[mapserver-commits] r11099 - trunk/msautotest/wxs
Sun Mar 6 15:36:20 EST 2011
Author: rouault
Date: 2011-03-06 12:36:19 -0800 (Sun, 06 Mar 2011)
New Revision: 11099
   trunk/msautotest/wxs/wms_time_pattern.map
correct the mapfiles (but the tests are still KO)
Modified: trunk/msautotest/wxs/wms_time_pattern.map
--- trunk/msautotest/wxs/wms_time_pattern.map	2011-03-06 20:15:49 UTC (rev 11098)
+++ trunk/msautotest/wxs/wms_time_pattern.map	2011-03-06 20:36:19 UTC (rev 11099)
@@ -9,235 +9,235 @@
 # Draw a layer by using single time value
-# wms_time_pattern1a.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern1&Time=20040101" > [RESULT_DEMIME]
+# wms_time_pattern1a.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern1&Time=20040101" > [RESULT_DEMIME]
 # Draw a layer by using multiple time values (See note above)
-# wms_time_pattern1b.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern1&Time=20040101,20040102" > [RESULT_DEMIME]
+# wms_time_pattern1b.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern1&Time=20040101,20040102" > [RESULT_DEMIME]
 # Draw a layer by using a range time values (See note above)
-# wms_time_pattern1c.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern1&Time=20040101/20040102" > [RESULT_DEMIME]
+# wms_time_pattern1c.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern1&Time=20040101/20040102" > [RESULT_DEMIME]
 # Draw a layer by using multiple ranges time values (See note above)
-# wms_time_pattern1d.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern1&Time=20040101/20040102,20040103/20040104" > [RESULT_DEMIME]
+# wms_time_pattern1d.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern1&Time=20040101/20040102,20040103/20040104" > [RESULT_DEMIME]
 #Pattern2 : "%Y-%m-%dT%H:%M:%SZ"
-# RUN_PARMS: wms_time_pattern2a.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern2&Time=2004-01-01T14:10:00Z" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern2a.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern2&Time=2004-01-01T14:10:00Z" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern2b.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern2&Time=2004-01-01T14:10:00Z,2004-01-01T15:10:00Z" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern2b.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern2&Time=2004-01-01T14:10:00Z,2004-01-01T15:10:00Z" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern2c.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern2&Time=2004-01-01T14:10:00Z/2004-01-01T15:10:00Z" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern2c.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern2&Time=2004-01-01T14:10:00Z/2004-01-01T15:10:00Z" > [RESULT_DEMIME]
-# wms_time_pattern2d.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern2&Time=20040101/20040102,20040103/20040104" > [RESULT_DEMIME]
+# wms_time_pattern2d.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern2&Time=20040101/20040102,20040103/20040104" > [RESULT_DEMIME]
 #Pattern3 : "%Y-%m-%dT%H:%M:%S"
-# RUN_PARMS: wms_time_pattern3a.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern3&Time=2004-01-01T14:10:00" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern3a.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern3&Time=2004-01-01T14:10:00" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern3b.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern3&Time=2004-01-01T14:10:00,2004-01-01T15:10:00" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern3b.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern3&Time=2004-01-01T14:10:00,2004-01-01T15:10:00" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern3c.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern3&Time=2004-01-01T14:10:00/2004-01-01T15:10:00" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern3c.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern3&Time=2004-01-01T14:10:00/2004-01-01T15:10:00" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern3d.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern3&Time=2004-01-01T14:10:00/2004-01-01T15:10:00,2004-01-01T16:10:00/2004-01-01T17:10:00" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern3d.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern3&Time=2004-01-01T14:10:00/2004-01-01T15:10:00,2004-01-01T16:10:00/2004-01-01T17:10:00" > [RESULT_DEMIME]
 #Pattern4 : "%Y-%m-%d %H:%M:%S"
-# RUN_PARMS: wms_time_pattern4a.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern4&Time=2004-01-01%2014:10:00" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern4a.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern4&Time=2004-01-01%2014:10:00" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern4b.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern4&Time=2004-01-01%2014:10:00,2004-01-01%2015:10:00" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern4b.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern4&Time=2004-01-01%2014:10:00,2004-01-01%2015:10:00" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern4c.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern4&Time=2004-01-01%2014:10:00/2004-01-01%2015:10:00" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern4c.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern4&Time=2004-01-01%2014:10:00/2004-01-01%2015:10:00" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern4d.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern4&Time=2004-01-01%2014:10:00/2004-01-01%2015:10:00,2004-01-01%2016:10:00/2004-01-01%2017:10:00" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern4d.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern4&Time=2004-01-01%2014:10:00/2004-01-01%2015:10:00,2004-01-01%2016:10:00/2004-01-01%2017:10:00" > [RESULT_DEMIME]
 #Pattern5 : "%Y-%m-%dT%H:%M"
-# RUN_PARMS: wms_time_pattern5a.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern5&Time=2004-01-01T14:10" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern5a.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern5&Time=2004-01-01T14:10" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern5b.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern5&Time=2004-01-01T14:10,2004-01-01T15:10" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern5b.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern5&Time=2004-01-01T14:10,2004-01-01T15:10" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern5c.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern5&Time=2004-01-01T14:10/2004-01-01T15:10" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern5c.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern5&Time=2004-01-01T14:10/2004-01-01T15:10" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern5d.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern5&Time=2004-01-01T14:10/2004-01-01T15:10,2004-01-01T16:10/2004-01-01T17:10" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern5d.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern5&Time=2004-01-01T14:10/2004-01-01T15:10,2004-01-01T16:10/2004-01-01T17:10" > [RESULT_DEMIME]
 #Pattern6 : "%Y-%m-%d %H:%M"
-# RUN_PARMS: wms_time_pattern6a.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern6&Time=2004-01-01%2014:10" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern6a.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern6&Time=2004-01-01%2014:10" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern6b.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern6&Time=2004-01-01%2014:10,2004-01-01%2015:10" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern6b.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern6&Time=2004-01-01%2014:10,2004-01-01%2015:10" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern6c.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern6&Time=2004-01-01%2014:10/2004-01-01%2015:10" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern6c.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern6&Time=2004-01-01%2014:10/2004-01-01%2015:10" > [RESULT_DEMIME]
 # Draw a layer by using multiple range time values
-# RUN_PARMS: wms_time_pattern6d.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern6&Time=2004-01-01%2014:10/2004-01-01%2015:10,2004-01-01%2016:10/2004-01-01%2017:10" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern6d.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern6&Time=2004-01-01%2014:10/2004-01-01%2015:10,2004-01-01%2016:10/2004-01-01%2017:10" > [RESULT_DEMIME]
 #Pattern7 : "%Y-%m-%dT%H"
-# RUN_PARMS: wms_time_pattern7a.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern7&Time=2004-01-01T14" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern7a.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern7&Time=2004-01-01T14" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern7b.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern7&Time=2004-01-01T14,2004-01-01T15" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern7b.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern7&Time=2004-01-01T14,2004-01-01T15" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern7c.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern7&Time=2004-01-01T14/2004-01-01T15" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern7c.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern7&Time=2004-01-01T14/2004-01-01T15" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern7d.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern7&Time=2004-01-01T14/2004-01-01T15,2004-01-01T16/2004-01-01T17" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern7d.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern7&Time=2004-01-01T14/2004-01-01T15,2004-01-01T16/2004-01-01T17" > [RESULT_DEMIME]
 #Pattern8 : "%Y-%m-%d %H"
-# RUN_PARMS: wms_time_pattern8a.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern8&Time=2004-01-01%2014" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern8a.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern8&Time=2004-01-01%2014" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern8b.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern8&Time=2004-01-01%2014,2004-01-01%2015" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern8b.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern8&Time=2004-01-01%2014,2004-01-01%2015" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern8c.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern8&Time=2004-01-01%2014/2004-01-01%2015" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern8c.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern8&Time=2004-01-01%2014/2004-01-01%2015" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern8d.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern8&Time=2004-01-01%2014/2004-01-01%2015,2004-01-01%2016/2004-01-01%2017" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern8d.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern8&Time=2004-01-01%2014/2004-01-01%2015,2004-01-01%2016/2004-01-01%2017" > [RESULT_DEMIME]
 #Pattern9 : "%Y-%m-%d"
-# RUN_PARMS: wms_time_pattern9a.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern9&Time=2004-01-01" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern9a.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern9&Time=2004-01-01" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern9b.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern9&Time=2004-01-01,2004-01-02" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern9b.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern9&Time=2004-01-01,2004-01-02" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern9c.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern9&Time=2004-01-01/2004-01-02" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern9c.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern9&Time=2004-01-01/2004-01-02" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern9d.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern9&Time=2004-01-01/2004-01-02,2004-01-03/2004-01-04" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern9d.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern9&Time=2004-01-01/2004-01-02,2004-01-03/2004-01-04" > [RESULT_DEMIME]
 #Pattern10 : "%Y-%m"
-# RUN_PARMS: wms_time_pattern10a.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern10&Time=2004-01" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern10a.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern10&Time=2004-01" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern10b.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern10&Time=2004-01,2004-02" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern10b.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern10&Time=2004-01,2004-02" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern10c.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern10&Time=2004-01/2004-02" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern10c.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern10&Time=2004-01/2004-02" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern10d.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern10&Time=2004-01/2004-02,2004-03/2004-04" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern10d.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern10&Time=2004-01/2004-02,2004-03/2004-04" > [RESULT_DEMIME]
 #Pattern11 : "%Y"
-# RUN_PARMS: wms_time_pattern11a.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern11&Time=2004" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern11a.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern11&Time=2004" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern11b.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern11&Time=2004,2005" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern11b.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern11&Time=2004,2005" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern11c.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern11&Time=2004/2005" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern11c.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern11&Time=2004/2005" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern11d.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern11&Time=2004/2005,2006/2007" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern11d.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern11&Time=2004/2005,2006/2007" > [RESULT_DEMIME]
 #Pattern14 : "%Y-%m-%d %H:%M:%SZ"
-# RUN_PARMS: wms_time_pattern14a.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern14&&Time=2004-01-01%2014:10:00Z" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern14a.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern14&&Time=2004-01-01%2014:10:00Z" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern14b.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern14&Time=2004-01-01%2014:10:00Z,2004-01-01%2015:10:00Z" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern14b.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern14&Time=2004-01-01%2014:10:00Z,2004-01-01%2015:10:00Z" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern14c.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern14&Time=2004-01-01%2014:10:00Z/2004-01-01%2015:10:00Z" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern14c.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern14&Time=2004-01-01%2014:10:00Z/2004-01-01%2015:10:00Z" > [RESULT_DEMIME]
 # Draw a layer by using multiples range time values
-# RUN_PARMS: wms_time_pattern14d.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern14&Time=2004-01-01%2014:10:00Z/2004-01-01%2015:10:00Z,2004-01-01%2016:10:00Z/2004-01-01%2017:10:00Z" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern14d.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern14&Time=2004-01-01%2014:10:00Z/2004-01-01%2015:10:00Z,2004-01-01%2016:10:00Z/2004-01-01%2017:10:00Z" > [RESULT_DEMIME]
 #Pattern15 : "%Y-%m-%dZ"
-# RUN_PARMS: wms_time_pattern15a.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern15&&Time=2004-01-01Z" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern15a.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern15&&Time=2004-01-01Z" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern15b.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern15&Time=2004-01-01Z,2004-01-02Z" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern15b.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern15&Time=2004-01-01Z,2004-01-02Z" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern15c.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern15&Time=2004-01-01Z/2004-01-02Z" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern15c.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern15&Time=2004-01-01Z/2004-01-02Z" > [RESULT_DEMIME]
-# RUN_PARMS: wms_time_pattern15d.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern15&Time=2004-01-01Z/2004-01-02Z,2004-01-03Z/2004-01-04Z" > [RESULT_DEMIME]
+# RUN_PARMS: wms_time_pattern15d.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-132,4,-68,68&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=pattern15&Time=2004-01-01Z/2004-01-02Z,2004-01-03Z/2004-01-04Z" > [RESULT_DEMIME]
@@ -255,15 +255,6 @@
 IMAGECOLOR 255 255 255
 FONTSET ./etc/fonts.txt
-OUTPUTFORMAT
-  NAME GDPNG
-  DRIVER "GD/PNG"
-  MIMETYPE "image/png"
-  IMAGEMODE RGB
-  EXTENSION "png"
-END
 # Start of web interface definition
 WEB
@@ -279,7 +270,8 @@
       "WMS_SRS"              "EPSG:4326"
       "OWS_SCHEMAS_LOCATION" "http://ogc.dmsolutions.ca"
       "WMS_ACCESSCONTRAINTS" "none"
-      "WMS_FEES"             "none"
+      "WMS_FEES"             "none"
+      "ows_enable_request"   "*"
    END
 END
