_subst_files=''
 # Initialize some variables set by options.
@@ -935,6 +935,7 @@
                           Include FriBidi Support (ARG=yes/path to
                           fribidi-config or fribidi.pc)
   --with-cairo[=ARG]      Include Cairo Support (ARG=yes/path to cairo.pc)
+  --with-libsvg-cairo[=ARG]      Include Cairo SVG Parser Support (ARG=yes/path to cairo.pc)
   --with-fastcgi=path     Enable FastCGI, point to installed tree.
   --with-httpd            Specify path to 'httpd' executable.
   --with-warnings[=flags] Enable strict warnings (or user defined warnings)
@@ -13471,7 +13472,7 @@
    { (exit 1); exit 1; }; }
   fi
 else
-  CAIRO_CONFIG=$with_cairo_config
+  CAIRO_CONFIG=$with_cairo
 fi
 if test "$CAIRO_CONFIG" = "no" ; then
@@ -13498,6 +13499,83 @@
 ALL_LIB="$CAIRO_LIB $ALL_LIB"
+echo "$as_me:$LINENO: checking if Cairo svg parser support requested" >&5
+echo $ECHO_N "checking if Cairo svg parser support requested... $ECHO_C" >&6
+LIBSVG_CAIRO_ENABLED=$LIBSVG_CAIRO_ENABLED
+LIBSVG_CAIRO_INC=$LIBSVG_CAIRO_INC
+LIBSVG_CAIRO_LIB=$LIBSVG_CAIRO_LIB
+# Check whether --with-libsvg-cairo or --without-libsvg-cairo was given.
+if test "${with_libsvg_cairo+set}" = set; then
+  withval="$with_libsvg_cairo"
+fi;
+if test "$with_libsvg_cairo" = "no" -o "$with_libsvg_cairo" = "" ; then
+  echo "$as_me:$LINENO: result: no" >&5
+echo "${ECHO_T}no" >&6
+  LIBSVG_CAIRO_CONFIG="no"
+elif test "$with_libsvg_cairo" = "yes" ; then
+  echo "$as_me:$LINENO: result: yes" >&5
+echo "${ECHO_T}yes" >&6
+  if test "$PKG_CONFIG" != "no" ; then
+     echo "$as_me:$LINENO: checking for libsvg-cairo pkg-config path" >&5
+echo $ECHO_N "checking for libsvg-cairo pkg-config path... $ECHO_C" >&6
+     `$PKG_CONFIG --silence-errors -- libsvg-cairo >> /dev/null`
+     if test $? -eq 0 ; then
+        LIBSVG_CAIRO_CONFIG="libsvg-cairo"
+     else
+       { { echo "$as_me:$LINENO: error: libsvg-cairo support requested, but not found." >&5
+echo "$as_me: error: libsvg-cairo support requested, but not found." >&2;}
+   { (exit 1); exit 1; }; }
+     fi
+  else
+    { { echo "$as_me:$LINENO: error: pkg-config required for libsvg-cairo support, try using --with-pkg-config=PATH" >&5
+echo "$as_me: error: pkg-config required for libsvg-cairo support, try using --with-pkg-config=PATH" >&2;}
+  fi
+else
+  LIBSVG_CAIRO_CONFIG=$with_libsvg_cairo
+fi
+if test "$LIBSVG_CAIRO_CONFIG" = "no" ; then
+  LIBSVG_CAIRO_ENABLED=
+  LIBSVG_CAIRO_INC=
+  LIBSVG_CAIRO_LIB=
+else
+  if test -z "$CAIRO_ENABLED"; then
+       { { echo "$as_me:$LINENO: error: libsvg-cairo support requires cairo support. (hint: rerun with --with-cairo)" >&5
+echo "$as_me: error: libsvg-cairo support requires cairo support. (hint: rerun with --with-cairo)" >&2;}
+  fi
+  echo "$as_me:$LINENO: result: yes, pkg-config defaults, or user supplied path to cairo.pc" >&5
+echo "${ECHO_T}yes, pkg-config defaults, or user supplied path to cairo.pc" >&6
+  LIBSVG_CAIRO_ENABLED="-DUSE_SVG_CAIRO"
+  LIBSVG_CAIRO_LIB=`$PKG_CONFIG --libs $LIBSVG_CAIRO_CONFIG`
+  LIBSVG_CAIRO_INC=`$PKG_CONFIG --cflags $LIBSVG_CAIRO_CONFIG`
+fi
+ALL_ENABLED="$LIBSVG_CAIRO_ENABLED $ALL_ENABLED"
+ALL_INC="$LIBSVG_CAIRO_INC $ALL_INC"
+ALL_LIB="$LIBSVG_CAIRO_LIB $ALL_LIB"
 echo "$as_me:$LINENO: checking FastCGI support" >&5
 echo $ECHO_N "checking FastCGI support... $ECHO_C" >&6
@@ -15370,6 +15448,9 @@
 s, at CAIRO_ENABLED@,$CAIRO_ENABLED,;t t
 s, at CAIRO_INC@,$CAIRO_INC,;t t
 s, at CAIRO_LIB@,$CAIRO_LIB,;t t
+s, at LIBSVG_CAIRO_ENABLED@,$LIBSVG_CAIRO_ENABLED,;t t
+s, at LIBSVG_CAIRO_INC@,$LIBSVG_CAIRO_INC,;t t
+s, at LIBSVG_CAIRO_LIB@,$LIBSVG_CAIRO_LIB,;t t
 s, at FASTCGI_ENABLED@,$FASTCGI_ENABLED,;t t
 s, at FASTCGI_INC@,$FASTCGI_INC,;t t
 s, at FASTCGI_LIB@,$FASTCGI_LIB,;t t
@@ -15708,6 +15789,8 @@
 echo "${ECHO_T}  SVG Symbol support:        ${AGG_SVG_SYMBOLS_ENABLED}" >&6
 echo "$as_me:$LINENO: result:   Cairo (SVG,PDF) support:   ${CAIRO_ENABLED}" >&5
 echo "${ECHO_T}  Cairo (SVG,PDF) support:   ${CAIRO_ENABLED}" >&6
+echo "$as_me:$LINENO: result:   Cairo SVG parser support:  ${LIBSVG_CAIRO_ENABLED}" >&5
+echo "${ECHO_T}  Cairo SVG parser support:  ${LIBSVG_CAIRO_ENABLED}" >&6
 echo "$as_me:$LINENO: result:   KML support:               ${KML_ENABLED}" >&5
 echo "${ECHO_T}  KML support:               ${KML_ENABLED}" >&6
 echo "$as_me:$LINENO: result: " >&5
Modified: trunk/mapserver/mapscript/php/mapscript_error.c
--- trunk/mapserver/mapscript/php/mapscript_error.c	2011-12-07 15:20:11 UTC (rev 12865)
+++ trunk/mapserver/mapscript/php/mapscript_error.c	2011-12-07 16:24:26 UTC (rev 12866)
@@ -33,7 +33,7 @@
 #include "zend_exceptions.h"
 #include "php_mapscript_util.h"
 #include <stdarg.h>
-#include "maperror.h"
+#include "../../maperror.h"
 #define MAX_EXCEPTION_MSG 256
Modified: trunk/mapserver/mapscript/php/php_mapscript.c
--- trunk/mapserver/mapscript/php/php_mapscript.c	2011-12-07 15:20:11 UTC (rev 12865)
+++ trunk/mapserver/mapscript/php/php_mapscript.c	2011-12-07 16:24:26 UTC (rev 12866)
@@ -37,7 +37,7 @@
 #include "ext/standard/info.h"
 #include "ext/standard/head.h"
 #include <time.h>
Modified: trunk/mapserver/mapscript/php/php_mapscript.h
--- trunk/mapserver/mapscript/php/php_mapscript.h	2011-12-07 15:20:11 UTC (rev 12865)
+++ trunk/mapserver/mapscript/php/php_mapscript.h	2011-12-07 16:24:26 UTC (rev 12866)
@@ -50,13 +50,13 @@
 #include <unistd.h>
 #endif
-#include "mapserver.h"
-#include "mapregex.h"
+#include "../../mapserver.h"
+#include "../../mapregex.h"
 #endif /* USE_PHP_REGEX */
-#include "maptemplate.h"
-#include "mapogcsld.h"
+#include "../../maptemplate.h"
+#include "../../mapogcsld.h"
 #define MAPSCRIPT_VERSION "($Revision$ $Date$)"
Modified: trunk/mapserver/mapscript/php/php_mapscript_util.c
--- trunk/mapserver/mapscript/php/php_mapscript_util.c	2011-12-07 15:20:11 UTC (rev 12865)
+++ trunk/mapserver/mapscript/php/php_mapscript_util.c	2011-12-07 16:24:26 UTC (rev 12866)
@@ -29,7 +29,7 @@
 zend_object_value mapscript_object_new(zend_object *zobj,
Modified: trunk/mapserver/mapscript/php/php_regex.c
--- trunk/mapserver/mapscript/php/php_regex.c	2011-12-07 15:20:11 UTC (rev 12865)
+++ trunk/mapserver/mapscript/php/php_regex.c	2011-12-07 16:24:26 UTC (rev 12866)
@@ -52,7 +52,7 @@
   doesn't #define away our ms_*/
 #define BUILDING_REGEX_PROXY 1
 /* regex_extra.h doesn't exist in PHP >=5.3 */
 #include "php.h"
