[mapserver-commits] r11974 - branches/branch-6-0/docs/en/mapfile trunk/docs/en/mapfile
Fri Jul 29 09:26:24 EDT 2011
Author: havatv
Date: 2011-07-29 06:26:24 -0700 (Fri, 29 Jul 2011)
New Revision: 11974
   branches/branch-6-0/docs/en/mapfile/expressions.txt
   trunk/docs/en/mapfile/expressions.txt
Expressions: Updated the expression document with spatial operators and functions (#3613)
Modified: branches/branch-6-0/docs/en/mapfile/expressions.txt
--- branches/branch-6-0/docs/en/mapfile/expressions.txt	2011-07-27 22:48:27 UTC (rev 11973)
+++ branches/branch-6-0/docs/en/mapfile/expressions.txt	2011-07-29 13:26:24 UTC (rev 11974)
@@ -1,3 +1,4 @@
 .. _expressions:
@@ -307,7 +308,7 @@
   ( ( Expression1 ) && ( Expression2 ) )
-  ... true when both of the logical expressions (Expression1 and
+  returns true when both of the logical expressions (Expression1 and
   Expression2) are true.
@@ -315,16 +316,16 @@
   ( ( Expression1 ) || ( Expression2 ) )
-  ... true when at least one of the logical expressions (Expression1
+  returns true when at least one of the logical expressions (Expression1
   or Expression2) is true.
 * NOT ( Expression1 )
   ! ( Expression1 )
-  ... true when Expression1 is false.
+  returns true when Expression1 is false.
-String operations that return a logical value
+String expressions that return a logical value
 Syntactically, a sting is something encapsulated in single or double
@@ -336,47 +337,47 @@
    ( "String1" = "String2" )
-   ... true when the strings are equal.  Case sensitive.
+   returns true when the strings are equal.  Case sensitive.
 *  ( "String1" =\* "String2" )
-   ... true when the strings are equal.  Case insensitive.
+   returns true when the strings are equal.  Case insensitive.
 *  ( "String1" != "String2" )
    ( "String1" ne "String2" )
-   ... true when the strings are not equal.
+   returns true when the strings are not equal.
 *  ( "String1" < "String2" )
    ( "String1" lt "String2" )
-   ... true when "String1" is lexicographically smaller than "String2"
+   returns true when "String1" is lexicographically smaller than "String2"
 *  ( "String1" > "String2" )
    ( "String1" gt "String2" )
-   ... true when "String1" is lexicographically larger than "String2".
+   returns true when "String1" is lexicographically larger than "String2".
 *  ( "String1" <= "String2" )
    ( "String1" le "String2" )
-   ... true when "String1" is lexicographically smaller than or equal
+   returns true when "String1" is lexicographically smaller than or equal
    to "String2"
 *  ( "String1" >= "String2" )
    ( "String1" ge "String2" )
-   ... true when "String1" is lexicographically larger than or equal
+   returns true when "String1" is lexicographically larger than or equal
    to "String2".
 *  ( "String1" IN "token1,token2,...,tokenN" )
-   ... true when "String1" is equal to one of the given tokens.
+   returns true when "String1" is equal to one of the given tokens.
    .. note::
@@ -384,41 +385,18 @@
       can not be unnecessary white space in the list and that tokens
       that have commas in them cannot be compared.
-*  ( "String1" =~ "regexp" )
+*  ( "String1" ~ "regexp" )
-   ... true, when "String1" matches the regular expression
+   returns true when "String1" matches the regular expression
    "regexp". This operation is identical to the regular expression
    matching described earlier.
-String operations that return string values
+*  ( "String1" ~* "regexp" )
-*  "String1" + "String2'
+   returns true when "String1" matches the regular expression "regexp"
+   (case insensitive). This operation is identical to the regular
+   expression matching described earlier.
-   ... returns "String1String2", that is, the two strings concatenated
-   to each other.
-String functions that return a number
-*  length ( "String1" )
-   ... returns the number of characters of "String1"
-Functions that return a string
-*  tostring ( n1, "Format1" )
-   ... uses "Format1" to format the number n1 (C style formatting
-   - sprintf).
-*  commify ( "String1" )
-   ... adds thousands separators (commas) to a long number to make it
-   more readable
 Arithmetic expressions that return a logical value
@@ -431,69 +409,150 @@
    ( n1 = n2 )
-   ... true when the numbers are equal.
+   returns true when the numbers are equal.
 *  ( n1 != n2 )
    ( n1 ne n2 )
-   ... true when the numbers are not equal.
+   returns true when the numbers are not equal.
 *  ( n1 < n2 )
    ( n1 lt n2 )
-   ... true when n1 is smaller than n2.
+   returns true when n1 is smaller than n2.
 *  ( n1 > n2 )
    ( n1 gt n2 )
-   ... true when n1 is larger than n2.
+   returns true when n1 is larger than n2.
 *  ( n1 <= n2 )
    ( n1 le n2 )
-   ... true when n1 is smaller than or equal to n2.
+   returns true when n1 is smaller than or equal to n2.
 *  ( n1 >= n2 )
    ( n1 ge n2 )
-   ... true when n1 is larger than or equal to n2.
+   returns true when n1 is larger than or equal to n2.
 *  ( n1 IN "number1,number2,...,numberN" )
-   ... true when n1 is equal to one of the given numbers.
+   returns true when n1 is equal to one of the given numbers.
-Arithmetic expressions that return a number
+Spatial expressions that return a logical value (GEOS)
+*  ( shape1 eq shape2 )
+   returns true if shape1 and shape2 are equal
+*  ( shape1 intersects shape2 )
+   returns true if shape1 and shape2 intersect
+*  ( shape1 disjoint shape2 )
+   returns true if shape1 and shape2 are disjoint
+*  ( shape1 touches shape2 )
+   returns true if shape1 and shape2 touch
+*  ( shape1 overlaps shape2 )
+   returns true if shape1 and shape2 overlap
+*  ( shape1 crosses shape2 )
+   returns true if shape1 and shape2 cross
+*  ( shape1 within shape2 )
+   returns true if shape1 is within shape2
+*  ( shape1 contains shape2 )
+   returns true if shape1 contains shape2
+*  ( shape1 dwithin shape2 )
+   returns true if the distance between shape1 and shape2
+   is equal to 0
+*  ( shape1 beyond shape2 )
+   is greater than 0
+String operations that return a string
+*  "String1" + "String2'
+   returns "String1String2", that is, the two strings concatenated
+   to each other.
+Functions that return a string
+*  tostring ( n1, "Format1" )
+   uses "Format1" to format the number n1 (C style formatting
+   - sprintf).
+*  commify ( "String1" )
+   adds thousands separators (commas) to a long number to make it
+   more readable
+String functions that return a number
+*  length ( "String1" )
+   returns the number of characters of "String1"
+Arithmetic operations and functions that return a number
+*  round ( n1 , n2 )
+   returns n1 rounded to a multiple of n2: n2 * round(n1/n2)
 *  n1 + n2
-   ... returns the sum of n1 and n2
+   returns the sum of n1 and n2
 *  n1 - n2
-   ... returns n2 subtracted from n1
+   returns n2 subtracted from n1
 *  n1 \* n2
-   ... returns n1 multiplicated with n2
+   returns n1 multiplicated with n2
 *  n1 / n2>
-   ... returns n1 divided by n2
+   returns n1 divided by n2
 *  -n1
-   ... returns n1 negated
+   returns n1 negated
 *  n1 ^ n2
-   ... returns n1 to the power of n2
+   returns n1 to the power of n2
 .. note::
@@ -514,6 +573,37 @@
     would return false.
+Spatial functions that return a number (GEOS)
+*  area ( shape1 )
+   returns the area of shape1
+Spatial functions that return a shape (GEOS)
+*  fromtext ( "String1" )
+   returns the shape corresponding to String1 (WKT - well known text)
+     fromText('POINT(500000 5000000)')
+*  buffer (shape1 , n1 )
+   returns the shape that results when shape1 is buffered with
+   bufferdistance n1
+*  difference ( shape1 , shape2 )
+   returns the shape that results when the common area of
+   shape1 and shape2 is subtracted from shape1
 Temporal expressions
@@ -550,35 +640,35 @@
    ( t1 = t2 )
-   ... true when the times are equal.
+   returns true when the times are equal.
 *  ( t1 != t2 )
    ( t1 ne t2 )
-   ... true when the times are not equal.
+   returns true when the times are not equal.
 *  ( t1 < t2 )
    ( t1 lt t2 )
-   ... true when t1 is earlier than t2
+   returns true when t1 is earlier than t2
 *  ( t1 > t2 )
    ( t1 gt t2 )
-   ... true when t1 is later than t2.
+   returns true when t1 is later than t2.
 *  ( t1 <= t2 )
    ( t1 le t2 )
-   ... true when t1 is earlier than or equal to t2
+   returns true when t1 is earlier than or equal to t2
 *  ( t1 >= t2 )
    ( t1 ge t2 )
-   ... true when t1 is later than or equal to t2.
+   returns true when t1 is later than or equal to t2.
Modified: trunk/docs/en/mapfile/expressions.txt
--- trunk/docs/en/mapfile/expressions.txt	2011-07-27 22:48:27 UTC (rev 11973)
+++ trunk/docs/en/mapfile/expressions.txt	2011-07-29 13:26:24 UTC (rev 11974)
@@ -1,3 +1,4 @@
 .. _expressions:
@@ -307,7 +308,7 @@
   ! ( Expression1 )
    to "String2"
    to "String2".
    .. note::
-   to each other.
-   - sprintf).
-   more readable
    ( n1 = n2 )
 *  ( n1 != n2 )
    ( n1 ne n2 )
 *  ( n1 < n2 )
    ( n1 lt n2 )
 *  ( n1 > n2 )
    ( n1 gt n2 )
 *  ( n1 <= n2 )
    ( n1 le n2 )
 *  ( n1 >= n2 )
    ( n1 ge n2 )
+   is equal to 0
+   is greater than 0
+   to each other.
+   - sprintf).
+   more readable
 *  n1 + n2
 *  n1 - n2
 *  n1 \* n2
 *  n1 / n2>
 *  -n1
 *  n1 ^ n2
 .. note::
     would return false.
+*  area ( shape1 )
+   bufferdistance n1
    ( t1 = t2 )
 *  ( t1 != t2 )
    ( t1 ne t2 )
 *  ( t1 < t2 )
    ( t1 lt t2 )
 *  ( t1 > t2 )
    ( t1 gt t2 )
 *  ( t1 <= t2 )
    ( t1 le t2 )
 *  ( t1 >= t2 )
    ( t1 ge t2 )
