[mapserver-commits] r11080 - trunk/mapserver
Sat Mar 5 11:41:32 EST 2011
Author: tamas
Date: 2011-03-05 08:41:32 -0800 (Sat, 05 Mar 2011)
New Revision: 11080
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapprimitive.h
Remove shapeObj.line, shapeObj.values, lineObj.point from the SWIG API which are redundant and undocumented. (#3269)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-03-05 13:51:09 UTC (rev 11079)
+++ trunk/mapserver/HISTORY.TXT	2011-03-05 16:41:32 UTC (rev 11080)
@@ -14,6 +14,9 @@
 Current Version (SVN trunk):
+- Remove shapeObj.line, shapeObj.values, lineObj.point from the SWIG API
+  which are redundant and undocumented. (#3269)
 - Remove map-oriented query modes (e.g. QUERYMAP). Use qformat parameter instead. (#3712)
 - Implement single-pass query handling in mssql2008 driver as per RFC 65.
Modified: trunk/mapserver/mapprimitive.h
--- trunk/mapserver/mapprimitive.h	2011-03-05 13:51:09 UTC (rev 11079)
+++ trunk/mapserver/mapprimitive.h	2011-03-05 16:41:32 UTC (rev 11080)
@@ -56,7 +56,9 @@
 %immutable;
 #endif
   int numpoints;
+#ifndef SWIG
   pointObj *point;
+#endif
 #ifdef SWIG
 %mutable;
 #endif
@@ -68,10 +70,9 @@
 #endif
   int numlines;
   int numvalues;
+#ifndef SWIG
   lineObj *line;
   char **values;
-#ifndef SWIG
   void *geometry;
   void *renderer_cache;
 #endif
