[mapserver-commits] r11150 - in trunk/msautotest/misc: . data expected
Fri Mar 11 00:40:53 EST 2011
Author: sdlime
Date: 2011-03-10 21:40:53 -0800 (Thu, 10 Mar 2011)
New Revision: 11150
Added:
   trunk/msautotest/misc/attrbind.map
   trunk/msautotest/misc/data/attrbind.dbf
   trunk/msautotest/misc/data/attrbind.shp
   trunk/msautotest/misc/data/attrbind.shx
   trunk/msautotest/misc/expected/attrbind_test001.png
Added some initial attribute binding tests.
Added: trunk/msautotest/misc/attrbind.map
--- trunk/msautotest/misc/attrbind.map	                        (rev 0)
+++ trunk/msautotest/misc/attrbind.map	2011-03-11 05:40:53 UTC (rev 11150)
@@ -0,0 +1,70 @@
+# Test for label and style attribute binding.
+# REQUIRES: INPUT=SHAPE OUTPUT=PNG
+# RUN_PARMS: attrbind_test001.png [SHP2IMG] -m [MAPFILE] -l test001 -o [RESULT]
+MAP
+  NAME 'attrbind'
+  EXTENT -1.5 0.1 -0.6 1.0
+  SIZE 500 500
+  IMAGETYPE PNG
+  FONTSET fonts.lst
+  SYMBOL
+    NAME 'triangle'
+    TYPE VECTOR
+    POINTS
+      0 4
+      2 0
+      4 4
+      0 4
+    END
+    FILLED TRUE
+  END
+  SYMBOL
+    NAME 'square'
+    TYPE VECTOR
+    POINTS 0 0 1 0 1 1 0 1 0 0 END
+    FILLED TRUE
+  END
+  SYMBOL
+    NAME 'circle'
+    TYPE ELLIPSE
+    POINTS 1 1 END
+    FILLED TRUE
+  END
+  LAYER
+    NAME 'test001'
+    TYPE POINT
+    DATA 'data/attrbind'
+    STATUS OFF
+    LABELITEM 'text'
+    CLASS
+      STYLE # a shadow
+        COLOR 151 151 151
+        SYMBOL [symbol]
+        OFFSET 2 2
+        SIZE [size]
+      END
+      STYLE
+	COLOR [color]
+      	SYMBOL [symbol]
+      	SIZE [size]
+      END
+      LABEL
+        TYPE TRUETYPE
+        FONT 'default'
+        COLOR [lcolor]
+        SIZE [lsize]
+        POSITION UR
+      END
+   END
+  END
+END
\ No newline at end of file
Added: trunk/msautotest/misc/data/attrbind.dbf
(Binary files differ)
Property changes on: trunk/msautotest/misc/data/attrbind.dbf
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: trunk/msautotest/misc/data/attrbind.shp
Property changes on: trunk/msautotest/misc/data/attrbind.shp
Added: trunk/msautotest/misc/data/attrbind.shx
Property changes on: trunk/msautotest/misc/data/attrbind.shx
Added: trunk/msautotest/misc/expected/attrbind_test001.png
Property changes on: trunk/msautotest/misc/expected/attrbind_test001.png
