[mapserver-commits] r12877 - in trunk/msautotest/renderers: . expected
Sat Dec 10 04:29:20 EST 2011
Author: tbonfort
Date: 2011-12-10 01:29:20 -0800 (Sat, 10 Dec 2011)
New Revision: 12877
Added:
   trunk/msautotest/renderers/expected/point-polaroffset.cairopng.png
   trunk/msautotest/renderers/expected/point-polaroffset.gif
   trunk/msautotest/renderers/expected/point-polaroffset.pdf
   trunk/msautotest/renderers/expected/point-polaroffset.png.png
   trunk/msautotest/renderers/expected/point-polaroffset.svg
   trunk/msautotest/renderers/point-polaroffset.map
add test for polaroffset
Added: trunk/msautotest/renderers/expected/point-polaroffset.cairopng.png
(Binary files differ)
Property changes on: trunk/msautotest/renderers/expected/point-polaroffset.cairopng.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: trunk/msautotest/renderers/expected/point-polaroffset.gif
Property changes on: trunk/msautotest/renderers/expected/point-polaroffset.gif
Added: trunk/msautotest/renderers/expected/point-polaroffset.pdf
Property changes on: trunk/msautotest/renderers/expected/point-polaroffset.pdf
Added: trunk/msautotest/renderers/expected/point-polaroffset.png.png
Property changes on: trunk/msautotest/renderers/expected/point-polaroffset.png.png
Added: trunk/msautotest/renderers/expected/point-polaroffset.svg
--- trunk/msautotest/renderers/expected/point-polaroffset.svg	                        (rev 0)
+++ trunk/msautotest/renderers/expected/point-polaroffset.svg	2011-12-10 09:29:20 UTC (rev 12877)
@@ -0,0 +1,26 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<svg xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink" width="300pt" height="200pt" viewBox="0 0 300 200" version="1.1">
+<defs>
+<clipPath id="clip1">
+  <rect width="300" height="200"/>
+</clipPath>
+<g id="surface6" clip-path="url(#clip1)">
+<path style="fill:none;stroke-width:2;stroke-linecap:round;stroke-linejoin:round;stroke:rgb(0%,0%,0%);stroke-opacity:1;stroke-miterlimit:10;" d="M 16.464844 182.535156 L 23.535156 175.464844 "/>
+<path style="fill:none;stroke-width:1;stroke-linecap:round;stroke-linejoin:round;stroke:rgb(0%,0%,0%);stroke-opacity:1;stroke-miterlimit:10;" d="M 20.707031 183.949219 L 29.191406 169.808594 L 15.050781 178.292969 "/>
+<path style=" stroke:none;fill-rule:nonzero;fill:rgb(100%,0%,0%);fill-opacity:1;" d="M 22 179 C 22 181.667969 18 181.667969 18 179 C 18 176.332031 22 176.332031 22 179 "/>
+<path style=" stroke:none;fill-rule:nonzero;fill:rgb(0%,100%,0%);fill-opacity:1;" d="M 29.070312 171.929688 C 29.070312 174.59375 25.070312 174.59375 25.070312 171.929688 C 25.070312 169.261719 29.070312 169.261719 29.070312 171.929688 "/>
+<path style="fill:none;stroke-width:2;stroke-linecap:round;stroke-linejoin:round;stroke:rgb(0%,0%,0%);stroke-opacity:1;stroke-miterlimit:10;" d="M 150.339844 184 L 167.660156 174 "/>
+<path style="fill:none;stroke-width:1;stroke-linecap:round;stroke-linejoin:round;stroke:rgb(0%,0%,0%);stroke-opacity:1;stroke-miterlimit:10;" d="M 162.730469 181.464844 L 174.589844 170 L 158.730469 174.535156 "/>
+<path style=" stroke:none;fill-rule:nonzero;fill:rgb(100%,0%,0%);fill-opacity:1;" d="M 161 179 C 161 181.667969 157 181.667969 157 179 C 157 176.332031 161 176.332031 161 179 "/>
+<path style=" stroke:none;fill-rule:nonzero;fill:rgb(0%,100%,0%);fill-opacity:1;" d="M 178.320312 169 C 178.320312 171.667969 174.320312 171.667969 174.320312 169 C 174.320312 166.332031 178.320312 166.332031 178.320312 169 "/>
+<path style="fill:none;stroke-width:2;stroke-linecap:round;stroke-linejoin:round;stroke:rgb(0%,0%,0%);stroke-opacity:1;stroke-miterlimit:10;" d="M 110 117.320312 L 90 82.679688 "/>
+<path style="fill:none;stroke-width:1;stroke-linecap:round;stroke-linejoin:round;stroke:rgb(0%,0%,0%);stroke-opacity:1;stroke-miterlimit:10;" d="M 97.464844 87.609375 L 86 75.75 L 90.535156 91.609375 "/>
+<path style=" stroke:none;fill-rule:nonzero;fill:rgb(100%,0%,0%);fill-opacity:1;" d="M 102 100 C 102 102.667969 98 102.667969 98 100 C 98 97.332031 102 97.332031 102 100 "/>
+<path style=" stroke:none;fill-rule:nonzero;fill:rgb(0%,100%,0%);fill-opacity:1;" d="M 82 65.359375 C 82 68.027344 78 68.027344 78 65.359375 C 78 62.691406 82 62.691406 82 65.359375 "/>
+</g>
+</defs>
+<g id="surface2">
+<rect x="0" y="0" width="300" height="200" style="fill:rgb(100%,100%,100%);fill-opacity:1;stroke:none;"/>
+<use xlink:href="#surface6"/>
+</g>
+</svg>
Added: trunk/msautotest/renderers/point-polaroffset.map
--- trunk/msautotest/renderers/point-polaroffset.map	                        (rev 0)
+++ trunk/msautotest/renderers/point-polaroffset.map	2011-12-10 09:29:20 UTC (rev 12877)
@@ -0,0 +1,86 @@
+MAP
+  SIZE 300 200
+  IMAGETYPE png   # gif|png|jpeg|wbmp]
+  EXTENT 0 0 300 200
+  UNITS meters
+  SYMBOL
+    NAME "circlef"
+    TYPE ellipse
+    FILLED true
+    POINTS
+      1 1
+    END
+  END
+  SYMBOL
+    NAME "line"
+    TYPE vector
+    POINTS
+      0 0
+      1 0
+    END
+  END
+  SYMBOL
+    NAME "arrowhead"
+    TYPE vector
+    POINTS
+      0 2
+      4 1
+      0 0
+    END
+    #ANCHORPOINT 0 0.5
+  END
+  LAYER  # Points - vectors
+    STATUS DEFAULT
+    TYPE POINT
+    PROCESSING "ITEMS=length,rotation,length_2"
+    FEATURE
+      POINTS
+        20 20
+      END # Points
+      ITEMS "10;45;5"
+    END # Feature
+    FEATURE
+      POINTS
+        160 20
+      END # Points
+      ITEMS "20;30;10"
+    END # Feature
+    FEATURE
+      POINTS
+        100 100
+      END # Points
+      ITEMS "40;120;20"
+    END # Feature
+    CLASS
+      STYLE  # right offset rel. to line direction
+        SYMBOL "line"
+        COLOR 0 0 0 # black
+        SIZE [length]
+        ANGLE [rotation]
+        WIDTH 2
+      END # STYLE
+      STYLE  # polaroffset
+        SYMBOL "arrowhead"
+        ANGLE [rotation]
+        SIZE 8
+        #POLAROFFSET [length] [rotation]
+        POLAROFFSET [length_2] [rotation]
+        #POLAROFFSET [0] [rotation]
+      END # STYLE
+      STYLE  # red dot at the point's location
+        SYMBOL "circlef"
+        COLOR 255 0 0   # red
+        SIZE 4
+      END # STYLE
+      STYLE  # green dot at the polaroffset point
+        SYMBOL "circlef"
+        COLOR 0 255 0   # green
+        SIZE 4
+        #POLAROFFSET [length_2] [rotation]
+        POLAROFFSET [length] [rotation]
+      END # STYLE
+    END # CLASS
+  END # LAYER
+END # MAP`
