[mapserver-commits] r11950 - branches/branch-6-0/docs/en/mapfile/symbology
Mon Jul 18 13:07:26 EDT 2011
Author: jmckenna
Date: 2011-07-18 10:07:26 -0700 (Mon, 18 Jul 2011)
New Revision: 11950
   branches/branch-6-0/docs/en/mapfile/symbology/construction.txt
fix error causing PDF generation to break...yikes!  good riddance
Modified: branches/branch-6-0/docs/en/mapfile/symbology/construction.txt
--- branches/branch-6-0/docs/en/mapfile/symbology/construction.txt	2011-07-18 16:42:02 UTC (rev 11949)
+++ branches/branch-6-0/docs/en/mapfile/symbology/construction.txt	2011-07-18 17:07:26 UTC (rev 11950)
@@ -1113,10 +1113,10 @@
   |  LAYER  #                                           |                                           |
   |    STATUS DEFAULT                                   |                                           |
   |    TYPE LINE                                        |                                           |
-  |    FEATURE                                          |.. figure:: ../../images/symcon-offset.png |
+  |    FEATURE                                          |.. image:: ../../images/symcon-offset.png  |
   |      POINTS                                         |   :align: center                          |
   |        20 20                                        |                                           |
-  |        280 160                                      |   Line offset                             |
+  |        280 160                                      |Line offset                                |
   |        280 20                                       |                                           |
   |        160 20                                       |                                           |
   |        160 60                                       |                                           |
