[mapserver-commits] r11073 - trunk/mapserver
Fri Mar 4 14:57:49 EST 2011
Author: rouault
Date: 2011-03-04 11:57:49 -0800 (Fri, 04 Mar 2011)
New Revision: 11073
   trunk/mapserver/mapwcs20.c
fix memory leaks and Valgrind warning
Modified: trunk/mapserver/mapwcs20.c
--- trunk/mapserver/mapwcs20.c	2011-03-04 19:57:16 UTC (rev 11072)
+++ trunk/mapserver/mapwcs20.c	2011-03-04 19:57:49 UTC (rev 11073)
@@ -112,7 +112,11 @@
 static int msWCSParseTimeOrScalar20(timeScalarUnion *u, const char *string)
     struct tm time;
-    msStringTrim((char *) string);
+    if (string)
+        while(*string == ' ')
+            string ++;
     if (!string || strlen(string) == 0 || !u)
@@ -3373,10 +3377,13 @@
             map->extent = layer->extent;
             msFreeProjection(&(map->projection));
             map->projection = subsetProj;
+            msFreeProjection(&imageProj);
         else
+            msFreeProjection(&(map->projection));
             map->projection = imageProj;
+            msFreeProjection(&subsetProj);
