[mapserver-commits] r11068 - trunk/mapserver
Fri Mar 4 07:29:49 EST 2011
Author: tamas
Date: 2011-03-04 04:29:49 -0800 (Fri, 04 Mar 2011)
New Revision: 11068
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapmssql2008.c
Implement single-pass query handling in mssql2008 driver as per RFC 65
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-03-04 11:27:19 UTC (rev 11067)
+++ trunk/mapserver/HISTORY.TXT	2011-03-04 12:29:49 UTC (rev 11068)
@@ -14,6 +14,8 @@
 Current Version (SVN trunk):
+- Implement single-pass query handling in mssql2008 driver as per RFC 65.
 - Fixed Sql Server 2008 key column name truncation (#3654)
 - Added label position binding (#3612) and label shadow size binding (#2924)
Modified: trunk/mapserver/mapmssql2008.c
--- trunk/mapserver/mapmssql2008.c	2011-03-04 11:27:19 UTC (rev 11067)
+++ trunk/mapserver/mapmssql2008.c	2011-03-04 12:29:49 UTC (rev 11068)
@@ -707,6 +707,7 @@
         return set_up_result; /* relay error */
+    msFree(layerinfo->sql);
     layerinfo->sql = query_str;
     layerinfo->row_num = 0;
@@ -1410,6 +1411,7 @@
             record_oid = strtol(oidBuffer, NULL, 10);
             shape->index = record_oid;
+            shape->resultindex = (*record);
             find_bounds(shape);
             (*record)++;        /* move to next shape */
@@ -1465,6 +1467,7 @@
     int                 t;
     char buffer[32000] = "";
     long shapeindex = record->shapeindex;
+    long resultindex = record->resultindex;
     if(layer->debug) {
         msDebug("msMSSQL2008LayerGetShape called for shapeindex = %i\n", shapeindex);
@@ -1479,6 +1482,32 @@
         return MS_FAILURE;
+    if (resultindex >= 0 && layerinfo->sql)
+        /* trying to provide the result from the current resultset (single-pass query) */
+        if( resultindex < layerinfo->row_num)
+            /* re-issue the query */
+            if (!executeSQL(layerinfo->conn, layerinfo->sql))
+                msSetError(MS_QUERYERR, "Error executing MSSQL2008 SQL statement: %s\n-%s\n", "msMSSQL2008LayerGetShape()", layerinfo->sql, layerinfo->conn->errorMessage);
+                return MS_FAILURE;
+            layerinfo->row_num = 0;
+        while( layerinfo->row_num < resultindex )
+            /* move forward until we reach the desired index */
+            if (msMSSQL2008LayerGetShapeRandom(layer, shape, &(layerinfo->row_num)) != MS_SUCCESS)
+        return msMSSQL2008LayerGetShapeRandom(layer, shape, &(layerinfo->row_num));
+    /* non single-pass case, fetch the record from the database */
     if(layer->numitems == 0)
         snprintf(buffer, sizeof(buffer), "%s.STAsBinary(), convert(varchar(20), %s)", layerinfo->geom_column, layerinfo->urid_name);
@@ -1516,8 +1545,8 @@
         return MS_FAILURE;
-    msFree(layerinfo->sql);
-    layerinfo->sql = query_str;
+    /* we don't preserve the query string in this case (cannot be re-used) */
+    msFree(query_str);
