[mapserver-commits] r12913 - in trunk/mapserver: . mapscript/php
svn at osgeo.org
svn at osgeo.org
Fri Dec 23 10:48:08 EST 2011
Author: tbonfort
Date: 2011-12-23 07:48:08 -0800 (Fri, 23 Dec 2011)
New Revision: 12913
trunk/mapserver/configure
trunk/mapserver/configure.in
trunk/mapserver/mapscript/php/Makefile.in
make php mapscript configuration use the php-config utility
Modified: trunk/mapserver/configure
--- trunk/mapserver/configure 2011-12-23 15:03:41 UTC (rev 12912)
+++ trunk/mapserver/configure 2011-12-23 15:48:08 UTC (rev 12913)
@@ -620,21 +620,17 @@
OS_INCLUDE_DIR
JAVA_INCLUDE
_ACJNI_JAVAC
+SO_COMMAND_NAME
+SO_EXT
+LD_SHARED
+C_PIC
MAKE_PHPMS_CLEAN
MAKE_PHPMS
USE_PHP_REGEX
PHP_REGEX_OBJ
PHP_REGEX_INC
-PHP_LD
-PHP_CC
-PHP_SRC_DIR
PHP_VERSION_FLAG
PHPCONFIG
-PHP_LD_SHARED
-SO_COMMAND_NAME
-SO_EXT
-LD_SHARED
-C_PIC
DEBUG_FLAGS
USE_NINT
USE_POINT_Z_M
@@ -1628,7 +1624,8 @@
--with-apxs=/path/to/apxs Apache 2 apxs tool location
--with-apr-config path to apr-config program
--with-warnings[=flags] Enable strict warnings (or user defined warnings)
- --with-php=DIR Specify directory where PHP5's include files are
+ --with-php=yes|no|/path/to/php-config
+ Specify directory where PHP5's include files are
installed (or a pointer to the full source tree)
Required in order to compile the PHP/MapScript
module.
@@ -21923,6 +21920,8 @@
# Check whether --with-php was given.
if test "${with_php+set}" = set; then :
withval=$with_php;
+else
+ with_php=no
fi
@@ -21932,269 +21931,12 @@
fi
-if test -n "$with_php" -a -d "$with_php" ; then
- if test -z "$with_php" || echo "$with_php" | grep '^/' >/dev/null ; then
- PHP_SRC_DIR="$with_php"
- else
- PHP_SRC_DIR="`pwd`/$with_php"
+if test "$with_php" != "no" ; then
+ if test -d "$with_php"; then
+ as_fn_error $? "--with-php now expects an optional path to php-config, not a directory" "$LINENO" 5
fi
- if test "$enable_perlv_ld_detect" = "yes" ; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: Using perl -V macro to figure ld command to link php_mapscript.so" >&5
-$as_echo "Using perl -V macro to figure ld command to link php_mapscript.so" >&6; }
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether 'perl -V' works" >&5
-$as_echo_n "checking whether 'perl -V' works... " >&6; }
- if (perl -V > /dev/null 2>&1) ; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
-$as_echo "yes" >&6; }
-# The following is a massive hack. It tries to steal the
-# mechanism for build a dynamic library from Perl's -V output
-# If this script fails on this machine, try running 'perl -V'
-# manually and pick out the setting for:
-# cc, optimize, ccflags, ld, cccdlflags and lddlflags
-# Replace the below definitions with the output you see.
-if test ! -r "perl.out"; then
- perl -V > perl.out
-fi
-# if the greps and cuts don't do the job, set these manually
-PERL_CC="`grep ' cc=' perl.out | cut -d, -f1 | cut -d\' -f2 | grep -v undef`"
-PERL_OPT="`grep ' optimize=' perl.out | cut -d, -f2 | cut -d\' -f2 | grep -v undef`"
-PERL_CCFLAGS="`grep ' ccflags' perl.out | cut -d, -f1 | grep cflags | cut -d\' -f2 | grep -v undef` `grep ' ccflags' perl.out | cut -d, -f2 | grep ccflags | cut -d\' -f2 | grep -v undef`"
-PERL_LD="`grep ' ld=' perl.out | cut -d, -f1 | cut -d\' -f2 | grep -v undef`"
-PERL_LFLAGS="`grep ' cccdlflags=' perl.out | cut -d, -f1 | cut -d\' -f2 | grep -v undef`"
-PERL_CCDLFLAGS="`grep ' ccdlflags=' perl.out | cut -d, -f4 | cut -d\' -f2 | sed 's, ,,' | grep -v undef`"
-PERL_LDDLFLAGS=`grep ' lddlflags' perl.out | cut -d, -f2 | cut -d\' -f2 | grep -v undef`
-#if test -n "$PERL_CCDLFLAGS" ; then
-# echo "-------------------------"
-# echo "----- IMPORTANT !!! -----"
-# echo "To use PHP extensions on your OS, you will need to recompile "
-# echo "PHP. "
-# echo "You need to edit the Makefile in the php3 directory and add "
-# echo "$PERL_CCDLFLAGS to the start of the LDFLAGS line at the top "
-# echo "of the Makefile. Then type: 'make clean; make' "
-# echo "You can still go ahead and build the extensions now by typing"
-# echo "'make' in this directory. They just won't work correctly "
-# echo "until you recompile your PHP. "
-# echo "If you are compiling php as a module, you should also add "
-# echo "$PERL_CCDLFLAGS to the start of the EXTRA_LDFLAGS in Apache "
-# echo "Configuration file. Note that if you are using the APACI "
-# echo "build mechanism you should make this change in the "
-# echo "Configuration.tmpl file instead. "
-#fi
-PERL_CC="$PERL_CC $PERL_OPT $PERL_CCFLAGS -I. -I.. $PERL_LFLAGS"
-PERL_LD="$PERL_LD $PERL_LDDLFLAGS $PERL_CCDLFLAGS"
-rm -f perl.out
- PHP_CC="$PERL_CC"
- PHP_LD="$PERL_LD $PHP_LD_XTRAFLAGS"
- else
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: no" >&5
-$as_echo "no" >&6; }
- as_fn_error $? "ERROR: Cannot use --enable-perlv-ld-detect since Perl -V does not work on this system." "$LINENO" 5
- fi
- else
- echo 'void f(){}' > conftest.c
- if test -z "`${CC} -fPIC -c conftest.c 2>&1`"; then
- C_PIC=-fPIC
- else
- C_PIC=
- fi
- rm -f conftest*
- C_PIC=$C_PIC
- echo 'void g(); int main(){ g(); return 0; }' > conftest1.c
- echo '#include <stdio.h>' > conftest2.c
- echo 'void g(); void g(){printf("");}' >> conftest2.c
- ${CC} ${C_PIC} -c conftest2.c
- SO_EXT="so"
- SO_COMMAND_NAME="-soname"
- export SO_EXT
- export SO_COMMAND_NAME
- LD_SHARED="/bin/true"
- if test ! -z "`uname -a | grep IRIX`" ; then
- IRIX_ALL=-all
- else
- IRIX_ALL=
- fi
-# Check whether --with-ld-shared was given.
-if test "${with_ld_shared+set}" = set; then :
- withval=$with_ld_shared;
-fi
- if test "$with_ld_shared" != "" -a "$with_ld_shared" != "yes"; then
- if test "$with_ld_shared" = "no" ; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: user disabled shared library support." >&5
-$as_echo "user disabled shared library support." >&6; }
- else
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: using user supplied .so link command ... $with_ld_shared" >&5
-$as_echo "using user supplied .so link command ... $with_ld_shared" >&6; }
- fi
- LD_SHARED="$with_ld_shared"
- fi
- if test ! -z "`uname -a | grep CYGWIN`" \
- -a "$LD_SHARED" = "/bin/true" ; then
- if test -z "`gcc -shared conftest2.o -o libconftest.dll`" ; then
- if test -z "`${CC} conftest1.c -L./ -lconftest -o conftest1 2>&1`"; then
- LD_LIBRARY_PATH_OLD="$LD_LIBRARY_PATH"
- if test -z "$LD_LIBRARY_PATH" ; then
- LD_LIBRARY_PATH="`pwd`"
- else
- LD_LIBRARY_PATH="`pwd`:$LD_LIBRARY_PATH"
- fi
- export LD_LIBRARY_PATH
- if test -z "`./conftest1 2>&1`" ; then
- echo "checking for Cygwin gcc -shared ... yes"
- LD_SHARED="c++ -shared"
- SO_EXT="dll"
- fi
- LD_LIBRARY_PATH="$LD_LIBRARY_PATH_OLD"
- fi
- fi
- fi
- if test ! -z "`uname | grep Darwin`" \
- if test -z "`${CXX} -dynamiclib conftest2.o -o libconftest.so 2>&1`" ; then
- ${CC} -c conftest1.c
- if test -z "`${CXX} conftest1.o libconftest.so -o conftest1 2>&1`"; then
- DYLD_LIBRARY_PATH_OLD="$DYLD_LIBRARY_PATH"
- if test -z "$DYLD_LIBRARY_PATH" ; then
- DYLD_LIBRARY_PATH="`pwd`"
- else
- DYLD_LIBRARY_PATH="`pwd`:$DYLD_LIBRARY_PATH"
- fi
- export DYLD_LIBRARY_PATH
- echo "checking for ${CXX} -dynamiclib ... yes"
- LD_SHARED="${CXX} -dynamiclib -single_module -flat_namespace -undefined suppress"
- SO_EXT=dylib
- SO_COMMAND_NAME='-dylib_install_name'
- fi
- DYLD_LIBRARY_PATH="$DYLD_LIBRARY_PATH_OLD"
- fi
- rm -f conftest1.o
- fi
- fi
- if test "$LD_SHARED" = "/bin/true" \
- -a -z "`${CXX} -shared $IRIX_ALL conftest2.o -o libconftest.so 2>&1|grep -v WARNING`" ; then
- if test -z "`${CC} conftest1.c libconftest.so -o conftest1 2>&1`"; then
- else
- fi
- echo "checking for ${CXX} -shared ... yes"
- LD_SHARED="${CXX} -shared $IRIX_ALL"
- else
- echo "checking for ${CXX} -shared ... no(3)"
- fi
- else
- echo "checking for ${CXX} -shared ... no(2)"
- fi
- else
- if test "$LD_SHARED" = "/bin/true" ; then
- echo "checking for ${CXX} -shared ... no(1)"
- fi
- fi
- -a -z "`ld -shared conftest2.o -o libconftest.so 2>&1`" ; then
- else
- fi
- echo "checking for ld -shared ... yes"
- LD_SHARED="ld -shared"
- fi
- fi
- fi
- echo "checking for ld -shared ... no"
- if test ! -x /bin/true ; then
- LD_SHARED=/usr/bin/true
- fi
- fi
- if test "$LD_SHARED" = "no" ; then
- if test -x /bin/true ; then
- LD_SHARED=/bin/true
- else
- fi
- fi
- rm -f conftest* libconftest*
- LD_SHARED=$LD_SHARED
- SO_EXT=$SO_EXT
- SO_COMMAND_NAME=$SO_COMMAND_NAME
- if test ! -z "`uname | grep Darwin`" ;then
- PHP_LD_SHARED="${CXX} -bundle -flat_namespace -undefined suppress"
- else
- PHP_LD_SHARED=$LD_SHARED
- fi
-export PHP_LD_SHARED
-PHP_LD_SHARED=$PHP_LD_SHARED
- PHP_CC="$CC $C_PIC"
- PHP_LD="$PHP_LD_SHARED $PHP_LD_XTRAFLAGS"
- fi
- test -z "$PHPCONFIG" -a -x "$PHP_SRC_DIR/php-config" && PHPCONFIG="$PHP_SRC_DIR/php-config"
- test -z "$PHPCONFIG" -a -x "$PHP_SRC_DIR/bin/php-config" && PHPCONFIG="$PHP_SRC_DIR/bin/php-config"
- test -z "$PHPCONFIG" && # Extract the first word of "php-config", so it can be a program name with args.
+ if test "$with_php" == "yes" ; then
+ # Extract the first word of "php-config", so it can be a program name with args.
set dummy php-config; ac_word=$2
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $ac_word" >&5
$as_echo_n "checking for $ac_word... " >&6; }
@@ -22235,30 +21977,35 @@
fi
- test -z "$PHPCONFIG" && as_fn_error $? "failed to find php-config utility" "$LINENO" 5
- PHPCONFIG=$PHPCONFIG
+ if test "x$PHPCONFIG" == "xno"; then
+ as_fn_error $? "php-config not found on path, please give its full location" "$LINENO" 5
+ fi
+ else
+ PHPCONFIG="$with_php"
+ fi
+ if test ! -f "$PHPCONFIG"; then
+ as_fn_error $? "$PHPCONFIG not found" "$LINENO" 5
+ fi
+ PHPINCDIR=`$PHPCONFIG --include-dir`
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for location of php_config.h" >&5
$as_echo_n "checking for location of php_config.h... " >&6; }
- test -f "$PHP_SRC_DIR/main/php_config.h" && test -f "$PHP_SRC_DIR/main/php_version.h" && PHP_CONFIG_H="$PHP_SRC_DIR/main/php_config.h"
+ test -f "$PHPINCDIR/main/php_config.h" && PHP_CONFIG_H="$PHPINCDIR/main/php_config.h"
- test -f "$PHP_SRC_DIR/include/php/main/php_config.h" && PHP_SRC_DIR="$PHP_SRC_DIR/include/php/" && PHP_CONFIG_H="$PHP_SRC_DIR/main/php_config.h"
- test -f "$PHP_SRC_DIR/include/php5/main/php_config.h" && PHP_SRC_DIR="$PHP_SRC_DIR/include/php5/" && PHP_CONFIG_H="$PHP_SRC_DIR/main/php_config.h"
if test -n "$PHP_CONFIG_H" ; then
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $PHP_CONFIG_H" >&5
$as_echo "$PHP_CONFIG_H" >&6; }
else
as_fn_error $? "
-!!! Could not find php_config.h and php_version.h in $PHP_SRC_DIR. !!!
-!!! Has PHP been configured yet? !!!" "$LINENO" 5
+!!! Could not find php_config.h and php_version.h in $PHPINCDIR. !!!
+!!! Has PHP been installed yet? !!!" "$LINENO" 5
fi
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if we have PHP 5.2.0+" >&5
$as_echo_n "checking if we have PHP 5.2.0+... " >&6; }
- PHP_VERSION=`grep 'PHP_VERSION_ID' $PHP_SRC_DIR/main/php_version.h | cut -d' ' -f3`
+ PHP_VERSION=`$PHPCONFIG --vernum`
if test -z "$PHP_VERSION" || test $PHP_VERSION -lt 50200; then
as_fn_error $? "
!!! PHP MapScript now requires PHP 5.2.0 or more recent. !!!
@@ -22268,8 +22015,6 @@
fi
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $PHP_VERSION_FLAG" >&5
-$as_echo "$PHP_VERSION_FLAG" >&6; }
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether we should use PHP's regex" >&5
$as_echo_n "checking whether we should use PHP's regex... " >&6; }
@@ -22277,18 +22022,18 @@
- test -f "$PHP_SRC_DIR/regex/regex_extra.h" && PHP_NO_SOURCE="1"
+ test -f "$PHPINCDIR/regex/regex_extra.h" && PHP_NO_SOURCE="1"
if test -n "$PHP_NO_SOURCE" ; then
USE_PHP_REGEX="-DUSE_PHP_REGEX"
- PHP_REGEX_INC="-I$PHP_SRC_DIR"
+ PHP_REGEX_INC="-I$PHPINCDIR"
PHP_REGEX_OBJ=php_regex.lo
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: found regex_extra.h - building PHP MapScript with PHP's bundled regex " >&5
$as_echo " found regex_extra.h - building PHP MapScript with PHP's bundled regex " >&6; }
else
- test -f "$PHP_SRC_DIR/ext/ereg/regex/regex.h" && PHP_NO_SOURCE="1"
+ test -f "$PHPINCDIR/ext/ereg/regex/regex.h" && PHP_NO_SOURCE="1"
- PHP_REGEX_INC="-I$PHP_SRC_DIR/ext/ereg/"
+ PHP_REGEX_INC="-I$PHPINCDIR/ext/ereg/"
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: found regex.h - building PHP MapScript with PHP's bundled regex " >&5
$as_echo " found regex.h - building PHP MapScript with PHP's bundled regex " >&6; }
@@ -22308,14 +22053,10 @@
MAKE_PHPMS=php_mapscript
MAKE_PHPMS_CLEAN=php_mapscript_clean
- PHP_VERSION_FLAG=$PHP_VERSION_FLAG
+ PHP_VERSION_FLAG="-DPHP_VERSION_ID=$PHP_VERSION"
- PHP_SRC_DIR=$PHP_SRC_DIR
+ PHPCONFIG=$PHPCONFIG
- PHP_CC=$PHP_CC
- PHP_LD=$PHP_LD
PHP_REGEX_INC=$PHP_REGEX_INC
PHP_REGEX_OBJ=$PHP_REGEX_OBJ
@@ -22325,8 +22066,6 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: PHP/MapScript module configured." >&5
$as_echo " PHP/MapScript module configured." >&6; }
-elif test -n "$with_php" -a "$with_php" != "no" ; then
- as_fn_error $? "Missing or invalid PHP source directory in --with-php=DIR." "$LINENO" 5
else
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: PHP/MapScript module not configured." >&5
$as_echo " PHP/MapScript module not configured." >&6; }
@@ -25145,7 +24884,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: -------------- MapScript ----------------- " >&5
$as_echo " -------------- MapScript ----------------- " >&6; }
-if test -n "${PHP_SRC_DIR}"; then
+if test -n "${PHPCONFIG}"; then
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: PHP MapScript: yes" >&5
$as_echo " PHP MapScript: yes" >&6; }
else
Modified: trunk/mapserver/configure.in
--- trunk/mapserver/configure.in 2011-12-23 15:03:41 UTC (rev 12912)
+++ trunk/mapserver/configure.in 2011-12-23 15:48:08 UTC (rev 12913)
@@ -2560,10 +2560,11 @@
AC_CHECKING(for PHP/MapScript module options)
AC_ARG_WITH(php,
-[ --with-php=DIR Specify directory where PHP5's include files are
+[ --with-php=yes|no|/path/to/php-config
- module.],,)
+ module.],,[with_php=no])
AC_ARG_ENABLE(internal-ld-detect,
[ --enable-perlv-ld-detect
@@ -2572,65 +2573,38 @@
link php_mapscript.so. Try this only if the default
internal macro didn't work.],,)
- AC_EXPAND_PATH($with_php, PHP_SRC_DIR)
- dnl
- dnl Checks for shared library linking.
- dnl
- dnl Default to internal AC_LD_SHARED macro, or use the the perl-based
- dnl if requested and perl is available...
- dnl (The perl-V macro was the default in 3.6 and before but this was
- dnl changed in 3.7 to use the internal AC_LD_SHARED macro by default)
- dnl
- AC_MSG_RESULT(Using perl -V macro to figure ld command to link php_mapscript.so)
- AC_MSG_CHECKING([whether 'perl -V' works])
- AC_MSG_RESULT(yes)
- AC_LD_SHARED_FROM_PERL
- PHP_CC="$PERL_CC"
- else
- AC_MSG_RESULT(no)
- AC_MSG_ERROR([ERROR: Cannot use --enable-perlv-ld-detect since Perl -V does not work on this system.])
+ AC_MSG_ERROR([--with-php now expects an optional path to php-config, not a directory])
+ fi
+ AC_PATH_PROG(PHPCONFIG,php-config,no)
+ AC_MSG_ERROR([php-config not found on path, please give its full location])
fi
else
- dnl The default: use the internal AC_LD_SHARED macro
- dnl
- AC_COMPILER_PIC
- dnl AC_LD_SHARED
- AC_PHP_LD_SHARED
fi
- test -z "$PHPCONFIG" && AC_PATH_PROG(PHPCONFIG, php-config, no)
- test -z "$PHPCONFIG" && AC_MSG_ERROR([failed to find php-config utility])
- AC_SUBST(PHPCONFIG,$PHPCONFIG)
+ AC_MSG_ERROR([$PHPCONFIG not found])
+ fi
dnl
dnl Look for PHP5's php_config.h.
dnl We'll need the config file to find info about the PHP configuration
dnl
AC_MSG_CHECKING([for location of php_config.h])
dnl Look for the main/php_config.h
- dnl If php was installed, then the headers are under $prefix/include/php/*
- dnl In PHP 5, few distributions use "/usr/include/php5" directory
AC_MSG_RESULT([$PHP_CONFIG_H])
else
AC_MSG_ERROR([
-!!! Has PHP been configured yet? !!!])
+!!! Has PHP been installed yet? !!!])
fi
@@ -2638,7 +2612,7 @@
dnl Default is PHP3, and if ZEND_API is set then we assume that we have PHP4.
dnl
AC_MSG_CHECKING([if we have PHP 5.2.0+])
AC_MSG_ERROR([
@@ -2647,7 +2621,6 @@
else
AC_MSG_RESULT([yes])
fi
- AC_MSG_RESULT([$PHP_VERSION_FLAG])
dnl
dnl Check if PHP was compiled with the bundled regex, and if so then
@@ -2659,20 +2632,20 @@
dnl We'll check for regex_extra.h - that might let use build
dnl without the source using libphp_common.so
dnl Found regex_extra.h
AC_MSG_RESULT([ found regex_extra.h - building PHP MapScript with PHP's bundled regex ])
else
dnl PHP 5.3 changed the layout of regex-related files.
dnl Found regex.h
AC_MSG_RESULT([ found regex.h - building PHP MapScript with PHP's bundled regex ])
else
@@ -2690,17 +2663,13 @@
- AC_SUBST(PHP_VERSION_FLAG, $PHP_VERSION_FLAG)
- AC_SUBST(PHP_SRC_DIR, $PHP_SRC_DIR)
- AC_SUBST(PHP_CC, $PHP_CC)
- AC_SUBST(PHP_LD, $PHP_LD)
+ AC_SUBST(PHP_VERSION_FLAG, "-DPHP_VERSION_ID=$PHP_VERSION")
+ AC_SUBST(PHPCONFIG, $PHPCONFIG)
AC_SUBST(PHP_REGEX_INC, $PHP_REGEX_INC)
AC_SUBST(PHP_REGEX_OBJ, $PHP_REGEX_OBJ)
AC_SUBST(USE_PHP_REGEX, $USE_PHP_REGEX)
AC_MSG_RESULT([ PHP/MapScript module configured.])
- AC_MSG_ERROR([Missing or invalid PHP source directory in --with-php=DIR.])
else
AC_MSG_RESULT([ PHP/MapScript module not configured.])
fi
@@ -2837,7 +2806,7 @@
AC_MSG_RESULT()
AC_MSG_RESULT([ -------------- MapScript ----------------- ])
AC_MSG_RESULT([ PHP MapScript: yes])
else
AC_MSG_RESULT([ PHP MapScript: no])
Modified: trunk/mapserver/mapscript/php/Makefile.in
--- trunk/mapserver/mapscript/php/Makefile.in 2011-12-23 15:03:41 UTC (rev 12912)
+++ trunk/mapserver/mapscript/php/Makefile.in 2011-12-23 15:48:08 UTC (rev 12913)
@@ -47,6 +47,7 @@
LD= @CXX@
LIBTOOL=@LIBTOOL@
INSTALL=@INSTALL@
+PHPCONFIG=@PHPCONFIG@
LTCC=$(LIBTOOL) --mode=compile --tag=CC
LTCXX=$(LIBTOOL) --mode=compile --tag=CXX
@@ -58,13 +59,8 @@
CFLAGS = @CFLAGS@ @USE_PHP_REGEX@ -DCOMPILE_DL=1 @PHP_VERSION_FLAG@
-# Set PHP_SRC_DIR to point to the root of the PHP source tree
-PHP_SRC_DIR = @PHP_SRC_DIR@
-PHP_INC = -I$(PHP_SRC_DIR) -I$(PHP_SRC_DIR)/dl -I$(PHP_SRC_DIR)/main \
- -I$(PHP_SRC_DIR)/Zend -I$(PHP_SRC_DIR)/include \
- -I$(PHP_SRC_DIR)/TSRM @APACHE_INC@
+PHP_INC = `$(PHPCONFIG) --includes ` @APACHE_INC@
# IMPORTANT NOTE ABOUT REGEX FOR PHP_MAPSCRIPT USERS:
@@ -74,7 +70,6 @@
PHP_REGEX_OBJ=@PHP_REGEX_OBJ@
PHP_REGEX_INC=@PHP_REGEX_INC@
-PHPCONFIG=@PHPCONFIG@
More information about the mapserver-commits
