[mapserver-commits] r12879 - in trunk/docs: . en/input/vector en/mapfile
Sun Dec 11 18:28:09 EST 2011
Author: havatv
Date: 2011-12-11 15:28:08 -0800 (Sun, 11 Dec 2011)
New Revision: 12879
Added:
   trunk/docs/en/input/vector/vector_field.txt
   trunk/docs/conf.py
   trunk/docs/en/input/vector/index.txt
   trunk/docs/en/mapfile/layer.txt
   trunk/docs/en/mapfile/style.txt
Documentation of INITIALGAP (new) in STYLE, documentation page for vector field (new) and documentation of CONNECTIONTYPE uvvector (new) in layer (#4094 and #4117).  Added keywords for syntax highlighter.
Modified: trunk/docs/conf.py
--- trunk/docs/conf.py	2011-12-10 12:09:44 UTC (rev 12878)
+++ trunk/docs/conf.py	2011-12-11 23:28:08 UTC (rev 12879)
@@ -292,11 +292,11 @@
             r'CHART|CIRCLE|CL|CR|CSV|MYSQL|'
             r'POSTGRESQL|DEFAULT|DD|ELLIPSE|EMBED|FALSE|FEET|FOLLOW|'
             r'GIANT|HATCH|HILITE|INCHES|KILOMETERS|LARGE|LC|'
-            r'LEFT|LINE|LL|LR|MEDIUM|METERS|MILES|MITER|MULTIPLE|NONE|'
+            r'LEFT|LINE|LL|LOCAL|LR|MEDIUM|METERS|MILES|MITER|MULTIPLE|NONE|'
             r'NORMAL|OFF|OGR|ON|ONE-TO-ONE|ONE-TO-MANY|ORACLESPATIAL|'
             r'PERCENTAGES|PIXMAP|PIXELS|POINT|POLYGON|POSTGIS|MYGIS|'
             r'PLUGIN|QUERY|RASTER|RIGHT|ROUND|SDE|SELECTED|SIMPLE|SINGLE|'
-            r'SMALL|SQUARE|TINY|TRIANGLE|TRUE|TRUETYPE|UC|UL|UR|VECTOR|'
+            r'SMALL|SQUARE|TINY|TRIANGLE|TRUE|TRUETYPE|UC|UL|UNION|UR|UV_ANGLE|UV_MINUS_ANGLE|UV_LENGTH|UV_LENGTH_2|UVRASTER|VECTOR|'
             r'WFS|WMS|ALPHA|'
             r'GIF|JPEG|JPG|PNG|WBMP|SWF|PDF|GTIFF|PC256|RGB|RGBA|INT16|FLOAT32|GD|'
             r'AGG|CAIRO|PNG8|SVG|KML|KMZ|GDAL'
@@ -320,7 +320,7 @@
             r'MINLENGTH|MINSIZE|MINSUBDIVIDE|MINTEMPLATE|MINWIDTH|NAME|OFFSET|OFFSITE|'
             r'OPACITY|OUTLINECOLOR|OUTLINEWIDTH|OUTPUTFORMAT|OVERLAYBACKGROUNDCOLOR|'
             r'OVERLAYCOLOR|OVERLAYMAXSIZE|OVERLAYMINSIZE|OVERLAYOUTLINECOLOR|'
-            r'OVERLAYSIZE|OVERLAYSYMBOL|PARTIALS|PATTERN|POINTS|POSITION|POSTLABELCACHE|'
+            r'OVERLAYSIZE|OVERLAYSYMBOL|PARTIALS|PATTERN|POINTS|POLAROFFSET|POSITION|POSTLABELCACHE|'
             r'PRIORITY|PROCESSING|PROJECTION|QUERYFORMAT|QUERYMAP|REFERENCE|REGION|'
             r'RELATIVETO|REQUIRES|RESOLUTION|SCALE|SCALEDENOM|SHADOWCOLOR|SHADOWSIZE|'
             r'SHAPEPATH|SIZE|SIZEUNITS|STATUS|STYLE|STYLEITEM|SYMBOL|SYMBOLSCALE|'
Modified: trunk/docs/en/input/vector/index.txt
--- trunk/docs/en/input/vector/index.txt	2011-12-10 12:09:44 UTC (rev 12878)
+++ trunk/docs/en/input/vector/index.txt	2011-12-11 23:28:08 UTC (rev 12879)
@@ -74,5 +74,6 @@
    S57
    sqlite
    tiger
+   vector_field
    VirtualSpatialData
    wfs
Added: trunk/docs/en/input/vector/vector_field.txt
--- trunk/docs/en/input/vector/vector_field.txt	                        (rev 0)
+++ trunk/docs/en/input/vector/vector_field.txt	2011-12-11 23:28:08 UTC (rev 12879)
@@ -0,0 +1,128 @@
+.. index::
+   single: Vector field
+.. index::
+   single: uvraster
+.. _input_vector_field
+ Vector field rendering - UVraster
+Vector fields are used for instance in meteorology to store/display
+wind direction and magnitude.
+The source is two bands of raster data, the first band represents the
+U component of the vector, and the second band the V component.  Using
+the u,v values at a given location we can compute a rotation and
+magnitude and use that to draw an arrow of a size proportional to the
+magnitude and pointing in the direction of the phenomenon (wind,
+current, etc.)
+For more details about vector fields, refer to: `Vector field`_
+A vector field :ref:`LAYER` is a hybrid layer, which has a raster data
+source as input and vector features as output.  The output features
+are represented as points.  Queries are not supported.
+Since the data source is a raster, all raster processing options can
+be used (e.g. RESAMPLE).  RESAMPLE=AVERAGE generally gives a good
+result, and the default.  This can be overridden by explicitly
+specifying the type of resampling.
+Vector field layers are of `TYPE` `point`, and have `CONNECTIONTYPE`
+`uvraster`.  The raster data set is specified in `DATA`.  The two
+bands that define the vector field are specified using `PROCESSING`
+`BANDS` (U first, V second).
+The UVraster connection type offers the following attributes:
+* [u]: the raw u value
+* [v]: the raw v value
+* [uv_angle]: the vector angle
+* [uv_minus_angle]: the vector angle - opposite direction
+* [uv_length]: the vector length (scaled with the `UV_SIZE_SCALE`
+  optional value)
+* [uv_length_2]: half the vector length
+Optional `PROCESSING` settings:
+* `UV_SPACING`: The spacing is simply the distance, in pixels, between
+  arrows to be displayed in the vector field. Default is 32.
+* `UV_SIZE_SCALE`: The uv size scale is used to convert the vector
+  lengths (magnitude) of the raster to pixels for a better
+  rendering. Default is 1.
+Example of a layer definition:
+.. code-block:: mapfile
+  SYMBOL
+    NAME "horizline"
+    TYPE VECTOR
+    POINTS
+       0 0
+       1 0
+    END # points
+  END # symbol
+  SYMBOL
+    NAME "arrowhead"
+    TYPE vector
+    FILLED true
+    #ANCHORPOINT 0 0.5
+    POINTS
+      0 2
+      4 1
+      0 0
+    END # points
+  END # symbol
+  SYMBOL
+    NAME "arrowtail"
+    TYPE vector
+    FILLED true
+    ANCHORPOINT 1 0.5 # to shift the arrowtail
+    POINTS
+      0 2
+      4 1
+      0 0
+      -99 -99
+      0 1
+      4 1
+    END # points
+  END # symbol
+  LAYER
+    NAME "my_uv_test"
+    TYPE POINT
+    STATUS DEFAULT
+    CONNECTIONTYPE uvraster
+    DATA /path/wind.grib2
+    PROCESSING "BANDS=1,2"
+    PROCESSING "UV_SPACING=40"
+    PROCESSING "UV_SIZE_SCALE=0.2"
+    CLASS
+      STYLE
+        SYMBOL "horizline"
+        ANGLE [uv_angle]
+        SIZE [uv_length]
+        WIDTH 3
+        COLOR 100 255 0
+      END # style
+      STYLE
+        SYMBOL "arrowhead"
+        ANGLE [uv_angle]
+        SIZE 10
+        COLOR 255 0 0
+        POLAROFFSET [uv_length_2] [uv_angle]
+      END # style
+      STYLE
+        SYMBOL "arrowtail"
+        ANGLE [uv_angle]
+        SIZE 10
+        COLOR 255 0 0
+        POLAROFFSET [uv_length_2] [uv_minus_angle]
+      END # style
+    END # class
+  END # layer
+.. _`Vector field`: http://en.wikipedia.org/wiki/Vector_field
Modified: trunk/docs/en/mapfile/layer.txt
--- trunk/docs/en/mapfile/layer.txt	2011-12-10 12:09:44 UTC (rev 12878)
+++ trunk/docs/en/mapfile/layer.txt	2011-12-11 23:28:08 UTC (rev 12879)
@@ -70,7 +70,37 @@
 .. index::
    pair: LAYER; CONNECTIONTYPE
-CONNECTIONTYPE [local|sde|ogr|postgis|oraclespatial|wms|wfs|plugin|union]
+.. index::
+   triple: LAYER; CONNECTIONTYPE; local
+.. index::
+   triple: LAYER; CONNECTIONTYPE; ogr
+.. index::
+   triple: LAYER; CONNECTIONTYPE; oraclespatial
+.. index::
+   triple: LAYER; CONNECTIONTYPE; plugin
+.. index::
+   triple: LAYER; CONNECTIONTYPE; postgis
+.. index::
+   triple: LAYER; CONNECTIONTYPE; sde
+.. index::
+   triple: LAYER; CONNECTIONTYPE; union
+.. index::
+   triple: LAYER; CONNECTIONTYPE; uvraster
+.. index::
+   triple: LAYER; CONNECTIONTYPE; wfs
+.. index::
+   triple: LAYER; CONNECTIONTYPE; wms
+CONNECTIONTYPE [local|ogr|oraclespatial|plugin|postgis|sde|union|uvraster|wfs|wms]
     Type of connection. Default is local. See additional documentation for
     any other type.
Modified: trunk/docs/en/mapfile/style.txt
--- trunk/docs/en/mapfile/style.txt	2011-12-10 12:09:44 UTC (rev 12878)
+++ trunk/docs/en/mapfile/style.txt	2011-12-11 23:28:08 UTC (rev 12879)
@@ -391,6 +391,67 @@
     .. versionadded:: 6.0 moved from :ref:`SYMBOL`
 .. index::
+   pair: STYLE; POLAROFFSET
+POLAROFFSET [double|attribute] [double|attribute]
+    Offset given in polar coordinates.
+    The first parameter is a double value in layer `SIZEUNITS` (or the
+    name of a layer attribute) that specifies the radius/distance.
+    The second parameter is a double value (or the name of a layer
+    attribute) that specifies the angle (counter clockwise).
+    When scaling of symbols is in effect (`SYMBOLSCALEDENOM` is
+    specified for the :ref:`LAYER`), `POLAROFFSET` gives the
+    distance in layer `SIZEUNITS` at the map scale
+    1:`SYMBOLSCALEDENOM`.
+    A `POLAROFFSET` of `20` `40` will shift the geometry to a position
+    that is 20 `SIZEUNITS` away along a line that is at an angle of 40
+    degrees with a line that goes horizontally to the right.
+    When `POLAROFFSET` is used with layers that have `CONNECTIONTYPE`
+    `uvraster` (:ref:`vector field <input_vector_field>`), the special
+    attributes `uv_length`, `uv_length_2`, `uv_angle` and
+    `uv_minus_angle` are available, making it convenient to specify
+    arrow heads and tails.  Example:
+    .. code-block:: mapfile
+      LAYER
+        TYPE POINT
+        CLASS
+          STYLE
+            SYMBOL "arrowbody"
+            ANGLE [uv_angle]
+            SIZE [uv_length]
+            WIDTH 3
+            COLOR 100 255 0
+          END
+          STYLE
+            ANGLE [uv_angle]
+            SIZE 10
+            COLOR 255 0 0
+          END
+          STYLE
+            ANGLE [uv_angle]
+            SIZE 10
+            COLOR 255 0 0
+          END
+        END #class
+      END #layer
+    .. versionadded:: 6.2 (:ref:`rfc78`)
+.. index::
    pair: STYLE; SIZE
 SIZE [double|attribute]
