[mapserver-commits] r11978 - trunk/docs/en/input/vector
Fri Jul 29 11:17:28 EDT 2011
Author: jmckenna
Date: 2011-07-29 08:17:28 -0700 (Fri, 29 Jul 2011)
New Revision: 11978
   trunk/docs/en/input/vector/filegdb.txt
add note about CONNECTION path
Modified: trunk/docs/en/input/vector/filegdb.txt
--- trunk/docs/en/input/vector/filegdb.txt	2011-07-29 15:10:23 UTC (rev 11977)
+++ trunk/docs/en/input/vector/filegdb.txt	2011-07-29 15:17:28 UTC (rev 11978)
@@ -33,7 +33,7 @@
   DATA "layername"
 .. note::
-   During testing on Windows, a full path was required for the CONNECTION parameter.
+   The CONNECTION path is relative to the mapfile (SHAPEPATH is not used here).  Full paths can also be used.
 OGRINFO Examples
@@ -103,7 +103,7 @@
       TYPE POLYGON
       STATUS ON
       CONNECTIONTYPE OGR
-      CONNECTION "C:/ms4w/apps/ms101/data/filegdb/us_states.gdb"
+      CONNECTION "../data/filegdb/us_states.gdb"
       DATA "statesp020"
       LABELITEM "STATE"
       CLASS
