[mapserver-commits] r11160 - trunk/mapserver
Tue Mar 15 15:15:37 EDT 2011
Author: sdlime
Date: 2011-03-15 12:15:37 -0700 (Tue, 15 Mar 2011)
New Revision: 11160
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/maplayer.c
   trunk/mapserver/maputil.c
Allow attribute references, that is [itemname], within a TEXT string (#3736)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-03-15 19:11:59 UTC (rev 11159)
+++ trunk/mapserver/HISTORY.TXT	2011-03-15 19:15:37 UTC (rev 11160)
@@ -14,6 +14,8 @@
 Current Version (SVN trunk):
+- Allow attribute references, that is [itemname], within a TEXT string (#3736)
 - Fixed segmentation fault when parsing invalid extent arguments in shp2img (#3734)
 - Make "openlayers mode" work even without OWS support (#3732)
Modified: trunk/mapserver/maplayer.c
--- trunk/mapserver/maplayer.c	2011-03-15 19:11:59 UTC (rev 11159)
+++ trunk/mapserver/maplayer.c	2011-03-15 19:15:37 UTC (rev 11160)
@@ -356,7 +356,7 @@
   int token;
   /* TODO: make sure the constants can't somehow reference invalid expression types */
-  if(expression->type != MS_EXPRESSION && expression->type != MS_GEOMTRANSFORM_EXPRESSION) return MS_SUCCESS;
+  // if(expression->type != MS_EXPRESSION && expression->type != MS_GEOMTRANSFORM_EXPRESSION) return MS_SUCCESS;
   msAcquireLock(TLOCK_PARSER);
   msyystate = MS_TOKENIZE_EXPRESSION;
@@ -515,7 +515,7 @@
     nt += layer->class[i]->label.numbindings;
-    if(layer->class[i]->text.type == MS_EXPRESSION)
+    if(layer->class[i]->text.type == MS_EXPRESSION || (layer->class[i]->text.string && strchr(layer->class[i]->text.string,'[') != NULL && strchr(layer->class[i]->text.string,']') != NULL))
       nt += msCountChars(layer->class[i]->text.string, '[');
@@ -561,9 +561,10 @@
       /* class text and label bindings */
-      if(layer->class[i]->text.type == MS_EXPRESSION) msTokenizeExpression(&(layer->class[i]->text), layer->items, &(layer->numitems));
+        msTokenizeExpression(&(layer->class[i]->text), layer->items, &(layer->numitems));
       for(k=0; k<MS_LABEL_BINDING_LENGTH; k++)
-        if(layer->class[i]->label.bindings[k].item) layer->class[i]->label.bindings[k].index = string2list(layer->items, &(layer->numitems), layer->class[i]->label.bindings[k].item);
+        if(layer->class[i]->label.bindings[k].item) layer->class[i]->label.bindings[k].index = string2list(layer->items, &(layer->numitems), layer->class[i]->label.bindings[k].item);
     /* layer filter */
Modified: trunk/mapserver/maputil.c
--- trunk/mapserver/maputil.c	2011-03-15 19:11:59 UTC (rev 11159)
+++ trunk/mapserver/maputil.c	2011-03-15 19:15:37 UTC (rev 11160)
@@ -31,7 +31,6 @@
  * DEALINGS IN THE SOFTWARE.
 #include <time.h>
 #include "mapserver.h"
@@ -39,7 +38,6 @@
 #include "mapthread.h"
 #include "mapcopy.h"
 #if defined(_WIN32) && !defined(__CYGWIN__)
 # include <windows.h>
 # include <tchar.h>
@@ -546,7 +544,27 @@
   if(layer->class[shape->classindex]->text.string) { /* test for global label first */
     switch(layer->class[shape->classindex]->text.type) {
     case(MS_STRING):
-      tmpstr = msStrdup(layer->class[shape->classindex]->text.string);
+        char *target=NULL;
+        tokenListNodeObjPtr node=NULL;
+        tokenListNodeObjPtr nextNode=NULL;
+        tmpstr = msStrdup(layer->class[shape->classindex]->text.string);
+        node = layer->class[shape->classindex]->text.tokens;
+        if(node) {
+          while(node != NULL) {
+            nextNode = node->next;
+            if(node->token == MS_TOKEN_BINDING_DOUBLE || node->token == MS_TOKEN_BINDING_INTEGER || node->token == MS_TOKEN_BINDING_STRING || node->token == MS_TOKEN_BINDING_TIME) {
+              target = (char *) msSmallMalloc(strlen(node->tokenval.bindval.item) + 3);
+              sprintf(target, "[%s]", node->tokenval.bindval.item);
+              tmpstr = msReplaceSubstring(tmpstr, target, shape->values[node->tokenval.bindval.index]);
+              msFree(target);
+            node = nextNode;
       break;
     case(MS_EXPRESSION):
