[mapserver-commits] r11891 - branches/branch-5-6/mapserver
Tue Jul 12 09:09:18 EDT 2011
Author: assefa
Date: 2011-07-12 06:09:18 -0700 (Tue, 12 Jul 2011)
New Revision: 11891
   branches/branch-5-6/mapserver/HISTORY.TXT
   branches/branch-5-6/mapserver/maplayer.c
   branches/branch-5-6/mapserver/mapogcfilter.c
   branches/branch-5-6/mapserver/mapogcfilter.h
   branches/branch-5-6/mapserver/mapogcsos.c
   branches/branch-5-6/mapserver/mapogr.cpp
   branches/branch-5-6/mapserver/mappostgis.c
   branches/branch-5-6/mapserver/mapserver.h
Security fixes (#3903)
Modified: branches/branch-5-6/mapserver/HISTORY.TXT
--- branches/branch-5-6/mapserver/HISTORY.TXT	2011-07-12 13:06:14 UTC (rev 11890)
+++ branches/branch-5-6/mapserver/HISTORY.TXT	2011-07-12 13:09:18 UTC (rev 11891)
@@ -14,6 +14,14 @@
 Version 5.6.7 (SVN branch-5-6):
+IMPORTANT SECURITY FIXE:
+-  Fixes to prevent SQL injections through OGC filter encoding (in WMS, WFS
+   and SOS), as well as a potential SQL injection in WMS time support.
+   Your system may be vulnerable if it has MapServer with OGC protocols
+   enabled, with layers connecting to an SQL RDBMS backend, either
+   natively or via OGR (#3903)
 - Fixed PHP/MapScript ms_iogetstdoutbufferbytes() always returning 0 bytes written (#3041)
 - OGC Filter: fix segfault when a ows_varname_type or wfs_varname_type is
Modified: branches/branch-5-6/mapserver/maplayer.c
--- branches/branch-5-6/mapserver/maplayer.c	2011-07-12 13:06:14 UTC (rev 11890)
+++ branches/branch-5-6/mapserver/maplayer.c	2011-07-12 13:09:18 UTC (rev 11891)
@@ -1051,6 +1051,85 @@
   return MS_FAILURE;
+/*                          LayerDefaultEscapeSQLParam                  */
+/*      Default function used to escape strings and avoid sql           */
+/*      injection. Specific drivers should redefine if an escaping      */
+/*      function is available in the driver.                            */
+char *LayerDefaultEscapeSQLParam(layerObj *layer, const char* pszString)
+     char *pszEscapedStr=NULL;
+     if (pszString)
+         int nSrcLen;
+         char c;
+         int i=0, j=0;
+         nSrcLen = (int)strlen(pszString);
+         pszEscapedStr = (char*) malloc( 2 * nSrcLen + 1);
+         for(i = 0, j = 0; i < nSrcLen; i++)
+             c = pszString[i];
+             if (c == '\'')
+                 pszEscapedStr[j++] = '\'';
+             else if (c == '\\')
+                 pszEscapedStr[j++] = '\\';
+             else
+               pszEscapedStr[j++] = c;
+         pszEscapedStr[j] = 0;
+     return pszEscapedStr;
+/*                          LayerDefaultEscapePropertyName              */
+/*      Return the property name in a properly escaped and quoted form. */
+char *LayerDefaultEscapePropertyName(layerObj *layer, const char* pszString)
+     char* pszEscapedStr=NULL;
+     int i, j = 0;
+     if (layer && pszString && strlen(pszString) > 0)
+         int nLength = strlen(pszString);
+         pszEscapedStr = (char*) malloc( 1 + 2 * nLength + 1 + 1);
+         pszEscapedStr[j++] = '"';
+         for (i=0; i<nLength; i++)
+             char c = pszString[i];
+             if (c == '"')
+                 pszEscapedStr[j++] ='"';
+             else
+         pszEscapedStr[j++] = 0;
  * msConnectLayer
@@ -1108,6 +1187,10 @@
   vtable->LayerGetNumFeatures = LayerDefaultGetNumFeatures;
+  vtable->LayerEscapeSQLParam = LayerDefaultEscapeSQLParam;
+  vtable->LayerEscapePropertyName = LayerDefaultEscapePropertyName;
   return MS_SUCCESS;
@@ -1280,6 +1363,32 @@
     return i;
+Returns an escaped string
+char  *msLayerEscapeSQLParam(layerObj *layer, const char*pszString)
+    if ( ! layer->vtable) {
+        int rv =  msInitializeVirtualTable(layer);
+        if (rv != MS_SUCCESS)
+            return "";
+    return layer->vtable->LayerEscapeSQLParam(layer, pszString);
+char  *msLayerEscapePropertyName(layerObj *layer, const char*pszString)
+            return "";
+    return layer->vtable->LayerEscapePropertyName(layer, pszString);
 int
 msINLINELayerInitializeVirtualTable(layerObj *layer)
@@ -1312,5 +1421,7 @@
     /* layer->vtable->LayerCreateItems, use default */
     layer->vtable->LayerGetNumFeatures = msINLINELayerGetNumFeatures;
+    /*layer->vtable->LayerEscapeSQLParam, use default*/
+    /*layer->vtable->LayerEscapePropertyName, use default*/
     return MS_SUCCESS;
Modified: branches/branch-5-6/mapserver/mapogcfilter.c
--- branches/branch-5-6/mapserver/mapogcfilter.c	2011-07-12 13:06:14 UTC (rev 11890)
+++ branches/branch-5-6/mapserver/mapogcfilter.c	2011-07-12 13:09:18 UTC (rev 11891)
@@ -175,7 +175,7 @@
         if (tokens && nTokens == 2)
             char szTmp[32];
-            sprintf(szTmp, "init=epsg:%s",tokens[1]);
+            snprintf(szTmp, sizeof(szTmp), "init=epsg:%s",tokens[1]);
             msInitProjection(psProj);
             if (msLoadProjectionString(psProj, szTmp) == 0)
               nStatus = MS_TRUE;
@@ -200,7 +200,7 @@
             if (nEpsgTmp > 0)
                 char szTmp[32];
-                sprintf(szTmp, "init=epsg:%d",nEpsgTmp);
+                snprintf(szTmp, sizeof(szTmp), "init=epsg:%d",nEpsgTmp);
                   nStatus = MS_TRUE;
@@ -996,7 +996,7 @@
             char szTmp[32];
             msInitProjection(&sProjTmp);
             if (msLoadProjectionString(&sProjTmp, szTmp) == 0)
               msProjectRect(&sProjTmp, &map->projection,  &sQueryRect);
@@ -1021,7 +1021,7 @@
             if (nEpsgTmp > 0)
                 char szTmp[32];
@@ -2798,9 +2798,9 @@
                               bString = 1;
                         if (bString)
-                          sprintf(szTmp, "('[%s]' = '%s')" , pszAttribute, tokens[i]);
+                          snprintf(szTmp, sizeof(szTmp), "('[%s]' = '%s')" , pszAttribute, tokens[i]);
                         else
-                           sprintf(szTmp, "([%s] = %s)" , pszAttribute, tokens[i]);
+                          snprintf(szTmp, sizeof(szTmp), "([%s] = %s)" , pszAttribute, tokens[i]);
                         if (pszExpression != NULL)
                           pszExpression = msStringConcatenate(pszExpression, " OR ");
@@ -2865,8 +2865,7 @@
                                 "PropertyIsLike") == 0)
                  pszExpression =
-                   FLTGetIsLikeComparisonSQLExpression(psFilterNode,
-                                                       connectiontype);
+                   FLTGetIsLikeComparisonSQLExpression(psFilterNode, lp);
@@ -2903,6 +2902,7 @@
                 bString = 0;
                 if (tokens && nTokens > 0)
+                    char *pszEscapedStr = NULL;
                     for (i=0; i<nTokens; i++)
                         if (i == 0)
@@ -2910,7 +2910,7 @@
                             char *pszTmpType = NULL;
                             pszTmpType = (char *)malloc(sizeof(char)*strlen(pszAttribute)+7);
                             pszTmp = tokens[0];
-                            sprintf(pszTmpType, "%s_type",  pszAttribute);
+                            snprintf(pszTmpType, sizeof(szTmp), "%s_type",  pszAttribute);
                             if (msOWSLookupMetadata(&(lp->metadata), "G", pszTmpType) != NULL &&
                                 (strcasecmp(msOWSLookupMetadata(&(lp->metadata), "G", pszTmpType), "Character") == 0))
                               bString = 1;
@@ -2920,11 +2920,15 @@
                             msFree(pszTmpType);
+                        pszEscapedStr = msLayerEscapeSQLParam(lp, tokens[i]);
                         if (bString)
-                          sprintf(szTmp, "(%s = '%s')" , pszAttribute, tokens[i]);
+                          snprintf(szTmp, sizeof(szTmp), "(%s = '%s')" , pszAttribute, pszEscapedStr);
                         else
-                           sprintf(szTmp, "(%s = %s)" , pszAttribute, tokens[i]);
+                          snprintf(szTmp, sizeof(szTmp), "(%s = %s)" , pszAttribute, pszEscapedStr);
+                        msFree(pszEscapedStr);
+                        pszEscapedStr=NULL;
                         else
@@ -3208,6 +3212,7 @@
 char *FLTGetBinaryComparisonExpresssion(FilterEncodingNode *psFilterNode, layerObj *lp)
+    const size_t bufferSize = 1024;
     char szBuffer[1024];
     int bString=0;
     char szTmp[256];
@@ -3238,16 +3243,16 @@
     if (bString)
-      strcat(szBuffer, " (\"[");
+      strlcat(szBuffer, " (\"[", bufferSize);
     else
-      strcat(szBuffer, " ([");
+      strlcat(szBuffer, " ([", bufferSize);
     /* attribute */
-    strcat(szBuffer, psFilterNode->psLeftNode->pszValue);
+    strlcat(szBuffer, psFilterNode->psLeftNode->pszValue, bufferSize);
     if (bString)
-      strcat(szBuffer, "]\" ");
+      strlcat(szBuffer, "]\" ", bufferSize);
     else
-      strcat(szBuffer, "] ");
+     strlcat(szBuffer, "] ", bufferSize);
     /* logical operator */
@@ -3258,40 +3263,40 @@
         if (psFilterNode->psRightNode->pOther &&
             (*(int *)psFilterNode->psRightNode->pOther) == 1)
-            strcat(szBuffer, "IEQ");
+            strlcat(szBuffer, "IEQ", bufferSize);
         else
-          strcat(szBuffer, "=");
+          strlcat(szBuffer, "=",bufferSize);
     else if (strcasecmp(psFilterNode->pszValue,
                         "PropertyIsNotEqualTo") == 0)
-      strcat(szBuffer, "!=");
+      strlcat(szBuffer, "!=", bufferSize);
                         "PropertyIsLessThan") == 0)
-      strcat(szBuffer, "<");
+      strlcat(szBuffer, "<", bufferSize);
                         "PropertyIsGreaterThan") == 0)
-      strcat(szBuffer, ">");
+      strlcat(szBuffer, ">", bufferSize);
                         "PropertyIsLessThanOrEqualTo") == 0)
-      strcat(szBuffer, "<=");
+      strlcat(szBuffer, "<=", bufferSize);
                         "PropertyIsGreaterThanOrEqualTo") == 0)
-      strcat(szBuffer, ">=");
+      strlcat(szBuffer, ">=", bufferSize);
-    strcat(szBuffer, " ");
+    strlcat(szBuffer, " ", bufferSize);
     /* value */
     if (bString)
-      strcat(szBuffer, "\"");
+      strlcat(szBuffer, "\"", bufferSize);
     if (psFilterNode->psRightNode->pszValue)
-      strcat(szBuffer, psFilterNode->psRightNode->pszValue);
+      strlcat(szBuffer, psFilterNode->psRightNode->pszValue,bufferSize);
     if (bString)
+      strlcat(szBuffer, "\"",bufferSize);
-    strcat(szBuffer, ") ");
+    strlcat(szBuffer, ") ",bufferSize);
     return strdup(szBuffer);
@@ -3306,9 +3311,11 @@
 char *FLTGetBinaryComparisonSQLExpresssion(FilterEncodingNode *psFilterNode,
                                            layerObj *lp)
     int bString=0;
     char szTmp[256];
+    char* pszEscapedStr = NULL;
     szBuffer[0] = '\0';
     if (!psFilterNode || !
@@ -3338,8 +3345,10 @@
     /*opening bracket*/
-    strcat(szBuffer, " (");
+    strlcat(szBuffer, " (", bufferSize);
+    pszEscapedStr = msLayerEscapePropertyName(lp, psFilterNode->psLeftNode->pszValue);
     /* attribute */
     /*case insensitive set ? */
     if (bString &&
@@ -3348,35 +3357,37 @@
-        sprintf(szTmp, "lower(%s) ",  psFilterNode->psLeftNode->pszValue);
-        strcat(szBuffer, szTmp);
+        snprintf(szTmp, sizeof(szTmp), "lower(%s) ",  pszEscapedStr);
+        strlcat(szBuffer, szTmp, bufferSize);
     else
+      strlcat(szBuffer, pszEscapedStr, bufferSize);
+    pszEscapedStr = NULL;
-    if (strcasecmp(psFilterNode->pszValue,
+   if (strcasecmp(psFilterNode->pszValue,
                    "PropertyIsEqualTo") == 0)
+      strlcat(szBuffer, "=", bufferSize);
-      strcat(szBuffer, "<>");
+      strlcat(szBuffer, "<>", bufferSize);
     /* value */
@@ -3387,23 +3398,33 @@
-        sprintf(szTmp, "lower('%s') ",  psFilterNode->psRightNode->pszValue);
+        snprintf(szTmp, sizeof(szTmp), "lower('%s') ",  psFilterNode->psRightNode->pszValue);
     else
         if (bString)
-          strcat(szBuffer, "'");
+          strlcat(szBuffer, "'", bufferSize);
+            if (bString)
+                char* pszEscapedStr;
+                pszEscapedStr = msLayerEscapeSQLParam(lp, psFilterNode->psRightNode->pszValue);
+            else
+              strlcat(szBuffer, psFilterNode->psRightNode->pszValue, bufferSize);
         if (bString)
     /*closing bracket*/
+    strlcat(szBuffer, ") ", bufferSize);
@@ -3417,13 +3438,14 @@
 char *FLTGetIsBetweenComparisonSQLExpresssion(FilterEncodingNode *psFilterNode,
                                               layerObj *lp)
     char **aszBounds = NULL;
     int nBounds = 0;
     int bString=0;
     char szTmp[256];
     szBuffer[0] = '\0';
         !(strcasecmp(psFilterNode->pszValue, "PropertyIsBetween") == 0))
@@ -3467,32 +3489,46 @@
 /*      build expresssion.                                              */
     /*opening paranthesis */
+    strlcat(szBuffer, " (",bufferSize);
     /* attribute */
     /*between*/
-    strcat(szBuffer, " BETWEEN ");
+    strlcat(szBuffer, " BETWEEN ",bufferSize);
     /*bound 1*/
     if (bString)
-      strcat(szBuffer,"'");
-    strcat(szBuffer, aszBounds[0]);
+      strlcat(szBuffer,"'",bufferSize);
+    pszEscapedStr = msLayerEscapeSQLParam( lp, aszBounds[0]);
     if (bString)
-    strcat(szBuffer, " AND ");
+    strlcat(szBuffer, " AND ",bufferSize);
     /*bound 2*/
     if (bString)
-    strcat(szBuffer, aszBounds[1]);
+      strlcat(szBuffer, "'",bufferSize);
+    pszEscapedStr = msLayerEscapeSQLParam( lp, aszBounds[1]);
     if (bString)
     /*closing paranthesis*/
-    strcat(szBuffer, ")");
+    strlcat(szBuffer, ")",bufferSize);
@@ -3506,6 +3542,7 @@
 char *FLTGetIsBetweenComparisonExpresssion(FilterEncodingNode *psFilterNode,
                                            layerObj *lp)
     int nBounds = 0;
@@ -3526,7 +3563,10 @@
     aszBounds = msStringSplit(psFilterNode->psRightNode->pszValue, ';', &nBounds);
     if (nBounds != 2)
+      msFreeCharArray(aszBounds, nBounds);
       return NULL;
 /*      check if the value is a numeric value or alphanumeric. If it    */
 /*      is alphanumeric, add quotes around attribute and values.        */
@@ -3537,9 +3577,9 @@
         const char* pszOFGType;
         snprintf(szTmp, sizeof(szTmp), "%s_type",  psFilterNode->psLeftNode->pszValue);
         pszOFGType = msOWSLookupMetadata(&(lp->metadata), "OFG", szTmp);
-        if (pszOFGType != NULL && strcasecmp(pszOFGType, "Character") == 0)
+        if (pszOFGType!= NULL && strcasecmp(pszOFGType, "Character") == 0)
           bString = 1;
-        else if (FLTIsNumeric(aszBounds[0]) == MS_FALSE)
+        else if (FLTIsNumeric(aszBounds[0]) == MS_FALSE)
           bString = 1;
     if (!bString)
@@ -3556,50 +3596,51 @@
     if (bString)
     else
     /* attribute */
     if (bString)
     else
-    strcat(szBuffer, " >= ");
+    strlcat(szBuffer, " >= ", bufferSize);
     if (bString)
-      strcat(szBuffer,"\"");
+      strlcat(szBuffer,"\"", bufferSize);
+    strlcat(szBuffer, aszBounds[0], bufferSize);
     if (bString)
+    strlcat(szBuffer, " AND ", bufferSize);
     if (bString)
-      strcat(szBuffer, " \"[");
+      strlcat(szBuffer, " \"[", bufferSize);
     else
-      strcat(szBuffer, " [");
+      strlcat(szBuffer, " [", bufferSize);
     /* attribute */
     if (bString)
     else
-    strcat(szBuffer, " <= ");
+    strlcat(szBuffer, " <= ", bufferSize);
     if (bString)
+    strlcat(szBuffer, aszBounds[1], bufferSize);
     if (bString)
+    strlcat(szBuffer, ")", bufferSize);
@@ -3610,6 +3651,7 @@
 char *FLTGetIsLikeComparisonExpression(FilterEncodingNode *psFilterNode)
     char *pszValue = NULL;
@@ -3657,43 +3699,49 @@
-        if (pszValue[i] != pszWild[0] &&
-            pszValue[i] != pszSingle[0] &&
-            pszValue[i] != pszEscape[0])
+        if (iBuffer < 1024)
-            szBuffer[iBuffer] = pszValue[i];
-            iBuffer++;
-            szBuffer[iBuffer] = '\0';
-        else if  (pszValue[i] == pszSingle[0])
-             szBuffer[iBuffer] = '.';
-             iBuffer++;
-        else if  (pszValue[i] == pszEscape[0])
-            szBuffer[iBuffer] = '\\';
-            iBuffer++;
+            if (pszValue[i] != pszWild[0] &&
+                pszValue[i] != pszSingle[0] &&
+                pszValue[i] != pszEscape[0])
+                szBuffer[iBuffer] = pszValue[i];
+                iBuffer++;
+                szBuffer[iBuffer] = '\0';
+            else if  (pszValue[i] == pszSingle[0])
+                szBuffer[iBuffer] = '.';
+                iBuffer++;
+            else if  (pszValue[i] == pszEscape[0])
+                szBuffer[iBuffer] = '\\';
+                iBuffer++;
+            else if (pszValue[i] == pszWild[0])
+                /* strcat(szBuffer, "[0-9,a-z,A-Z,\\s]*"); */
+                /* iBuffer+=17; */
+                strlcat(szBuffer, ".*",bufferSize);
+                iBuffer+=2;
-        else if (pszValue[i] == pszWild[0])
-            /* strcat(szBuffer, "[0-9,a-z,A-Z,\\s]*"); */
-            /* iBuffer+=17; */
-            strcat(szBuffer, ".*");
-            iBuffer+=2;
-    szBuffer[iBuffer] = '/';
-    if (bCaseInsensitive == 1)
-      szBuffer[++iBuffer] = 'i';
-    szBuffer[++iBuffer] = '\0';
+        szBuffer[iBuffer] = '/';
+        if (bCaseInsensitive == 1)
+            szBuffer[++iBuffer] = 'i';
+        szBuffer[++iBuffer] = '\0';
@@ -3704,8 +3752,9 @@
 /*      Build an sql expression for IsLike filter.                      */
 char *FLTGetIsLikeComparisonSQLExpression(FilterEncodingNode *psFilterNode,
-                                          int connectiontype)
+                                           layerObj *lp)
@@ -3714,9 +3763,11 @@
     char *pszEscape = NULL;
     char szTmp[4];
-    int nLength=0, i=0, iBuffer = 0;
+    int nLength=0, i=0, j=0;
     int  bCaseInsensitive = 0;
     if (!psFilterNode || !psFilterNode->pOther || !psFilterNode->psLeftNode ||
         !psFilterNode->psRightNode || !psFilterNode->psRightNode->pszValue)
       return NULL;
@@ -3735,60 +3786,80 @@
     szBuffer[0] = '\0';
     /*opening bracket*/
     /* attribute name */
-    if (bCaseInsensitive == 1 && connectiontype == MS_POSTGIS)
-      strcat(szBuffer, " ilike '");
+    if (bCaseInsensitive == 1 && lp->connectiontype == MS_POSTGIS)
+      strlcat(szBuffer, " ilike '",bufferSize);
     else
-      strcat(szBuffer, " like '");
+      strlcat(szBuffer, " like '",bufferSize);
     pszValue = psFilterNode->psRightNode->pszValue;
     nLength = strlen(pszValue);
-    iBuffer = strlen(szBuffer);
+    pszEscapedStr = (char*) malloc( 3 * nLength + 1);
+        char c = pszValue[i];
+        if (c != pszWild[0] &&
+            c != pszSingle[0] &&
+            c != pszEscape[0])
-            iBuffer++;
+            if (c == '\'')
+            else
+        else if  (c == pszSingle[0])
-             szBuffer[iBuffer] = '_';
-             iBuffer++;
+            pszEscapedStr[j++] = '_';
+        else if  (c == pszEscape[0])
-            szBuffer[iBuffer] = pszEscape[0];
-            iBuffer++;
-            /*if (i<nLength-1)
+            pszEscapedStr[j++] = pszEscape[0];
+            if (i+1<nLength)
-                szBuffer[iBuffer] = pszValue[i+1];
-                iBuffer++;
+                char nextC = pszValue[i+1];
+                i++;
+                if (nextC == '\'')
+                else
+                    pszEscapedStr[j++] = nextC;
+        else if (c == pszWild[0])
-            strcat(szBuffer, "%");
-            iBuffer++;
+            pszEscapedStr[j++] = '%';
-    if (connectiontype != MS_OGR)
+    if (lp->connectiontype != MS_OGR)
-      strcat(szBuffer, " escape '");
+        strlcat(szBuffer, " escape '",bufferSize);
       szTmp[0] = pszEscape[0];
       if (pszEscape[0] == '\\')
@@ -3802,9 +3873,9 @@
           szTmp[2] = '\0';
+      strlcat(szBuffer,  szTmp,bufferSize);
@@ -4115,7 +4186,7 @@
                 if (!lp->items[i] || strlen(lp->items[i]) <= 0)
                     continue;
-                sprintf(szTmp, "%s_alias", lp->items[i]);
+                snprintf(szTmp, sizeof(szTmp), "%s_alias", lp->items[i]);
                 pszFullName = msOWSLookupMetadata(&(lp->metadata), namespaces, szTmp);
                 if (pszFullName)
Modified: branches/branch-5-6/mapserver/mapogcfilter.h
--- branches/branch-5-6/mapserver/mapogcfilter.h	2011-07-12 13:06:14 UTC (rev 11890)
+++ branches/branch-5-6/mapserver/mapogcfilter.h	2011-07-12 13:09:18 UTC (rev 11891)
@@ -113,8 +113,8 @@
 MS_DLL_EXPORT char *FLTGetSQLExpression(FilterEncodingNode *psFilterNode,layerObj *lp);
 MS_DLL_EXPORT char *FLTGetBinaryComparisonSQLExpresssion(FilterEncodingNode *psFilterNode, layerObj *lp);
 MS_DLL_EXPORT char *FLTGetIsBetweenComparisonSQLExpresssion(FilterEncodingNode *psFilterNode, layerObj *lp);
-MS_DLL_EXPORT char *FLTGetIsLikeComparisonSQLExpression(FilterEncodingNode *psFilterNode,
-                                       int connectiontype);
+MS_DLL_EXPORT char *FLTGetIsLikeComparisonSQLExpression(FilterEncodingNode *psFilterNode, layerObj *lp);
 MS_DLL_EXPORT char *FLTGetLogicalComparisonSQLExpresssion(FilterEncodingNode *psFilterNode,
                                             layerObj *lp);
 MS_DLL_EXPORT int FLTIsSimpleFilter(FilterEncodingNode *psFilterNode);
Modified: branches/branch-5-6/mapserver/mapogcsos.c
--- branches/branch-5-6/mapserver/mapogcsos.c	2011-07-12 13:06:14 UTC (rev 11890)
+++ branches/branch-5-6/mapserver/mapogcsos.c	2011-07-12 13:09:18 UTC (rev 11891)
@@ -1820,6 +1820,7 @@
   char *pszProcedureValue = NULL;
   int iItemPosition, status;
   shapeObj sShape;
   sBbox = map->extent;
@@ -2051,15 +2052,25 @@
               pszBuffer = msStringConcatenate(pszBuffer, "(");
               if (!bSpatialDB)
-                pszBuffer = msStringConcatenate(pszBuffer, "'[");
+                  pszBuffer = msStringConcatenate(pszBuffer, "'[");
+                  pszBuffer = msStringConcatenate(pszBuffer, (char *)pszProcedureItem);
+              else
+                  pszEscapedStr = msLayerEscapePropertyName(lp, (char *)pszProcedureItem);
+                  pszBuffer = msStringConcatenate(pszBuffer, pszEscapedStr);
-              pszBuffer = msStringConcatenate(pszBuffer, (char *)pszProcedureItem);
               if (!bSpatialDB)
                 pszBuffer = msStringConcatenate(pszBuffer, "]'");
               pszBuffer = msStringConcatenate(pszBuffer, " = '");
-              pszBuffer = msStringConcatenate(pszBuffer,  tokens[j]);
+              pszEscapedStr = msLayerEscapeSQLParam(lp, tokens[j]);
               pszBuffer = msStringConcatenate(pszBuffer,  "')");
Modified: branches/branch-5-6/mapserver/mapogr.cpp
--- branches/branch-5-6/mapserver/mapogr.cpp	2011-07-12 13:06:14 UTC (rev 11890)
+++ branches/branch-5-6/mapserver/mapogr.cpp	2011-07-12 13:09:18 UTC (rev 11891)
@@ -3471,6 +3471,66 @@
+/*                           msOGREscapeSQLParam                        */
+char *msOGREscapeSQLParam(layerObj *layer, const char *pszString)
+    char* pszEscapedStr =NULL;
+#ifdef USE_OGR
+    if(layer && pszString && strlen(pszString) > 0)
+        char* pszEscapedOGRStr =  CPLEscapeString(pszString, strlen(pszString),
+		                                    CPLES_SQL );
+	pszEscapedStr = strdup(pszEscapedOGRStr);
+        CPLFree(pszEscapedOGRStr);
+#else
+ * OGR Support not included...
+  msSetError(MS_MISCERR, "OGR support is not available.",
+             "msOGREscapeSQLParam()");
+  return NULL;
+#endif /* USE_OGR */
+char *msOGREscapePropertyName(layerObj *layer, const char *pszString)
+    int i =0;
+#ifdef USE_OGR
+        unsigned char ch;
+        for(i=0; (ch = ((unsigned char*)pszString)[i]) != '\0'; i++)
+            if ( !(isalnum(ch) || ch == '_' || ch > 127) )
+                return strdup("invalid_property_name");
+        pszEscapedStr = strdup(pszString);
+#else
+             "msOGREscapePropertyName()");
+  return NULL;
 /*                  msOGRLayerInitializeVirtualTable()                  */
 int
@@ -3497,6 +3557,9 @@
     /* layer->vtable->LayerGetNumFeatures, use default */
+    layer->vtable->LayerEscapeSQLParam = msOGREscapeSQLParam;
+    layer->vtable->LayerEscapePropertyName = msOGREscapePropertyName;
     return MS_SUCCESS;
Modified: branches/branch-5-6/mapserver/mappostgis.c
--- branches/branch-5-6/mapserver/mappostgis.c	2011-07-12 13:06:14 UTC (rev 11890)
+++ branches/branch-5-6/mapserver/mappostgis.c	2011-07-12 13:09:18 UTC (rev 11891)
@@ -549,7 +549,7 @@
         return(MS_FAILURE);
-    pgresult = PQexec(layerinfo->pgconn, sql);
+    pgresult = PQexecParams(layerinfo->pgconn, sql,0, NULL, NULL, NULL, NULL, 0);
     if ( !pgresult || PQresultStatus(pgresult) != PGRES_TUPLES_OK) {
         char *tmp1;
         char *tmp2 = NULL;
@@ -1774,7 +1774,7 @@
         msDebug("msPostGISLayerWhichShapes query: %s\n", strSQL);
-    pgresult = PQexec(layerinfo->pgconn, strSQL);
+    pgresult = PQexecParams(layerinfo->pgconn, strSQL,0, NULL, NULL, NULL, NULL, 0);
     if ( layer->debug > 1 ) {
         msDebug("msPostGISLayerWhichShapes query status: %s (%d)\n", PQresStatus(PQresultStatus(pgresult)), PQresultStatus(pgresult));
@@ -1979,7 +1979,7 @@
         msDebug("msPostGISLayerGetShape query: %s\n", strSQL);
     /* Something went wrong. */
     if ( (!pgresult) || (PQresultStatus(pgresult) != PGRES_TUPLES_OK) ) {
@@ -2073,7 +2073,7 @@
         msDebug("msPostGISLayerGetItems executing SQL: %s\n", sql);
         msSetError(MS_QUERYERR, "Error (%s) executing SQL: %s", "msPostGISLayerGetItems()", PQerrorMessage(layerinfo->pgconn), sql);
Modified: branches/branch-5-6/mapserver/mapserver.h
--- branches/branch-5-6/mapserver/mapserver.h	2011-07-12 13:06:14 UTC (rev 11890)
+++ branches/branch-5-6/mapserver/mapserver.h	2011-07-12 13:09:18 UTC (rev 11891)
@@ -1556,6 +1556,8 @@
     int (*LayerCreateItems)(layerObj *layer, int nt);
     int (*LayerGetNumFeatures)(layerObj *layer);
+    char* (*LayerEscapeSQLParam)(layerObj *layer, const char* pszString);
+    char* (*LayerEscapePropertyName)(layerObj *layer, const char* pszString);
 #endif /*SWIG*/
@@ -1955,6 +1957,9 @@
 /* maplayer.c */
 MS_DLL_EXPORT int msLayerGetNumFeatures(layerObj *layer);
+MS_DLL_EXPORT char *msLayerEscapeSQLParam(layerObj *layer, const char* pszString);
+MS_DLL_EXPORT char *msLayerEscapePropertyName(layerObj *layer, const char* pszString);
 /* These are special because SWF is using these */
 int msOGRLayerNextShape(layerObj *layer, shapeObj *shape);
 int msOGRLayerGetItems(layerObj *layer);
