[mapserver-commits] r11954 - trunk/docs/en/input/vector
Mon Jul 18 18:54:28 EDT 2011
Author: jmckenna
Date: 2011-07-18 15:54:28 -0700 (Mon, 18 Jul 2011)
New Revision: 11954
Added:
   trunk/docs/en/input/vector/filegdb.txt
   trunk/docs/en/input/vector/index.txt
add FileGDB page
Added: trunk/docs/en/input/vector/filegdb.txt
--- trunk/docs/en/input/vector/filegdb.txt	                        (rev 0)
+++ trunk/docs/en/input/vector/filegdb.txt	2011-07-18 22:54:28 UTC (rev 11954)
@@ -0,0 +1,120 @@
+.. _filegdb:
+ ESRI File Geodatabase
+ESRI File Geodatabases exist in a file folder and offer improved performance and size limitations.  For more information see the ESRI `description page`_.
+.. _`description page`: http://resources.arcgis.com/content/geodatabases/10.0/types-of-geodatabases
+.. note::
+   Only file geodatabases created by AcrGIS 10.0 and above can be read by GDAL/MapServer.
+File listing
+File geodatabases are made up of a set of files within a folder. The files are made up of geographic data, attribute data,
+index files, and lock files.  A better description of the file contents can be found `here <http://webhelp.esri.com/arcgisserver/9.3/java/index.htm#geodatabases/file_ge-516860750.htm>`__.
+Data Access / Connection Method
+File geodatabase access is available through OGR. See the OGR `driver page <http://www.gdal.org/ogr/drv_filegdb.html>`__
+for specific driver information.  The driver is available for GDAL >= 1.9.0.
+The CONNECTION parameter must be used to point to the name of the file folder, and the DATA parameter
+should be the name of the spatial table (or OGR layer).
+  CONNECTIONTYPE ogr
+  CONNECTION "filegdb.gdb"
+  DATA "layername"
+.. note::
+   During testing on Windows, a full path was required for the CONNECTION parameter.
+OGRINFO Examples
+First you should make sure that your GDAL/OGR build contains the file
+geodatabase "FileGDB" driver, by using the '--formats' command:
+  >ogrinfo --formats
+     Supported Formats:
+     "FileGDB" (read/write)
+     "ESRI Shapefile" (read/write)
+     "MapInfo File" (read/write)
+     "UK .NTF" (readonly)
+     "SDTS" (readonly)
+     "TIGER" (read/write)
+If you don't have the driver, see GDAL's `BuildHints <http://trac.osgeo.org/gdal/wiki/FileGDB>`__ page for
+compiling the driver.
+Once you have the FileGDB driver you are ready to try an ogrinfo command on your
+database to get a list of spatial tables.  In the example below our folder is named `us_states.gdb`:
+  ogrinfo us_states.gdb
+    INFO: Open of `us_states.gdb'
+    using driver `FileGDB' successful.
+    1: statesp020 (Multi Polygon)
+Now use ogrinfo to get information on the structure of the `statesp020` table:
+  ogrinfo us_states.gdb statesp020 -summary
+    Layer name: statesp020
+    Geometry: Multi Polygon
+    Feature Count: 2895
+    Extent: (-179.000000, 17.000000) - (179.000000, 71.000000)
+    Layer SRS WKT:
+    GEOGCS["GCS_North_American_1983",
+       DATUM["North_American_Datum_1983",
+           SPHEROID["GRS_1980",6378137.0,298.257222101]],
+       PRIMEM["Greenwich",0.0],
+       UNIT["Degree",0.017453292519943295]]
+    FID Column = OBJECTID
+    Geometry Column = SHAPE
+    AREA: Real (0.0)
+    PERIMETER: Real (0.0)
+    STATESP020: Real (0.0)
+    STATE: String (0.0)
+    STATE_FIPS: String (0.0)
+Mapfile Example
+.. code-block:: mapfile
+    LAYER
+      NAME "fgdb_poly"
+      TYPE POLYGON
+      STATUS ON
+      CONNECTIONTYPE OGR
+      CONNECTION "C:/ms4w/apps/ms101/data/filegdb/us_states.gdb"
+      DATA "statesp020"
+      LABELITEM "STATE"
+      CLASS
+        NAME "US States"
+        STYLE
+          COLOR 120 120 120
+          OUTLINECOLOR 0 0 0
+        END
+        LABEL
+          COLOR 255 255 255
+        END
+      END
+    END
\ No newline at end of file
Modified: trunk/docs/en/input/vector/index.txt
--- trunk/docs/en/input/vector/index.txt	2011-07-18 22:50:43 UTC (rev 11953)
+++ trunk/docs/en/input/vector/index.txt	2011-07-18 22:54:28 UTC (rev 11954)
@@ -4,11 +4,11 @@
  Vector Data
+:Author: Jeff McKenna
+:Contact: jmckenna at gatewaygeomatics.com
 :Author: Tyler Mitchell
 :Contact: tmitchell at osgeo.org
-:Author: Jeff McKenna
-:Contact: jmckenna at gatewaygeomatics.com
-:Last Updated: 2011-04-11
+:Last Updated: 2011-07-18
 This work is licensed under the Creative Commons Attribution-ShareAlike
 License. To view a copy of this license, visit:
@@ -56,6 +56,7 @@
    ArcInfo
    arcsde
    dgn
+   filegdb
    pgeo
    shapefiles
    gml
