[mapserver-commits] r11141 - trunk/mapserver/mapscript/php
Thu Mar 10 13:43:33 EST 2011
Author: assefa
Date: 2011-03-10 10:43:32 -0800 (Thu, 10 Mar 2011)
New Revision: 11141
   trunk/mapserver/mapscript/php/class.c
   trunk/mapserver/mapscript/php/grid.c
   trunk/mapserver/mapscript/php/image.c
   trunk/mapserver/mapscript/php/layer.c
   trunk/mapserver/mapscript/php/line.c
   trunk/mapserver/mapscript/php/map.c
   trunk/mapserver/mapscript/php/owsrequest.c
   trunk/mapserver/mapscript/php/php_mapscript.c
   trunk/mapserver/mapscript/php/php_mapscript_util.h
   trunk/mapserver/mapscript/php/shape.c
   trunk/mapserver/mapscript/php/shapefile.c
   trunk/mapserver/mapscript/php/style.c
   trunk/mapserver/mapscript/php/symbol.c
fix windows build #3714
Modified: trunk/mapserver/mapscript/php/class.c
--- trunk/mapserver/mapscript/php/class.c	2011-03-10 16:11:36 UTC (rev 11140)
+++ trunk/mapserver/mapscript/php/class.c	2011-03-10 18:43:32 UTC (rev 11141)
@@ -111,6 +111,7 @@
     classObj *class;
     php_layer_object *php_layer;
     php_class_object *php_class, *php_class2;
+    parent_object parent;
     PHP_MAPSCRIPT_ERROR_HANDLING(TRUE);
     if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "O|O",
@@ -383,6 +384,7 @@
     zval *zobj = getThis();
     php_class_object *php_class;
     styleObj *style = NULL;
     if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "l",
Modified: trunk/mapserver/mapscript/php/grid.c
--- trunk/mapserver/mapscript/php/grid.c	2011-03-10 16:11:36 UTC (rev 11140)
+++ trunk/mapserver/mapscript/php/grid.c	2011-03-10 18:43:32 UTC (rev 11141)
@@ -53,6 +53,7 @@
     zval *zlayer;
     php_grid_object *php_grid, *php_old_grid;
     if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "O",
Modified: trunk/mapserver/mapscript/php/image.c
--- trunk/mapserver/mapscript/php/image.c	2011-03-10 16:11:36 UTC (rev 11140)
+++ trunk/mapserver/mapscript/php/image.c	2011-03-10 18:43:32 UTC (rev 11141)
@@ -209,7 +209,7 @@
             return;
-#ifdef USE_AGG
+#ifdef undef //USE_AGG
     if( MS_RENDERER_AGG(php_imageSrc->image->format))
       msAlphaAGG2GD(php_imageSrc->image);
     if( MS_RENDERER_AGG(php_image->image->format))
Modified: trunk/mapserver/mapscript/php/layer.c
--- trunk/mapserver/mapscript/php/layer.c	2011-03-10 16:11:36 UTC (rev 11140)
+++ trunk/mapserver/mapscript/php/layer.c	2011-03-10 18:43:32 UTC (rev 11141)
@@ -182,6 +182,7 @@
     int index;
     php_map_object *php_map;
     php_layer_object *php_layer, *php_layer2;
@@ -672,6 +673,7 @@
     long index;
     classObj *class = NULL;
@@ -945,6 +947,7 @@
     long index;
     resultObj *result = NULL;
@@ -1045,6 +1048,7 @@
     shapeObj *shape = NULL;
     if (zend_parse_parameters_none() == FAILURE) {
@@ -1093,6 +1097,7 @@
     rectObj *rect = NULL;
@@ -1584,6 +1589,7 @@
     long index;
     classObj *class;
@@ -1837,6 +1843,7 @@
     php_result_object *php_result;
Modified: trunk/mapserver/mapscript/php/line.c
--- trunk/mapserver/mapscript/php/line.c	2011-03-10 16:11:36 UTC (rev 11140)
+++ trunk/mapserver/mapscript/php/line.c	2011-03-10 18:43:32 UTC (rev 11141)
@@ -279,6 +279,7 @@
     php_line_object *php_line;
     long index;
     if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "l", &index) == FAILURE) {
Modified: trunk/mapserver/mapscript/php/map.c
--- trunk/mapserver/mapscript/php/map.c	2011-03-10 16:11:36 UTC (rev 11140)
+++ trunk/mapserver/mapscript/php/map.c	2011-03-10 18:43:32 UTC (rev 11141)
@@ -480,6 +480,7 @@
     long symbolId;
     symbolObj *symbol = NULL;
@@ -805,6 +806,7 @@
     long index;
     layerObj *layer = NULL;
@@ -839,6 +841,7 @@
     long layerName_len;
     if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "s",
@@ -873,6 +876,7 @@
     paletteObj palette;
     colorObj color;
@@ -3231,6 +3235,7 @@
     long index = -1;
@@ -3263,6 +3268,7 @@
     long index = -1;
     labelCacheMemberObj *labelCacheMember = NULL;
@@ -3300,6 +3306,7 @@
     rectObj     geoRefExt;
Modified: trunk/mapserver/mapscript/php/owsrequest.c
--- trunk/mapserver/mapscript/php/owsrequest.c	2011-03-10 16:11:36 UTC (rev 11140)
+++ trunk/mapserver/mapscript/php/owsrequest.c	2011-03-10 18:43:32 UTC (rev 11141)
@@ -162,12 +162,12 @@
     thread_context = NULL;
 #endif
-    PHP_MAPSCRIPT_ERROR_HANDLING(TRUE);
+    //PHP_MAPSCRIPT_ERROR_HANDLING(TRUE);
-        PHP_MAPSCRIPT_RESTORE_ERRORS(TRUE);
+      //PHP_MAPSCRIPT_RESTORE_ERRORS(TRUE);
         return;
     php_owsrequest = (php_owsrequest_object *) zend_object_store_get_object(zobj TSRMLS_CC);
Modified: trunk/mapserver/mapscript/php/php_mapscript.c
--- trunk/mapserver/mapscript/php/php_mapscript.c	2011-03-10 16:11:36 UTC (rev 11140)
+++ trunk/mapserver/mapscript/php/php_mapscript.c	2011-03-10 18:43:32 UTC (rev 11141)
@@ -188,6 +188,7 @@
     int index;
@@ -229,6 +230,7 @@
     char *projString;
     long projString_len;
     projectionObj *projection = NULL;
@@ -278,6 +280,7 @@
 PHP_FUNCTION(ms_newPointObj)
     pointObj *point = NULL;
@@ -336,6 +339,7 @@
     styleObj *style;
     php_style_object *php_style;
@@ -369,6 +373,7 @@
     classObj *class;
@@ -537,6 +542,7 @@
     zval *zlayer;
     php_grid_object *php_grid;
Modified: trunk/mapserver/mapscript/php/php_mapscript_util.h
--- trunk/mapserver/mapscript/php/php_mapscript_util.h	2011-03-10 16:11:36 UTC (rev 11140)
+++ trunk/mapserver/mapscript/php/php_mapscript_util.h	2011-03-10 18:43:32 UTC (rev 11141)
@@ -87,7 +87,6 @@
     MAPSCRIPT_DELREF(parent.val);
 #define MAPSCRIPT_MAKE_PARENT(zobj, ptr)            \
-    parent_object parent; \
     parent.val = zobj; \
     parent.child_ptr = ptr;
Modified: trunk/mapserver/mapscript/php/shape.c
--- trunk/mapserver/mapscript/php/shape.c	2011-03-10 16:11:36 UTC (rev 11140)
+++ trunk/mapserver/mapscript/php/shape.c	2011-03-10 18:43:32 UTC (rev 11141)
@@ -149,6 +149,7 @@
     php_shape_object *php_shape;
     long type;
@@ -273,6 +274,7 @@
     long index;
@@ -391,6 +393,7 @@
     double measure;
     if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "d",
@@ -422,6 +425,7 @@
     pointObj *intersection = NULL;
     php_point_object *php_point;
@@ -489,6 +493,7 @@
     double width;
@@ -517,6 +522,7 @@
@@ -544,6 +550,7 @@
@@ -602,6 +609,7 @@
     zval *zshape;
     shapeObj *shape;
     php_shape_object *php_shape, *php_shape2;
@@ -633,6 +641,7 @@
     zval *zshape;
     shapeObj *shape;
@@ -664,6 +673,7 @@
     zval *zshape;
     shapeObj *shape;
@@ -695,6 +705,7 @@
     zval *zshape;
     shapeObj *shape;
@@ -899,6 +910,7 @@
     pointObj *point;
@@ -972,6 +984,7 @@
     pointObj *point;
@@ -1054,6 +1067,7 @@
     double tolerance;
@@ -1083,6 +1097,7 @@
     double tolerance;
Modified: trunk/mapserver/mapscript/php/shapefile.c
--- trunk/mapserver/mapscript/php/shapefile.c	2011-03-10 16:11:36 UTC (rev 11140)
+++ trunk/mapserver/mapscript/php/shapefile.c	2011-03-10 18:43:32 UTC (rev 11141)
@@ -168,6 +168,7 @@
     long index;
     shapeObj *shape;
     php_shapefile_object *php_shapefile;
@@ -209,6 +210,7 @@
     long index;
     pointObj *point;
@@ -347,6 +349,7 @@
     if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "Ol",
Modified: trunk/mapserver/mapscript/php/style.c
--- trunk/mapserver/mapscript/php/style.c	2011-03-10 16:11:36 UTC (rev 11140)
+++ trunk/mapserver/mapscript/php/style.c	2011-03-10 18:43:32 UTC (rev 11141)
@@ -79,6 +79,7 @@
     styleObj *style;
     php_style_object *php_style, *php_style2;
Modified: trunk/mapserver/mapscript/php/symbol.c
--- trunk/mapserver/mapscript/php/symbol.c	2011-03-10 16:11:36 UTC (rev 11140)
+++ trunk/mapserver/mapscript/php/symbol.c	2011-03-10 18:43:32 UTC (rev 11141)
@@ -69,6 +69,7 @@
     int symbolId = -1;
     php_symbol_object *php_symbol;
     if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "Os",
