[mapserver-commits] r12927 - in trunk/msautotest/wxs: . expected
Wed Dec 28 11:22:25 EST 2011
Author: schpidi
Date: 2011-12-28 08:22:25 -0800 (Wed, 28 Dec 2011)
New Revision: 12927
Added:
   trunk/msautotest/wxs/expected/wms_empty_cap100.xml
   trunk/msautotest/wxs/expected/wms_empty_cap111.xml
   trunk/msautotest/wxs/expected/wms_empty_cap130.xml
   trunk/msautotest/wxs/expected/wms_empty_cap_latestversion.xml
   trunk/msautotest/wxs/wms_empty.map
Addint tests for WMS GetCapabilities with an empty list of layers (#3755 comment 5).
Added: trunk/msautotest/wxs/expected/wms_empty_cap100.xml
--- trunk/msautotest/wxs/expected/wms_empty_cap100.xml	                        (rev 0)
+++ trunk/msautotest/wxs/expected/wms_empty_cap100.xml	2011-12-28 16:22:25 UTC (rev 12927)
@@ -0,0 +1,53 @@
+<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
+<!DOCTYPE WMT_MS_Capabilities SYSTEM "http://schemas.opengis.net/wms/1.0.0/capabilities_1_0_0.dtd"
+ <!ELEMENT VendorSpecificCapabilities EMPTY>
+ ]>  <!-- end of DOCTYPE declaration -->
+<WMT_MS_Capabilities version="1.0.0">
+<!-- MapServer version 6.1-dev-v1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE -->
+<Service>
+  <Name>GetMap</Name>
+  <Title>Test simple wms</Title>
+  <OnlineResource>http://www.mapserver.org/</OnlineResource>
+</Service>
+<Capability>
+  <Request>
+    <Map>
+      <Format><GIF /><PNG /><JPEG /><SVG /></Format>
+      <DCPType>
+        <HTTP>
+          <Get onlineResource="http://localhost/path/to/wms_simple?" />
+          <Post onlineResource="http://localhost/path/to/wms_simple?" />
+        </HTTP>
+      </DCPType>
+    </Map>
+    <Capabilities>
+      <Format><WMS_XML /></Format>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </Capabilities>
+    <FeatureInfo>
+      <Format><MIME /><GML.1 /></Format>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </FeatureInfo>
+  </Request>
+  <Exception>
+    <Format><BLANK /><INIMAGE /><WMS_XML /></Format>
+  </Exception>
+  <VendorSpecificCapabilities />
+  <!-- WARNING: No WMS layers are enabled. Check wms/ows_enable_request settings. -->
+</Capability>
+</WMT_MS_Capabilities>
Added: trunk/msautotest/wxs/expected/wms_empty_cap111.xml
--- trunk/msautotest/wxs/expected/wms_empty_cap111.xml	                        (rev 0)
+++ trunk/msautotest/wxs/expected/wms_empty_cap111.xml	2011-12-28 16:22:25 UTC (rev 12927)
@@ -0,0 +1,97 @@
+<!DOCTYPE WMT_MS_Capabilities SYSTEM "http://schemas.opengis.net/wms/1.1.1/WMS_MS_Capabilities.dtd"
+<WMT_MS_Capabilities version="1.1.1">
+<Service>
+  <Name>OGC:WMS</Name>
+  <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.mapserver.org/"/>
+  <ContactInformation>
+  </ContactInformation>
+</Service>
+<Capability>
+  <Request>
+    <GetCapabilities>
+      <Format>application/vnd.ogc.wms_xml</Format>
+      <DCPType>
+        <HTTP>
+          <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://localhost/path/to/wms_simple?"/></Get>
+          <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://localhost/path/to/wms_simple?"/></Post>
+        </HTTP>
+      </DCPType>
+    </GetCapabilities>
+    <GetMap>
+      <Format>image/png</Format>
+      <Format>image/jpeg</Format>
+      <Format>image/gif</Format>
+      <Format>image/png; mode=8bit</Format>
+      <Format>application/x-pdf</Format>
+      <Format>image/svg+xml</Format>
+      <Format>image/tiff</Format>
+      <Format>application/vnd.google-earth.kml+xml</Format>
+      <Format>application/vnd.google-earth.kmz</Format>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </GetMap>
+    <GetFeatureInfo>
+      <Format>text/plain</Format>
+      <Format>application/vnd.ogc.gml</Format>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </GetFeatureInfo>
+    <DescribeLayer>
+      <Format>text/xml</Format>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </DescribeLayer>
+    <GetLegendGraphic>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </GetLegendGraphic>
+    <GetStyles>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </GetStyles>
+  </Request>
+  <Exception>
+    <Format>application/vnd.ogc.se_xml</Format>
+    <Format>application/vnd.ogc.se_inimage</Format>
+    <Format>application/vnd.ogc.se_blank</Format>
+  </Exception>
+  <UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1" RemoteWFS="0"/>
+</Capability>
Added: trunk/msautotest/wxs/expected/wms_empty_cap130.xml
--- trunk/msautotest/wxs/expected/wms_empty_cap130.xml	                        (rev 0)
+++ trunk/msautotest/wxs/expected/wms_empty_cap130.xml	2011-12-28 16:22:25 UTC (rev 12927)
@@ -0,0 +1,93 @@
+<WMS_Capabilities version="1.3.0"  xmlns="http://www.opengis.net/wms"   xmlns:sld="http://www.opengis.net/sld"   xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"   xmlns:ms="http://mapserver.gis.umn.edu/mapserver"   xsi:schemaLocation="http://www.opengis.net/wms http://schemas.opengis.net/wms/1.3.0/capabilities_1_3_0.xsd  http://www.opengis.net/sld http://schemas.opengis.net/sld/1.1.0/sld_capabilities.xsd  http://mapserver.gis.umn.edu/mapserver http://localhost/path/to/wms_simple?service=WMS&amp;version=1.3.0&amp;request=GetSchemaExtension">
+<Service>
+  <Name>WMS</Name>
+  <MaxWidth>2048</MaxWidth>
+  <MaxHeight>2048</MaxHeight>
+</Service>
+<Capability>
+  <Request>
+    <GetCapabilities>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    <GetMap>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </GetMap>
+    <GetFeatureInfo>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </GetFeatureInfo>
+    <sld:DescribeLayer>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </sld:DescribeLayer>
+    <sld:GetLegendGraphic>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </sld:GetLegendGraphic>
+    <ms:GetStyles>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </ms:GetStyles>
+  </Request>
+  <Exception>
+    <Format>XML</Format>
+    <Format>INIMAGE</Format>
+    <Format>BLANK</Format>
+  </Exception>
+  <sld:UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1" RemoteWFS="0" InlineFeature="0" RemoteWCS="0"/>
+</Capability>
+</WMS_Capabilities>
Added: trunk/msautotest/wxs/expected/wms_empty_cap_latestversion.xml
--- trunk/msautotest/wxs/expected/wms_empty_cap_latestversion.xml	                        (rev 0)
+++ trunk/msautotest/wxs/expected/wms_empty_cap_latestversion.xml	2011-12-28 16:22:25 UTC (rev 12927)
@@ -0,0 +1,93 @@
+<Service>
+  <Name>WMS</Name>
+</Service>
+<Capability>
+  <Request>
+    <GetCapabilities>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    <GetMap>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </GetMap>
+    <GetFeatureInfo>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </GetFeatureInfo>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    <ms:GetStyles>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </ms:GetStyles>
+  </Request>
+  <Exception>
+  </Exception>
+</Capability>
Added: trunk/msautotest/wxs/wms_empty.map
--- trunk/msautotest/wxs/wms_empty.map	                        (rev 0)
+++ trunk/msautotest/wxs/wms_empty.map	2011-12-28 16:22:25 UTC (rev 12927)
@@ -0,0 +1,22 @@
+# Test empty WMS
+# REQUIRES: OUTPUT=PNG SUPPORTS=WMS
+# Capabilities (return no/empty layers element)
+# RUN_PARMS: wms_empty_cap_latestversion.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&REQUEST=GetCapabilities" > [RESULT_DEMIME]
+# RUN_PARMS: wms_empty_cap130.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities" > [RESULT_DEMIME]
+# RUN_PARMS: wms_empty_cap111.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities" > [RESULT_DEMIME]
+# RUN_PARMS: wms_empty_cap100.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.0.0&REQUEST=GetCapabilities" > [RESULT_DEMIME]
+MAP
+  WEB
+    METADATA
+      "wms_title"             "Test simple wms"
+      "wms_onlineresource"    "http://localhost/path/to/wms_simple?"
+      "ows_service_onlineresource" "http://www.mapserver.org/"
+      "ows_enable_request" "*"
+    END
+  END
+END # Map File
