[mapserver-commits] r11929 - sandbox/inspire_soc2011/mapserver
Wed Jul 13 09:54:51 EDT 2011
Author: stefanl
Date: 2011-07-13 06:54:51 -0700 (Wed, 13 Jul 2011)
New Revision: 11929
Added:
   sandbox/inspire_soc2011/mapserver/rfc73.rst
first draft of rfc
Added: sandbox/inspire_soc2011/mapserver/rfc73.rst
--- sandbox/inspire_soc2011/mapserver/rfc73.rst	                        (rev 0)
+++ sandbox/inspire_soc2011/mapserver/rfc73.rst	2011-07-13 13:54:51 UTC (rev 11929)
@@ -0,0 +1,279 @@
+.. _rfc73:
+MS RFC 73: INSPIRE view service support
+:Date:  2011/07/01
+:Author: gsoc2011
+:Contact:
+:Last Edited:  2011/07/13
+:Status:
+:Version: MapServer 6.2
+:Id:
+1. Overview
+In order to achieve INSPIRE view service compliance, several enhancements need to be implemented in MapServer to support the specification_ :
+- Activation of INSPIRE support (two scenarios)
+- Multi-language support for certain capabilities fields
+- Provision of INSPIRE specific metadata
+This RFC aggregates and extends the already provided ideas/solutions regarding INSPIRE view service support.
+2. Activation of INSPIRE support
+INSPIRE specific metadata can either be referenced in an external INSPIRE service metadata document (scenario 1) or can be directly embedded in the capabilities document (scenario 2). MapServer needs to support both scenarios.
+As suggested in Ticket 3608_, activation of the corresponding scenario for INSPIRE support takes place in the WEB.METADATA section of the mapfile through "wms_inspire_capabilities". If activated, the corresponding INSPIRE namespace as well as appropriate validation warnings are generated in the capabilities document.
+Scenario 1 - activate INSPIRE support using a reference to external service metadata
+  WEB
+   METADATA
+    "wms_inspire_capabilities" "url"
+   END
+  END
+Scenario 2 - activate INSPIRE support using embedded service metadata
+  WEB
+   METADATA
+    "wms_inspire_capabilities" "embed"
+   END
+  END
+3. Multi-language support for certain capabilities fields
+INSPIRE requires multi-language support and requests a list of all supported languages as well as the default language in the capabilities document. Based on the language parameter in the GetCapabilites request, certain specific metadata values, namely
+  - "wms_title"
+  - "wms_abstract"
+  - "wms_rootlayer_abstract"
+as well as language dependent reference data like
+  - DATA "shapes/rivers.shp"
+need to be provided in the requested language. If the language is not supported (or no language parameter is present), the default language has to be used.
+As suggested in Ticket 3608_, all supported languages are specified as comma separated list (first language is default) through "wms_inspire_languages" in the WEB.METADATA section of the mapfile. Through "wms_inspire_languagesubstitution" a language parameter can be added to the onlineresource in the GetCapabilites output.
+  WEB
+   METADATA
+    "wms_inspire_languages" "eng,ger"                         #first default, values according ISO 639-2/B
+    "wms_inspire_languagesubstitution" "true"                 #add language parameter to onlineresource
+   END
+  END
+To address the second issue, different options_ regarding implementation were evaluated.
+For language specific metadata values, a key extension method is applied.
+  WEB
+   METADATA
+    "wms_title_eng" "Transport networks: Road Link"
+    "wms_title_ger" "Verkehrsnetze: Strassensegment"
+    "wms_abstract" "mylayerabstract"                          #to test fallback
+    "wms_abstract_ger" "mylayerabstractger"
+   END
+  END
+For language dependent reference data, the already existing runtime-substitution_ feature of MapServer is used.
+    DATA "shapes/rivers_%language%.shp
+4. Provision of INSPIRE specific metadata
+Depending on the scenario, additional metadata information is required to support the specification. The INSPIRE related fields are provided below:
+Scenario 1 - INSPIRE related fields using referenced external service metadata
+  WEB
+   METADATA
+    "wms_metadataurl_href" "http://INSPIRE.service/metadata"
+    "wms_metadataurl_format" "application/vnd.ogc.csw.capabilities.response_xml"
+    "wms_inspire_keyword" "infoMapAccessService"              #value according "classification of spatial data services"
+    "wms_title" "Transport networks: Road Area"
+    "wms_abstract" "myabstract"
+    "wms_fees" "conditions unknown"                           #value either "no conditions apply"|default "conditions unknown"|<specific conditions>
+    "wms_accessconstraints" "None"                            #value according ISO 19115 (MD_RestrictionCode codelist) or default "None"
+    "wms_contactorganization" "MapServer"                     #responsible organisation
+    "wms_contactposition" "owner"                             #responsible organisation, value according "INSPIRE Metadata Regulation" (part D6)
+    "wms_inspire_style_name" "inspire_common:DEFAULT"         #style name
+    "wms_inspire_style_title" "mystyletitle"                  #style title
+   END
+  END
+Scenario 2 - INSPIRE related fields using embedded service metadata
+  WEB
+   METADATA
+    "wms_inspire_temporal_reference" "2011-09-19"             #date of last revision, value according YYYY-MM-DD
+    "wms_inspire_conformity" "not evaluated"                  #value either "conformant"|"not conformant"|default "not evaluated"
+    "wms_inspire_mpoc_name" "mympocname"                      #point of contact
+    "wms_inspire_mpoc_email" "mympocemail"                    #point of contact
+    "wms_inspire_metadatadate" "2011-09-19"                   #value according YYYY-MM-DD
+   END
+  END
+Notes:
+  a) several fields require certain values, these values are not validated by MapServer itself
+  b) only one keyword through "wms_inspire_keyword" is supported, a possibly provided "wms_keywordlist" will be ignored
+  c) as suggested in this document_ regarding scenario 2, <inspire_common:ResourceType> is always set to service and <inspire_common:SpatialDataServiceType> is always set to view, both values can't be altered through the mapfile
+  d) for the root layer, the style name is set through "wms_inspire_style_name" (inspire_common:DEFAULT), the style title through "wms_inspire_style_title"
+  e) as discussed here_, the usage of group/classgroup in the mapfile is necessary to set the layer style name to the according value (inspire_common:DEFAULT).
+  f) as suggested in Ticket 3850_, the layer style titles can be overwritten through wms_style_<stylename>_title, the layer style legendURLs through wms_style_<stylename>_legendurl_* (width, height, format and href need to be provided)
+         LAYER
+          NAME TN.RoadTransportNetwork.RoadLink
+          DATA road
+          TEMPLATE "ttt"
+          METADATA
+           "wms_keywordlist" "mylayerkeyword1,mylayerkeyword2"
+           "wms_style_inspire_common:DEFAULT_title" "mylayerstyletitle"                      #override style title
+           "wms_style_inspire_common:DEFAULT_legendurl_width" "mylayerstylelegendurlwidth"   #override style legendurl (mandatory: width, height, format, href)
+           "wms_style_inspire_common:DEFAULT_legendurl_height" "mylayerstylelegendurlheight"
+           "wms_style_inspire_common:DEFAULT_legendurl_format" "mylayerstylelegendurlformat"
+           "wms_style_inspire_common:DEFAULT_legendurl_href" "mylayerstylelegendurlhref"
+          END
+         END
+         CLASSGROUP "inspire_common:DEFAULT"
+         CLASSITEM "NAME_E"
+         CLASS
+          NAME "myclass1"
+          GROUP "inspire_common:DEFAULT"
+          EXPRESSION "Trans-Canada Highway"
+          COLOR 255 0 0
+         END
+         CLASS
+          NAME "myclass2"
+          COLOR 0 255 0
+         END
+5. Implementation details
+In order to implement this enhancement, the following changes need to be implemented in the MapServer codebase:
+1) get language from request and validate it, pass it through all functions as additional parameter
+2) detect if INSPIRE support is activated, if so add corresponding namespace
+3) output extended capabilitities with language list and INSPIRE specific metadata (depending on scenario 1 or 2)
+4) add language parameter to onlineresource in output (if enabled through "wms_inspire_languagesubstitution")
+5) consider key extension based on language (e.g. "wms_title_eng") when deriving metadata from the mapobject, use fallback with no extension (e.g. "wms_title")
+6) override style titles and legendURLs if specified in mapfile (e.g. "wms_style_<stylename>_title")
+7) add warnings for missing but mandatory INSPIRE specific metadata
+5.1 Files affected
+The following files will be modified by this RFC:
+  mapows.h
+  mapows.c
+  mapwms.c
+5.2 MapScript issues
+This change provides new functionality with no MapScript issues being considered.
+5.3 Backwards compatibility issues
+This change provides new functionality with no backwards compatibility issues being considered.
+6. Solution
+The code for this RFC can be found in the inspire_soc2011_ sandbox.
+Incorporated tickets:
+  - Ticket 3608_: INSPIRE related support
+  - Ticket 3850_: allow to define a title for styles and possibility to override autogenerated legendurl href
+Related (but currently not addressed) tickets:
+  - Ticket 1632_: support for named group layers using wms_layer_group
+7. Tests
+2 example mapfiles were created for testing purposes:
+  - mapfile inspire scenario1_
+  - mapfile inspire scenario2_
+The GetCapabilites responses with these mapfiles validate against the inspire schemas_ as well as the WMS INSPIRE tester_ without warnings/errors.
+8. Voting history
+.. _specification: http://INSPIRE.jrc.ec.europa.eu/documents/Network_Services/TechnicalGuidance_ViewServices_v3.0.pdf
+.. _3608: http://trac.osgeo.org/mapserver/ticket/3608
+.. _options: http://trac.osgeo.org/mapserver/wiki/gsoc2011/work#multilanguagesupport
+.. _runtime-substitution: http://mapserver.org/cgi/runsub.html
+.. _inspire_soc2011: https://svn.osgeo.org/mapserver/sandbox/inspire_soc2011
+.. _document: http://www.neogeo-online.net/blog/wp-content/uploads/2011/04/MAPSERVER_INSPIRE.pdf
+.. _here: http://lists.osgeo.org/pipermail/mapserver-INSPIRE/2011-April/000027.html
+.. _3850: http://trac.osgeo.org/mapserver/ticket/3850
+.. _1632: http://trac.osgeo.org/mapserver/ticket/1632
+.. _scenario1: https://svn.osgeo.org/mapserver/sandbox/inspire_soc2011/msautotest/wxs/wms_inspire_scenario1.map
+.. _scenario2: https://svn.osgeo.org/mapserver/sandbox/inspire_soc2011/msautotest/wxs/wms_inspire_scenario2.map
+.. _schemas: http://inspire.ec.europa.eu/schemas/inspire_vs/
+.. _tester: http://inspire_tester.neogeo-online.net/
\ No newline at end of file
