[mapserver-commits] r12887 - trunk/docs/en/mapfile
Mon Dec 12 13:43:22 EST 2011
Author: jmckenna
Date: 2011-12-12 10:43:22 -0800 (Mon, 12 Dec 2011)
New Revision: 12887
   trunk/docs/en/mapfile/style.txt
clarify GEOMTRANSFORM LABELPNT explanation
Modified: trunk/docs/en/mapfile/style.txt
--- trunk/docs/en/mapfile/style.txt	2011-12-12 18:42:56 UTC (rev 12886)
+++ trunk/docs/en/mapfile/style.txt	2011-12-12 18:43:22 UTC (rev 12887)
@@ -165,7 +165,7 @@
     - *end*: produces the last point of the current feature
       geometry. When used with `ANGLE` AUTO, it can for instance be
       used to render arrowheads on line segments.
-    - *labelpnt*: used for :ref:`LABEL` styles.  draws a marker on
+    - *labelpnt*: used for :ref:`LABEL` styles.  Draws a marker on
       the geographic position the label is attached to. This
       corresponds to the center of the label text only if the label
       is in position CC.
