[mapserver-commits] r11180 - trunk/mapserver
Wed Mar 16 15:53:16 EDT 2011
Author: assefa
Date: 2011-03-16 12:53:16 -0700 (Wed, 16 Mar 2011)
New Revision: 11180
Removed:
   trunk/mapserver/shp2pdf.c
remove shp2pdf #3747
Deleted: trunk/mapserver/shp2pdf.c
--- trunk/mapserver/shp2pdf.c	2011-03-16 19:35:13 UTC (rev 11179)
+++ trunk/mapserver/shp2pdf.c	2011-03-16 19:53:16 UTC (rev 11180)
@@ -1,205 +0,0 @@
- * $Id$
- * Project:  MapServer
- * Purpose:  Commandline shape to pdf converter.
- * Author:   Steve Lime and the MapServer team.
- * Copyright (c) 1996-2005 Regents of the University of Minnesota.
- * Permission is hereby granted, free of charge, to any person obtaining a
- * copy of this software and associated documentation files (the "Software"),
- * to deal in the Software without restriction, including without limitation
- * the rights to use, copy, modify, merge, publish, distribute, sublicense,
- * and/or sell copies of the Software, and to permit persons to whom the
- * Software is furnished to do so, subject to the following conditions:
- * The above copyright notice and this permission notice shall be included in
- * all copies of this Software or works derived from this Software.
- * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
- * OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
- * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
- * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
- * DEALINGS IN THE SOFTWARE.
-#include "mapserver.h"
-MS_CVSID("$Id$")
-#ifdef USE_PDF
-#include <pdflib.h>
-PDF *
-initializePDF(char *filename)
-  PDF *pdf = PDF_new();
-  PDF_open_file(pdf, filename);
-  PDF_set_info(pdf, "Creator", "Mapserver");
-  PDF_set_info(pdf, "Author", "Mapserver");
-  PDF_set_info(pdf, "Title", "Mapserver PDF Map");
-  return pdf;
-void
-releasePDF(PDF *pdf){
-  PDF_end_page(pdf);
-  PDF_close(pdf);
-  PDF_delete(pdf);
-#endif
-int main(int argc, char *argv[])
-#ifndef USE_PDF
-  fprintf(stdout, "%s\n", msGetVersion());
-  fprintf(stdout, "Compiled without PDF support.");
-  exit(0);
-#else
-  int i,j,k;
-  imageObj *image;
-  mapObj *map=NULL;
-  outputFormatObj *format=NULL;
-  /* gdImagePtr       img=NULL; */
-  char **layers=NULL;
-  int num_layers=0;
-  int layer_found=0;
-  char *invalid_layer=NULL;
-  char *outfile=NULL; /* no -o sends image to STDOUT */
-  /* A4 Portrait */
-  int PagePixelWidth = 595;
-  int PagePixelHeight = 842;
-  int PagePixelMargin = 50;
-  if(argc > 1 && strcmp(argv[1], "-v") == 0) {
-    printf("%s\n", msGetVersion());
-    exit(0);
-  /* ---- check the number of arguments, return syntax if not correct ---- */
-  if( argc < 3 ) {
-    fprintf(stdout, "\nPurpose: convert a mapfile to a PDF document\n\n");
-    fprintf(stdout,"Syntax: shp2pdf -m mapfile -o pdf [-e minx miny maxx maxy] [-l \"layer1 [layers2...]\"] [-t] [-d layername datavalue]\n" );
-    fprintf(stdout,"  -m mapfile: Map file to operate on - required\n" );
-    fprintf(stdout,"  -o pdf: output filename (stdout if not provided)\n");
-    fprintf(stdout,"  -e minx miny maxx maxy: extents to render\n");
-    fprintf(stdout,"  -l layers: layers to enable - make sure they are quoted and space seperated if more than one listed\n" );
-    fprintf(stdout,"  -t : turn on transparency\n");
-    fprintf(stdout,"  -d layername datavalue: change DATA value for a layer\n" );
-    exit(0);
-  for(i=1;i<argc;i++) { /* Step though the user arguments, 1st to find map file */
-    if(strncmp(argv[i],"-m",2) == 0) {
-      map = msLoadMap(argv[i+1], NULL);
-      if(!map) {
-    msWriteError(stderr);
-    exit(0);
-  if(!map) {
-    fprintf(stderr, "Mapfile (-m) option not specified.\n");
-    exit(0);
-  for(i=1;i<argc;i++) { /* Step though the user arguments */
-    if(strncmp(argv[i],"-m",2) == 0) { /* skip it */
-      i+=1;
-    if(strncmp(argv[i],"-o",2) == 0) {
-      outfile = msStrdup(argv[i+1]);
-      i+=1;
-    if(strncmp(argv[i],"-d",2) == 0) { /* swap layer data */
-      for(j=0; j<map->numlayers; j++) {
-     if(strcmp(GET_LAYER(map, j)->name, argv[i+1]) == 0) {
-       free(GET_LAYER(map, j)->data);
-       GET_LAYER(map, j)->data = msStrdup(argv[i+2]);
-       break;
-      i+=2;
-    /*if(strncmp(argv[i], "-t", 2) == 0)  transparency
-      map->transparent = MS_ON;*/
-    if(strncmp(argv[i],"-e",2) == 0) { /* change extent */
-      map->extent.minx = atof(argv[i+1]);
-      map->extent.miny = atof(argv[i+2]);
-      map->extent.maxx = atof(argv[i+3]);
-      map->extent.maxy = atof(argv[i+4]);
-      i+=4;
-    format = msCreateDefaultOutputFormat(map, "pdf");
-    map->outputformat = format;
-    if(strncmp(argv[i],"-l",2) == 0) { /* load layer list */
-      layers = msStringSplit(argv[i+1], ' ', &(num_layers));
-      for(j=0; j<num_layers; j++) { /* loop over -l */
-        layer_found=0;
-        for(k=0; k<map->numlayers; k++) {
-          if(GET_LAYER(map, k)->name && strcmp(GET_LAYER(map, k)->name, layers[j]) == 0) {
-            layer_found=1;
-            break;
-          else {
-            invalid_layer = msStrdup(layers[j]);
-        if (layer_found==0) {
-          fprintf(stderr, "Layer (-l) %s not found\n", invalid_layer);
-          msCleanup();
-          exit(0);
-        if(GET_LAYER(map, j)->status == MS_DEFAULT)
-          continue;
-        else {
-          GET_LAYER(map, j)->status = MS_OFF;
-          for(k=0; k<num_layers; k++) {
-            if(strcmp(GET_LAYER(map, j)->name, layers[k]) == 0) {
-              GET_LAYER(map, j)->status = MS_ON;
-              break;
-      msFreeCharArray(layers, num_layers);
-      i+=1;
-  /*gdImageDestroy(img);*/
-  map->height = PagePixelHeight-(2*PagePixelMargin);
-  map->width = PagePixelWidth-(2*PagePixelMargin);
-  image = msDrawMap(map, MS_FALSE);
-  msSaveImage(map, image, outfile);
-  msFreeMap(map);
-  free(outfile);
-#endif
-  return(0);
-} /* ---- END Main Routine ---- */
