[mapserver-commits] r11155 - trunk/mapserver
Fri Mar 11 15:19:13 EST 2011
Author: assefa
Date: 2011-03-11 12:19:13 -0800 (Fri, 11 Mar 2011)
New Revision: 11155
Added:
   trunk/mapserver/mapaxisorder.csv
   trunk/mapserver/mapaxisorder.h
   trunk/mapserver/mapaxisorder.sh
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapfile.c
add a static table to define axis order for some epsg codes (#3582)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-03-11 19:59:30 UTC (rev 11154)
+++ trunk/mapserver/HISTORY.TXT	2011-03-11 20:19:13 UTC (rev 11155)
@@ -14,6 +14,8 @@
 Current Version (SVN trunk):
+- Add a static table to define the axis order for soem epsg codes (/3582)
 - Add possibility to use KML_NAME_ITEM (#3728)
 - Fixed mapfile parsing error when a label angle referenced an attribute
Added: trunk/mapserver/mapaxisorder.csv
--- trunk/mapserver/mapaxisorder.csv	                        (rev 0)
+++ trunk/mapserver/mapaxisorder.csv	2011-03-11 20:19:13 UTC (rev 11155)
@@ -0,0 +1,8 @@
+epsg_code,inverted
+3034,1
+3035,1
+3042,1
+3043,1
+4326,1
+4559,1
+4471,0
Property changes on: trunk/mapserver/mapaxisorder.csv
___________________________________________________________________
Added: svn:executable
Added: trunk/mapserver/mapaxisorder.h
--- trunk/mapserver/mapaxisorder.h	                        (rev 0)
+++ trunk/mapserver/mapaxisorder.h	2011-03-11 20:19:13 UTC (rev 11155)
@@ -0,0 +1,56 @@
+ * $Id: $
+ * Project:  MapServer
+ * Purpose:  Axis lookup table
+ * Copyright (c) 1996-2005 Regents of the University of Minnesota.
+ * Permission is hereby granted, free of charge, to any person obtaining a
+ * copy of this software and associated documentation files (the "Software"),
+ * to deal in the Software without restriction, including without limitation
+ * the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ * and/or sell copies of the Software, and to permit persons to whom the
+ * Software is furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included in
+ * all copies of this Software or works derived from this Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
+ * OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+ * Generated file
+ * This file was generated from by means of a script. Do not edit manually.
+#ifdef __cplusplus
+extern "C" {
+#endif
+static struct axisOrientationEpsgCodes_s {
+	int	code;
+ int	inverted; /*true=1, false =0*/
+} axisOrientationEpsgCodes[] = {
+  {3034,1},
+  {3035,1},
+  {3042,1},
+  {3043,1},
+  {4326,1},
+  {4559,1},
+  {4471,0},
+#define AXIS_ORIENTATION_TABLE_SIZE 8
+#ifdef __cplusplus
+#endif
Added: trunk/mapserver/mapaxisorder.sh
--- trunk/mapserver/mapaxisorder.sh	                        (rev 0)
+++ trunk/mapserver/mapaxisorder.sh	2011-03-11 20:19:13 UTC (rev 11155)
@@ -0,0 +1,87 @@
+#!/bin/bash
+INFILE="./mapaxisorder.csv"
+OUTFILE="./mapaxisorder.h"
+# create array of elements from $INFILE
+unset ARRAY i
+while read -r LINE; do ARRAY[i++]=$LINE; done < $INFILE
+print_header ()
+	echo '/******************************************************************************'
+	echo ' * $Id: $'
+	echo ' *'
+	echo ' * Project:  MapServer'
+	echo ' * Purpose:  Axis lookup table'
+	echo ' *'
+	echo ' ******************************************************************************'
+	echo ' * Copyright (c) 1996-2005 Regents of the University of Minnesota.'
+	echo ' *'
+	echo ' * Permission is hereby granted, free of charge, to any person obtaining a'
+	echo ' * copy of this software and associated documentation files (the "Software"),'
+	echo ' * to deal in the Software without restriction, including without limitation'
+	echo ' * the rights to use, copy, modify, merge, publish, distribute, sublicense,'
+	echo ' * and/or sell copies of the Software, and to permit persons to whom the'
+	echo ' * Software is furnished to do so, subject to the following conditions:'
+	echo ' *'
+	echo ' * The above copyright notice and this permission notice shall be included in '
+	echo ' * all copies of this Software or works derived from this Software.'
+	echo ' *'
+	echo ' * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS'
+	echo ' * OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,'
+	echo ' * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL'
+	echo ' * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER'
+	echo ' * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING'
+	echo ' * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER'
+	echo ' * DEALINGS IN THE SOFTWARE.'
+	echo ' ****************************************************************************/'
+print_comment ()
+	echo ' '
+	echo '/*'
+	echo ' * Generated file'
+	echo ' *'
+	echo ' * This file was generated from by means of a script. Do not edit manually.'
+	echo ' */'
+	echo ' '
+print_body ()
+	echo '#ifdef __cplusplus'
+	echo 'extern "C" '{
+	echo '#endif'
+	echo ' '
+	echo 'static struct axisOrientationEpsgCodes_s {'
+	echo '	int	code;'
+	echo ' int	inverted; /*true=1, false =0*/'
+	echo '} axisOrientationEpsgCodes[] = {'
+	# unset first array element
+   unset ARRAY[0]
+   # traverse array and print out elements
+	for x in "${ARRAY[@]}"; do
+		echo "  {${x}},"
+	done
+	echo '};'
+   echo ' '
+	echo '#define AXIS_ORIENTATION_TABLE_SIZE 8'
+   echo ' '
+	echo '}'
+	echo '#endif'
+print_header > ./$OUTFILE
+print_comment >> ./$OUTFILE
+print_body >> ./$OUTFILE
+exit 0
\ No newline at end of file
Property changes on: trunk/mapserver/mapaxisorder.sh
Modified: trunk/mapserver/mapfile.c
--- trunk/mapserver/mapfile.c	2011-03-11 19:59:30 UTC (rev 11154)
+++ trunk/mapserver/mapfile.c	2011-03-11 20:19:13 UTC (rev 11155)
@@ -37,6 +37,7 @@
 #include "mapfile.h"
 #include "mapthread.h"
 #include "maptime.h"
+#include "mapaxisorder.h"
 #ifdef USE_GDAL
 #  include "cpl_conv.h"
@@ -66,6 +67,29 @@
 static int loadStyle(styleObj *style);
 static void writeStyle(FILE* stream, int indent, styleObj *style);
 static int msResolveSymbolNames(mapObj *map);
+/*                           int msIsAxisInverted                       */
+/*      check to see if we shoudl invert the axis.                      */
+static int msIsAxisInverted(int epsg_code)
+    int i;
+    /*check first in the static table*/
+    for (i=0; i<AXIS_ORIENTATION_TABLE_SIZE; i++)
+        if (axisOrientationEpsgCodes[i].code == epsg_code)
+          return axisOrientationEpsgCodes[i].inverted;
+    if ( epsg_code >=4000 &&  epsg_code < 5000)
+      return MS_TRUE;
+    return MS_FALSE;
 ** Symbol to string static arrays needed for writing map files.
 ** Must be kept in sync with enumerations and defines found in mapserver.h.
@@ -1258,8 +1282,9 @@
         p->args = (char**)msSmallMalloc(sizeof(char*) * 2);
         p->args[0] = init_string;
         p->numargs = 1;
-        if( atoi(value+5) >= 4000 && atoi(value+5) < 5000 )
+        if( msIsAxisInverted(atoi(value+5)))
             p->args[1] = msStrdup("+epsgaxis=ne");
             p->numargs = 2;
