[mapserver-commits] r11939 - sandbox/inspire_soc2011/mapserver
Fri Jul 15 01:45:32 EDT 2011
Author: stefanl
Date: 2011-07-14 22:45:32 -0700 (Thu, 14 Jul 2011)
New Revision: 11939
   sandbox/inspire_soc2011/mapserver/mapows.c
   sandbox/inspire_soc2011/mapserver/mapows.h
   sandbox/inspire_soc2011/mapserver/mapwms.c
inspire view service metadata support (scenario1+2)
Modified: sandbox/inspire_soc2011/mapserver/mapows.c
--- sandbox/inspire_soc2011/mapserver/mapows.c	2011-07-14 14:00:50 UTC (rev 11938)
+++ sandbox/inspire_soc2011/mapserver/mapows.c	2011-07-15 05:45:32 UTC (rev 11939)
@@ -1085,13 +1085,13 @@
                               const char *namespaces, const char *name,
                               int action_if_not_found,
                               const char *format, const char *default_value,
-                              const char *language)
+                              const char *validated_language)
     const char *value;
     char * pszEncodedValue=NULL;
     int status = MS_NOERR;
-    if((value = msOWSLookupMetadataWithLanguage(metadata, namespaces, name, language)))
+    if((value = msOWSLookupMetadataWithLanguage(metadata, namespaces, name, validated_language)))
         pszEncodedValue = msEncodeHTMLEntities(value);
         msIO_fprintf(stream, format, pszEncodedValue);
@@ -1101,7 +1101,7 @@
         if (action_if_not_found == OWS_WARN)
-            msIO_fprintf(stream, "<!-- WARNING: Mandatory metadata '%s%s%s%s' was missing in this context. -->\n", (namespaces?"..._":""), name, (language?"_":""), (language?language:""));
+            msIO_fprintf(stream, "<!-- WARNING: Mandatory metadata '%s%s%s%s' was missing in this context. -->\n", (namespaces?"..._":""), name, (validated_language?"_":""), (validated_language?validated_language:""));
             status = action_if_not_found;
@@ -1192,11 +1192,25 @@
 ** If a default value is provided and metadata is absent then the
 ** default will be used.
+int msOWSPrintGroupMetadata(FILE *stream, mapObj *map, char* pszGroupName,
+                            const char *namespaces, const char *name,
+                            int action_if_not_found,
+                            const char *format, const char *default_value)
+    return msOWSPrintGroupMetadata2(stream, map, pszGroupName, namespaces, name, action_if_not_found, format, default_value, NULL);
-int msOWSPrintGroupMetadata(FILE *stream, mapObj *map, char* pszGroupName,
+** msOWSPrintGroupMetadata2()
+** Attempt to output a capability item in the requested language.
+** Fallback using no language parameter.
+int msOWSPrintGroupMetadata2(FILE *stream, mapObj *map, char* pszGroupName,
-                            const char *format, const char *default_value)
+                            const char *format, const char *default_value,
     const char *value;
     char *encoded;
@@ -1207,7 +1221,7 @@
         if (GET_LAYER(map, i)->group && (strcmp(GET_LAYER(map, i)->group, pszGroupName) == 0) && &(GET_LAYER(map, i)->metadata))
-         if((value = msOWSLookupMetadata(&(GET_LAYER(map, i)->metadata), namespaces, name)))
+         if((value = msOWSLookupMetadataWithLanguage(&(GET_LAYER(map, i)->metadata), namespaces, name, validated_language)))
             encoded = msEncodeHTMLEntities(value);
             msIO_fprintf(stream, format, encoded);
Modified: sandbox/inspire_soc2011/mapserver/mapows.h
--- sandbox/inspire_soc2011/mapserver/mapows.h	2011-07-14 14:00:50 UTC (rev 11938)
+++ sandbox/inspire_soc2011/mapserver/mapows.h	2011-07-15 05:45:32 UTC (rev 11939)
@@ -205,6 +205,11 @@
                             const char *format, const char *default_value);
+                            const char *validated_language);
 int msOWSPrintURLType(FILE *stream, hashTableObj *metadata,
                       int action_if_not_found, const char *tag_format,
Modified: sandbox/inspire_soc2011/mapserver/mapwms.c
--- sandbox/inspire_soc2011/mapserver/mapwms.c	2011-07-14 14:00:50 UTC (rev 11938)
+++ sandbox/inspire_soc2011/mapserver/mapwms.c	2011-07-15 05:45:32 UTC (rev 11939)
@@ -2731,12 +2731,12 @@
                             lp->group);
              msOWSPrintEncodeParam(stdout, "GROUP.NAME", lp->group,
                                    OWS_NOERR, "      <Name>%s</Name>\n", NULL);
-             msOWSPrintGroupMetadata(stdout, map, lp->group,
+             msOWSPrintGroupMetadata2(stdout, map, lp->group,
                                      "MO", "GROUP_TITLE", OWS_WARN,
-                                     "      <Title>%s</Title>\n", lp->group);
+                                     "      <Title>%s</Title>\n", lp->group, validated_language);
                                      "MO", "GROUP_ABSTRACT", OWS_NOERR,
-                                     "      <Abstract>%s</Abstract>\n", lp->group);
+                                     "      <Abstract>%s</Abstract>\n", lp->group, validated_language);
              /*build a getlegendgraphicurl*/
              if( script_url_encoded)
