[mapserver-commits] r11042 - trunk/mapserver
Thu Mar 3 09:10:45 EST 2011
Author: tamas
Date: 2011-03-03 06:10:45 -0800 (Thu, 03 Mar 2011)
New Revision: 11042
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapdraw.c
   trunk/mapserver/maplayer.c
   trunk/mapserver/mapogr.cpp
   trunk/mapserver/maporaclespatial.c
   trunk/mapserver/mapserver.h
Fixed OGR query handling according to RFC 65 (#3647)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-03-03 13:50:48 UTC (rev 11041)
+++ trunk/mapserver/HISTORY.TXT	2011-03-03 14:10:45 UTC (rev 11042)
@@ -14,6 +14,8 @@
 Current Version (SVN trunk):
+- Fixed OGR query handling according to RFC 65 (#3647)
 - Implement CLOSE_CONNECTION=ALWAYS to suppress the connection pooling
   for a particular layer.
Modified: trunk/mapserver/mapdraw.c
--- trunk/mapserver/mapdraw.c	2011-03-03 13:50:48 UTC (rev 11041)
+++ trunk/mapserver/mapdraw.c	2011-03-03 14:10:45 UTC (rev 11042)
@@ -898,7 +898,7 @@
     /* style parameters for this shape. */
     if(layer->styleitem) {
         if(strcasecmp(layer->styleitem, "AUTO") == 0) {
-            if (msLayerGetAutoStyle(map, layer, layer->class[shape.classindex], shape.tileindex, shape.index) != MS_SUCCESS) {
+            if (msLayerGetAutoStyle(map, layer, layer->class[shape.classindex], &shape) != MS_SUCCESS) {
                 retcode = MS_FAILURE;
                 break;
@@ -1074,6 +1074,9 @@
 	if (msCopyLayer(&tmp_layer, layer) != MS_SUCCESS)
 		return(MS_FAILURE);
+    /* disable the connection pool for this layer */
+    msLayerSetProcessingKey(&tmp_layer, "CLOSE_CONNECTION", "ALWAYS");
     status = msDrawLayer(map, &tmp_layer, image);
 	freeLayer(&tmp_layer);
Modified: trunk/mapserver/maplayer.c
--- trunk/mapserver/maplayer.c	2011-03-03 13:50:48 UTC (rev 11041)
+++ trunk/mapserver/maplayer.c	2011-03-03 14:10:45 UTC (rev 11042)
@@ -628,8 +628,7 @@
 ** twice.
-int msLayerGetAutoStyle(mapObj *map, layerObj *layer, classObj *c,
-                        int tile, long record)
+int msLayerGetAutoStyle(mapObj *map, layerObj *layer, classObj *c, shapeObj* shape)
   if ( ! layer->vtable) {
       int rv =  msInitializeVirtualTable(layer);
@@ -1124,7 +1123,7 @@
   return MS_FAILURE;
-int LayerDefaultGetAutoStyle(mapObj *map, layerObj *layer, classObj *c, int tile, long record)
+int LayerDefaultGetAutoStyle(mapObj *map, layerObj *layer, classObj *c, shapeObj* shape)
   msSetError(MS_MISCERR, "'STYLEITEM AUTO' not supported for this data source.", "msLayerGetAutoStyle()");
   return MS_FAILURE;
Modified: trunk/mapserver/mapogr.cpp
--- trunk/mapserver/mapogr.cpp	2011-03-03 13:50:48 UTC (rev 11041)
+++ trunk/mapserver/mapogr.cpp	2011-03-03 14:10:45 UTC (rev 11042)
@@ -82,7 +82,7 @@
 static int msOGRLayerIsOpen(layerObj *layer);
 static int msOGRLayerInitItemInfo(layerObj *layer);
 static int msOGRLayerGetAutoStyle(mapObj *map, layerObj *layer, classObj *c,
-                                  int tile, long record);
+                                  shapeObj* shape);
 static void msOGRCloseConnection( void *conn_handle );
@@ -1914,8 +1914,8 @@
       shape->type = MS_SHAPE_NULL;
-  /* TODO: Need to set result index too! */
-  shape->index = psInfo->last_record_index_read;
+  shape->index =  OGR_F_GetFID( hFeature );;
+  shape->resultindex = psInfo->last_record_index_read;
   shape->tileindex = psInfo->nTileId;
   if (layer->debug >= MS_DEBUGLEVEL_VVV)
@@ -2037,7 +2037,17 @@
-  shape->index = record;
+  if (record_is_fid)
+      shape->index = record;
+      shape->resultindex = -1;
+  else
+      shape->resultindex = record;
   // Keep ref. to last feature read in case we need style info.
@@ -2672,10 +2682,14 @@
   long shapeindex = record->shapeindex;
   int tileindex = record->tileindex;
   int resultindex = record->resultindex;
+  int record_is_fid = TRUE;
-  ** TODO: Merge logic from msOGRLayerResultGetShape() based on result->resultindex (if not -1).
+  /* set the resultindex as shapeindex if available */
+  if (resultindex >= 0)
+    record_is_fid = FALSE;
+    shapeindex = resultindex;
   if (psInfo == NULL || psInfo->hLayer == NULL)
@@ -2684,7 +2698,7 @@
   if( layer->tileindex == NULL )
-      return msOGRFileGetShape(layer, shape, shapeindex, psInfo, TRUE );
+      return msOGRFileGetShape(layer, shape, shapeindex, psInfo, record_is_fid );
   else
       if( psInfo->poCurTile == NULL
@@ -2694,7 +2708,7 @@
               return MS_FAILURE;
-      return msOGRFileGetShape(layer, shape, shapeindex, psInfo->poCurTile, TRUE );
+      return msOGRFileGetShape(layer, shape, shapeindex, psInfo->poCurTile, record_is_fid );
 #else
@@ -2709,52 +2723,6 @@
- *                     msOGRLayerResultGetShape()
- * Returns shape from OGR data source by index into the current results
- * set. TODO: THIS FUNCTION GOES AWAY!
- * Returns MS_SUCCESS/MS_FAILURE
-int msOGRLayerResultGetShape(layerObj *layer, shapeObj *shape, int tile,
-                             long record)
-#ifdef USE_OGR
-  msOGRFileInfo *psInfo =(msOGRFileInfo*)layer->layerinfo;
-  if (psInfo == NULL || psInfo->hLayer == NULL)
-    msSetError(MS_MISCERR, "Assertion failed: OGR layer not opened!!!",
-               "msOGRLayerNextShape()");
-    return(MS_FAILURE);
-  if( layer->tileindex == NULL )
-      return msOGRFileGetShape(layer, shape, record, psInfo, FALSE );
-  else
-      if( psInfo->poCurTile == NULL
-          || psInfo->poCurTile->nTileId != tile )
-          if( msOGRFileReadTile( layer, psInfo, tile ) != MS_SUCCESS )
-              return MS_FAILURE;
-      return msOGRFileGetShape(layer, shape, record, psInfo->poCurTile, FALSE );
-#else
- * OGR Support not included...
-  msSetError(MS_MISCERR, "OGR support is not available.",
-             "msOGRLayerGetShape()");
-#endif /* USE_OGR */
  *                     msOGRLayerGetExtent()
  * Returns the layer extents.
@@ -3589,7 +3557,7 @@
  * the next call and that shouldn't be freed by the caller.
+                                  shapeObj* shape)
 #ifdef USE_OGR
@@ -3603,7 +3571,7 @@
   if( layer->tileindex != NULL )
-      if( (psInfo->poCurTile == NULL || tile != psInfo->poCurTile->nTileId)
+      if( (psInfo->poCurTile == NULL || shape->tileindex != psInfo->poCurTile->nTileId)
           && msOGRFileReadTile( layer, psInfo ) != MS_SUCCESS )
           return MS_FAILURE;
@@ -3615,7 +3583,7 @@
   ACQUIRE_OGR_LOCK;
   if (psInfo->hLastFeature == NULL ||
-      psInfo->last_record_index_read != record)
+      psInfo->last_record_index_read != shape->resultindex)
       RELEASE_OGR_LOCK;
@@ -3760,7 +3728,6 @@
     layer->vtable->LayerIsOpen = msOGRLayerIsOpen;
     layer->vtable->LayerWhichShapes = msOGRLayerWhichShapes;
     layer->vtable->LayerNextShape = msOGRLayerNextShape;
-    // layer->vtable->LayerResultsGetShape = msOGRLayerResultGetShape;
     layer->vtable->LayerGetShape = msOGRLayerGetShape;
     layer->vtable->LayerClose = msOGRLayerClose;
     layer->vtable->LayerGetItems = msOGRLayerGetItems;
Modified: trunk/mapserver/maporaclespatial.c
--- trunk/mapserver/maporaclespatial.c	2011-03-03 13:50:48 UTC (rev 11041)
+++ trunk/mapserver/maporaclespatial.c	2011-03-03 14:10:45 UTC (rev 11042)
@@ -3482,7 +3482,7 @@
     /* nothing to do */
-int msOracleSpatialLayerGetAutoStyle( mapObj *map, layerObj *layer, classObj *c, int tile, long record )
+int msOracleSpatialLayerGetAutoStyle( mapObj *map, layerObj *layer, classObj *c, shapeObj *shape )
     msSetError( MS_ORACLESPATIALERR, "Function not implemented yet", "msLayerGetAutoStyle()" );
     return MS_FAILURE;
@@ -3550,7 +3550,7 @@
   msSetError( MS_ORACLESPATIALERR, "OracleSpatial is not supported", "msOracleSpatialLayerFreeItemInfo()" );
   msSetError( MS_ORACLESPATIALERR, "OracleSpatial is not supported", "msLayerGetAutoStyle()" );
   return MS_FAILURE;
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2011-03-03 13:50:48 UTC (rev 11041)
+++ trunk/mapserver/mapserver.h	2011-03-03 14:10:45 UTC (rev 11042)
@@ -1623,7 +1623,7 @@
   int (*LayerClose)(layerObj *layer);
   int (*LayerGetItems)(layerObj *layer);
   int (*LayerGetExtent)(layerObj *layer, rectObj *extent);
-  int (*LayerGetAutoStyle)(mapObj *map, layerObj *layer, classObj *c, int tile, long record);
+  int (*LayerGetAutoStyle)(mapObj *map, layerObj *layer, classObj *c, shapeObj* shape);
   int (*LayerCloseConnection)(layerObj *layer);
   int (*LayerSetTimeFilter)(layerObj *layer, const char *timestring, const char *timefield);
   int (*LayerApplyFilterToLayer)(FilterEncodingNode *psNode, mapObj *map, int iLayerIndex);
@@ -2038,7 +2038,7 @@
 MS_DLL_EXPORT int msLayerGetShape(layerObj *layer, shapeObj *shape, resultObj *record);
 MS_DLL_EXPORT int msLayerGetExtent(layerObj *layer, rectObj *extent);
 MS_DLL_EXPORT int msLayerSetExtent( layerObj *layer, double minx, double miny, double maxx, double maxy);
-MS_DLL_EXPORT int msLayerGetAutoStyle(mapObj *map, layerObj *layer, classObj *c, int tile, long record);
+MS_DLL_EXPORT int msLayerGetAutoStyle(mapObj *map, layerObj *layer, classObj *c, shapeObj* shape);
 MS_DLL_EXPORT int msLayerGetFeatureStyle(mapObj *map, layerObj *layer, classObj *c, shapeObj* shape);
 MS_DLL_EXPORT void msLayerAddProcessing( layerObj *layer, const char *directive );
 MS_DLL_EXPORT void msLayerSetProcessingKey( layerObj *layer, const char *key,
