[mapserver-commits] r12902 - trunk/docs/en/development/rfc
Mon Dec 19 03:39:17 EST 2011
Author: havatv
Date: 2011-12-19 00:39:17 -0800 (Mon, 19 Dec 2011)
New Revision: 12902
   trunk/docs/en/development/rfc/ms-rfc-45.txt
Included some references in RFC45.
Modified: trunk/docs/en/development/rfc/ms-rfc-45.txt
--- trunk/docs/en/development/rfc/ms-rfc-45.txt	2011-12-16 15:01:21 UTC (rev 12901)
+++ trunk/docs/en/development/rfc/ms-rfc-45.txt	2011-12-19 08:39:17 UTC (rev 12902)
@@ -15,7 +15,7 @@
 discussions with other developers working on cartographic output*)
-Scale Dependant Rendering
+Scale Dependent Rendering
 - All symbols can be scaled. When SYMBOLSCALEDENOM is given for a layer, the
@@ -62,6 +62,9 @@
 - Default value is the centre of the symbol's bounding box.
 - Applies to TYPE ellipse, vector, pixmap, truetype.
+  .. note::
+     Implemented as `ANCHORPOINT`.
 ANGLE [double|attribute] [DEFAULT|CLOCKWISE|COMPASS]
@@ -71,7 +74,7 @@
 To specify rotation, you need a point of rotation, a reference direction, a
 direction of rotation and a unit of rotation.
-Currently, angles for labels have a reference direction to the right (west),
+Currently, angles for labels have a reference direction to the right (east),
 and a counter-clockwise direction of rotation specified in degrees (0..360).
 When specifying direction/rotation for symbols, compass direction is often used
@@ -146,11 +149,16 @@
   a way that the symbol's x-axis is directed along the line.
+  .. note::
+     `INITIALGAP` was introduced to address a part of this
 DASHPATTERN ([double on] [double off])+ END
 - renamed from STYLE
 - the distances are scaled
+  .. note::
+     `PATTERN` was used instead of  `DASHPATTERN`.
 more to come?
@@ -180,7 +188,7 @@
 eg for drawing road lines with a cached outline
-- It is currently impossible to have scale dependant road networks with a fixed
+- It is currently impossible to have scale dependent road networks with a fixed
   width outline, this addition will remedy this.
 - This would also be a shorthand to be able to specify an outline for linear
@@ -205,6 +213,8 @@
   used for example to add arrowheads to lines
   - default angle is direction of first/last segment
+  .. note::
+     :ref:`rfc48` addresses this (`GEOMTRANSFORM`).
 Files Affected
@@ -224,4 +234,17 @@
 Individual modifications will be tracked with their own tickets which will
 be listed here.
- - B1: http://trac.osgeo.org/mapserver/ticket/2766
+ - B1: http://trac.osgeo.org/mapserver/ticket/2766 (double)
+ - http://trac.osgeo.org/mapserver/ticket/4066 (precise symbol
+   placement - anchorpoint)
+ - http://trac.osgeo.org/mapserver/ticket/3847 (stable rendering for
+   tile generation)
+ - http://trac.osgeo.org/mapserver/ticket/3797 (move from symbol to style)
+ - http://trac.osgeo.org/mapserver/ticket/3752 (scalable gap and pattern)
+ - http://trac.osgeo.org/mapserver/ticket/33879 (initialgap)
