[mapserver-commits] r11124 - trunk/mapserver
Tue Mar 8 23:54:06 EST 2011
Author: sdlime
Date: 2011-03-08 20:54:06 -0800 (Tue, 08 Mar 2011)
New Revision: 11124
   trunk/mapserver/MIGRATION_GUIDE.TXT
Added MapScript changes necessary as part of RFC 65.
Modified: trunk/mapserver/MIGRATION_GUIDE.TXT
--- trunk/mapserver/MIGRATION_GUIDE.TXT	2011-03-08 22:48:54 UTC (rev 11123)
+++ trunk/mapserver/MIGRATION_GUIDE.TXT	2011-03-09 04:54:06 UTC (rev 11124)
@@ -99,7 +99,35 @@
   - symbolObj: getPatternArray
   - layerObj: getItems, getProcessing, getGridIntersectionCoordinates
   - mapObj: getLayersIndexByGroup, getAllGroupNames, getLayersDrawingOrder, getAllLayerNames
+MapScript (All Flavors)
+The layer query result handing has been re-worked (again) to address some issues introduced in
+the 5.4/5.6 versions. Gone are resultsGetShape and getFeature methods. You should now use a
+refactored getShape method to access layer shapes. That method takes a resultObj and returns
+a shapeObj. Typical use would be (in Perl):
+  $layer->queryByRect($map, $map->{extent}); # layer is still open
+  for($i=0; $i<$layer->getNumResults(); $i++) {
+    $shape = $layer->getShape($layer->getResult($i));
+    print "$i: ". $shape->getValue(1) ."\n";
+  $layer->close();
+A resultObj encapsulates the data used to manage a result set.
+To access shapes independently of a query use the new resultObj class:
+  $layer->open();
+  $shape = $layer->getShape(new mapscript::resultObj(1));
+  $layer->close();
+See http://mapserver.org/development/rfc/ms-rfc-65.html for more information.
 OUTPUTFORMAT
