[mapserver-commits] r11897 - branches/branch-4-10/mapserver
Tue Jul 12 09:19:08 EDT 2011
Author: assefa
Date: 2011-07-12 06:19:08 -0700 (Tue, 12 Jul 2011)
New Revision: 11897
   branches/branch-4-10/mapserver/HISTORY.TXT
   branches/branch-4-10/mapserver/map.h
   branches/branch-4-10/mapserver/maplayer.c
   branches/branch-4-10/mapserver/mapogcfilter.c
   branches/branch-4-10/mapserver/mapogcfilter.h
   branches/branch-4-10/mapserver/mapogr.cpp
   branches/branch-4-10/mapserver/mappostgis.c
Security fixes (#3903)
Modified: branches/branch-4-10/mapserver/HISTORY.TXT
--- branches/branch-4-10/mapserver/HISTORY.TXT	2011-07-12 13:17:28 UTC (rev 11896)
+++ branches/branch-4-10/mapserver/HISTORY.TXT	2011-07-12 13:19:08 UTC (rev 11897)
@@ -9,7 +9,18 @@
 For a complete change history, please see the Subversion log comments.
+Current Version:
+IMPORTANT SECURITY FIXE:
+-  Fixes to prevent SQL injections through OGC filter encoding (in WMS, WFS
+   and SOS), as well as a potential SQL injection in WMS time support.
+   Your system may be vulnerable if it has MapServer with OGC protocols
+   enabled, with layers connecting to an SQL RDBMS backend, either
+   natively or via OGR (#3903)
 Version 4.10.6 (2010-07-09)
Modified: branches/branch-4-10/mapserver/map.h
--- branches/branch-4-10/mapserver/map.h	2011-07-12 13:17:28 UTC (rev 11896)
+++ branches/branch-4-10/mapserver/map.h	2011-07-12 13:19:08 UTC (rev 11897)
@@ -1199,6 +1199,8 @@
     int (*LayerCreateItems)(layerObj *layer, int nt);
     int (*LayerGetNumFeatures)(layerObj *layer);
+    char* (*LayerEscapeSQLParam)(layerObj *layer, const char* pszString);
+    char* (*LayerEscapePropertyName)(layerObj *layer, const char* pszString);
 #endif /*SWIG*/
@@ -1528,6 +1530,9 @@
 /* maplayer.c */
 MS_DLL_EXPORT int msLayerGetNumFeatures(layerObj *layer);
+MS_DLL_EXPORT char *msLayerEscapeSQLParam(layerObj *layer, const char* pszString);
+MS_DLL_EXPORT char *msLayerEscapePropertyName(layerObj *layer, const char* pszString);
 /* These are special because SWF is using these */
 int msOGRLayerNextShape(layerObj *layer, shapeObj *shape);
 int msOGRLayerGetItems(layerObj *layer);
Modified: branches/branch-4-10/mapserver/maplayer.c
--- branches/branch-4-10/mapserver/maplayer.c	2011-07-12 13:17:28 UTC (rev 11896)
+++ branches/branch-4-10/mapserver/maplayer.c	2011-07-12 13:19:08 UTC (rev 11897)
@@ -1133,6 +1133,85 @@
     return MS_FAILURE;
+/*                          LayerDefaultEscapeSQLParam                  */
+/*      Default function used to escape strings and avoid sql           */
+/*      injection. Specific drivers should redefine if an escaping      */
+/*      function is available in the driver.                            */
+char *LayerDefaultEscapeSQLParam(layerObj *layer, const char* pszString)
+     char *pszEscapedStr=NULL;
+     if (pszString)
+         int nSrcLen;
+         char c;
+         int i=0, j=0;
+         nSrcLen = (int)strlen(pszString);
+         pszEscapedStr = (char*) malloc( 2 * nSrcLen + 1);
+         for(i = 0, j = 0; i < nSrcLen; i++)
+             c = pszString[i];
+             if (c == '\'')
+                 pszEscapedStr[j++] = '\'';
+             else if (c == '\\')
+                 pszEscapedStr[j++] = '\\';
+             else
+               pszEscapedStr[j++] = c;
+         pszEscapedStr[j] = 0;
+     return pszEscapedStr;
+/*                          LayerDefaultEscapePropertyName              */
+/*      Return the property name in a properly escaped and quoted form. */
+char *LayerDefaultEscapePropertyName(layerObj *layer, const char* pszString)
+     char* pszEscapedStr=NULL;
+     int i, j = 0;
+     if (layer && pszString && strlen(pszString) > 0)
+         int nLength = strlen(pszString);
+         pszEscapedStr = (char*) malloc( 1 + 2 * nLength + 1 + 1);
+         pszEscapedStr[j++] = '"';
+         for (i=0; i<nLength; i++)
+             char c = pszString[i];
+             if (c == '"')
+                 pszEscapedStr[j++] ='"';
+             else
+         pszEscapedStr[j++] = 0;
  * msConnectLayer
@@ -1190,6 +1269,10 @@
     vtable->LayerGetNumFeatures = LayerDefaultGetNumFeatures;
+    vtable->LayerEscapeSQLParam = LayerDefaultEscapeSQLParam;
+    vtable->LayerEscapePropertyName = LayerDefaultEscapePropertyName;
     return MS_SUCCESS;
@@ -1354,6 +1437,31 @@
     return i;
+Returns an escaped string
+char  *msLayerEscapeSQLParam(layerObj *layer, const char*pszString)
+    if ( ! layer->vtable) {
+        int rv =  msInitializeVirtualTable(layer);
+        if (rv != MS_SUCCESS)
+            return "";
+    return layer->vtable->LayerEscapeSQLParam(layer, pszString);
+char  *msLayerEscapePropertyName(layerObj *layer, const char*pszString)
+            return "";
+    return layer->vtable->LayerEscapePropertyName(layer, pszString);
 int
 msINLINELayerInitializeVirtualTable(layerObj *layer)
@@ -1385,5 +1493,8 @@
     /* layer->vtable->LayerCreateItems, use default */
     layer->vtable->LayerGetNumFeatures = msINLINELayerGetNumFeatures;
+    /*layer->vtable->LayerEscapeSQLParam, use default*/
+    /*layer->vtable->LayerEscapePropertyName, use default*/
     return MS_SUCCESS;
Modified: branches/branch-4-10/mapserver/mapogcfilter.c
--- branches/branch-4-10/mapserver/mapogcfilter.c	2011-07-12 13:17:28 UTC (rev 11896)
+++ branches/branch-4-10/mapserver/mapogcfilter.c	2011-07-12 13:19:08 UTC (rev 11897)
@@ -448,7 +448,7 @@
         if (tokens && nTokens == 2)
             char szTmp[32];
-            sprintf(szTmp, "init=epsg:%s",tokens[1]);
+            snprintf(szTmp,  sizeof(szTmp), "init=epsg:%s",tokens[1]);
             msInitProjection(&sProjTmp);
             if (msLoadProjectionString(&sProjTmp, szTmp) == 0)
               msProjectRect(&sProjTmp, &map->projection,  &sQueryRect);
@@ -473,7 +473,7 @@
             if (nEpsgTmp > 0)
                 char szTmp[32];
-                sprintf(szTmp, "init=epsg:%d",nEpsgTmp);
+                snprintf(szTmp,  sizeof(szTmp), "init=epsg:%d",nEpsgTmp);
@@ -995,7 +995,7 @@
             char szTmp[32];
@@ -1020,7 +1020,7 @@
             if (nEpsgTmp > 0)
                 char szTmp[32];
                   msProjectRect( &sProjTmp, &map->projection, &sQueryRect);
@@ -1036,7 +1036,7 @@
     lp->class[0].type = lp->type;
     lp->class[0].template = strdup("ttt.html");
-    szExpression = FLTGetSQLExpression(psNode, lp->connectiontype);
+    szExpression = FLTGetSQLExpression(psNode, lp);
     if (szExpression)
         pszBuffer = (char *)malloc(sizeof(char) * (strlen(szExpression) + 8));
@@ -2638,7 +2638,7 @@
 /*      Build SQL expressions from the mapserver nodes.                 */
-char *FLTGetSQLExpression(FilterEncodingNode *psFilterNode, int connectiontype)
+char *FLTGetSQLExpression(FilterEncodingNode *psFilterNode, layerObj *lp)
     char *pszExpression = NULL;
@@ -2652,20 +2652,20 @@
             if (FLTIsBinaryComparisonFilterType(psFilterNode->pszValue))
                 pszExpression =
-                  FLTGetBinaryComparisonSQLExpresssion(psFilterNode);
+                  FLTGetBinaryComparisonSQLExpresssion(psFilterNode, lp);
             else if (strcasecmp(psFilterNode->pszValue,
                                 "PropertyIsBetween") == 0)
                  pszExpression =
-                   FLTGetIsBetweenComparisonSQLExpresssion(psFilterNode);
+                   FLTGetIsBetweenComparisonSQLExpresssion(psFilterNode, lp);
                                 "PropertyIsLike") == 0)
                  pszExpression =
-                   FLTGetIsLikeComparisonSQLExpression(psFilterNode,
-                                                       connectiontype);
+                   FLTGetIsLikeComparisonSQLExpression(psFilterNode, lp);
@@ -2676,14 +2676,13 @@
             strcasecmp(psFilterNode->pszValue, "OR") == 0)
             pszExpression =
-              FLTGetLogicalComparisonSQLExpresssion(psFilterNode,
-                                                    connectiontype);
+              FLTGetLogicalComparisonSQLExpresssion(psFilterNode, lp);
         else if (strcasecmp(psFilterNode->pszValue, "NOT") == 0)
             pszExpression =
-                                                    connectiontype);
+              FLTGetLogicalComparisonSQLExpresssion(psFilterNode,lp);
@@ -2728,8 +2727,7 @@
 /*      Return the expression for logical comparison expression.        */
-char *FLTGetLogicalComparisonSQLExpresssion(FilterEncodingNode *psFilterNode,
-                                            int connectiontype)
+char *FLTGetLogicalComparisonSQLExpresssion(FilterEncodingNode *psFilterNode, layerObj *lp)
     char *pszBuffer = NULL;
     char *pszTmp = NULL;
@@ -2744,9 +2742,9 @@
          (strcasecmp(psFilterNode->psRightNode->pszValue, "BBOX") == 0)))
          if (strcasecmp(psFilterNode->psLeftNode->pszValue, "BBOX") != 0)
-           pszTmp = FLTGetSQLExpression(psFilterNode->psLeftNode, connectiontype);
+           pszTmp = FLTGetSQLExpression(psFilterNode->psLeftNode, lp);
          else
-           pszTmp = FLTGetSQLExpression(psFilterNode->psRightNode, connectiontype);
+           pszTmp = FLTGetSQLExpression(psFilterNode->psRightNode, lp);
          if (!pszTmp)
           return NULL;
@@ -2760,7 +2758,7 @@
     else if (psFilterNode->psLeftNode && psFilterNode->psRightNode)
         if (!pszTmp)
           return NULL;
@@ -2777,7 +2775,7 @@
         free( pszTmp );
         nTmp = strlen(pszBuffer);
         if (!pszTmp)
           return NULL;
@@ -2792,7 +2790,7 @@
         if (!pszTmp)
           return NULL;
@@ -2949,6 +2947,7 @@
 char *FLTGetBinaryComparisonExpresssion(FilterEncodingNode *psFilterNode)
+    const size_t bufferSize = 1024;
     char szBuffer[1024];
     int i=0, bString=0, nLenght = 0;
@@ -2983,16 +2982,16 @@
     if (bString)
-      strcat(szBuffer, " (\"[");
+      strlcat(szBuffer, " (\"[", bufferSize);
     else
-      strcat(szBuffer, " ([");
+      strlcat(szBuffer, " ([", bufferSize);
     /* attribute */
-    strcat(szBuffer, psFilterNode->psLeftNode->pszValue);
+    strlcat(szBuffer, psFilterNode->psLeftNode->pszValue, bufferSize);
     if (bString)
-      strcat(szBuffer, "]\" ");
+      strlcat(szBuffer, "]\" ", bufferSize);
     else
-      strcat(szBuffer, "] ");
+      strlcat(szBuffer, "] ", bufferSize);
     /* logical operator */
@@ -3003,40 +3002,40 @@
         if (psFilterNode->psRightNode->pOther &&
             (*(int *)psFilterNode->psRightNode->pOther) == 1)
-            strcat(szBuffer, "IEQ");
+            strlcat(szBuffer, "IEQ", bufferSize);
         else
-          strcat(szBuffer, "=");
+          strlcat(szBuffer, "=", bufferSize);
                         "PropertyIsNotEqualTo") == 0)
-      strcat(szBuffer, "!=");
+      strlcat(szBuffer, "!=", bufferSize);
                         "PropertyIsLessThan") == 0)
-      strcat(szBuffer, "<");
+      strlcat(szBuffer, "<", bufferSize);
                         "PropertyIsGreaterThan") == 0)
-      strcat(szBuffer, ">");
+      strlcat(szBuffer, ">", bufferSize);
                         "PropertyIsLessThanOrEqualTo") == 0)
-      strcat(szBuffer, "<=");
+      strlcat(szBuffer, "<=", bufferSize);
                         "PropertyIsGreaterThanOrEqualTo") == 0)
-      strcat(szBuffer, ">=");
+      strlcat(szBuffer, ">=", bufferSize);
-    strcat(szBuffer, " ");
+    strlcat(szBuffer, " ", bufferSize);
     /* value */
     if (bString)
-      strcat(szBuffer, "\"");
+      strlcat(szBuffer, "\"", bufferSize);
     if (psFilterNode->psRightNode->pszValue)
-      strcat(szBuffer, psFilterNode->psRightNode->pszValue);
+      strlcat(szBuffer, psFilterNode->psRightNode->pszValue, bufferSize);
     if (bString)
-    strcat(szBuffer, ") ");
+    strlcat(szBuffer, ") ", bufferSize);
     return strdup(szBuffer);
@@ -3048,11 +3047,14 @@
 /*      Return the expression for a binary comparison filter node.      */
-char *FLTGetBinaryComparisonSQLExpresssion(FilterEncodingNode *psFilterNode)
+char *FLTGetBinaryComparisonSQLExpresssion(FilterEncodingNode *psFilterNode,
+                                           layerObj *lp)
     char szTmp[100];
+    char* pszEscapedStr = NULL;
     szBuffer[0] = '\0';
     if (!psFilterNode || !
@@ -3086,8 +3088,10 @@
     /*opening bracket*/
-    strcat(szBuffer, " (");
+    strlcat(szBuffer, " (", bufferSize);
+    pszEscapedStr = msLayerEscapePropertyName(lp, psFilterNode->psLeftNode->pszValue);
     /* attribute */
     /*case insensitive set ? */
     if (bString &&
@@ -3096,35 +3100,37 @@
-        sprintf(szTmp, "lower(%s) ",  psFilterNode->psLeftNode->pszValue);
-        strcat(szBuffer, szTmp);
+        snprintf(szTmp, sizeof(szTmp), "lower(%s) ",  pszEscapedStr);
+        strlcat(szBuffer, szTmp, bufferSize);
     else
+      strlcat(szBuffer, pszEscapedStr, bufferSize);
+    msFree(pszEscapedStr);
+    pszEscapedStr = NULL;
                    "PropertyIsEqualTo") == 0)
-      strcat(szBuffer, "<>");
+      strlcat(szBuffer, "<>", bufferSize);
     /* value */
@@ -3135,23 +3141,34 @@
-        sprintf(szTmp, "lower('%s') ",  psFilterNode->psRightNode->pszValue);
+        snprintf(szTmp,  sizeof(szTmp), "lower('%s') ",  psFilterNode->psRightNode->pszValue);
     else
         if (bString)
-          strcat(szBuffer, "'");
+          strlcat(szBuffer, "'", bufferSize);
+            if (bString)
+                char* pszEscapedStr;
+                pszEscapedStr = msLayerEscapeSQLParam(lp, psFilterNode->psRightNode->pszValue);
+                pszEscapedStr=NULL;
+            else
         if (bString)
     /*closing bracket*/
@@ -3162,14 +3179,15 @@
 /*      Build an SQL expresssion for IsBteween Filter.                  */
-char *FLTGetIsBetweenComparisonSQLExpresssion(FilterEncodingNode *psFilterNode)
+char *FLTGetIsBetweenComparisonSQLExpresssion(FilterEncodingNode *psFilterNode, layerObj *lp)
     char **aszBounds = NULL;
     int nBounds = 0;
     szBuffer[0] = '\0';
         !(strcasecmp(psFilterNode->pszValue, "PropertyIsBetween") == 0))
@@ -3222,32 +3240,47 @@
 /*      build expresssion.                                              */
     /*opening paranthesis */
     /* attribute */
     /*between*/
-    strcat(szBuffer, " BETWEEN ");
+    strlcat(szBuffer, " BETWEEN ", bufferSize);
     /*bound 1*/
     if (bString)
-      strcat(szBuffer,"'");
-    strcat(szBuffer, aszBounds[0]);
+      strlcat(szBuffer,"'", bufferSize);
+    pszEscapedStr = msLayerEscapeSQLParam( lp, aszBounds[0]);
     if (bString)
-    strcat(szBuffer, " AND ");
+    strlcat(szBuffer, " AND ", bufferSize);
     /*bound 2*/
     if (bString)
-    strcat(szBuffer, aszBounds[1]);
+    pszEscapedStr = msLayerEscapeSQLParam( lp, aszBounds[1]);
     if (bString)
     /*closing paranthesis*/
-    strcat(szBuffer, ")");
+    strlcat(szBuffer, ")", bufferSize);
@@ -3260,6 +3293,7 @@
 char *FLTGetIsBetweenComparisonExpresssion(FilterEncodingNode *psFilterNode)
     int nBounds = 0;
@@ -3318,48 +3352,48 @@
     if (bString)
     else
     /* attribute */
     if (bString)
     else
-    strcat(szBuffer, " >= ");
+    strlcat(szBuffer, " >= ", bufferSize);
     if (bString)
-      strcat(szBuffer,"\"");
+      strlcat(szBuffer,"\"", bufferSize);
+    strlcat(szBuffer, aszBounds[0], bufferSize);
     if (bString)
     if (bString)
-      strcat(szBuffer, " \"[");
+      strlcat(szBuffer, " \"[", bufferSize);
     else
-      strcat(szBuffer, " [");
+      strlcat(szBuffer, " [", bufferSize);
     /* attribute */
     if (bString)
     else
-    strcat(szBuffer, " <= ");
+    strlcat(szBuffer, " <= ", bufferSize);
     if (bString)
+    strlcat(szBuffer, aszBounds[1], bufferSize);
     if (bString)
@@ -3372,6 +3406,7 @@
 char *FLTGetIsLikeComparisonExpression(FilterEncodingNode *psFilterNode)
     char *pszValue = NULL;
@@ -3419,43 +3454,48 @@
-        if (pszValue[i] != pszWild[0] &&
-            pszValue[i] != pszSingle[0] &&
-            pszValue[i] != pszEscape[0])
-            szBuffer[iBuffer] = pszValue[i];
-            iBuffer++;
-            szBuffer[iBuffer] = '\0';
-        else if  (pszValue[i] == pszSingle[0])
-             szBuffer[iBuffer] = '.';
-             iBuffer++;
-        else if  (pszValue[i] == pszEscape[0])
-            szBuffer[iBuffer] = '\\';
-            iBuffer++;
+        if (iBuffer < 1024)
+            if (pszValue[i] != pszWild[0] &&
+                pszValue[i] != pszSingle[0] &&
+                pszValue[i] != pszEscape[0])
+                szBuffer[iBuffer] = pszValue[i];
+                iBuffer++;
+                szBuffer[iBuffer] = '\0';
+            else if  (pszValue[i] == pszSingle[0])
+                szBuffer[iBuffer] = '.';
+                iBuffer++;
+            else if  (pszValue[i] == pszEscape[0])
+                szBuffer[iBuffer] = '\\';
+                iBuffer++;
+            else if (pszValue[i] == pszWild[0])
+                /* strcat(szBuffer, "[0-9,a-z,A-Z,\\s]*"); */
+                /* iBuffer+=17; */
+                strlcat(szBuffer, ".*", bufferSize);
+                iBuffer+=2;
-        else if (pszValue[i] == pszWild[0])
+        szBuffer[iBuffer] = '/';
+        if (bCaseInsensitive == 1)
-            /* strcat(szBuffer, "[0-9,a-z,A-Z,\\s]*"); */
-            /* iBuffer+=17; */
-            strcat(szBuffer, ".*");
-            iBuffer+=2;
-    szBuffer[iBuffer] = '/';
-    if (bCaseInsensitive == 1)
-      szBuffer[++iBuffer] = 'i';
-    szBuffer[++iBuffer] = '\0';
+            szBuffer[++iBuffer] = 'i';
+        szBuffer[++iBuffer] = '\0';
@@ -3465,9 +3505,9 @@
 /*      Build an sql expression for IsLike filter.                      */
-char *FLTGetIsLikeComparisonSQLExpression(FilterEncodingNode *psFilterNode,
+char *FLTGetIsLikeComparisonSQLExpression(FilterEncodingNode *psFilterNode, layerObj *lp)
@@ -3476,9 +3516,11 @@
     char *pszEscape = NULL;
     char szTmp[3];
-    int nLength=0, i=0, iBuffer = 0;
+    int nLength=0, i=0, j=0;
     int  bCaseInsensitive = 0;
+    char *pszEscapedStr = NULL;
     if (!psFilterNode || !psFilterNode->pOther || !psFilterNode->psLeftNode ||
         !psFilterNode->psRightNode || !psFilterNode->psRightNode->pszValue)
       return NULL;
@@ -3497,60 +3539,73 @@
     szBuffer[0] = '\0';
     /*opening bracket*/
     /* attribute name */
-    if (bCaseInsensitive == 1 && connectiontype != MS_OGR)
-      strcat(szBuffer, " ilike '");
+    if (bCaseInsensitive == 1 && lp->connectiontype != MS_OGR)
+      strlcat(szBuffer, " ilike '", bufferSize);
     else
-      strcat(szBuffer, " like '");
+      strlcat(szBuffer, " like '", bufferSize);
     pszValue = psFilterNode->psRightNode->pszValue;
     nLength = strlen(pszValue);
-    iBuffer = strlen(szBuffer);
+    pszEscapedStr = (char*) malloc( 3 * nLength + 1);
+        char c = pszValue[i];
+        if (c != pszWild[0] &&
+            c != pszSingle[0] &&
+            c != pszEscape[0])
-            iBuffer++;
+            if (c == '\'')
+            else
+        else if  (c == pszSingle[0])
-             szBuffer[iBuffer] = '_';
-             iBuffer++;
+            pszEscapedStr[j++] = '_';
+        else if  (c == pszEscape[0])
-            szBuffer[iBuffer] = pszEscape[0];
-            iBuffer++;
-            /*if (i<nLength-1)
+            pszEscapedStr[j++] = pszEscape[0];
+            if (i+1<nLength)
-                szBuffer[iBuffer] = pszValue[i+1];
-                iBuffer++;
+                char nextC = pszValue[i+1];
+                i++;
+                if (nextC == '\'')
+                else
+                    pszEscapedStr[j++] = nextC;
+        else if (c == pszWild[0])
-            strcat(szBuffer, "%");
-            iBuffer++;
+            pszEscapedStr[j++] = '%';
-    if (connectiontype != MS_OGR)
+    if (lp->connectiontype != MS_OGR)
-      strcat(szBuffer, " escape '");
+      strlcat(szBuffer, " escape '", bufferSize);
       szTmp[0] = pszEscape[0];
       if (pszEscape[0] == '\\')
@@ -3564,9 +3619,9 @@
           szTmp[2] = '\0';
Modified: branches/branch-4-10/mapserver/mapogcfilter.h
--- branches/branch-4-10/mapserver/mapogcfilter.h	2011-07-12 13:17:28 UTC (rev 11896)
+++ branches/branch-4-10/mapserver/mapogcfilter.h	2011-07-12 13:19:08 UTC (rev 11897)
@@ -165,13 +165,11 @@
 int FLTApplySimpleSQLFilter(FilterEncodingNode *psNode, mapObj *map,
                           int iLayerIndex);
-char *FLTGetSQLExpression(FilterEncodingNode *psFilterNode,int connectiontype);
-char *FLTGetBinaryComparisonSQLExpresssion(FilterEncodingNode *psFilterNode);
-char *FLTGetIsBetweenComparisonSQLExpresssion(FilterEncodingNode *psFilterNode);
-                                       int connectiontype);
+char *FLTGetSQLExpression(FilterEncodingNode *psFilterNode,layerObj *lp);
+char *FLTGetBinaryComparisonSQLExpresssion(FilterEncodingNode *psFilterNode, layerObj *lp);
+char *FLTGetIsBetweenComparisonSQLExpresssion(FilterEncodingNode *psFilterNode,layerObj *lp);
+char *FLTGetIsLikeComparisonSQLExpression(FilterEncodingNode *psFilterNode, layerObj *lp);
+char *FLTGetLogicalComparisonSQLExpresssion(FilterEncodingNode *psFilterNode, layerObj *lp);
 int FLTIsSimpleFilter(FilterEncodingNode *psFilterNode);
Modified: branches/branch-4-10/mapserver/mapogr.cpp
--- branches/branch-4-10/mapserver/mapogr.cpp	2011-07-12 13:17:28 UTC (rev 11896)
+++ branches/branch-4-10/mapserver/mapogr.cpp	2011-07-12 13:19:08 UTC (rev 11897)
@@ -2405,6 +2405,66 @@
+/*                           msOGREscapeSQLParam                        */
+char *msOGREscapeSQLParam(layerObj *layer, const char *pszString)
+    char* pszEscapedStr =NULL;
+#ifdef USE_OGR
+    if(layer && pszString && strlen(pszString) > 0)
+        char* pszEscapedOGRStr =  CPLEscapeString(pszString, strlen(pszString),
+		                                    CPLES_SQL );
+	pszEscapedStr = strdup(pszEscapedOGRStr);
+        CPLFree(pszEscapedOGRStr);
+#else
+ * OGR Support not included...
+  msSetError(MS_MISCERR, "OGR support is not available.",
+             "msOGREscapeSQLParam()");
+  return NULL;
+#endif /* USE_OGR */
+char *msOGREscapePropertyName(layerObj *layer, const char *pszString)
+    int i =0;
+#ifdef USE_OGR
+        unsigned char ch;
+        for(i=0; (ch = ((unsigned char*)pszString)[i]) != '\0'; i++)
+            if ( !(isalnum(ch) || ch == '_' || ch > 127) )
+                return strdup("invalid_property_name");
+        pszEscapedStr = strdup(pszString);
+#else
+             "msOGREscapePropertyName()");
+  return NULL;
 /*                  msOGRLayerInitializeVirtualTable()                  */
 int
@@ -2435,6 +2495,9 @@
     /* layer->vtable->LayerGetNumFeatures, use default */
+    layer->vtable->LayerEscapeSQLParam = msOGREscapeSQLParam;
+    layer->vtable->LayerEscapePropertyName = msOGREscapePropertyName;
     return MS_SUCCESS;
Modified: branches/branch-4-10/mapserver/mappostgis.c
--- branches/branch-4-10/mapserver/mappostgis.c	2011-07-12 13:17:28 UTC (rev 11896)
+++ branches/branch-4-10/mapserver/mappostgis.c	2011-07-12 13:19:08 UTC (rev 11897)
@@ -614,7 +614,7 @@
     if(layer->debug) {
         msDebug("query_string_0_6:%s\n", query_string_0_6);
-    result = PQexec(layerinfo->conn, query_string_0_6);
+    result = PQexecParams(layerinfo->conn, query_string_0_6,0, NULL, NULL, NULL, NULL, 0);
     if(result && PQresultStatus(result) == PGRES_COMMAND_OK)
@@ -1317,7 +1317,7 @@
     PQclear(query_result);
-    query_result = PQexec(layerinfo->conn, query_str);
+    query_result = PQexecParams(layerinfo->conn, query_str,0, NULL, NULL, NULL, NULL, 0);
     if(!query_result || PQresultStatus(query_result) != PGRES_COMMAND_OK) {
         msSetError(MS_QUERYERR, "Error executing POSTGIS SQL statement (in FETCH ALL): %s\n-%s\nMore Help:", "msPOSTGISLayerGetShape()", query_str, PQerrorMessage(layerinfo->conn));
@@ -1526,7 +1526,7 @@
     /* geom_column_name is needed later */
     free(table_name);
-    query_result = PQexec(layerinfo->conn, sql);
+    query_result = PQexecParams(layerinfo->conn, sql,0, NULL, NULL, NULL, NULL, 0);
     if(!query_result || PQresultStatus(query_result) != PGRES_TUPLES_OK) {
         msSetError(MS_QUERYERR, "Error executing POSTGIS SQL statement (in msPOSTGISLayerGetItems): %s\n-%s\n", "msPOSTGISLayerGetItems()", sql, PQerrorMessage(layerinfo->conn));
